[s6-init] making user provided files available at /var/run/s6/etc...exited 0.
[s6-init] ensuring user provided files have correct perms...exited 0.
[fix-attrs.d] applying ownership & permissions fixes...
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts...
[cont-init.d] mosquitto.sh: executing...
[20:30:37] INFO: SSL is not enabled
[cont-init.d] mosquitto.sh: exited 0.
[cont-init.d] nginx.sh: executing...
[cont-init.d] nginx.sh: exited 0.
[cont-init.d] done.
[services.d] starting services
[services.d] done.
[20:30:40] INFO: Starting NGINX for authentication handling...
[20:30:41] INFO: Starting mosquitto MQTT broker...
1657650641: Warning: Mosquitto should not be run as root/administrator.
[20:30:46] INFO: Successfully send discovery information to Home Assistant.
[20:30:47] INFO: Successfully send service information to the Supervisor.
1657650641: mosquitto version 2.0.11 starting
1657650641: Config loaded from /etc/mosquitto/mosquitto.conf.
1657650641: Loading plugin: /usr/share/mosquitto/go-auth.so
1657650641: ├── Username/password checking enabled.
1657650641: ├── TLS-PSK checking enabled.
1657650641: └── Extended authentication not enabled.
1657650641: Opening ipv4 listen socket on port 1883.
1657650641: Opening ipv6 listen socket on port 1883.
1657650641: Opening websockets listen socket on port 1884.
1657650641: mosquitto version 2.0.11 running
1657650642: New connection from 127.0.0.1:59486 on port 1883.
1657650642: Client <unknown> closed its connection.
1657650644: New connection from 172.30.32.1:56275 on port 1883.
1657650644: New client connected from 172.30.32.1:56275 as 4nHK8b1vYlbQ6Czjk7Lgp7 (p2, c1, k60, u'homeassistant').
1657650665: New connection from 172.30.32.2:54052 on port 1883.
1657650665: Client <unknown> closed its connection.
1657650785: New connection from 172.30.32.2:54054 on port 1883.
1657650785: Client <unknown> closed its connection.
1657650905: New connection from 172.30.32.2:54056 on port 1883.
1657650905: Client <unknown> closed its connection.
1657651025: New connection from 172.30.32.2:54058 on port 1883.
1657651025: Client <unknown> closed its connection.
Le log de Zigbee2MQTT :
cont-init: info: running /etc/cont-init.d/socat.sh
[21:32:39] INFO: Socat not enabled, marking service as down
cont-init: info: /etc/cont-init.d/socat.sh exited 0
cont-init: info: running /etc/cont-init.d/zigbee2mqtt.sh
cont-init: info: /etc/cont-init.d/zigbee2mqtt.sh exited 0
services-up: info: copying legacy longrun socat (no readiness notification)
services-up: info: copying legacy longrun zigbee2mqtt (no readiness notification)
[21:32:47] INFO: Handing over control to Zigbee2MQTT Core ...
> zigbee2mqtt@1.26.0 start
> node index.js
Zigbee2MQTT:info 2022-07-12 21:33:00: Logging to console and directory: '/config/zigbee2mqtt/log/2022-07-12.21-33-00' filename: log.txt
Zigbee2MQTT:info 2022-07-12 21:33:01: Starting Zigbee2MQTT version 1.26.0 (commit #unknown)
Zigbee2MQTT:info 2022-07-12 21:33:01: Starting zigbee-herdsman (0.14.40)
Zigbee2MQTT:error 2022-07-12 21:33:12: Error while starting zigbee-herdsman
Zigbee2MQTT:error 2022-07-12 21:33:12: Failed to start zigbee
Zigbee2MQTT:error 2022-07-12 21:33:12: Check https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start.html for possible solutions
Zigbee2MQTT:error 2022-07-12 21:33:12: Exiting...
Zigbee2MQTT:error 2022-07-12 21:33:12: undefined
J'ai passé les 2 derniers jour à essayer de trouver une solution mais malheureusement en vain.
J'ai vu que l'erreur 502 était une erreur "générique" qui pouvait être différente, dans mon cas je vois qu'il n'arrive pas à lancer zigbee-herdsman.
J'ai une clé Conbee II et une prise zigbee "Nous" achetées toutes les 2 il y a une semaine.
Vu que tu utilises HA Os et l’adon Mosquito, tu n’as pas besoin de renseigner le user/pwd, il utilisera un compte technique automatiquement.
Et tu as juste à préciser base_topic: zigbee2mqtt dans la zone mqtt.
Es tu certain de cela ??? J’utilise HA OS et j’ai bien un USER et PASSWORD dans la config mqtt de zigbee2mqtt.
Ce login et ce mdp sont ceux définis dans la partie LOGINS de la configuration de Mosquitto
Fausse joie, j'ai enlever user & password et également enlever server: mqtt://core-mosquitto:1883, ça a fonctionné quelque instants, j'ai pu lancer Zigbee2MQTT après une minute, j'ai de nouveau l'erreur 502 ...
