Bonjour à tous, si quelqu’un peut m’aider à diagnostiquer mon problème :
Ma configuration Zigbee2MQTT ne fonctionne plus depuis ce matin,
Les Logs dans Mosquitto Broker évoque des. paquets malformés :
2024-12-14 09:39:15: New connection from 172.30.33.2:44670 on port 1883.
2024-12-14 09:39:15: New client connected from 172.30.33.2:44670 as mqttjs_24bacbfc (p2, c1, k60, u'addons').
2024-12-14 09:39:15: Client mqttjs_24bacbfc disconnected due to malformed packet.
2024-12-14 09:39:16: New connection from 172.30.33.2:44682 on port 1883.
2024-12-14 09:39:16: New client connected from 172.30.33.2:44682 as mqttjs_24bacbfc (p2, c1, k60, u'addons').
2024-12-14 09:39:16: Client mqttjs_24bacbfc disconnected due to malformed packet.
2024-12-14 09:39:17: New connection from 172.30.33.2:44686 on port 1883.
2024-12-14 09:39:17: New client connected from 172.30.33.2:44686 as mqttjs_24bacbfc (p2, c1, k60, u'addons').
2024-12-14 09:39:17: Client mqttjs_24bacbfc disconnected due to malformed packet.
2024-12-14 09:39:18: New connection from 172.30.33.2:44692 on port 1883.
2024-12-14 09:39:18: New client connected from 172.30.33.2:44692 as mqttjs_24bacbfc (p2, c1, k60, u'addons').
2024-12-14 09:39:18: Client mqttjs_24bacbfc disconnected due to malformed packet.
2024-12-14 09:39:19: New connection from 172.30.33.2:44694 on port 1883.
2024-12-14 09:39:19: New client connected from 172.30.33.2:44694 as mqttjs_24bacbfc (p2, c1, k60, u'addons').
2024-12-14 09:39:19: Client mqttjs_24bacbfc disconnected due to malformed packet.
coté zigbee2mqtt j’ai des messages du type :
|[2024-12-14 09:53:11] error: |z2m: Not connected to MQTT server!|
|[2024-12-14 09:53:11] error: |z2m: Cannot send message: topic: 'zigbee2mqtt/Capteur_Temp_Hum_Polution', payload: '{humidity:45,linkquality:189,pm25:5,temperature:20,update:{installed_version:16777233,latest_version:16777233,state:idle},update_available:null,voc_index:134}|
|[2024-12-14 09:53:11] error: |z2m: Cannot send message: topic: 'zigbee2mqtt/Mouvement_Garage', payload: '{battery:100,illuminance:4771,illuminance_lux:3,linkquality:58,occupancy:false,update:{installed_version:16777316,latest_version:16777316,state:idle},update_available:null}|
|[2024-12-14 09:53:12] error: |z2m: Not connected to MQTT server!|
|[2024-12-14 09:53:22] error: |z2m: Not connected to MQTT server!|
|[2024-12-14 09:53:31] error: |z2m: Not connected to MQTT server!|
version |
core-2024.12.3 |
installation_type |
Home Assistant OS |
dev |
false |
hassio |
true |
docker |
true |
user |
root |
virtualenv |
false |
python_version |
3.13.0 |
os_name |
Linux |
os_version |
6.6.51-haos-raspi |
arch |
aarch64 |
timezone |
Europe/Paris |
config_dir |
/config |
GitHub API |
ok |
GitHub Content |
ok |
GitHub Web |
ok |
HACS Data |
ok |
GitHub API Calls Remaining |
5000 |
Installed Version |
2.0.1 |
Stage |
running |
Available Repositories |
1488 |
Downloaded Repositories |
5 |
logged_in |
false |
can_reach_cert_server |
ok |
can_reach_cloud_auth |
ok |
can_reach_cloud |
ok |
host_os |
Home Assistant OS 14.0 |
update_channel |
stable |
supervisor_version |
supervisor-2024.11.4 |
agent_version |
1.6.0 |
docker_version |
27.2.0 |
disk_total |
116.8 GB |
disk_used |
9.2 GB |
healthy |
true |
supported |
true |
host_connectivity |
true |
supervisor_connectivity |
true |
ntp_synchronized |
true |
virtualization |
board |
rpi4-64 |
supervisor_api |
ok |
version_api |
ok |
installed_addons |
Advanced SSH & Web Terminal (19.0.0), Studio Code Server (5.17.3), Music Assistant Server (beta) (2.4.0b7), Matter Server (6.6.1), Mosquitto broker (6.4.1), Zigbee2MQTT (1.42.0-2) |
dashboards |
5 |
resources |
4 |
views |
20 |
mode |
storage |
oldest_recorder_run |
1 décembre 2024 à 00:09 |
current_recorder_run |
14 décembre 2024 à 09:52 |
estimated_db_size |
99.50 MiB |
database_engine |
sqlite |
database_version |
3.45.3 |
Spotify
api_endpoint_reachable |
ok |
