Zigbee2MQTT avec SLZB-06M - Fresh install erreur
je suis sur une fresh install… je viens du monde Jeedom. j’ai acheté une SLZB-06M en POE. j’ai installé Zigbee2MQTT. la SLZB-06M est sortie d’usine. j’ai essayé de la flasher via le site (FLASH) en la mettant en USB mais impossible ça met un message d’erreur.
mon fichier de configuration est le suivant :
data_path: /config/zigbee2mqtt
socat:
  enabled: false
  master: pty,raw,echo=0,link=/tmp/ttyZ2M,mode=777
  slave: tcp-listen:8485,keepalive,nodelay,reuseaddr,keepidle=1,keepintvl=1,keepcnt=5
  options: "-d -d"
  log: false
mqtt:
  base_topic: zigbee2mqtt
  user: mqtt_adm
  password: ****
serial:
  port: tcp://10.0.4.68:6638
  adapter: ember
  baudrate: 115200
  advanced:
    transmit_power: 20
et voici le log :
[13:56:01] INFO: Preparing to start...
[13:56:01] INFO: Socat not enabled
[13:56:02] INFO: Starting Zigbee2MQTT...
[2024-07-20 13:56:04] info: 	z2m: Logging to console, file (filename: log.log)
[2024-07-20 13:56:04] info: 	z2m: Starting Zigbee2MQTT version 1.39.0 (commit #unknown)
[2024-07-20 13:56:04] info: 	z2m: Starting zigbee-herdsman (0.50.1)
[2024-07-20 13:56:04] info: 	zh:ember: Using default stack config.
[2024-07-20 13:56:04] info: 	zh:ember: ======== Ember Adapter Starting ========
[2024-07-20 13:56:04] info: 	zh:ember:ezsp: ======== EZSP starting ========
[2024-07-20 13:56:04] info: 	zh:ember:uart:ash: ======== ASH NCP reset ========
[2024-07-20 13:56:04] info: 	zh:ember:uart:ash: Socket ready
[2024-07-20 13:56:04] info: 	zh:ember:uart:ash: ======== ASH starting ========
[2024-07-20 13:56:05] info: 	zh:ember:uart:ash: ======== ASH connected ========
[2024-07-20 13:56:05] info: 	zh:ember:uart:ash: ======== ASH started ========
[2024-07-20 13:56:05] info: 	zh:ember:ezsp: ======== EZSP started ========
[2024-07-20 13:56:05] error: 	z2m: Error while starting zigbee-herdsman
[2024-07-20 13:56:05] error: 	z2m: Failed to start zigbee
[2024-07-20 13:56:05] error: 	z2m: Check https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start.html for possible solutions
[2024-07-20 13:56:05] error: 	z2m: Exiting...
[2024-07-20 13:56:05] error: 	z2m: Error: NCP EZSP protocol version of 12 does not match Host version 13
    at EmberAdapter.emberVersion (/app/node_modules/zigbee-herdsman/src/adapter/ember/adapter/emberAdapter.ts:1714:19)
    at processTicksAndRejections (node:internal/process/task_queues:95:5)
    at EmberAdapter.initEzsp (/app/node_modules/zigbee-herdsman/src/adapter/ember/adapter/emberAdapter.ts:893:9)
    at EmberAdapter.start (/app/node_modules/zigbee-herdsman/src/adapter/ember/adapter/emberAdapter.ts:2722:24)
    at Controller.start (/app/node_modules/zigbee-herdsman/src/controller/controller.ts:129:29)
    at Zigbee.start (/app/lib/zigbee.ts:63:27)
    at Controller.start (/app/lib/controller.ts:139:27)
    at start (/app/index.js:154:5)
et la configuration de la SLZB-06M :
J’ai le dernier firmware fourni par le constructeur et le dernier OTA.
une idée? car pour le moment impossible d’avancer.
