Zigbee2mqtt ne démarre plus suite à la maj
suite à la derniere maj, z2m ne démarre plus...
voila ma config:
data_path: /config/zigbee2mqtt
socat:
  enabled: false
  master: pty,raw,echo=0,link=/tmp/ttyZ2M,mode=777
  slave: tcp-listen:8485,keepalive,nodelay,reuseaddr,keepidle=1,keepintvl=1,keepcnt=5
  options: -d -d
  log: false
mqtt:
  server: mqtt://192.168.1.25:1883
  user: xxxxxx
  password: yyyyyyy
serial:
  port: >-
    /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0e7fb61eca3aec11bb75a4957a0af07f-if00-port0
et les logs:
[22:20:47] INFO: Preparing to start...
[22:20:47] INFO: Socat not enabled
[22:20:47] INFO: Starting Zigbee2MQTT...
[22:23:34] INFO: Preparing to start...
[22:23:34] INFO: Socat not enabled
[22:23:35] INFO: Starting Zigbee2MQTT...
[22:26:22] INFO: Preparing to start...
[22:26:22] ERROR: Got unexpected response from the API: System is not ready with state: shutdown
[22:26:22] ERROR: Failed to get addon config from Supervisor API
[22:26:22] FATAL:
[22:26:22] FATAL: A required add-on configuration option is missing!
[22:26:22] FATAL:
[22:26:22] FATAL: Please set a value for the 'data_path' option.
[22:26:22] FATAL:
[22:26:22] FATAL: If unsure, check the add-on manual for more information.
[22:26:22] FATAL:
[22:26:22] FATAL:
[22:26:22] FATAL:
[22:26:22] FATAL:
[22:26:22] FATAL:
[22:26:23] INFO: Preparing to start...
[22:26:23] ERROR: Got unexpected response from the API: System is not ready with state: shutdown
[22:26:23] ERROR: Failed to get addon config from Supervisor API
[22:26:23] FATAL:
[22:26:23] FATAL: A required add-on configuration option is missing!
[22:26:23] FATAL:
[22:26:23] FATAL: Please set a value for the 'data_path' option.
[22:26:23] FATAL:
[22:26:23] FATAL: If unsure, check the add-on manual for more information.
[22:26:23] FATAL:
[22:26:23] FATAL:
[22:26:23] FATAL:
[22:26:23] FATAL:
[22:26:23] FATAL:
[22:26:24] INFO: Preparing to start...
[22:26:24] ERROR: Got unexpected response from the API: System is not ready with state: shutdown
[22:26:24] ERROR: Failed to get addon config from Supervisor API
[22:26:24] FATAL:
[22:26:24] FATAL: A required add-on configuration option is missing!
[22:26:24] FATAL:
[22:26:24] FATAL: Please set a value for the 'data_path' option.
[22:26:24] FATAL:
[22:26:24] FATAL: If unsure, check the add-on manual for more information.
[22:26:24] FATAL:
[22:26:24] FATAL:
[22:26:24] FATAL:
[22:26:24] FATAL:
[22:26:24] FATAL:
[22:26:25] INFO: Preparing to start...
[22:26:25] ERROR: Got unexpected response from the API: System is not ready with state: shutdown
[22:26:25] ERROR: Failed to get addon config from Supervisor API
[22:26:25] FATAL:
[22:26:25] FATAL: A required add-on configuration option is missing!
[22:26:25] FATAL:
[22:26:25] FATAL: Please set a value for the 'data_path' option.
[22:26:25] FATAL:
[22:26:25] FATAL: If unsure, check the add-on manual for more information.
[22:26:25] FATAL:
[22:30:33] INFO: Preparing to start...
[22:30:33] INFO: Socat not enabled
[22:30:34] INFO: Starting Zigbee2MQTT...
[2026-09-04 22:31:00] error: 	zh:controller:device: Read response to 0xf84477fffe0f801a failed (ZCL command 0xf84477fffe0f801a/1 genTime.readRsp({"time":841869047,"localTime":841876247}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":true,"direction":1,"srcEndpoint":1,"reservedBits":0,"transactionSequenceNumber":16,"writeUndiv":false}) failed (Data request failed with error: 'NWK_NO_ROUTE' (0xcd)))
[22:33:15] INFO: Preparing to start...
