Merci pour ta reponse.
Ok je comprend pour la redondance, pourquoi pas.
J’ai re appairé le capteur, a priori j’ai le même problème. c’est surprenant car c’est quand meme un capteur assez basique et dans la doc on dirait que la calibration est prise en charge.
parc ontre je vois que j’ai une erreur dans le journal. J’arrive pas a décrypter ce langage ^’ ca pourrait avoir un lien ?
Error <small>2024-05-01 08:36:22</small>`Failed to configure 'Temperature1', attempt 12 (Error: ZCL command 0xa4c13898423d37ec/1 genBasic.read(["manufacturerName","zclVersion","appVersion","modelId","powerSource",65534], {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":true,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null,"writeUndiv":false}) failed (Timeout - 34245 - 1 - 38 - 0 - 1 after 10000ms) at Object.start (/app/node_modules/zigbee-herdsman/src/utils/waitress.ts:63:23) at EZSPAdapter.sendZclFrameToEndpointInternal (/app/node_modules/zigbee-herdsman/src/adapter/ezsp/adapter/ezspAdapter.ts:492:47) at Queue.execute (/app/node_modules/zigbee-herdsman/src/utils/queue.ts:35:20) at Request.send (/app/node_modules/zigbee-herdsman/src/controller/helpers/request.ts:79:20) at Endpoint.zclCommand (/app/node_modules/zigbee-herdsman/src/controller/model/endpoint.ts:760:28) at Endpoint.read (/app/node_modules/zigbee-herdsman/src/controller/model/endpoint.ts:404:24) at Object.configureMagicPacket [as configure] (/app/node_modules/zigbee-herdsman-converters/src/lib/tuya.ts:377:9) at Configure.configure (/app/lib/extension/configure.ts:122:13) at Configure.onMQTTMessage (/app/lib/extension/configure.ts:55:21) at EventEmitter.wrappedCallback (/app/lib/eventBus.ts:174:17))`
Info <small>2024-05-01 08:36:22</small>`MQTT publish: topic 'zigbee2mqtt/bridge/response/device/configure', payload '{"data":{"id":"Temperature1"},"error":"Failed to configure (ZCL command 0xa4c13898423d37ec/1 genBasic.read([\"manufacturerName\",\"zclVersion\",\"appVersion\",\"modelId\",\"powerSource\",65534], {\"timeout\":10000,\"disableResponse\":false,\"disableRecovery\":false,\"disableDefaultResponse\":true,\"direction\":0,\"srcEndpoint\":null,\"reservedBits\":0,\"manufacturerCode\":null,\"transactionSequenceNumber\":null,\"writeUndiv\":false}) failed (Timeout - 34245 - 1 - 38 - 0 - 1 after 10000ms))","status":"error","transaction":"5tt1c-3"}'`
