Voici le log:
[13:21:38] INFO: Preparing to start...
[13:21:40] INFO: Socat not enabled
[13:21:45] INFO: Starting Zigbee2MQTT...
[2024-08-17 13:22:02] info: z2m: Logging to console, file (filename: log.log)
[2024-08-17 13:22:02] info: z2m: Starting Zigbee2MQTT version 1.39.1 (commit #unknown)
[2024-08-17 13:22:02] info: z2m: Starting zigbee-herdsman (0.55.3)
[2024-08-17 13:22:03] info: z2m: zigbee-herdsman started (resumed)
[2024-08-17 13:22:04] info: z2m: Coordinator firmware version: '{"meta":{"maintrel":0,"majorrel":38,"minorrel":114,"product":0,"revision":"0x26720700","transportrev":0},"type":"ConBee2/RaspBee2"}'
[2024-08-17 13:22:04] info: z2m: Currently 8 devices are joined:
[2024-08-17 13:22:04] info: z2m: 0x00124b002a538b96 (0x00124b002a538b96): SNZB-02 - SONOFF Temperature and humidity sensor (EndDevice)
[2024-08-17 13:22:04] info: z2m: 0x00124b002a4f091c (0x00124b002a4f091c): SNZB-02 - SONOFF Temperature and humidity sensor (EndDevice)
[2024-08-17 13:22:04] info: z2m: 0x00124b002934a04b (0x00124b002934a04b): SNZB-02 - SONOFF Temperature and humidity sensor (EndDevice)
[2024-08-17 13:22:04] info: z2m: 0x00124b002a52f246 (0x00124b002a52f246): SNZB-02 - SONOFF Temperature and humidity sensor (EndDevice)
[2024-08-17 13:22:04] info: z2m: 0x00124b002a532cc4 (0x00124b002a532cc4): SNZB-02 - SONOFF Temperature and humidity sensor (EndDevice)
[2024-08-17 13:22:04] info: z2m: 0x00124b002a4f4ec5 (0x00124b002a4f4ec5): SNZB-02 - SONOFF Temperature and humidity sensor (EndDevice)
[2024-08-17 13:22:04] info: z2m: Lixee_Principal (0x00158d0005d2481c): ZLinky_TIC - LiXee Lixee ZLinky (Router)
[2024-08-17 13:22:04] info: z2m: Lixee-OA (0x00158d0005d247d3): ZLinky_TIC - LiXee Lixee ZLinky (Router)
[2024-08-17 13:22:04] info: z2m: Zigbee: disabling joining new devices.
[2024-08-17 13:22:04] info: z2m: Connecting to MQTT server at http:\\192.168.1.129:1883
[2024-08-17 13:22:05] info: z2m: Connected to MQTT server
[2024-08-17 13:22:05] info: z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/bridge/state', payload 'online'
[2024-08-17 13:22:06] info: z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/0x00124b002a538b96/availability', payload 'online'
[2024-08-17 13:22:06] info: z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/0x00124b002a4f091c/availability', payload 'online'
[2024-08-17 13:22:06] info: z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Lixee_Principal/availability', payload 'online'
[2024-08-17 13:22:06] info: z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Lixee_Principal', payload '{"active_register_tier_delivered":"TH..","apparent_power":200,"available_power":45,"current_summ_delivered":39938,"current_tarif":"BASE","linkquality":255,"meter_serial_number":"022161973381","mot_d_etat":"000000","rms_current":0,"rms_current_max":90,"update":{"installed_version":1,"latest_version":13,"state":"available"},"update_available":true,"warn_d_p_s":0}'
[2024-08-17 13:22:06] info: z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/0x00124b002934a04b/availability', payload 'online'
[2024-08-17 13:22:06] info: z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Lixee-OA/availability', payload 'online'
[2024-08-17 13:22:06] info: z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Lixee-OA', payload '{"active_energy_out_d01":0,"active_energy_out_d02":0,"active_energy_out_d03":0,"active_energy_out_d04":0,"active_power":0,"active_power_max":10,"active_power_ph_b":0,"apparent_power":0,"available_power":2,"average_rms_voltage_meas_period":235,"current_date":"E240817131005","current_index_tarif":1,"current_price":"INDEX NON CONSO","current_summ_delivered":0,"current_summ_received":24221,"current_tarif":"PRODUCTEUR","current_tier10_summ_delivered":0,"current_tier1_summ_delivered":0,"current_tier2_summ_delivered":0,"current_tier3_summ_delivered":0,"current_tier4_summ_delivered":0,"current_tier5_summ_delivered":0,"current_tier6_summ_delivered":0,"current_tier7_summ_delivered":0,"current_tier8_summ_delivered":0,"current_tier9_summ_delivered":0,"drawn_v_a_max_n1":11,"injected_active_load_n":1756,"injected_active_load_n1":1692,"injected_v_a":1805,"injected_v_a_max_n":1877,"injected_v_a_max_n1":2217,"linkquality":255,"message1":"PAS