Voici le dernier log de Mosquitto :
1657708029: New connection from 172.30.32.2:55058 on port 1883.
1657708029: Client <unknown> closed its connection.
1657708140: Client 5O8s8qbXxzWuv6XFBkgY4R closed its connection.
1657708143: New connection from 172.30.33.3:57288 on port 1883.
error: received null username or password for unpwd check
1657708143: Client <unknown> disconnected, not authorised.
1657708149: New connection from 172.30.32.2:55062 on port 1883.
1657708149: Client <unknown> closed its connection.
1657708166: New connection from 172.30.33.3:57290 on port 1883.
1657708166: Client <unknown> disconnected, not authorised.
1657708192: New connection from 172.30.33.3:57292 on port 1883.
1657708192: Client <unknown> disconnected, not authorised.
1657708217: New connection from 172.30.33.3:57294 on port 1883.
[12:45:03] INFO: Handing over control to Zigbee2MQTT Core ...
> node index.js
Zigbee2MQTT:info 2022-07-13 12:45:16: Logging to console and directory: '/config/zigbee2mqtt/log/2022-07-13.12-45-16' filename: log.txt
Zigbee2MQTT:info 2022-07-13 12:45:16: Starting Zigbee2MQTT version 1.26.0 (commit #unknown)
Zigbee2MQTT:info 2022-07-13 12:45:16: Starting zigbee-herdsman (0.14.40)
Zigbee2MQTT:error 2022-07-13 12:45:27: Error while starting zigbee-herdsman
Zigbee2MQTT:error 2022-07-13 12:45:27: Failed to start zigbee
Zigbee2MQTT:error 2022-07-13 12:45:27: Check https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start.html for possible solutions
Zigbee2MQTT:error 2022-07-13 12:45:27: Exiting...
Zigbee2MQTT:error 2022-07-13 12:45:27: undefined
Mosquitto à l'air d'avoir un problème au niveau du user & password.
Du côté de Zigbee2MQTT il n'arrive de nouveau pas à lancer zigbee-herdsman...
Dans les intégrations, losrque je vais dans Mosquitto broker => Configure => Re-configure MQTT, j'ai ceci :
houla ne mélange pas tout. tu n’arrives pas à démarrer zigbee2mqtt donc tu reconfigures Mosquitto ???
l’erreur 502 signifie que Z2m n’a pas terminé sa procédure de démarrage parce qu’il a rencontré une erreur. donc si tu ne le configures pas comme il faut, tu peux toujours tout modifier dans ton HA, il ne démarrera pas pour autant.
Comme tu as touché à la config mosquitto, il t’indique maintenant qu’il y a une erreur car tu n’as pas configuré un USER et un MDP.
donc commence par mettre ces deux éléments en place.
Ensuite tu redémarres ton Mosquitto
puis tu configures ces même USER et MDP dans la partie MQTT de Z2M.
Tu finis par redémarrer ton Z2M
qu’il soit automatique ou pas, si Z2M n’utilise pas les mêmes paramètres que Mosquitto, ça pause problème puisque mosquitto refuse la connexion de Z2M.
@AnthonyD que tu utilises une méthode ou l’autre, il faut que les deux possèdent les même paramètres
Dans l’image que j’ai montrée « Broker options » je n’ai rien touché, je voulais juste être certain que je pouvais laisser ces informations et que je ne devais rien modifier.
Zigbee2MQTT fonctionne de nouveau (alors que je n’ai absolument rien modifier depuis ce midi)
Voici le log Zigbee2MQTT
[16:39:41] INFO: Handing over control to Zigbee2MQTT Core ...
> node index.js
Zigbee2MQTT:info 2022-07-13 16:39:59: Logging to console and directory: '/config/zigbee2mqtt/log/2022-07-13.16-39-59' filename: log.txt
Zigbee2MQTT:info 2022-07-13 16:40:00: Starting Zigbee2MQTT version 1.26.0 (commit #unknown)
Zigbee2MQTT:info 2022-07-13 16:40:00: Starting zigbee-herdsman (0.14.40)
Zigbee2MQTT:info 2022-07-13 16:40:01: zigbee-herdsman started (resumed)
Zigbee2MQTT:info 2022-07-13 16:40:01: Coordinator firmware version: '{"meta":{"maintrel":0,"majorrel":38,"minorrel":114,"product":0,"revision":"0x26720700","transportrev":0},"type":"ConBee2/RaspBee2"}'
Zigbee2MQTT:info 2022-07-13 16:40:01: Currently 0 devices are joined:
Zigbee2MQTT:info 2022-07-13 16:40:01: Zigbee: disabling joining new devices.
