Hi there, thanks for the LiXee which I found reliable so far and easy to integra…te.
I post this message in english in case @Koenkk wants to jump in the conversation.
I have several zigbee devices configured in my Z2M but LiXee is spreading a lot of similar info at the same time as you can see in the following extract:
zlinky config: standard, single_phase, false, BASE
Zigbee2MQTT:info 2023-05-10 08:21:50: MQTT publish: topic 'zigbee2mqtt/LiXee', payload '{"active_enerfy_out_d01":31608.11,"active_power":822,"active_power_max":3493,"active_power_ph_b":594,"active_register_tier_delivered":"","apparent_power":2493,"available_power":12,"average_rms_voltage_meas_period":243,"current_date":"E230510082123","current_index_tarif":1,"current_price":"BASE","current_summ_delivered":39167.61,"current_tarif":"BASE","current_tier1_summ_delivered":39167.6,"current_tier2_summ_delivered":0,"drawn_v_a_max_n1":3316,"linkquality":69,"message1":"PAS DE MESSAGE","message2":"","meter_serial_number":"0123456789","power_threshold":12,"relais":0,"rms_current":10,"rms_current_max":0,"rms_voltage":242,"site_id":"0123456789","software_revision":2,"status_register":"003A4001","update":{"installed_version":13,"latest_version":13,"state":"idle"},"update_available":false,"warn_d_p_s":0}'
Zigbee2MQTT:info 2023-05-10 08:21:50: MQTT publish: topic 'zigbee2mqtt/LiXee', payload '{"active_enerfy_out_d01":31608.11,"active_power":822,"active_power_max":3493,"active_power_ph_b":594,"active_register_tier_delivered":"","apparent_power":2493,"available_power":12,"average_rms_voltage_meas_period":243,"current_date":"E230510082123","current_index_tarif":1,"current_price":"BASE","current_summ_delivered":39167.61,"current_tarif":"BASE","current_tier1_summ_delivered":39167.6,"current_tier2_summ_delivered":0,"drawn_v_a_max_n1":3316,"linkquality":72,"message1":"PAS DE MESSAGE","message2":"","meter_serial_number":"0123456789","power_threshold":12,"relais":0,"rms_current":10,"rms_current_max":0,"rms_voltage":242,"site_id":"0123456789","software_revision":2,"status_register":"003A4001","update":{"installed_version":13,"latest_version":13,"state":"idle"},"update_available":false,"warn_d_p_s":0}'
Zigbee2MQTT:info 2023-05-10 08:21:50: MQTT publish: topic 'zigbee2mqtt/LiXee', payload '{"active_enerfy_out_d01":31608.11,"active_power":822,"active_power_max":3493,"active_power_ph_b":594,"active_register_tier_delivered":"","apparent_power":2493,"available_power":12,"average_rms_voltage_meas_period":243,"current_date":"E230510082145","current_index_tarif":1,"current_price":"BASE","current_summ_delivered":39167.61,"current_tarif":"BASE","current_tier1_summ_delivered":39167.6,"current_tier2_summ_delivered":0,"drawn_v_a_max_n1":3316,"linkquality":69,"message1":"PAS DE MESSAGE","message2":"","meter_serial_number":"0123456789","power_threshold":12,"relais":0,"rms_current":10,"rms_current_max":0,"rms_voltage":242,"site_id":"0123456789","software_revision":2,"status_register":"003A4001","update":{"installed_version":13,"latest_version":13,"state":"idle"},"update_available":false,"warn_d_p_s":0}'
Zigbee2MQTT:info 2023-05-10 08:21:50: MQTT publish: topic 'zigbee2mqtt/LiXee', payload '{"active_enerfy_out_d01":31608.11,"active_power":822,"active_power_max":3493,"active_power_ph_b":594,"active_register_tier_delivered":"","apparent_power":2493,"available_power":12,"average_rms_voltage_meas_period":243,"current_date":"E230510082145","current_index_tarif":1,"current_price":"BASE","current_summ_delivered":39167.61,"current_tarif":"BASE","current_tier1_summ_delivered":39167.6,"current_tier2_summ_delivered":0,"drawn_v_a_max_n1":3316,"linkquality":72,"message1":"PAS DE MESSAGE","message2":"","meter_serial_number":"0123456789","power_threshold":12,"relais":0,"rms_current":10,"rms_current_max":0,"rms_voltage":242,"site_id":"0123456789","software_revision":2,"status_register":"003A4001","update":{"installed_version":13,"latest_version":13,"state":"idle"},"update_available":false,"warn_d_p_s":0}'
Zigbee2MQTT:info 2023-05-10 08:21:51: MQTT publish: topic 'zigbee2mqtt/LiXee', payload '{"active_enerfy_out_d01":31608.11,"active_power":822,"active_power_max":3493,"active_power_ph_b":594,"active_register_tier_delivered":"","apparent_power":2493,"available_power":12,"average_rms_voltage_meas_period":243,"current_date":"E230510082145","current_index_tarif":1,"current_price":"BASE","current_summ_delivered":39167.61,"current_tarif":"BASE","current_tier1_summ_delivered":39167.6,"current_tier2_summ_delivered":0,"drawn_v_a_max_n1":3316,"linkquality":72,"message1":"PAS DE MESSAGE","message2":"","meter_serial_number":"0123456789","power_threshold":12,"relais":0,"rms_current":10,"rms_current_max":0,"rms_voltage":242,"site_id":"0123456789","software_revision":2,"status_register":"003A4001","update":{"installed_version":13,"latest_version":13,"state":"idle"},"update_available":false,"warn_d_p_s":0}'