DE MESSAGE","message2":"","meter_serial_number":"031861103520","power_threshold":2,"reactive_power":187,"reactive_power_ph_b":-21229,"reactive_power_ph_c":1040,"relais":0,"relais_breakout":{"relais1":0,"relais2":0,"relais3":0,"relais4":0,"relais5":0,"relais6":0,"relais7":0,"relais8":0},"rms_current":8,"rms_voltage":235,"site_id":"24391895643708","software_revision":2,"start_mobile_point1":0,"start_mobile_point2":0,"start_mobile_point3":0,"status_register":"003A0301","status_register_breakout":{"cache_borne_dist":"ferme","comm_euridis":"activee avec securite","contact_sec":"ouvert","depassement_ref_pow":0,"etat_cpl":"nouveau_verrouille","horloge":"correcte","organe_coupure":"ferme","pointe_mobile":"AUCUN","preavis_pointe_mobile":"AUCUN","producteur":1,"sens_energie_active":"negative","surtension_phase":0,"sync_cpl":"non_synchronise","tarif_dist":"index_1","tarif_four":"index_1","tempo_demain":"UNDEF","tempo_jour":"UNDEF","type_tic":"standard"},"stop_mobile_point1":0,"stop_mobile_point2":0,"stop_mobile_point3":0,"total_reactive_power":0,"update":{"installed_version":1,"latest_version":13,"state":"available"},"update_available":true,"warn_d_p_s":0}'
[2024-08-17 13:22:06] info: z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/0x00124b002a52f246/availability', payload 'online'
[2024-08-17 13:22:06] info: z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/0x00124b002a532cc4/availability', payload 'online'
[2024-08-17 13:22:06] info: z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/0x00124b002a4f4ec5/availability', payload 'online'
[2024-08-17 13:22:06] info: z2m: Started frontend on port 8099
[2024-08-17 13:22:06] info: z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/bridge/config', payload '{"commit":"unknown","coordinator":{"meta":{"maintrel":0,"majorrel":38,"minorrel":114,"product":0,"revision":"0x26720700","transportrev":0},"type":"ConBee2/RaspBee2"},"log_level":"info","network":{"channel":11,"extendedPanID":"0x91616cb26caa3bcc","panID":19640},"permit_join":false,"version":"1.39.1"}'
[2024-08-17 13:22:06] info: z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/bridge/state', payload 'online'
[2024-08-17 13:22:06] info: z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/0x00124b002a538b96', payload '{"battery":95.5,"humidity":75.12,"linkquality":255,"temperature":27.7,"voltage":2900}'
[2024-08-17 13:22:07] info: z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/0x00124b002a4f091c', payload '{"battery":100,"humidity":46.29,"linkquality":255,"temperature":26.19,"voltage":3200}'
[2024-08-17 13:22:07] info: z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/0x00124b002934a04b', payload '{"battery":100,"humidity":68.23,"linkquality":255,"temperature":29.53,"voltage":3000}'
[2024-08-17 13:22:07] info: z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/0x00124b002a52f246', payload '{"battery":100,"humidity":69.12,"linkquality":255,"temperature":27.27,"voltage":3000}'
[2024-08-17 13:22:07] info: z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/0x00124b002a532cc4', payload '{"battery":100,"humidity":66.91,"linkquality":255,"temperature":27.6,"voltage":3000}'
[2024-08-17 13:22:07] info: z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Lixee_Principal', payload '{"MOTDETAT":null,"active_register_tier_delivered":"TH..","apparent_power":200,"available_power":45,"current_summ_delivered":39938,"current_tarif":"BASE","linkquality":255,"meter_serial_number":"022161973381","mot_d_etat":"000000","rms_current":0,"rms_current_max":90,"update":{"installed_version":1,"latest_version":13,"state":"available"},"update_available":true,"warn_d_p_s":0}'