Zigbee2MQTT:info 2022-07-13 16:40:01: Connecting to MQTT server at mqtt://core-mosquitto:1883
Zigbee2MQTT:info 2022-07-13 16:40:04: Connected to MQTT server
Zigbee2MQTT:info 2022-07-13 16:40:04: MQTT publish: topic 'zigbee2mqtt/bridge/state', payload 'online'
Zigbee2MQTT:info 2022-07-13 16:40:04: Started frontend on port 0.0.0.0:8099
Zigbee2MQTT:info 2022-07-13 16:40:04: MQTT publish: topic 'zigbee2mqtt/bridge/config', payload '{"commit":"unknown","coordinator":{"meta":{"maintrel":0,"majorrel":38,"minorrel":114,"product":0,"revision":"0x26720700","transportrev":0},"type":"ConBee2/RaspBee2"},"log_level":"info","network":{"channel":11,"extendedPanID":"0xdddddddddddddddd","panID":6754},"permit_join":false,"version":"1.26.0"}'
J’ai pu ajouter ma prise zigbee à Zigbee2MQTT, j’ai redémarré HA afin de voir si ça allait de nouveau m’afficher l’erreur 502 mais pour le moment ça tient…
Je préfère ne pas y toucher pour le moment et voir si ça reste comme ça.
Si ça ne pose pas de problème je souhaiterais laisser le post ouvert quelques jours.
Mauvaise nouvelle, je n’ai rien changé à la configuration de Zigbee2MQTT (voir photo dans mon précédent post) ni à Mosquitto mais j’ai de nouveau l’erreur 502.
Mosquitto n’affiche aucun problème dans les logs (à part qu’il ne faut pas l’exécuter comme administrateur) :
[fix-attrs.d] done.
[20:50:57] INFO: Certificates found: SSL is available
[cont-init.d] done.
[services.d] done.
[20:50:59] INFO: Starting NGINX for authentication handling...
[20:51:00] INFO: Starting mosquitto MQTT broker...
1658256660: Warning: Mosquitto should not be run as root/administrator.
[20:51:05] INFO: Successfully send discovery information to Home Assistant.
[20:51:06] INFO: Successfully send service information to the Supervisor.
Log Zigbee2MQTT :
[21:14:13] INFO: Socat not enabled, marking service as down
[21:14:22] INFO: Handing over control to Zigbee2MQTT Core ...
> node index.js
Zigbee2MQTT:info 2022-07-19 21:14:37: Logging to console and directory: '/config/zigbee2mqtt/log/2022-07-19.21-14-36' filename: log.txt
Zigbee2MQTT:info 2022-07-19 21:14:37: Starting Zigbee2MQTT version 1.26.0 (commit #unknown)
Zigbee2MQTT:info 2022-07-19 21:14:37: Starting zigbee-herdsman (0.14.40)
Zigbee2MQTT:error 2022-07-19 21:14:48: Error while starting zigbee-herdsman
Zigbee2MQTT:error 2022-07-19 21:14:48: Failed to start zigbee
Zigbee2MQTT:error 2022-07-19 21:14:48: Check https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start.html for possible solutions
Zigbee2MQTT:error 2022-07-19 21:14:48: Exiting...
Zigbee2MQTT:error 2022-07-19 21:14:48: undefined
Lorsque je redémarre HA, je peux me connecter à Zigbee2MQTT, ça dure max une minute, ensuite la connexion s’arrête
Si quelqu’un a de nouvelles idées …
Perso
J’ai bien z2mqtt qui tourne mais il se met en erreur tous les 2 /3 jours en erreur 502. Bizarre (souvent la nuit)
Je redémarre HA et cela revient ok
Sans donner de détaille sur ta config , et tes paramètre de ta config surtout coté mosquito et z2m, bonbon pour t’aidé a trouvé …
Quand cela arrive avant de faire quoi que ce soit, vas voir direct dans les journaux , au pire tu posté les ici.
Quel ta cle Zigbee?
As tu d’autre clé d’installé ?
As tu met une petite rallonge USB ?
As tu connecté celle ci sur un USB 3 ?
tu vois des questions il peux en avoir plein , pour déterminé ton souci…
Alors oui en effet pardon j'ai dis ça un peu comme un boulet...
Donc j'ai ha sur un pi3 avec ssd, 1 clé zigbee avec double adaptateur (USB vers usbc vers USB, j'avais passé rallonge sous le coude. 1 clé zwave, 1 boitier 433, pi3 en RJ45
Le core en 2023.9.3
Zigbee2 mqtt via mosquito
Dans les.log rien de ouf il s'arrête comme ça.on dirait
J'ai que lixee sur zigbee2mqtt. Fait avec le tuto en auto du forum.
La chelou la conso de 2000w en instantané y'a.rien qui tourne en n ce moment... Curieux est ce qu'il rattrape le vides ?
Regarde si ta cle zwave et ta zigbee change pas de port entre elle ou d’autre clé cela arrive
Tes clefs as tu prévu un hub alimenté , il se peux que ton pi a du mal a fournir les volts , donc l’alim de ta clé tombe. donc plus connecté.
De plus tu es sur un SSD , donc alim peux être faiblarde
Va voir direct dans les journaux de zigbee, tu as peux t’etre loupe quelque chose.
