Zigbee2MQTT rajout de nouveau appareil impossible "non pris en charge"
oui, c’est bizarre, en plus à l’époque elle fonctionnait j’avais pu allumer une lampe avec. Et d’un coup, elle s’est mis à buger et me mettre ces messages d’erreurs, ça m’a bloqué l’apparaige de nouveau équipement.
Comme tu m’avais montré, j’ai supprimé via Z2M et MQTT, après redémarrage, il me remet les mêmes messages. Heureusement ça ne me bloque plus l’appairage de nouveau équipement.
Elle n’apparait pas dans le fichier database.db ou le fichier state.json du répertoire zigbee2mqtt ?
je vais regarder je touche jamais au fichier brut, pour éviter toute mauvaise manip :slight_smile:
{"id":1,"type":"Coordinator","ieeeAddr":"0x00124b0024c8225f","nwkAddr":0,"manufId":0,"epList":[1,2,3,4,5,6,8,10,11,12,13,47,110,242],"endpoints":{"1":{"profId":260,"epId":1,"devId":5,"inClusterList":[],"outClusterList":[],"clusters":{},"binds":[],"configuredReportings":[],"meta":{}},"2":{"profId":257,"epId":2,"devId":5,"inClusterList":[],"outClusterList":[],"clusters":{},"binds":[],"configuredReportings":[],"meta":{}},"3":{"profId":260,"epId":3,"devId":5,"inClusterList":[],"outClusterList":[],"clusters":{},"binds":[],"configuredReportings":[],"meta":{}},"4":{"profId":263,"epId":4,"devId":5,"inClusterList":[],"outClusterList":[],"clusters":{},"binds":[],"configuredReportings":[],"meta":{}},"5":{"profId":264,"epId":5,"devId":5,"inClusterList":[],"outClusterList":[],"clusters":{},"binds":[],"configuredReportings":[],"meta":{}},"6":{"profId":265,"epId":6,"devId":5,"inClusterList":[],"outClusterList":[],"clusters":{},"binds":[],"configuredReportings":[],"meta":{}},"8":{"profId":260,"epId":8,"devId":5,"inClusterList":[],"outClusterList":[],"clusters":{},"binds":[],"configuredReportings":[],"meta":{}},"10":{"profId":260,"epId":10,"devId":5,"inClusterList":[],"outClusterList":[],"clusters":{},"binds":[],"configuredReportings":[],"meta":{}},"11":{"profId":260,"epId":11,"devId":1024,"inClusterList":[1281,10],"outClusterList":[1280,1282],"clusters":{},"binds":[],"configuredReportings":[],"meta":{}},"12":{"profId":49246,"epId":12,"devId":5,"inClusterList":[],"outClusterList":[],"clusters":{},"binds":[],"configuredReportings":[],"meta":{}},"13":{"profId":260,"epId":13,"devId":5,"inClusterList":[25],"outClusterList":[],"clusters":{},"binds":[],"configuredReportings":[],"meta":{}},"47":{"profId":260,"epId":47,"devId":5,"inClusterList":[],"outClusterList":[],"clusters":{},"binds":[],"configuredReportings":[],"meta":{}},"110":{"profId":260,"epId":110,"devId":5,"inClusterList":[],"outClusterList":[],"clusters":{},"binds":[],"configuredReportings":[],"meta":{}},"242":{"profId":41440,"epId":242,"devId":5,"inClusterList":[],"outClusterList":[],"clusters":{},"binds":[],"configuredReportings":[],"meta":{}}},"interviewCompleted":true,"meta":{},"lastSeen":null}