[2024-08-17 13:22:07] info: z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Lixee-OA', payload '{"active_energy_out_d01":0,"active_energy_out_d02":0,"active_energy_out_d03":0,"active_energy_out_d04":0,"active_power":0,"active_power_max":10,"active_power_ph_b":0,"apparent_power":0,"available_power":2,"average_rms_voltage_meas_period":235,"current_date":"E240817131005","current_index_tarif":1,"current_price":"INDEX NON CONSO","current_summ_delivered":0,"current_summ_received":24221,"current_tarif":"PRODUCTEUR","current_tier10_summ_delivered":0,"current_tier1_summ_delivered":0,"current_tier2_summ_delivered":0,"current_tier3_summ_delivered":0,"current_tier4_summ_delivered":0,"current_tier5_summ_delivered":0,"current_tier6_summ_delivered":0,"current_tier7_summ_delivered":0,"current_tier8_summ_delivered":0,"current_tier9_summ_delivered":0,"days_number_current_calendar":null,"days_number_next_calendar":null,"days_profile_current_calendar":null,"days_profile_next_calendar":null,"drawn_v_a_max_n1":11,"injected_active_load_n":1756,"injected_active_load_n1":1692,"injected_v_a":1805,"injected_v_a_max_n":1877,"injected_v_a_max_n1":2217,"linkquality":255,"message1":"PAS DE MESSAGE","message2":"","meter_serial_number":"031861103520","power_threshold":2,"reactive_power":187,"reactive_power_ph_b":-21229,"reactive_power_ph_c":1040,"relais":0,"relais_breakout":{"relais1":0,"relais2":0,"relais3":0,"relais4":0,"relais5":0,"relais6":0,"relais7":0,"relais8":0},"rms_current":8,"rms_voltage":235,"site_id":"24391895643708","software_revision":2,"start_mobile_point1":0,"start_mobile_point2":0,"start_mobile_point3":0,"status_register":"003A0301","status_register_breakout":{"cache_borne_dist":"ferme","comm_euridis":"activee avec securite","contact_sec":"ouvert","depassement_ref_pow":0,"etat_cpl":"nouveau_verrouille","horloge":"correcte","organe_coupure":"ferme","pointe_mobile":"AUCUN","preavis_pointe_mobile":"AUCUN","producteur":1,"sens_energie_active":"negative","surtension_phase":0,"sync_cpl":"non_synchronise","tarif_dist":"index_1","tarif_four":"index_1","tempo_demain":"UNDEF","tempo_jour":"UNDEF","type_tic":"standard"},"stop_mobile_point1":0,"stop_mobile_point2":0,"stop_mobile_point3":0,"total_reactive_power":0,"update":{"installed_version":1,"latest_version":13,"state":"available"},"update_available":true,"warn_d_p_s":0}'
[2024-08-17 13:22:07] info: z2m: Zigbee2MQTT started!
[2024-08-17 13:22:11] info: z2m:mqtt: MQTT publish: topic 'homeassistant/binary_sensor/1221051039810110150109113116116_0x00212effff0971f8/connection_state/config', payload '{"device":{"hw_version":"ConBee2/RaspBee2 0x26720700","identifiers":["zigbee2mqtt_bridge_0x00212effff0971f8"],"manufacturer":"Zigbee2MQTT","model":"Bridge","name":"Zigbee2MQTT Bridge","sw_version":"1.39.1"},"device_class":"connectivity","entity_category":"diagnostic","name":"Connection state","object_id":"zigbee2mqtt_bridge_connection_state","origin":{"name":"Zigbee2MQTT","sw":"1.39.1","url":"https://www.zigbee2mqtt.io"},"payload_off":"offline","payload_on":"online","state_topic":"zigbee2mqtt/bridge/state","unique_id":"bridge_0x00212effff0971f8_connection_state_zigbee2mqtt","value_template":"{{ value }}"}'
[2024-08-17 13:22:12] info: z2m:mqtt: MQTT publish: topic 'homeassistant/sensor/0x00158d0005d247d3/NJOURF+1/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state"},{"topic":"zigbee2mqtt/Lixee-OA/availability"}],"availability_mode":"all","device":{"identifiers":["zigbee2mqtt_0x00158d0005d247d3"],"manufacturer":"LiXee","model":"Lixee ZLinky (ZLinky_TIC)","name":"Lixee-OA","sw_version":"4000-0013","via_device":"zigbee2mqtt_bridge_0x00212effff0971f8"},"enabled_by_default":true,"json_attributes_topic":"zigbee2mqtt/Lixee-OA","name":"NJOURF+1","object_id":"lixee-oa_NJOURF+1","origin":{"name":"Zigbee2MQTT","sw":"1.39.1","url":"https://www.zigbee2mqtt.io"},"state_topic":"zigbee2mqtt/Lixee-OA","unique_id":"0x00158d0005d247d3_NJOURF+1_zigbee2mqtt","value_template":"{{ value_json.days_number_next_calendar }}"}'
[2024-08-17 13:22:15] error: z2m: Not connected to MQTT server!