version core-2024.7.3
python_version 3.12.4
os_version 6.6.33-haos
arch x86_64
supervisor_version supervisor-2024.06.2
agent_version 1.6.0
docker_version 26.1.4
disk_total 30.8 GB
disk_used 5.0 GB
virtualization kvm
board ova
installed_addons Samba Backup (5.2.0), Mosquitto broker (6.4.1), Zigbee2MQTT (1.39.0-1), File editor (5.8.0), Samba share (12.3.1)
dashboards 5
resources 0
views 3
oldest_recorder_run 17 juillet 2024 à 15:25
current_recorder_run 19 juillet 2024 à 23:22
estimated_db_size 3.61 MiB
database_version 3.45.3
Tu as mis le driver ember mais ton firmware est sur une version inférieure au 7.4.x
Tant que tu n’aura pas flashé ton adaptateur ça ne fonctionnera pas
j’ai flasher en effet sous Ember j’ai plus d’erreur dans le log… mais j’ai un joli message explicite :
[17:48:35] INFO: Preparing to start...
[17:48:35] INFO: Socat not enabled
[17:48:35] INFO: Starting Zigbee2MQTT...
[2024-07-20 17:48:37] info: 	z2m: Logging to console, file (filename: log.log)
[2024-07-20 17:48:37] info: 	z2m: Starting Zigbee2MQTT version 1.39.0 (commit #unknown)
[2024-07-20 17:48:37] info: 	z2m: Starting zigbee-herdsman (0.50.1)
[2024-07-20 17:48:37] info: 	zh:ember: Using default stack config.
[2024-07-20 17:48:37] info: 	zh:ember: ======== Ember Adapter Starting ========
[2024-07-20 17:48:37] info: 	zh:ember:ezsp: ======== EZSP starting ========
[2024-07-20 17:48:37] info: 	zh:ember:uart:ash: ======== ASH NCP reset ========
[2024-07-20 17:48:37] info: 	zh:ember:uart:ash: Socket ready
[2024-07-20 17:48:37] info: 	zh:ember:uart:ash: ======== ASH starting ========
[2024-07-20 17:48:38] info: 	zh:ember:uart:ash: ======== ASH connected ========
[2024-07-20 17:48:38] info: 	zh:ember:uart:ash: ======== ASH started ========
[2024-07-20 17:48:38] info: 	zh:ember:ezsp: ======== EZSP started ========
**[2024-07-20 17:48:38] warning: 	zh:ember: [EzspConfigId] Failed to SET "ADDRESS_TABLE_SIZE" TO "16" with status=ERROR_OUT_OF_MEMORY. Firmware value will be used instead.**
**[2024-07-20 17:48:38] warning: 	zh:ember: [EzspConfigId] Failed to SET "APS_UNICAST_MESSAGE_COUNT" TO "32" with status=ERROR_OUT_OF_MEMORY. Firmware value will be used instead.**
**[2024-07-20 17:48:38] warning: 	zh:ember: [EzspConfigId] Failed to SET "NEIGHBOR_TABLE_SIZE" TO "26" with status=ERROR_OUT_OF_MEMORY. Firmware value will be used instead.**
**[2024-07-20 17:48:38] warning: 	zh:ember: [EzspConfigId] Failed to SET "SOURCE_ROUTE_TABLE_SIZE" TO "200" with status=ERROR_INVALID_VALUE. Firmware value will be used instead.**
**[2024-07-20 17:48:38] warning: 	zh:ember: [EzspConfigId] Failed to SET "MULTICAST_TABLE_SIZE" TO "16" with status=ERROR_OUT_OF_MEMORY. Firmware** value will be used instead.
[2024-07-20 17:48:38] info: 	zh:ember: [STACK STATUS] Network up.
[2024-07-20 17:48:38] info: 	zh:ember: [INIT TC] NCP network matches config.
[2024-07-20 17:48:39] info: 	zh:ember: [CONCENTRATOR] Started source route discovery. 1247ms until next broadcast.
[2024-07-20 17:48:39] info: 	zh:ember:queue: Request dispatching started.
