Zigbee2MQTT - Erreur z2m: Failed to call 'HomeAssistant'
Débutant sur HA, je tente de configurer Zigbee2MQTT sur un Raspberry PI 5 dans le but d’ajouter une clé Lixee Zlinky.
Pour celà j’utilise une clé Sonoff_Zigbee_3.0_USB_Dongle_Plus
Bien sur, je rencontre un bug sur le paramétrage Zigbee2MQTT /MQTT, au lancement du module Zigbee2MQTT, j’ai le message suivant dans les logs :
[21:44:39] INFO: Preparing to start...
[21:44:40] INFO: Socat not enabled
[21:44:40] INFO: Starting Zigbee2MQTT...
[2024-10-10 21:44:42] info: 	z2m: Logging to console, file (filename: log.log)
[2024-10-10 21:44:42] info: 	z2m: Starting Zigbee2MQTT version 1.40.2 (commit #unknown)
[2024-10-10 21:44:42] info: 	z2m: Starting zigbee-herdsman (2.1.3)
[2024-10-10 21:44:43] error: 	zh:zstack:znp: Failed to determine if path is valid: 'Error: spawn udevadm ENOENT'
[2024-10-10 21:44:43] info: 	zh:zstack:znp: Opening SerialPort with {"path":"/dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_260acbd502e7ed11ab89cf770b2af5ab-if00-port0","baudRate":115200,"rtscts":false,"autoOpen":false}
[2024-10-10 21:44:43] info: 	zh:zstack:znp: Serialport opened
[2024-10-10 21:44:43] info: 	z2m: zigbee-herdsman started (resumed)
[2024-10-10 21:44:43] info: 	z2m: Coordinator firmware version: '{"meta":{"maintrel":1,"majorrel":2,"minorrel":7,"product":1,"revision":20210708,"transportrev":2},"type":"zStack3x0"}'
[2024-10-10 21:44:43] info: 	z2m: Currently 0 devices are joined.
[2024-10-10 21:44:43] info: 	z2m: Zigbee: disabling joining new devices.
[2024-10-10 21:44:43] info: 	z2m: Connecting to MQTT server at mqtt://core-mosquitto:1883
[2024-10-10 21:44:43] info: 	z2m: Connected to MQTT server
[2024-10-10 21:44:43] info: 	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/bridge/state', payload 'online'
[2024-10-10 21:44:43] error: 	z2m: Failed to call 'Bridge' 'start' (TypeError: Cannot read properties of undefined (reading 'getDevice')
    at Bridge.publishInfo (/app/lib/extension/bridge.ts:746:69)
    at Bridge.start (/app/lib/extension/bridge.ts:174:20)
    at Controller.callExtensions (/app/lib/controller.ts:399:17)
    at Controller.start (/app/lib/controller.ts:218:9)
    at start (/app/index.js:154:5))
[2024-10-10 21:44:43] info: 	z2m: Started frontend on port 8099
[2024-10-10 21:44:43] info: 	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/bridge/config', payload '{"commit":"unknown","coordinator":{"meta":{"maintrel":1,"majorrel":2,"minorrel":7,"product":1,"revision":20210708,"transportrev":2},"type":"zStack3x0"},"log_level":"info","network":{"channel":11,"extendedPanID":"0x58fe883029693868","panID":31293},"permit_join":false,"version":"1.40.2"}'
[2024-10-10 21:44:43] [color=#]error[/color]: 	z2m: Failed to call 'HomeAssistant' 'start' (TypeError: Cannot read properties of undefined (reading 'deviceIeeeAddress')
    at HomeAssistant.getBridgeEntity (/app/lib/extension/homeassistant.ts:2016:78)
    at HomeAssistant.start (/app/lib/extension/homeassistant.ts:476:28)
[2024-10-10 21:44:43] info: 	z2m: Zigbee2MQTT started!
Je cherche désespérément une solution depuis une semaine mais je ne trouve rien pour résoudre mon, problème.
J’ai essayé et vérifier plein de paramètres différents :
  • Clé sur Sonoff sur port usb 2.0
  • ZHA désactivé
  • etc…
Pour info voici une visu de mes modules :
MQTT :
Login :
- username : Mqtt_adm
  password : admin
Zigbee2MQTT
Socat :
enabled: false
master: pty,raw,echo=0,link=/tmp/ttyZ2M,mode=777
slave: tcp-listen:8485,keepalive,nodelay,reuseaddr,keepidle=1,keepintvl=1,keepcnt=5
options: "-d -d"
log: false
base_topic: zigbee2mqtt
user: mqtt_adm
password: admin
port: >-
Merci par avance pour votre aide.