[22:33:15] INFO: Socat not enabled
[22:33:15] INFO: Starting Zigbee2MQTT...
[22:35:58] INFO: Preparing to start...
[22:35:58] INFO: Socat not enabled
[22:35:58] INFO: Starting Zigbee2MQTT...
[22:38:40] INFO: Preparing to start...
[22:38:40] INFO: Socat not enabled
[22:38:41] INFO: Starting Zigbee2MQTT...
[22:41:23] INFO: Preparing to start...
[22:41:23] INFO: Socat not enabled
[22:41:24] INFO: Starting Zigbee2MQTT...
la version du foutware ... la meme depuis une éternité: 20221226, zéro modifs HW depuis un an...
version core-2026.8.3
container_arch aarch64
python_version 3.14.6
os_version 6.18.34-haos-raspi
logged_in true
subscription_expiration 19 décembre 2026 à 01:00
relayer_connected true
relayer_region eu-central-1
remote_enabled true
remote_connected true
remote_server eu-central-1-2.ui.nabu.casa
alexa_enabled false
google_enabled true
certificate_status ready
instance_id ac9ac8ddbfe9468f950a04eac5615569
iot_state connected
iot_tries 0
certificate_expire_date 20 octobre 2026 à 23:11
certificate_fingerprint 027160de2c84170234fa78131e7c6b19e1d6be99
certificate_alternative_names undefined
HACS
Installed Version 2.0.5
Available Repositories 4153
Downloaded Repositories 126
host_os Home Assistant OS 18.2
supervisor_version supervisor-2026.08.0
agent_version 1.10.0
docker_version 29.6.2
disk_total 457.7 GB
disk_used 57.0 GB
nameservers 192.168.1.2, fe80::56ec:b0ff:fe22:fb40, 2a01:cb05:9967:7800:56ec:b0ff:fe22:fb40
virtualization
board rpi5-64
disk_life_time 5 %
installed_addons Mosquitto broker (7.1.0), SQLite Web (6.1.1), chrony (6.1.0), Zigbee2MQTT (2.14.1-1), Studio Code Server (7.0.0), OpenThread Border Router (3.1.2), Matter Server (9.2.0), Piper (2.3.4), openWakeWord (2.1.1), Whisper (3.5.3), Advanced SSH & Web Terminal (24.1.3), Terminal & SSH (10.4.0), Network UPS Tools (0.18.1), SNMPD (0.6.0), Node-RED (22.0.5), rtl_433 (next) (next), rtl_433 MQTT Auto Discovery (next) (next), Z-Wave JS UI (7.6.0), SONOFF Dongle Flasher (1.3.4), Samba share (12.10.0), Home Assistant Time Machine (2.3.1), ESPHome Device Builder (2026.8.2), HassOS I2C Configurator (0.14), Z-Wave JS (1.7.1), Minitel-HA (1.0.0), CarConnectivity Add-on (0.8.26), Asterisk (6.2.0)
dashboards 17
resources 90
views 78
Network Configuration
adapters lo (disabled), end0 (enabled, default, auto), docker0 (disabled), hassio (disabled), vethee1dd93 (disabled), vethf4a23af (disabled), vethf5e97cc (disabled), veth52ac06d (disabled), vethc4fa3e2 (disabled), vethd0a47cb (disabled), vetha016fd4 (disabled), vethccc25c0 (disabled), veth883f6b3 (disabled), veth3746046 (disabled), veth9824a81 (disabled), wpan0 (disabled), vethe91af0a (disabled)
ipv4_addresses lo (127.0.0.1/8), end0 (192.168.1.25/24), docker0 (172.30.232.1/23), hassio (172.30.32.1/23), vethee1dd93 (), vethf4a23af (), vethf5e97cc (), veth52ac06d (), vethc4fa3e2 (), vethd0a47cb (), vetha016fd4 (), vethccc25c0 (), veth883f6b3 (), veth3746046 (), veth9824a81 (), wpan0 (), vethe91af0a ()
