Zigbee2mqtt : Error while starting zigbee-herdsman
Y a t-il une âme charitable pour m’éclairer sur mon problème ? :thinking:
Merci d’avance :pray:
Quand je clique dans le menu de gauche sur Zigbee2MQTT, j’ai ce message :
Le module complémentaire semble ne pas être prêt, il se peut qu’il soit encore en cours de démarrage. Voulez-vous réessayer ?
Avec en haut l’erreur 502: Bad Gateway
Voici le journal :
[21:23:04] INFO: Preparing to start...
[21:23:04] INFO: Socat not enabled
[21:23:04] INFO: Starting Zigbee2MQTT...
[2025-06-02 21:23:05] info: 	z2m: Logging to console, file (filename: log.log)
[2025-06-02 21:23:05] info: 	z2m: Starting Zigbee2MQTT version 2.4.0 (commit #unknown)
[2025-06-02 21:23:05] info: 	z2m: Starting zigbee-herdsman (4.1.0)
[2025-06-02 21:23:05] info: 	zh:adapter:discovery: Matched adapter: {"path":"/dev/ttyUSB0","manufacturer":"Itead","serialNumber":"44ad6b32af39ef118f2055f454516304","pnpId":"usb-Itead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_V2_44ad6b32af39ef118f2055f454516304-if00-port0","vendorId":"10c4","productId":"ea60"} => ember: path=/dev/ttyUSB0, score=4
[2025-06-02 21:23:05] info: 	zh:ember: Using default stack config.
[2025-06-02 21:23:05] info: 	zh:ember: ======== Ember Adapter Starting ========
[2025-06-02 21:23:05] info: 	zh:ember:ezsp: ======== EZSP starting ========
[2025-06-02 21:23:05] info: 	zh:ember:uart:ash: ======== ASH Adapter reset ========
[2025-06-02 21:23:05] info: 	zh:ember:uart:ash: RTS/CTS config is off, enabling software flow control.
[2025-06-02 21:23:05] info: 	zh:ember:uart:ash: Serial port opened
[2025-06-02 21:23:05] info: 	zh:ember:uart:ash: ======== ASH starting ========
[2025-06-02 21:23:07] info: 	zh:ember:uart:ash: ======== ASH Adapter reset ========
[2025-06-02 21:23:07] info: 	zh:ember:uart:ash: ======== ASH starting ========
[2025-06-02 21:23:10] info: 	zh:ember:uart:ash: ======== ASH Adapter reset ========
[2025-06-02 21:23:10] info: 	zh:ember:uart:ash: ======== ASH starting ========
[2025-06-02 21:23:12] info: 	zh:ember:uart:ash: ======== ASH Adapter reset ========
[2025-06-02 21:23:12] info: 	zh:ember:uart:ash: ======== ASH starting ========
[2025-06-02 21:23:15] info: 	zh:ember:uart:ash: ======== ASH Adapter reset ========
[2025-06-02 21:23:15] info: 	zh:ember:uart:ash: ======== ASH starting ========
[2025-06-02 21:23:18] error: 	z2m: Error while starting zigbee-herdsman
[2025-06-02 21:23:18] error: 	z2m: Failed to start zigbee-herdsman
[2025-06-02 21:23:18] error: 	z2m: Check https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start_crashes-runtime.html for possible solutions
[2025-06-02 21:23:18] error: 	z2m: Exiting...
[2025-06-02 21:23:18] error: 	z2m: Error: Failed to start EZSP layer with status=HOST_FATAL_ERROR.