version core-2024.10.1
python_version 3.12.4
os_version 6.6.31-haos-raspi
Installed Version 2.0.1
Available Repositories 1434
Downloaded Repositories 54
logged_in true
subscription_expiration 13 octobre 2024 à 02:00
relayer_connected true
relayer_region eu-central-1
remote_enabled true
remote_connected true
alexa_enabled true
google_enabled true
remote_server eu-central-1-19.ui.nabu.casa
certificate_status ready
instance_id 7ce70a18708b4104a738024ca1d4155b
host_os Home Assistant OS 13.2.rc1
update_channel beta
supervisor_version supervisor-2024.10.1
agent_version 1.6.0
docker_version 27.2.0
disk_total 57.8 GB
disk_used 11.0 GB
virtualization
board rpi5-64
installed_addons Matter Server (6.6.0), Terminal & SSH (9.15.0), Fusion (2024.7.1), eufy-security-ws (1.9.1), Linky (1.5.0), go2rtc (1.9.4), File editor (5.8.0), Mosquitto broker (6.4.1), Zigbee2MQTT (1.40.2-1), Silicon Labs Flasher (0.3.0)
dashboards 1
resources 35
views 11
oldest_recorder_run 29 septembre 2024 à 20:53
current_recorder_run 10 octobre 2024 à 17:53
estimated_db_size 110.95 MiB
database_version 3.45.3
Spotify
api_endpoint_reachable ok
Pour ton erreur, je ne saurais te dire ce que c’est, mais en tous cas:
  • L’erreur que tu mets en titre n’est pas la première dans tes logs…
  • Z2M ne se « connecte » pas à Home Assistant… vu qu’il y a MQTT entre les 2…
  • Il semblerait que Z2M soit tout de même démarré.
Tu ne le mentionnes pas, mais quand tu essayes d’aller sur Z2M, il marche ou pas ?
Car là ça semble se connecter à MQTT et ça dit que le front end est lancé…
Oui j’arrive sur la page Zigbee2Mqtt et quand je veux appairer ma clé. Il ne se passe rien.
Dans les paramètres de Zigbee2Mqtt il n’y a rien qui fait référence à ma clé Zigbee.
Ca devrait être dans Paramètres>Port Série
Tu n’appaire pas le coordinateur ( ta clé) mais les équipements zigbee ( inter, Switch, light, capteur de température…etc )
Tout semble vide dans Zigbee2Mqtt :
Quand je parlais d’appairer la clé je parlais du Zlinky pas de l’adaptateur Zigbee. :innocent:
dans Z2mqtt, dans le port, par rapport à ma config, il te manque une info :
port: >-
  /dev/serial/by-id/usb-Nabu_Casa_Home_Assistant_Connect_ZBT-1_5699e550a4dced11b73ce92d62c613ac-if00-port0
adapter: ember
C’est fonction de ton modèle de coordinateur , je te conseille d’aller voir ce tuto pour plus d’infos.
[TUTO] Installation de Zigbee2mqtt et Broker Mosquitto - Home Assistant - Tutoriels & Partages / Add-on - Home Assistant Communauté Francophone (hacf.fr)
Est-ce que dans les paramètres de Z2mqtt, tu vois les détails de ton coordinateur ?
Attention, c’est effectivement en fonction de la puce utilisée par la clé zigbee.
Celle utilisée par @Redsklns ne nécessite aucun paramètre supplémentaire.
tu as ignorer Zigbee Home Automation ( ZHA ) ?
regarde dans paramètres / appareils et services, si tu n’as pas une proposition d’installation de ZHA.
Si c’est le cas il faut cliquer sur ignorer.
Ok merci pour l’info.
Je viens de vérifier et non ZHA n’apparaît pas. Je l’ai ignoré.
J’ai l’impression que le problème se situe entre Zigbee2Mqtt et la clé sonoff. Cette dernière n’est pas reconnue/ajoutée.
Est-ce que tu trouves bien ta clé dans paramètres>système>materiel>tout le matériel?
Tu peux essayer de rajouter, adapter: zstack:
port: >-
adapter: zstack
J’ai vu quelques utilisateurs qui ont dû le mettre avec une clé sonoff P, même si ca fonctionne sans.
Oui la clé est bien détecté par HA
Je viens de tester avec. Pas de changement. Zigbee2Mqtt se lance toujours mais même après un redémarrage toujours pas de détection dans zigbee2Mqtt.
As tu une rallonge USB sur ta clé Zigbee ?
Non. Là clé est branchée directement sur une prise usb2 du Raspberry
Il faudrait essayer d’en mettre une.
J’ai essayé avec une rallonge. Pas de changement.
J’ai même renvoyer ma clé Sonoff pour prendre une clé SMLIGHT SLZB-07 Zigbee 3.0.
Je n’arrive pas à configurer Zigbee2Mqtt avec le même paramétrage que j’utilisais avant (j’ai juste changé le port pour mettre le nouvel iD).
Pouvez-vous me dire si il y a une subtilité avec la clé SMLIGHT SLZB-07 ? Peut être une ligne spécifique pour l’adapter ?