ipv6_addresses lo (::1/128), end0 (2a01:cb05:9967:7800:eb2:744a:31ef:5a1a/64, fdf8:91e9:2bf8:2b4d:e3ff:e436:e400:af7d/64, fe80::3bba:bcd9:40f7:a749/64), docker0 (fd0b:474:4fca::1/64, fe80::f4d0:caff:fece:f92d/64), hassio (fd0c:ac1e:2100::1/48, fe80::ec91:a0ff:fef0:cd44/64), vethee1dd93 (fe80::84b3:28ff:fe7e:4ea4/64), vethf4a23af (fe80::5c7a:a8ff:fe15:3f9d/64), vethf5e97cc (fe80::447c:66ff:fe43:78aa/64), veth52ac06d (fe80::ac9f:d2ff:fe73:4adc/64), vethc4fa3e2 (fe80::7c:99ff:fe7d:72f2/64), vethd0a47cb (fe80::4b9:37ff:fe50:e724/64), vetha016fd4 (fe80::4019:d9ff:fe91:61fd/64), vethccc25c0 (fe80::50e3:4bff:fe50:d8ae/64), veth883f6b3 (fe80::e4c3:1cff:fef0:d69d/64), veth3746046 (fe80::2814:2fff:fe7d:a96d/64), veth9824a81 (fe80::7c65:67ff:fea1:76f8/64), wpan0 (fd9b:f987:dca7::ff:fe00:fc11/64, fd4e:88c0:53a6:1:c856:6c30:db52:31ad/64, fd9b:f987:dca7::ff:fe00:fc38/64, fd9b:f987:dca7::ff:fe00:fc10/64, fd9b:f987:dca7::ff:fe00:fc00/64, fd9b:f987:dca7::ff:fe00:400/64, fd9b:f987:dca7:0:7f6c:cef4:56c7:4014/64, fe80::c77:94df:a145:3346/64), vethe91af0a (fe80::204f:a2ff:fe2d:8bfd/64)
announce_addresses 192.168.1.25, 2a01:cb05:9967:7800:eb2:744a:31ef:5a1a, fdf8:91e9:2bf8:2b4d:e3ff:e436:e400:af7d, fe80::3bba:bcd9:40f7:a749
oldest_recorder_run 24 août 2026 à 16:01
current_recorder_run 4 septembre 2026 à 22:28
estimated_db_size 3772.05 MiB
database_version 3.53.2
Sonoff
version 3.12.2 (871119a)
cloud_online 0 / 2
local_online 0 / 0
Spotify
api_endpoint_reachable ok
Truc qu'on arrive des fois
Débranches le dongle attends 10s et démarre z2m
Sinon il semble qu'il manque la directive data_path
Je ne sais pas s'il y est dans ton configuration.yaml dans le dossier de zigbee2mqtt, mais depuis un moment il faut ajouter adapter: zstack pour une sonoff P. Sinon Z2M, ne démarre pas.
serial:
  port: >-
    /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_3ee8ee205d29ec1193366f7840c9ce8d-if00-port0
  adapter: zstack
Bonjour et merci.
J'avais déja testé le shutdown et débranché tout les usb.
finalement, c'est reparti tout seul au bout d'une demi heure sans que je fasse quelque chose de plus.
la config affichée au dessus est la config de l'app.Z2M en mode yaml.
voici la config du fichier /config/zigbee2mqtt/configuration.yaml
homeassistant:
  enabled: true
  homeassistant_legacy_triggers: false
  discovery_topic: homeassistant
  status_topic: homeassistant/status
mqtt:
  base_topic: zigbee2mqtt
  user: xxxxxxx
  password: yyyyyyy
serial:
  adapter: zstack
  port: >-
frontend:
  enabled: true
  port: 8099
advanced:
  log_syslog:
    app_name: Zigbee2MQTT
    eol: /n
    host: localhost
    localhost: localhost
    path: /dev/log
    pid: process.pid
    port: 514
    protocol: udp4
    type: '5424'
  log_level: warning
device_options: {}
devices:
c'est à quel endroit qu'il faut faire les modifs maintenant ?
Si ça a redémarré c'est que ton soucis n'es pas due a la conf
C'est bon, tu a rien a faire.
Bon, si y'a plus rien à faire, je laisse comme çà... :wink:
