Zigbee2mqtt qui ne démarre plus
J'ai depuis quelques mois mon zigbee qui n'arrive pas à démarrer...
des fois ca marche du premier coup, des fois il reste bloqué une heure et repart...
j'ai un Z2M en 2.14.3-1
et une clef zigbee usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0e7fb61xxxxxxx
les logs sont comme cà:
[17:37:00] INFO: Preparing to start...
[17:37:00] INFO: Socat not enabled
[17:37:00] INFO: Starting Zigbee2MQTT...
[17:39:41] INFO: Preparing to start...
[17:39:41] INFO: Socat not enabled
[17:39:41] INFO: Starting Zigbee2MQTT...
[17:42:23] INFO: Preparing to start...
[17:42:23] INFO: Socat not enabled
[17:42:23] INFO: Starting Zigbee2MQTT...
la config z2m
data_path: /config/zigbee2mqtt
socat:
  enabled: false
  master: pty,raw,echo=0,link=/tmp/ttyZ2M,mode=777
  slave: tcp-listen:8485,keepalive,nodelay,reuseaddr,keepidle=1,keepintvl=1,keepcnt=5
  options: -d -d
  log: false
mqtt:
  server: mqtt://192.168.1.25:1883
  user: xxxxxx
  password: xxxxxx
serial:
  port: /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0e7fb61eca3aec11bb75a4957a0af07f-if00-port0
et
/config/zigbee2mqtt/configuration.yaml:
homeassistant:
  enabled: true
  homeassistant_legacy_triggers: false
  discovery_topic: homeassistant
  status_topic: homeassistant/status
mqtt:
  base_topic: zigbee2mqtt
  user: xxxxxx
  password: xxxxxx
serial:
  adapter: zstack
frontend:
  enabled: true
  port: 8099
advanced:
  log_syslog:
    app_name: Zigbee2MQTT
    eol: /n
    host: localhost
    localhost: localhost
    path: /dev/log
    pid: process.pid
    port: 514
    protocol: udp4
    type: '5424'
  log_level: warning
device_options: {}
devices:
  '0x9035eafffec07de6':
    friendly_name: RGB TV Bureau Benoit
    description: Ruban Led TV Chambre
    icon: device_icons/2bab7a960e244017b0962095dbf9fa34.png
  '0xf0d1b800001c0aa8':
et au niveau systeme:
DEVLINKS: >-
  /dev/serial/by-path/platform-xhci-hcd.0-usb-0:2:1.0-port0
  /dev/serial/by-path/platform-xhci-hcd.0-usbv2-0:2:1.0-port0
DEVNAME: /dev/ttyUSB0
DEVPATH: /devices/platform/axi/1000120000.pcie/1f00200000.usb/xhci-hcd.0/usb1/1-2/1-2:1.0/ttyUSB0/tty/ttyUSB0
ID_BUS: usb
ID_MODEL: Sonoff_Zigbee_3.0_USB_Dongle_Plus
ID_MODEL_ENC: Sonoff\x20Zigbee\x203.0\x20USB\x20Dongle\x20Plus
ID_MODEL_ID: ea60
ID_PATH: platform-xhci-hcd.0-usb-0:2:1.0
ID_PATH_TAG: platform-xhci-hcd_0-usb-0_2_1_0
ID_PATH_WITH_USB_REVISION: platform-xhci-hcd.0-usbv2-0:2:1.0
ID_REVISION: '0100'
ID_SERIAL: ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0e7fb61eca3aec11bb75a4957a0af07f
ID_SERIAL_SHORT: 0e7fb61eca3aec11bb75a4957a0af07f
ID_TYPE: generic
ID_USB_DRIVER: cp210x
ID_USB_INTERFACES: ':ff0000:'
ID_USB_INTERFACE_NUM: '00'
ID_USB_MODEL: Sonoff_Zigbee_3.0_USB_Dongle_Plus
ID_USB_MODEL_ENC: Sonoff\x20Zigbee\x203.0\x20USB\x20Dongle\x20Plus
ID_USB_MODEL_ID: ea60
ID_USB_REVISION: '0100'
ID_USB_SERIAL: ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0e7fb61eca3aec11bb75a4957a0af07f
ID_USB_SERIAL_SHORT: 0e7fb61eca3aec11bb75a4957a0af07f
ID_USB_TYPE: generic
ID_USB_VENDOR: ITead
ID_USB_VENDOR_ENC: ITead
ID_USB_VENDOR_ID: 10c4
ID_VENDOR: ITead
ID_VENDOR_ENC: ITead
ID_VENDOR_ID: 10c4
MAJOR: '188'
MINOR: '0'
SUBSYSTEM: tty
TAGS: ':systemd:'
USEC_INITIALIZED: '2504242237'
version core-2026.11.2
container_arch aarch64
python_version 3.14.10
os_version 6.18.59-haos-raspi
logged_in true
subscription_expiration 19 décembre 2026 à 01:00
relayer_connected true
relayer_region eu-central-1
remote_enabled true
remote_connected true
remote_server eu-3.ui.nabu.casa
alexa_enabled false
google_enabled true
certificate_status ready
instance_id ac9ac8ddbfe9468f950a04eac5615569
iot_state connected
iot_tries 0
certificate_expire_date 24 décembre 2026 à 22:30
certificate_fingerprint bb3ef3c61ee052c15ab50b849501e5cbb8ccf5a1
certificate_alternative_names undefined
host_os Home Assistant OS 18.5
supervisor_version supervisor-2026.11.0
agent_version 1.14.0
docker_version 29.8.2
disk_total 457.7 GB
disk_used 50.5 GB
nameservers 2a01:cb05:8294:1700:56ec:b0ff:fe22:fb40, 192.168.1.2, fe80::56ec:b0ff:fe22:fb40
virtualization