[2024-08-17 13:22:19] error: z2m: Not connected to MQTT server!
[2024-08-17 13:22:19] error: z2m: Cannot send message: topic: 'zigbee2mqtt/Lixee-OA', payload: '{"active_energy_out_d01":0,"active_energy_out_d02":0,"active_energy_out_d03":0,"active_energy_out_d04":0,"active_power":0,"active_power_max":10,"active_power_ph_b":0,"apparent_power":0,"available_power":2,"average_rms_voltage_meas_period":235,"current_date":"E240817131005","current_index_tarif":1,"current_price":"INDEX NON CONSO","current_summ_delivered":0,"current_summ_received":24221,"current_tarif":"PRODUCTEUR","current_tier10_summ_delivered":0,"current_tier1_summ_delivered":0,"current_tier2_summ_delivered":0,"current_tier3_summ_delivered":0,"current_tier4_summ_delivered":0,"current_tier5_summ_delivered":0,"current_tier6_summ_delivered":0,"current_tier7_summ_delivered":0,"current_tier8_summ_delivered":0,"current_tier9_summ_delivered":0,"days_number_current_calendar":null,"days_number_next_calendar":null,"days_profile_current_calendar":null,"days_profile_next_calendar":null,"drawn_v_a_max_n1":11,"injected_active_load_n":1756,"injected_active_load_n1":1692,"injected_v_a":1805,"injected_v_a_max_n":1877,"injected_v_a_max_n1":2217,"linkquality":255,"message1":"PAS DE MESSAGE","message2":"","meter_serial_number":"031861103520","power_threshold":2,"reactive_power":187,"reactive_power_ph_b":-21229,"reactive_power_ph_c":1040,"relais":0,"relais_breakout":{"relais1":0,"relais2":0,"relais3":0,"relais4":0,"relais5":0,"relais6":0,"relais7":0,"relais8":0},"rms_current":8,"rms_voltage":235,"site_id":"24391895643708","software_revision":2,"start_mobile_point1":0,"start_mobile_point2":0,"start_mobile_point3":0,"status_register":"003A0301","status_register_breakout":{"cache_borne_dist":"ferme","comm_euridis":"activee avec securite","contact_sec":"ouvert","depassement_ref_pow":0,"etat_cpl":"nouveau_verrouille","horloge":"correcte","organe_coupure":"ferme","pointe_mobile":"AUCUN","preavis_pointe_mobile":"AUCUN","producteur":1,"sens_energie_active":"negative","surtension_phase":0,"sync_cpl":"non_synchronise","tarif_dist":"index_1","tarif_four":"index_1","tempo_demain":"UNDEF","tempo_jour":"UNDEF","type_tic":"standard"},"stop_mobile_point1":0,"stop_mobile_point2":0,"stop_mobile_point3":0,"total_reactive_power":0,"update":{"installed_version":1,"latest_version":13,"state":"available"},"update_available":true,"warn_d_p_s":0}
[2024-08-17 13:22:25] error: z2m: Not connected to MQTT server!
[2024-08-17 13:22:35] error: z2m: Not connected to MQTT server!
[2024-08-17 13:22:45] error: z2m: Not connected to MQTT server!
[2024-08-17 13:22:54] error: z2m: Not connected to MQTT server!
[2024-08-17 13:22:54] error: z2m: Cannot send message: topic: 'zigbee2mqtt/Lixee_Principal', payload: '{"MOTDETAT":null,"active_register_tier_delivered":"TH..","apparent_power":200,"available_power":45,"current_summ_delivered":39938,"current_tarif":"BASE","linkquality":255,"meter_serial_number":"022161973381","mot_d_etat":"000000","rms_current":0,"rms_current_max":90,"update":{"installed_version":1,"latest_version":13,"state":"available"},"update_available":true,"warn_d_p_s":0}
[2024-08-17 13:22:55] error: z2m: Not connected to MQTT server!
[2024-08-17 13:23:05] error: z2m: Not connected to MQTT server!
[2024-08-17 13:23:08] error: z2m: Not connected to MQTT server!
[2024-08-17 13:23:08] error: z2m: Cannot send message: topic: 'zigbee2mqtt/Lixee_Principal', payload:
Apparement il se connecte puis se deconnecte… OFFLINE!