    at EmberAdapter.initEzsp (/app/node_modules/.pnpm/zigbee-herdsman@4.1.0/node_modules/zigbee-herdsman/src/adapter/ember/adapter/emberAdapter.ts:666:19)
    at EmberAdapter.start (/app/node_modules/.pnpm/zigbee-herdsman@4.1.0/node_modules/zigbee-herdsman/src/adapter/ember/adapter/emberAdapter.ts:1548:24)
    at Controller.start (/app/node_modules/.pnpm/zigbee-herdsman@4.1.0/node_modules/zigbee-herdsman/src/controller/controller.ts:133:29)
    at Zigbee.start (/app/lib/zigbee.ts:71:27)
    at Controller.start (/app/lib/controller.ts:102:13)
    at start (/app/index.js:149:5)
Voici la config de Zigbee2MQTT
data_path: /config/zigbee2mqtt
socat:
  enabled: false
  master: pty,raw,echo=0,link=/tmp/ttyZ2M,mode=777
  slave: tcp-listen:8485,keepalive,nodelay,reuseaddr,keepidle=1,keepintvl=1,keepcnt=5
  options: "-d -d"
  log: false
mqtt:
  base_topic: zigbee2mqtt
  server: mqtt://core-mosquitto
  user: xxxx
  password: xxxx
serial:
  serial:
    port: >-
      /dev/serial/by-id/usb-Itead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_V2_44ad6b32af39ef118f2055f454516304-if00-port0
    adapter: ember
version core-2025.5.3
python_version 3.13.3
os_version 6.6.74-haos-raspi
timezone Indian/Reunion
Installed Version 2.0.5
Available Repositories 1996
Downloaded Repositories 5
host_os Home Assistant OS 15.2
supervisor_version supervisor-2025.05.3
agent_version 1.7.2
docker_version 28.0.4
disk_total 457.7 GB
disk_used 7.5 GB
virtualization
board yellow
installed_addons Terminal & SSH (9.17.0), Samba share (12.5.1), Zigbee2MQTT (2.4.0-1), Mosquitto broker (6.5.1), Music Assistant Server (2.5.4)
dashboards 4
resources 1
views 10
Network Configuration
adapters lo (disabled), end0 (enabled, default, auto), hassio (disabled), docker0 (disabled), vethce659d6 (disabled), veth1c52ed1 (disabled), veth81cdc2b (disabled), vethbf2be38 (disabled), veth4b6778d (disabled), veth20fca76 (disabled), vethbfdb97b (disabled), veth730f775 (disabled)
ipv4_addresses lo (127.0.0.1/8), end0 (10.15.5.2/24), hassio (172.30.32.1/23), docker0 (172.30.232.1/23), vethce659d6 (), veth1c52ed1 (), veth81cdc2b (), vethbf2be38 (), veth4b6778d (), veth20fca76 (), vethbfdb97b (), veth730f775 ()
ipv6_addresses lo (::1/128), end0 (fe80::97c2:e480:131:fc5/64), hassio (fe80::888d:f1ff:fe55:b177/64), docker0 (fe80::c8a9:58ff:fe59:f861/64), vethce659d6 (fe80::acc6:3eff:fe5b:d47b/64), veth1c52ed1 (fe80::f89e:84ff:fe3e:843d/64), veth81cdc2b (fe80::8c4e:8ff:fed4:b1c7/64), vethbf2be38 (fe80::e8e8:81ff:fec7:f490/64), veth4b6778d (fe80::e0b4:77ff:fec5:1609/64), veth20fca76 (fe80::c03a:a7ff:fe1b:a61d/64), vethbfdb97b (fe80::886b:fbff:fe75:a31c/64), veth730f775 (fe80::3c6b:1aff:fe02:32ae/64)
announce_addresses 10.15.5.2, fe80::97c2:e480:131:fc5
oldest_recorder_run 30 mai 2025 à 14:14
current_recorder_run 1 juin 2025 à 20:16
estimated_db_size 7.88 MiB
database_version 3.48.0
Tu as bien flashé ton dongle avec le dernier firmware qui doit être le 7.4.5
D’ailleurs quel dongle utilise tu ?
Édit : vu l’adresse du dongle c’est un sonoff typeE donc il faut s’assurer que la version du firmware est ok
Oui c’est bien un sonoff type E
Tu as raison ,j’ai flashé le dongle avec la version 8.0.2 et ca fonctionne
Merci pour ton aide :blush:
D’ailleurs il y a une version routeur du firmware, c’est quoi cette version et quel est l’interêt ?
Ça permet de transformer le dongle en routeur zigbee
Ok donc pas utile sachant que j’ai la yellow box
ça n’a pas de rapport
un routeur zigbee c’est juste un élément qui permet de mailler ton reseau
Et l’application Zigbee2mqtt le fait ? Ou je dois flasher le dongle avec le mode routeur ?
non encore une fois ça n’a aucun rapport XD
quasiment tous les devices zigbee sur secteur sont aussi des routeurs, a contrario des devices sur piles (et certains modules sans neutre) qui sont des end devices, et il est possible de flasher ces clés pour les transformer en routeur mais si elles sont routeurs elle ne peuvent pas être coordinateur
