Bonsoir à tous,
Depuis plusieurs jours j’ai le message suivant dans les logs Zigbee2mqtt, sachant que je n’ai rien changer à ma configuration, juste passer les update HA
Zigbee2MQTT:error 2021-10-11 18:40:50: Error while starting zigbee-herdsman
Zigbee2MQTT:error 2021-10-11 18:40:50: Failed to start zigbee
Zigbee2MQTT:error 2021-10-11 18:40:50: Check https://www.zigbee2mqtt.io/information/FAQ.html#help-zigbee2mqtt-fails-to-start for possible solutions
Zigbee2MQTT:error 2021-10-11 18:40:50: Exiting...
Zigbee2MQTT:error 2021-10-11 18:40:50: Error: Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B0018E32F0B-if00'
at SerialPort.<anonymous> (/app/node_modules/zigbee-herdsman/src/adapter/z-stack/znp/znp.ts:146:28)
at SerialPort._error (/app/node_modules/zigbee-herdsman/node_modules/@serialport/stream/lib/index.js:198:14)
at /app/node_modules/zigbee-herdsman/node_modules/@serialport/stream/lib/index.js:242:12
[18:40:50] INFO: Handing over control to Zigbee2mqtt Core ...
> zigbee2mqtt@1.21.2 start
> node index.js
Voici ma configuration Z2M
data_path: /config/zigbee2mqtt
external_converters: []
devices: devices.yaml
groups: groups.yaml
homeassistant: true
permit_join: true
mqtt:
base_topic: zigbee2mqtt
server: mqtt://192.168.0.23
user: xxxx
password: xxxx
serial:
port: >-
advanced:
log_level: warn
pan_id: 6754
channel: 11
network_key:
- 1
- 3
- 5
- 7
- 9
- 11
- 13
- 15
- 0
- 2
- 4
- 6
- 8
- 10
- 12
- 13
availability_blocklist: []
availability_passlist: []
zigbee_herdsman_debug: true
device_options:
'0x842e14fffe60df8d':
friendly_name: Bouton Store Veranda
legacy: false
blocklist: []
passlist: []
queue: {}
frontend:
port: 8099
experimental: {}
socat:
enabled: false
master: pty,raw,echo=0,link=/tmp/ttyZ2M,mode=777
slave: tcp-listen:8485,keepalive,nodelay,reuseaddr,keepidle=1,keepintvl=1,keepcnt=5
options: '-d -d'
log: false
Merci pour votre support
