Tout nouveau sur HA, j’essaie d’installer zigbee2mqtt, malheureusement sans succès.
Je me demande si le problème vient de l’incompatibilité entre zigbee2mqtt et Zigate USB-TTL
Voici les informations mises et obtenues.
ZiGate USB-TTL
ttyUSB0
/dev/serial/by-id/usb-Silicon_Labs_ZiGate_0001-if00-port0
Sous-système:
tty
Chemin d’accès au périphérique:
/dev/ttyUSB0
ID:
data_path: /config/zigbee2mqtt
socat:
enabled: false
master: pty,raw,echo=0,link=/tmp/ttyZ2M,mode=777
slave: tcp-listen:8485,keepalive,nodelay,reuseaddr,keepidle=1,keepintvl=1,keepcnt=5
options: « -d -d »
log: false
mqtt:
base_topic: zigbee2mqtt
server: mqtt://core-mosquitto
user: user
password: mdp
serial:
port: /dev/ttyUSB0
adapter: zigate
[14:11:23] INFO: Preparing to start…
[14:11:25] INFO: Socat not enabled
[14:11:31] INFO: Starting Zigbee2MQTT…
Zigbee2MQTT:info 2023-05-29 14:11:49: Logging to console and directory: ‹ /config/zigbee2mqtt/log/2023-05-29.14-11-49 › filename: log.txt
Zigbee2MQTT:info 2023-05-29 14:11:49: Starting Zigbee2MQTT version 1.30.4 (commit #unknown)
Zigbee2MQTT:info 2023-05-29 14:11:49: Starting zigbee-herdsman (0.14.111)
Zigbee2MQTT:error 2023-05-29 14:12:01: Error while starting zigbee-herdsman
Zigbee2MQTT:error 2023-05-29 14:12:01: Failed to start zigbee
Zigbee2MQTT:error 2023-05-29 14:12:01: Check Zigbee2MQTT fails to start | Zigbee2MQTT for possible solutions
Zigbee2MQTT:error 2023-05-29 14:12:01: Exiting…
Zigbee2MQTT:error 2023-05-29 14:12:02: Error: failed to connect to zigate adapter sendCommand error: Error: [object Object] after 10000ms
at ZiGateAdapter.start (/app/node_modules/zigbee-herdsman/src/adapter/zigate/adapter/zigateAdapter.ts:100:19)
at Zigbee.start (/app/lib/zigbee.ts:58:27)
at Controller.start (/app/lib/controller.ts:101:27)
at start (/app/index.js:107:5)
Est-ce que quelqu’un a une idée ?
Merci,