[2024-07-20 17:48:39] info: 	z2m: zigbee-herdsman started (resumed)
[2024-07-20 17:48:39] info: 	z2m: Coordinator firmware version: '{"meta":{"build":0,"ezsp":13,"major":7,"minor":4,"patch":1,"revision":"7.4.1 [GA]","special":0,"type":170},"type":"EmberZNet"}'
[2024-07-20 17:48:39] info: 	z2m: Currently 5 devices are joined:
[2024-07-20 17:48:39] info: 	z2m: Telecommande 1 (0x5c0272fffef6f915): LDSENK09 - ADEO Security system key fob (EndDevice)
[2024-07-20 17:48:39] info: 	z2m: Temp - Sdb Enfants (0x00124b0022698353): SNZB-02 - SONOFF Temperature and humidity sensor (EndDevice)
[2024-07-20 17:48:39] info: 	z2m: Test (0x00158d00090e78c1): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
[2024-07-20 17:48:39] info: 	z2m: Couloir (0x00158d0006ffd9c6): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
[2024-07-20 17:48:39] info: 	z2m: Prise (0xa4c138876b51a037): A1Z - Nous Smart plug (with power monitoring) (Router)
[u]***[2024-07-20 17:48:39] info: 	z2m: Zigbee: disabling joining new devices.***[/u]
[2024-07-20 17:48:39] info: 	z2m: Connecting to MQTT server at mqtt://core-mosquitto:1883
[2024-07-20 17:48:39] info: 	z2m: Connected to MQTT server
[2024-07-20 17:48:39] info: 	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/bridge/state', payload '{"state":"online"}'
[2024-07-20 17:48:39] info: 	z2m: Started frontend on port 8099
[2024-07-20 17:48:39] info: 	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Telecommande 1', payload '{"action":null,"linkquality":196}'
[2024-07-20 17:48:39] info: 	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Temp - Sdb Enfants', payload '{"battery":75,"humidity":81.26,"linkquality":176,"temperature":25.67,"voltage":2900}'
[2024-07-20 17:48:39] info: 	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Test', payload '{"battery":100,"contact":true,"device_temperature":29,"linkquality":255,"power_outage_count":17,"trigger_count":6,"voltage":3215}'
[2024-07-20 17:48:39] info: 	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Couloir', payload '{"battery":100,"contact":true,"device_temperature":29,"linkquality":196,"power_outage_count":107,"trigger_count":0,"voltage":3225}'
[2024-07-20 17:48:39] info: 	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Prise', payload '{"child_lock":"UNLOCK","countdown":0,"current":0,"energy":26.55,"indicator_mode":"off/on","linkquality":176,"power":0,"power_outage_memory":"restore","state":"ON","update":{"installed_version":-1,"latest_version":-1,"state":null},"update_available":null,"voltage":236}'
[2024-07-20 17:48:39] info: 	z2m: Zigbee2MQTT started!
[2024-07-20 17:48:44] info: 	z2m:mqtt: MQTT publish: topic 'homeassistant/binary_sensor/1221051039810110150109113116116_0x847127fffedca5c0/connection_state/config', payload '{"device":{"hw_version":"EmberZNet 7.4.1 [GA]","identifiers":["zigbee2mqtt_bridge_0x847127fffedca5c0"],"manufacturer":"Zigbee2MQTT","model":"Bridge","name":"Zigbee2MQTT Bridge","sw_version":"1.39.0"},"device_class":"connectivity","entity_category":"diagnostic","name":"Connection state","object_id":"zigbee2mqtt_bridge_connection_state","origin":{"name":"Zigbee2MQTT","sw":"1.39.0","url":"https://www.zigbee2mqtt.io"},"payload_off":"offline","payload_on":"online","state_topic":"zigbee2mqtt/bridge/state","unique_id":"bridge_0x847127fffedca5c0_connection_state_zigbee2mqtt","value_template":"{{ value_json.state }}"}'
le message suivant est : info: z2m: Zigbee: disabling joining new devices.***[/u] et en effet il est impossible d’ajouter des périphériques.
mon fichier configuration.yaml est comme ceci :
socat:
  enabled: false
  options: "-d -d"
  log: false
mqtt:
  user: mqtt_adm
  password:
serial:
  adapter: ember
  baudrate: 115200
permit_join: true
Une idée? merci
As-tu essayé de faire un démarrage complet de HA ?
Vérifie la configuration avant de redémarrer au cas où.
dans le doute reboot ça fonctionne aussi pour Ha on dirait! merci !
Tout à fait normal ce message il t’indique juste au démarrage que l’appairage est désactivé
