Zigbee2mqtt ....encore
Bonsoir,
Après avoir configuré un nouvel HA, je me heurte à nouveau à zigbee2mqtt.
Le tutoriel d’origine
J’ai utilisé ce tutoriel: Tuto installation zigbee2mqtt et Broker mosquito
J’ai rajouté dans configuration.yaml
homeassistant: true
permit_join: true
mon souci
la connexion Mosquitto est refusée, le journal zigbee2mqtt:
[19:20:32] INFO: Preparing to start...
[19:20:32] INFO: Socat not enabled
[19:20:33] INFO: Starting Zigbee2MQTT...
Zigbee2MQTT:info  2023-07-13 19:20:36: Logging to console and directory: '/config/zigbee2mqtt/log/2023-07-13.19-20-36' filename: log.txt
Zigbee2MQTT:info  2023-07-13 19:20:36: Starting Zigbee2MQTT version 1.32.1 (commit #unknown)
Zigbee2MQTT:info  2023-07-13 19:20:36: Starting zigbee-herdsman (0.16.0)
Zigbee2MQTT:info  2023-07-13 19:20:37: zigbee-herdsman started (resumed)
Zigbee2MQTT:info  2023-07-13 19:20:37: Coordinator firmware version: '{"meta":{"maintrel":0,"majorrel":38,"minorrel":114,"product":0,"revision":"0x26720700","transportrev":0},"type":"ConBee2/RaspBee2"}'
Zigbee2MQTT:info  2023-07-13 19:20:37: Currently 0 devices are joined:
Zigbee2MQTT:warn  2023-07-13 19:20:37: `permit_join` set to  `true` in configuration.yaml.
Zigbee2MQTT:warn  2023-07-13 19:20:37: Allowing new devices to join.
Zigbee2MQTT:warn  2023-07-13 19:20:37: Set `permit_join` to `false` once you joined all devices.
Zigbee2MQTT:info  2023-07-13 19:20:37: Zigbee: allowing new devices to join.
Zigbee2MQTT:info  2023-07-13 19:20:37: Connecting to MQTT server at mqtt://core-mosquitto
Zigbee2MQTT:error 2023-07-13 19:20:38: MQTT error: Connection refused: Not authorized
Zigbee2MQTT:error 2023-07-13 19:20:38: MQTT failed to connect, exiting...
Zigbee2MQTT:info  2023-07-13 19:20:38: Stopping zigbee-herdsman...
Zigbee2MQTT:info  2023-07-13 19:20:39: Stopped zigbee-herdsman
Configuration mosquitto:
logins: []
require_certificate: false
certfile: fullchain.pem
keyfile: privkey.pem
customize:
  active: false
  folder: mosquitto
Configuration zigbee2mqtt:
data_path: /config/zigbee2mqtt
socat:
  enabled: false
  master: pty,raw,echo=0,link=/tmp/ttyZ2M,mode=777
  slave: tcp-listen:8485,keepalive,nodelay,reuseaddr,keepidle=1,keepintvl=1,keepcnt=5
  options: "-d -d"
  log: false
mqtt:
  base_topic: zigbee2mqtt
  server: mqtt://core-mosquitto
serial:
  port: >-
    /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2686100-if00
  adapter: deconz
Je dois passer à coté d’un truc, je ne trouve pas, vos lumières me seraient utiles…
tu est sur que ça vient pas de la ? il faut une ip normalement non du moins c’est comme ça que c’est configurer chez moi
et dans l’ideal cree un utilisateur sur mqtt et rentre les info dans z2m
voici mon exemple :
homeassistant: true
permit_join: false
mqtt:
  server: mqtt://IP:PORT
  user: username
  password: ******
  keepalive: 60
  reject_unauthorized: true
  version: 4
serial:
  port: /dev/ttyUSB0
Je n’ai vu aucune info dans les tutos. Je viens d’ essayer mais ça ne fonctionne pas. Dommage…
c’est configuré comme ça chez moi
mais tout dépend où est installé le serveur mqtt.
tout est sur un Nas Synology et VM. Je me connecte en local sur ce port 1883. L’ajout du port ne change rien, même message d’erreur.
Zigbee2MQTT:info  2023-07-13 21:48:11: Connecting to MQTT server at mqtt://core-mosquitto:1883
Zigbee2MQTT:error 2023-07-13 21:48:11: MQTT error: Connection refused: Not authorized
Zigbee2MQTT:error 2023-07-13 21:48:11: MQTT failed to connect, exiting...
Zigbee2MQTT:info  2023-07-13 21:48:11: Stopping zigbee-herdsman...
Bon perso j’ai pas suivi le tuto, Z2M et mosquitto se trouvent où ? perso j’ai HA sur un pi Z2M sur un 2e pi et mosquitto sur un 3e pi
cdt
Bonsoir,
Tout est sur un NAS Synology et machine virtuelle
Après il se peux que simplement mqtt demande d’avoir a minima un usernme et un password d’ou la connexion refuser. Regarde pour créer un utilisateur sur mqtt et ajoute-le dans la config de z2m.
Testé, mais pas de résultat, accès toujours refusé
Bonsoir,
Il y a des trucs incompréhensibles. J’ai:
  • désinstallé Mosquitto
  • réinstallé Mosquitto
  • rien changé aux configurations Zigbee2mqtt et Mosquitto
    Maintenant tout fonctionne.
    Problème résolu…
Re,
un soucis d’interface chaise / clavier ça arrive à tout le monde :wink:
le principal c’est que ça fonctionne, même si du coup on sait pas pourquoi :slight_smile:
cdt
