Zigbee2mqtt + mqtt
j’ai voulu essayer l’intégration de zigbee en utilisant zigbee2mqtt + mqtt, j’espère l’avoir bien configurée ?
version core-2023.10.3
python_version 3.11.5
os_version 6.1.56
arch x86_64
timezone Europe/Brussels
GitHub API Calls Remaining 4961
Installed Version 1.33.0
Available Repositories 1310
Downloaded Repositories 5
host_os Home Assistant OS 11.0
supervisor_version supervisor-2023.10.0
agent_version 1.6.0
docker_version 24.0.6
disk_total 439.4 GB
disk_used 9.2 GB
board generic-x86-64
installed_addons ESPHome (2023.9.3), File editor (5.6.0), Advanced SSH & Web Terminal (15.1.0), Spotify Connect (0.12.6), Terminal & SSH (9.7.1), Network UPS Tools (0.12.2), Home Assistant Google Drive Backup (0.111.1), Mosquitto broker (6.3.1), Zigbee2MQTT (1.33.1-1), MQTT Explorer (browser-1.0.1)
dashboards 3
resources 1
views 11
oldest_recorder_run 7 octobre 2023 à 08:03
current_recorder_run 17 octobre 2023 à 13:28
estimated_db_size 369.50 MiB
database_version 3.41.2
Spotify
api_endpoint_reachable ok
La configuration de zigbee2mqtt
homeassistant: true
advanced:
  network_key:
    - 214
    - 75
    - 235
    - 204
    - 34
    - 224
    - 79
    - 149
    - 49
    - 58
    - 189
    - 42
    - 32
    - 117
    - 76
    - 147
  pan_id: 60149
  ext_pan_id:
    - 79
    - 225
    - 88
    - 164
    - 75
    - 249
    - 84
    - 12
  log_level: warn
  log_syslog:
    app_name: Zigbee2MQTT
    eol: /n
    host: localhost
    localhost: localhost
    path: /dev/log
    pid: process.pid
    port: 514
    protocol: udp4
    type: '5424'
  last_seen: ISO_8601
mqtt:
  user: xxxx
  password: xxxxxxxx
  keepalive: 60
  reject_unauthorized: true
  version: 4
serial:
  port: >-
    /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE3020248-if00
  adapter: deconz
frontend:
  port: 8099
availability:
  active:
    timeout: 20
  passive:
    timeout: 240
devices:
  'xxxxx':
    friendly_name: Détecteur incendie - étage 1
    temperature_precision: ''
  'xxxxx9':
    friendly_name: Détecteur incendie - cave
  'xxxxxx':
    friendly_name: Détecteur incendie - cuisine
ota:
  ikea_ota_use_test_url: false
J’ai pu appareiller mes 3 détecteurs frient mais l’intégration
ConBee II
Zigbee Home Automation
est toujours découverte, est-ce normal ? Impossible de la supprimer.
De plus, je ne vois pas trace des différentes entités pour les différents détecteurs. Sauf dans l’écran de gestion de zigbee2mqtt, certaines entités apparaissent : batterie, détection de fumée ou pas, mais toutefois la température est marquée sans valeur °C par exemple.
EDIT
Je viens d’installer mqtt explorer et je vois bien les différents capteurs en revanche comment faire pour que ceux-ci apparaissent dans les entités pour pouvoir les utiliser dans les cartes.
tant que tu auras deux intégrations qui tournerons en parallèle en se connectant a la meme clé zigbee se sera la cata
Merci pour le tuto.
J'avais bien compris qu'il ne faut pas avoir deux intégration zigbee. Mais impossible de supprimer
Lorsque je clique sur les 3 points, j'ai un lien vers la documentation
Et dans la configuration, que je viens de mettre, l'intégration zha n'apparait pas.
Normal que la clef n'apparait pas ?
EDIT: un lien n'est pas affiché
J'ai voulu créer un groupe et on me demande de choisir un point de terminaison pour le détecteur. Que choisir ?
Edit 2 : j'ai à chaque fois des messages d'erreur lorsque je modifie la configuration des détecteurs
Failed to configure 'Alarme-incendie-cuisine', attempt 3 (Error: Bind xxxxxxxx genBasic from xxxxxxxx' failed (Error: status: 140) at DeconzAdapter.bind (/app/node_modules/zigbee-herdsman/src/adapter/deconz/adapter/deconzAdapter.ts:766:19) at Endpoint.bind (/app/node_modules/zigbee-herdsman/src/controller/model/endpoint.ts:645:13) at Object.bind (/app/node_modules/zigbee-herdsman-converters/src/lib/reporting.ts:43:9) at Object.configure (/app/node_modules/zigbee-herdsman-converters/src/devices/develco.ts:470:13) at Configure.configure (/app/lib/extension/configure.ts:117:13))
Oui, c’est normal que le coordinateur n’apparaisse pas dans la liste des appareils de Z2M
J’ai supprimé mqtt, reconfiguré, redémarré HA. Ceci dit, je l’avais fait (afin, je pense).
Je suis passé de 0 à 5 appareils (mes 5 détecteurs) ensuite de 0 entités à plus de 75 entités.
Pas de remontée de données pour la sonde de température des détecteurs.
Par contre sous ZHA, j’avais bien la température de la pièce.
sensor.alarme_incendie_cave_temperature : inconnu