Zigbee2MQTT:info 2023-05-10 08:21:51: MQTT publish: topic 'zigbee2mqtt/LiXee', payload '{"active_enerfy_out_d01":31608.11,"active_power":822,"active_power_max":3493,"active_power_ph_b":594,"active_register_tier_delivered":"","apparent_power":2493,"available_power":12,"average_rms_voltage_meas_period":243,"current_date":"E230510082145","current_index_tarif":1,"current_price":"BASE","current_summ_delivered":39167.61,"current_tarif":"BASE","current_tier1_summ_delivered":39167.6,"current_tier2_summ_delivered":0,"drawn_v_a_max_n1":3316,"linkquality":69,"message1":"PAS DE MESSAGE","message2":"","meter_serial_number":"0123456789","power_threshold":12,"relais":0,"rms_current":10,"rms_current_max":0,"rms_voltage":242,"site_id":"0123456789","software_revision":2,"status_register":"003A4001","update":{"installed_version":13,"latest_version":13,"state":"idle"},"update_available":false,"warn_d_p_s":0}'
Zigbee2MQTT:info 2023-05-10 08:21:51: MQTT publish: topic 'zigbee2mqtt/LiXee', payload '{"active_enerfy_out_d01":31608.11,"active_power":822,"active_power_max":3493,"active_power_ph_b":594,"active_register_tier_delivered":"","apparent_power":2493,"available_power":12,"average_rms_voltage_meas_period":243,"current_date":"E230510082145","current_index_tarif":1,"current_price":"BASE","current_summ_delivered":39167.61,"current_tarif":"BASE","current_tier1_summ_delivered":39167.6,"current_tier2_summ_delivered":0,"drawn_v_a_max_n1":3316,"linkquality":80,"message1":"PAS DE MESSAGE","message2":"","meter_serial_number":"0123456789","power_threshold":12,"relais":0,"rms_current":10,"rms_current_max":0,"rms_voltage":242,"site_id":"0123456789","software_revision":2,"status_register":"003A4001","update":{"installed_version":13,"latest_version":13,"state":"idle"},"update_available":false,"warn_d_p_s":0}'
Zigbee2MQTT:info 2023-05-10 08:21:51: MQTT publish: topic 'zigbee2mqtt/LiXee', payload '{"active_enerfy_out_d01":31608.11,"active_power":822,"active_power_max":3493,"active_power_ph_b":594,"active_register_tier_delivered":"","apparent_power":2493,"available_power":12,"average_rms_voltage_meas_period":243,"current_date":"E230510082145","current_index_tarif":1,"current_price":"BASE","current_summ_delivered":39167.61,"current_tarif":"BASE","current_tier1_summ_delivered":39167.61,"current_tier2_summ_delivered":0,"drawn_v_a_max_n1":3316,"linkquality":72,"message1":"PAS DE MESSAGE","message2":"","meter_serial_number":"0123456789","power_threshold":12,"relais":0,"rms_current":10,"rms_current_max":0,"rms_voltage":242,"site_id":"0123456789","software_revision":2,"status_register":"003A4001","update":{"installed_version":13,"latest_version":13,"state":"idle"},"update_available":false,"warn_d_p_s":0}'
Zigbee2MQTT:info 2023-05-10 08:21:51: MQTT publish: topic 'zigbee2mqtt/LiXee', payload '{"active_enerfy_out_d01":31608.11,"active_power":822,"active_power_max":3493,"active_power_ph_b":594,"active_register_tier_delivered":"","apparent_power":2493,"available_power":12,"average_rms_voltage_meas_period":243,"current_date":"E230510082145","current_index_tarif":1,"current_price":"BASE","current_summ_delivered":39167.61,"current_tarif":"BASE","current_tier1_summ_delivered":39167.61,"current_tier2_summ_delivered":0,"drawn_v_a_max_n1":3316,"linkquality":69,"message1":"PAS DE MESSAGE","message2":"","meter_serial_number":"0123456789","power_threshold":12,"relais":0,"rms_current":10,"rms_current_max":0,"rms_voltage":242,"site_id":"0123456789","software_revision":2,"status_register":"003A4001","update":{"installed_version":13,"latest_version":13,"state":"idle"},"update_available":false,"warn_d_p_s":0}'
Zigbee2MQTT:info 2023-05-10 08:21:51: MQTT publish: topic 'zigbee2mqtt/LiXee', payload '{"active_enerfy_out_d01":31608.11,"active_power":822,"active_power_max":3493,"active_power_ph_b":594,"active_register_tier_delivered":"","apparent_power":2493,"available_power":12,"average_rms_voltage_meas_period":243,"current_date":"E230510082145","current_index_tarif":1,"current_price":"BASE","current_summ_delivered":39167.61,"current_tarif":"BASE","current_tier1_summ_delivered":39167.61,"current_tier2_summ_delivered":0,"drawn_v_a_max_n1":3316,"linkquality":65,"message1":"PAS DE MESSAGE","message2":"","meter_serial_number":"0123456789","power_threshold":12,"relais":0,"rms_current":10,"rms_current_max":0,"rms_voltage":242,"site_id":"0123456789","software_revision":2,"status_register":"003A4001","update":{"installed_version":13,"latest_version":13,"state":"idle"},"update_available":false,"warn_d_p_s":0}'
This happens at every poll, currently configured at 15s.
I don't understand why there are some many lines in a short period of time.
I don't know neither if the problem comes from the LiXee firmware (`4000-0013`) or from Zigbee2MQTT (`1.30.4 commit: b2dd21e`).
Log level is `info`, changing to `warn` removes all lines with payload.
Any clue?
Thanks.