{"id":2,"type":"EndDevice","ieeeAddr":"0x00124b002510d784","nwkAddr":24422,"manufId":0,"manufName":"eWeLink","powerSource":"Battery","modelId":"TH01","epList":[1],"endpoints":{"1":{"profId":260,"epId":1,"devId":770,"inClusterList":[0,3,1026,1029,1],"outClusterList":[3],"clusters":{"genBasic":{"attributes":{"modelId":"TH01","manufacturerName":"eWeLink"}},"genPowerCfg":{"attributes":{"batteryVoltage":30,"batteryPercentageRemaining":200}},"msTemperatureMeasurement":{"attributes":{"measuredValue":1816}},"msRelativeHumidity":{"attributes":{"measuredValue":6156}}},"binds":[{"cluster":1026,"type":"endpoint","deviceIeeeAddress":"0x00124b0024c8225f","endpointID":1},{"cluster":1029,"type":"endpoint","deviceIeeeAddress":"0x00124b0024c8225f","endpointID":1},{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00124b0024c8225f","endpointID":1}],"configuredReportings":[{"cluster":1026,"attrId":0,"minRepIntval":5,"maxRepIntval":1800,"repChange":20},{"cluster":1029,"attrId":0,"minRepIntval":10,"maxRepIntval":3600,"repChange":100},{"cluster":1,"attrId":32,"minRepIntval":3600,"maxRepIntval":7200,"repChange":0},{"cluster":1,"attrId":33,"minRepIntval":3600,"maxRepIntval":7200,"repChange":0}],"meta":{}}},"appVersion":5,"hwVersion":1,"dateCode":"20211103","zclVersion":1,"interviewCompleted":true,"meta":{"configured":-1904545032},"lastSeen":1707064158425}
{"id":3,"type":"EndDevice","ieeeAddr":"0x00124b00251bfcf6","nwkAddr":55103,"manufId":0,"manufName":"eWeLink","powerSource":"Battery","modelId":"TH01","epList":[1],"endpoints":{"1":{"profId":260,"epId":1,"devId":770,"inClusterList":[0,3,1026,1029,1],"outClusterList":[3],"clusters":{"genBasic":{"attributes":{"modelId":"TH01","manufacturerName":"eWeLink"}},"genPowerCfg":{"attributes":{"batteryVoltage":29,"batteryPercentageRemaining":150}},"msTemperatureMeasurement":{"attributes":{"measuredValue":2002}},"msRelativeHumidity":{"attributes":{"measuredValue":5630}}},"binds":[{"cluster":1026,"type":"endpoint","deviceIeeeAddress":"0x00124b0024c8225f","endpointID":1},{"cluster":1029,"type":"endpoint","deviceIeeeAddress":"0x00124b0024c8225f","endpointID":1},{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00124b0024c8225f","endpointID":1}],"configuredReportings":[{"cluster":1026,"attrId":0,"minRepIntval":5,"maxRepIntval":1800,"repChange":20,"manufacturerCode":null},{"cluster":1029,"attrId":0,"minRepIntval":10,"maxRepIntval":3600,"repChange":100,"manufacturerCode":null},{"cluster":1,"attrId":32,"minRepIntval":3600,"maxRepIntval":7200,"repChange":0,"manufacturerCode":null},{"cluster":1,"attrId":33,"minRepIntval":3600,"maxRepIntval":7200,"repChange":0,"manufacturerCode":null}],"meta":{}}},"appVersion":5,"hwVersion":1,"dateCode":"20201026","zclVersion":1,"interviewCompleted":true,"meta":{"configured":-1904545032},"lastSeen":1707063987879}