board rpi5-64
disk_life_time 5 %
installed_addons Mosquitto broker (7.1.3), SQLite Web (6.1.1), chrony (6.1.0), Zigbee2MQTT (2.14.3-1), Studio Code Server (7.2.0), OpenThread Border Router (3.4.0), Matter Server (9.3.0), Piper (2.5.4), openWakeWord (2.1.1), Whisper (3.6.1), Advanced SSH & Web Terminal (24.2.1), Terminal & SSH (10.6.0), Network UPS Tools (0.18.2), SNMPD (0.8.0), rtl_433 (next) (next), rtl_433 MQTT Auto Discovery (next) (next), Z-Wave JS UI (7.8.2), SONOFF Dongle Flasher (1.3.4), Samba share (12.11.0), Home Assistant Time Machine (2.4.3), ESPHome Device Builder (2026.10.2), HassOS I2C Configurator (0.14), Z-Wave JS (1.11.0), Minitel-HA (1.3.0), Asterisk (6.4.0)
dashboards 17
resources 94
views 78
Marketplace
download_profile default
github_api ok
github_content ok
github_web ok
catalog_data ok
github_connected true
installed_version 2026.11.2
stage running
available_repositories 6929
installed_repositories 128
github_api_calls_remaining 4834
Network Configuration
adapters lo (disabled), end0 (enabled, default, auto), docker0 (disabled), hassio (disabled), vethf7b90ff (disabled), veth2ac13da (disabled), veth99fc84a (disabled), vethd2b7d5c (disabled), veth888fae7 (disabled), veth1c2ff65 (disabled), veth436acc9 (disabled), vethab843ee (disabled), vethd269df0 (disabled), veth68fa9d4 (disabled), veth26e980d (disabled), wpan0 (disabled)
ipv4_addresses lo (127.0.0.1/8), end0 (192.168.1.25/24), docker0 (172.30.232.1/23), hassio (172.30.32.1/23), vethf7b90ff (), veth2ac13da (), veth99fc84a (), vethd2b7d5c (), veth888fae7 (), veth1c2ff65 (), veth436acc9 (), vethab843ee (), vethd269df0 (), veth68fa9d4 (), veth26e980d (), wpan0 ()
ipv6_addresses lo (::1/128), end0 (2a01:cb05:8294:1700:7b75:4095:5d67:e950/64, fdf8:91e9:2bf8:2b4d:e3ff:e436:e400:af7d/64, fe80::3bba:bcd9:40f7:a749/64), docker0 (fd0b:474:4fca::1/64, fe80::409a:e9ff:fedb:db48/64), hassio (fd0c:ac1e:2100::1/48, fe80::d89d:d7ff:fe44:12e8/64), vethf7b90ff (fe80::181b:aff:fedc:874/64), veth2ac13da (fe80::2899:58ff:fec3:240e/64), veth99fc84a (fe80::a4db:33ff:fe9b:c64/64), vethd2b7d5c (fe80::504c:68ff:fe70:4e23/64), veth888fae7 (fe80::48d3:5dff:fe03:ee67/64), veth1c2ff65 (fe80::6871:3fff:fe72:e9be/64), veth436acc9 (fe80::9c48:dfff:fe44:c21c/64), vethab843ee (fe80::8c0b:bcff:fed9:882c/64), vethd269df0 (fe80::1463:6bff:fecd:d225/64), veth68fa9d4 (fe80::9c07:b3ff:fe41:d828/64), veth26e980d (fe80::9c08:32ff:fe9b:cadd/64), wpan0 (fd9b:f987:dca7::ff:fe00:fc11/64, fdfa:3c53:8c0f:1:823:ea05:8ee0:dc0/64, fd9b:f987:dca7::ff:fe00:5000/64, fd9b:f987:dca7:0:7f6c:cef4:56c7:4014/64, fe80::c77:94df:a145:3346/64)
announce_addresses 192.168.1.25, 2a01:cb05:8294:1700:7b75:4095:5d67:e950, fdf8:91e9:2bf8:2b4d:e3ff:e436:e400:af7d, fe80::3bba:bcd9:40f7:a749
oldest_recorder_run 8 novembre 2026 à 11:02
current_recorder_run 20 novembre 2026 à 18:09
estimated_db_size 3344.23 MiB
database_version 3.53.4
Sonoff
version 3.13.3 (ddbd13e)
cloud_online 0 / 2
local_online 0 / 0
Spotify
api_endpoint_reachable ok
Il te manque adapter dans ta config.
serial:
  adapter: zstack
  rtscts: false
  adapter_delay: 1000
Ah non il apparaît dans la suite de ton message
Voir ce qui se passe vraiment : désactive temporairement le « Watchdog » dans l’onglet Info de l’add-on, puis passe les logs en debug dans configuration.yaml :
advanced:
  log_level: debug
Supprime au passage tout le bloc log_syslog, il ne contient que les valeurs du gabarit et ne sert à rien. Relance l’add-on et laisse-le tourner : l’erreur réelle devrait s’afficher (timeout, SRSP, Failed to connect to the adapter…).
bonjour,
essai de debrancher et rebrancher la clee
déja fait, débranché, rebranché,
débranché, reboot du systeme, rebranché
reboot du systeme...
et au bout d'une heure, ca a démarré....
Là çà a démarré, je laisse comme çà, je garde ton mode opératoire sous le coude pour la prochaine fois...
je passerai log_level de warning à debug dans /config/zigbee2mqtt/configuration.yaml
Moet and see comme on dit en champagne...
Il y a un article sur Domo blog qui évoque des soucis au démarrage… il est paru cette semaine.
