Wiser via Matter
J’ai utilisé Mater pour configurer mon Wiser de deuxième génération, mais les chiffres de consommation d’énergie sont incorrects. L’application affiche 5,11kW, alors que Home Assistant indique 0,00511 kW. Quelqu’un a une solution ? Merci.
version core-2026.2.0b2
container_arch amd64
python_version 3.13.11
os_version 6.12.67-haos
arch x86_64
Installed Version 2.0.5
Available Repositories 2682
Downloaded Repositories 13
logged_in true
subscription_expiration 7 avril 2026 à 02:00
relayer_connected true
relayer_region eu-central-1
remote_enabled true
remote_connected true
alexa_enabled true
google_enabled false
remote_server eu-central-1-0.ui.nabu.casa
certificate_status ready
instance_id cafad735ee6e4264ac10a333d7197558
host_os Home Assistant OS 17.1.rc1
update_channel beta
supervisor_version supervisor-2026.02.0
agent_version 1.8.1
docker_version 29.1.3
disk_total 30.8 GB
disk_used 10.4 GB
nameservers 192.168.1.1
virtualization kvm
board ova
installed_addons Mosquitto broker (6.5.2), Get HACS (1.3.1), File editor (5.8.0), Samba share (12.5.4), ESPHome Device Builder (2026.1.3), Matter Server (8.2.2), Zigbee2MQTT (2.8.0-1), OpenThread Border Router (2.16.0), Home Assistant Version Control (1.0.0), Zigbee2MQTT Edge (edge), Assist Microphone (1.3.0), Terminal & SSH (9.22.0), Network UPS Tools (0.17.0), go2rtc (1.9.14)
dashboards 3
resources 5
views 5
Network Configuration
adapters lo (disabled), enp6s18 (enabled, default, auto), hassio (disabled), docker0 (disabled), veth93e827e (disabled), veth5d4fe27 (disabled), vethcace367 (disabled), vethc87027e (disabled), vethc0ceb6a (disabled), veth619ce3f (disabled), vethf7945d4 (disabled), veth681e4bf (disabled), wpan0 (disabled), veth33fc346 (disabled), vethc95a58c (disabled), vethf1e6dcf (disabled), veth3aeec74 (disabled), vetha857010 (disabled)
ipv4_addresses lo (127.0.0.1/8), enp6s18 (192.168.1.33/24), hassio (172.30.32.1/23), docker0 (172.30.232.1/23), veth93e827e (), veth5d4fe27 (), vethcace367 (), vethc87027e (), vethc0ceb6a (), veth619ce3f (), vethf7945d4 (), veth681e4bf (), wpan0 (), veth33fc346 (), vethc95a58c (), vethf1e6dcf (), veth3aeec74 (), vetha857010 ()
ipv6_addresses lo (::1/128), enp6s18 (fd75:739a:ce62:2eb0:e82c:917b:3c6e:d410/64, fe80::e168:d626:9ac:5470/64), hassio (fd0c:ac1e:2100::1/48, fe80::9c1b:d8ff:fecc:5470/64), docker0 (fe80::1014:6ff:fed2:a451/64), veth93e827e (fe80::4088:1bff:fe73:896b/64), veth5d4fe27 (fe80::5426:68ff:fe9e:ac5/64), vethcace367 (fe80::a077:63ff:fedb:9fa5/64), vethc87027e (fe80::9871:dfff:fe3b:83db/64), vethc0ceb6a (fe80::30cf:abff:fe24:5f10/64), veth619ce3f (fe80::20:d6ff:fed6:af10/64), vethf7945d4 (fe80::1c58:97ff:fedc:8cc4/64), veth681e4bf (fe80::501d:44ff:feb6:804b/64), wpan0 (fd9d:9701:fbc3:ec32:0:ff:fe00:fc11/64, fde5:fcfe:f16e:1:9d33:bbfb:341f:c130/64, fd9d:9701:fbc3:ec32:0:ff:fe00:fc10/64, fd9d:9701:fbc3:ec32:0:ff:fe00:fc38/64, fd9d:9701:fbc3:ec32:0:ff:fe00:fc00/64, fd9d:9701:fbc3:ec32:0:ff:fe00:ac00/64, fd9d:9701:fbc3:ec32:9097:8a5e:493a:f54f/64, fe80::a43d:8cee:cd0e:232a/64), veth33fc346 (fe80::f012:96ff:fe04:287d/64), vethc95a58c (fe80::8f4:70ff:fe22:ee36/64), vethf1e6dcf (fe80::d4d9:c4ff:fed1:d1d/64), veth3aeec74 (fe80::a008:66ff:fed7:7320/64), vetha857010 (fe80::44df:86ff:fe96:377e/64)
announce_addresses 192.168.1.33, fd75:739a:ce62:2eb0:e82c:917b:3c6e:d410, fe80::e168:d626:9ac:5470
oldest_recorder_run 20 janvier 2026 à 16:55
current_recorder_run 3 février 2026 à 01:12
estimated_db_size 203.27 MiB
database_version 3.49.2
C’est pas complétement faux c’est juste l’échelle qui est fausse
Il faut utiliser un sensor template pour repasser ton capteur en kw en multipliant par 1000 ta valeur
Tu peux créer ce sensor depuis une entrée dans le menu intégration
Merci pour votre retour !
Effectivement, il y a bien un décalage. J’ai créé des sensor templates, mais je n’ai pas réussi à les intégrer au Dashboard énergie.
Du coup, j’ai simplifié les choses : j’ai supprimé la passerelle et je me connecte maintenant directement en Zigbee.
ma question était plus de savoir si d’autre avait le même souci .
