23-04-02 23:57:39 INFO (SyncWorker_7) [supervisor.docker.addon] Starting Docker add-on homeassistant/aarch64-addon-mosquitto with version 6.2.0
23-04-02 23:57:48 WARNING (MainThread) [supervisor.addons.addon] core_mosquitto is already running!
23-04-02 23:57:54 WARNING (MainThread) [supervisor.addons.options] Unknown option 'base_topic' for Zigbee2MQTT (45df7312_zigbee2mqtt)
23-04-02 23:57:56 WARNING (MainThread) [supervisor.addons.options] Unknown option 'base_topic' for Zigbee2MQTT (45df7312_zigbee2mqtt)
23-04-02 23:57:57 WARNING (MainThread) [supervisor.addons.options] Unknown option 'base_topic' for Zigbee2MQTT (45df7312_zigbee2mqtt)
23-04-02 23:57:57 INFO (SyncWorker_4) [supervisor.docker.interface] Cleaning addon_45df7312_zigbee2mqtt application
23-04-02 23:57:57 WARNING (SyncWorker_4) [supervisor.addons.options] Unknown option 'base_topic' for Zigbee2MQTT (45df7312_zigbee2mqtt)
23-04-02 23:57:59 ERROR (SyncWorker_4) [supervisor.docker.manager] Can't start addon_45df7312_zigbee2mqtt: 500 Server Error for http+docker://localhost/v1.41/containers/de24fe518293c39bac4b6778712942ab2a81504a0ec47205bf5e10d40f8a5a4e/start: Internal Server Error ("driver failed programming external connectivity on endpoint addon_45df7312_zigbee2mqtt (f777a247e29be8692c09b34e77294e8be75d10adc806a571aa51cf01a32c8f1c): Bind for 0.0.0.0:8485 failed: port is already allocated")
23-04-02 23:58:01 ERROR (MainThread) [supervisor.services.modules.mqtt] There is already a MQTT service in use from core_mosquitto
23-04-02 23:59:03 INFO (MainThread) [supervisor.homeassistant.api] Updated Home Assistant API token
23-04-03 00:10:35 WARNING (MainThread) [supervisor.addons.options] Unknown option 'base_topic' for Zigbee2MQTT (45df7312_zigbee2mqtt)
23-04-03 00:13:19 WARNING (MainThread) [supervisor.addons.options] Unknown option 'base_topic' for Zigbee2MQTT (45df7312_zigbee2mqtt)
23-04-03 00:13:22 WARNING (MainThread) [supervisor.addons.options] Unknown option 'base_topic' for Zigbee2MQTT (45df7312_zigbee2mqtt)
23-04-03 00:13:22 INFO (SyncWorker_5) [supervisor.docker.interface] Cleaning addon_45df7312_zigbee2mqtt application
23-04-03 00:13:22 WARNING (SyncWorker_5) [supervisor.addons.options] Unknown option 'base_topic' for Zigbee2MQTT (45df7312_zigbee2mqtt)
23-04-03 00:13:24 ERROR (SyncWorker_5) [supervisor.docker.manager] Can't start addon_45df7312_zigbee2mqtt: 500 Server Error for http+docker://localhost/v1.41/containers/40767cec11b0caae5513b2c7ebb1d24c8a7b142d79e3129354430fe2c2a2925c/start: Internal Server Error ("driver failed programming external connectivity on endpoint addon_45df7312_zigbee2mqtt (8b1d9f53516b23d07d7c78b880cfe47fc0d6067463788fb2819442408caae153): Bind for 0.0.0.0:8485 failed: port is already allocated")
mosquito:
Mosquitto broker
cont-init: info: running /etc/cont-init.d/mosquitto.sh
[23:57:51] INFO: SSL is not enabled
cont-init: info: /etc/cont-init.d/mosquitto.sh exited 0
cont-init: info: running /etc/cont-init.d/nginx.sh
cont-init: info: /etc/cont-init.d/nginx.sh exited 0
services-up: info: copying legacy longrun mosquitto (no readiness notification)
services-up: info: copying legacy longrun nginx (no readiness notification)
[23:57:55] INFO: Starting NGINX for authentication handling...
[23:57:55] INFO: Starting mosquitto MQTT broker...
2023-04-02 23:57:55: Warning: Mosquitto should not be run as root/administrator.
[23:58:01] INFO: Successfully send discovery information to Home Assistant.
[23:58:03] INFO: Successfully send service information to the Supervisor.
on dirait qu’il ne trouve pas mon device (le dongle?)
EDIT: j’ai ce message concernant le Bluetooth dans les log HA
Logger: homeassistant.components.bluetooth.scanner
Source: components/bluetooth/scanner.py:301
Integration: Bluetooth (documentation, issues)
First occurred: 05:02:07 (42 occurrences)
Last logged: 06:24:08
hci0 (B8:27:EB:27:CA:A7): Failed to restart Bluetooth scanner: hci0 (B8:27:EB:27:CA:A7): Failed to start Bluetooth: [org.bluez.Error.NotReady] Resource Not Ready
File "/usr/src/homeassistant/homeassistant/components/bluetooth/scanner.py", line 219, in _async_start
await self.scanner.start() # type: ignore[no-untyped-call]
File "/usr/local/lib/python3.10/site-packages/bleak/__init__.py", line 156, in start
await self._backend.start()
File "/usr/local/lib/python3.10/site-packages/bleak/backends/bluezdbus/scanner.py", line 191, in start
self._stop = await manager.active_scan(
File "/usr/local/lib/python3.10/site-packages/bleak/backends/bluezdbus/manager.py", line 357, in active_scan
assert_reply(reply)
File "/usr/local/lib/python3.10/site-packages/bleak/backends/bluezdbus/utils.py", line 20, in assert_reply
raise BleakDBusError(reply.error_name, reply.body)
bleak.exc.BleakDBusError: [org.bluez.Error.NotReady] Resource Not Ready
The above exception was the direct cause of the following exception:
File "/usr/src/homeassistant/homeassistant/components/bluetooth/scanner.py", line 346, in _async_restart_scanner
await self._async_start()
File "/usr/src/homeassistant/homeassistant/components/bluetooth/scanner.py", line 301, in _async_start
raise ScannerStartError(
homeassistant.components.bluetooth.scanner.ScannerStartError: hci0 (B8:27:EB:27:CA:A7): Failed to start Bluetooth: [org.bluez.Error.NotReady] Resource Not Ready
Quel est le dongle que tu utilises ?
Et les logs de z2m ne sont pas complet.
Peux-tu mettre la partie manquante ?
A priori, l’erreur bluetooth ne devrait pas avoir d’impact.
Le log que je poste est tout ce qui apparaît quand je clique sur l’onglet log de l’addon
Le dongle est celui ci: Silicon_Labs_Sonoff_Zigbee_3.0_USB_Dongle_Plus
Le driver est bien mis a jour et j’ai essayé de suivre la procedure de flash en suivant ce tuto mais sans succès. (Au moment de demarrer le flash, a l’etape 9 la barre de chargement est rouge…)
Hello, il faut maintenir le bouton du dongle avant de l’insérer sur ton PC et pendant au moins 10 secondes une fois qu’il est inséré. j’ai du refaire plusieurs fois la manip pour y arriver
Dans ton log Z2M , le coordinateur (dongle ) est bien détecté.
Vu que tu n’as pas encore appairé d’équipements, il est normal qu’il t’indique 0 devices joined
En regardant tes captures d’écrans, je viens de voir que tu avais certainement activé l’option Home assistant cloud ( Nabu-Casa), ce qui change les URL de ton système.
Je te conseille de la désactiver pour l’instant, redémarrer ton système, et essayer de nouveau en remettant les ports par défaut pour Z2M et Mosquitto.
Bon même si ça n’a surement pas de rapport avec ton souci de port.
Quand tu es chez toi ce n’est pas la peine d’utiliser ton adresse NabuCasa, qu’il ne faudrait d’ailleurs pas vraiment poster sur un forum public sur internet
Sinon le « 502 Bad Gateway », c’est quand t’essayes d’ouvrir l’interface d’un add-on qui n’est pas démarré. Donc si ton Zigbee2MQTT n’a pas démarré c’est normal d’avoir ça.
Je vais supprimer les deux liens, je n’avais pas pensé à ça
Meme en local j’ai le souci du port 8485 bloque…
Et le 502 bad gateway, je l’ai que quand j’arrive a demarrer z2m. Autrement, si je clique sur l’interface web, il me met une fenetre popup pour me demander d’activer l’addon
Oui c’est vrai, j’aurais dû dire n’est pas « bien » démarré
Concernant le port, vu le peu d’add-ons que tu as, ça me parait super bizarre que 8485 soit pris par quelque chose. Ca ne viendrait pas de plusieurs tentatives infructueuses et que des choses trainent…
Je dirais que le premier truc à faire si tu ne l’as pas déjà fait c’est supprimer Zigbee2MQTT (après avoir récupéré tes infos de config). Puis redémarrer la machine comme conseillé plus haut, pour que le docker de HAOS se relance proprement.
Et ensuite réinstaller Z2M.
Sinon je n’ai plus Z2M en add-on dans HA mais sur une autre machine, mais il me semble que la configuration a été assez simplifiée au niveau de l’add-on, par exemple « base_topic » ton log dans le premier message semble ne pas aimer d’avoir ce paramètre.
Problème résolu en regardant sur ce poste qui date de 27j… je suis tombé dessus par hazard et il s’avère que j’avais juste a mettre mon ip (local mais je suppose que celle de nabu casa fonctionne aussi) suivie du port proposé dans la config. (192.168.xxx.xxx:1883)
Merci à tous pour votre aide. J’ai pu apprendre encore d’autre choses grâce à vos conseils
reste plus qu’a trouver comment inclure mes appareils appairés dans z2m, dans mes groupes existant de HA pour qu’il fonctionnent avec mes automatisations