{"id":4,"type":"Router","ieeeAddr":"0xa4c13877b250cdd9","nwkAddr":51508,"manufId":4417,"manufName":"_TZ3000_ynmowqk2","powerSource":"Mains (single phase)","modelId":"TS011F","epList":[1,242],"endpoints":{"1":{"profId":260,"epId":1,"devId":266,"inClusterList":[3,4,5,6,1794,2820,57345,57344,0],"outClusterList":[25,10],"clusters":{"genBasic":{"attributes":{"65503":"\u000b�G-\u0003","65506":54,"65508":0,"65534":0,"appVersion":192,"modelId":"TS011F","manufacturerName":"_TZ3000_ynmowqk2","powerSource":1,"zclVersion":3,"stackVersion":0,"hwVersion":1,"dateCode":""}},"haElectricalMeasurement":{"attributes":{"acCurrentDivisor":1000,"acCurrentMultiplier":1,"rmsVoltage":218,"rmsCurrent":0,"activePower":0}},"seMetering":{"attributes":{"divisor":100,"multiplier":1,"currentSummDelivered":[0,7858]}},"genOnOff":{"attributes":{"32768":0,"onOff":0,"onTime":0,"offWaitTime":0,"tuyaBacklightMode":1,"moesStartUpOnOff":0,"tuyaBacklightSwitch":1}},"manuSpecificTuya_3":{"attributes":{"53248":0,"53249":0,"53250":0,"53251":0,"53252":0,"53253":0,"powerOnBehavior":0,"switchType":0}}},"binds":[{"cluster":6,"type":"endpoint","deviceIeeeAddress":"0x00124b0024c8225f","endpointID":1},{"cluster":2820,"type":"endpoint","deviceIeeeAddress":"0x00124b0024c8225f","endpointID":1}],"configuredReportings":[{"cluster":2820,"attrId":1285,"minRepIntval":5,"maxRepIntval":3600,"repChange":5,"manufacturerCode":null},{"cluster":2820,"attrId":1288,"minRepIntval":5,"maxRepIntval":3600,"repChange":50,"manufacturerCode":null},{"cluster":2820,"attrId":1291,"minRepIntval":5,"maxRepIntval":3600,"repChange":10,"manufacturerCode":null}],"meta":{}},"242":{"profId":41440,"epId":242,"devId":97,"inClusterList":[],"outClusterList":[33],"clusters":{},"binds":[],"configuredReportings":[],"meta":{}}},"appVersion":192,"stackVersion":0,"hwVersion":1,"dateCode":"","zclVersion":3,"interviewCompleted":true,"meta":{"configured":-1289829400},"lastSeen":1706468614566}
{"id":5,"type":"Router","ieeeAddr":"0x9035eafffe2c2729","nwkAddr":33619,"manufId":4098,"manufName":"_TZE200_aoclfnxz","powerSource":"Mains (single phase)","modelId":"TS0601","epList":[1],"endpoints":{"1":{"profId":260,"epId":1,"devId":81,"inClusterList":[0,4,5,61184],"outClusterList":[25,10],"clusters":{"genBasic":{"attributes":{"65503":"\u0000\u0000\u0000\u0000\u0007\u0000\u0000\u0000\u0000\u0007","65506":31,"65508":0,"modelId":"TS0601","manufacturerName":"_TZE200_aoclfnxz","powerSource":1,"zclVersion":3,"appVersion":72,"stackVersion":0,"hwVersion":1,"dateCode":""}}},"binds":[],"configuredReportings":[],"meta":{}}},"appVersion":72,"stackVersion":0,"hwVersion":1,"dateCode":"","zclVersion":3,"interviewCompleted":true,"meta":{},"lastSeen":1707064391572}
{"id":6,"type":"Router","ieeeAddr":"0xa4c13898f601d11e","nwkAddr":35180,"manufId":4417,"manufName":"_TZ3000_ynmowqk2","powerSource":"Mains (single phase)","modelId":"TS011F","epList":[1,242],"endpoints":{"1":{"profId":260,"epId":1,"devId":266,"inClusterList":[3,4,5,6,1794,2820,57345,57344,0],"outClusterList":[25,10],"clusters":{"genBasic":{"attributes":{"65503":"��2-\u0003","65506":54,"65508":0,"65534":0,"modelId":"TS011F","manufacturerName":"_TZ3000_ynmowqk2","powerSource":1,"zclVersion":3,"appVersion":192,"stackVersion":0,"hwVersion":1,"dateCode":""}},"haElectricalMeasurement":{"attributes":{"acCurrentDivisor":1000,"acCurrentMultiplier":1,"rmsVoltage":222,"rmsCurrent":0,"activePower":0}},"seMetering":{"attributes":{"divisor":100,"multiplier":1,"currentSummDelivered":[0,3742]}},"genOnOff":{"attributes":{"32768":0,"onOff":0,"onTime":0,"offWaitTime":0,"tuyaBacklightMode":1,"moesStartUpOnOff":0,"tuyaBacklightSwitch":1}},"manuSpecificTuya_3":{"attributes":{"53248":0,"53249":0,"53250":0,"53251":0,"53252":0,"53253":0,"powerOnBehavior":0,"switchType":0}}},"binds":[{"cluster":6,"type":"endpoint","deviceIeeeAddress":"0x00124b0024c8225f","endpointID":1},{"cluster":2820,"type":"endpoint","deviceIeeeAddress":"0x00124b0024c8225f","endpointID":1}],"configuredReportings":[{"cluster":2820,"attrId":1285,"minRepIntval":5,"maxRepIntval":3600,"repChange":5,"manufacturerCode":null},{"cluster":2820,"attrId":1288,"minRepIntval":5,"maxRepIntval":3600,"repChange":50,"manufacturerCode":null},{"cluster":2820,"attrId":1291,"minRepIntval":5,"maxRepIntval":3600,"repChange":10,"manufacturerCode":null}],"meta":{}},"242":{"profId":41440,"epId":242,"devId":97,"inClusterList":[],"outClusterList":[33],"clusters":{},"binds":[],"configuredReportings":[],"meta":{}}},"appVersion":192,"stackVersion":0,"hwVersion":1,"dateCode":"","zclVersion":3,"interviewCompleted":true,"meta":{"configured":-1289829400},"lastSeen":1707064317430}
{"id":7,"type":"Router","ieeeAddr":"0xa4c138880764bcec","nwkAddr":22392,"manufId":4417,"manufName":"_TZ3000_ksw8qtmt","powerSource":"Mains (single phase)","modelId":"TS011F","epList":[1,242],"endpoints":{"1":{"profId":260,"epId":1,"devId":266,"inClusterList":[3,4,5,6,1794,2820,57344,57345,0],"outClusterList":[25,10],"clusters":{"genBasic":{"attributes":{"65503":"\n\u0000\u0000\u0000\u0012%{e+\u0012","65506":54,"65508":0,"65534":0,"stackVersion":0,"dateCode":"","manufacturerName":"_TZ3000_ksw8qtmt","zclVersion":3,"appVersion":192,"modelId":"TS011F","powerSource":1}},"genOnOff":{"attributes":{"32768":0,"onOff":0,"onTime":0,"offWaitTime":0,"tuyaBacklightMode":1,"moesStartUpOnOff":1,"tuyaBacklightSwitch":1}},"haElectricalMeasurement":{"attributes":{"acCurrentDivisor":1000,"acCurrentMultiplier":1,"rmsVoltage":224,"rmsCurrent":0,"activePower":0}},"seMetering":{"attributes":{"divisor":100,"multiplier":1,"currentSummDelivered":[0,5683],"status":0}},"manuSpecificTuya_3":{"attributes":{"53248":0,"53249":0,"53250":0,"53251":0,"53252":0,"53253":0,"powerOnBehavior":1,"switchType":0}}},"binds":[{"cluster":6,"type":"endpoint","deviceIeeeAddress":"0x00124b0024c8225f","endpointID":1},{"cluster":2820,"type":"endpoint","deviceIeeeAddress":"0x00124b0024c8225f","endpointID":1},{"cluster":1794,"type":"endpoint","deviceIeeeAddress":"0x00124b0024c8225f","endpointID":1}],"configuredReportings":[{"cluster":2820,"attrId":1285,"minRepIntval":5,"maxRepIntval":3600,"repChange":5,"manufacturerCode":null},{"cluster":2820,"attrId":1288,"minRepIntval":5,"maxRepIntval":3600,"repChange":50,"manufacturerCode":null},{"cluster":2820,"attrId":1291,"minRepIntval":5,"maxRepIntval":3600,"repChange":10,"manufacturerCode":null},{"cluster":1794,"attrId":0,"minRepIntval":5,"maxRepIntval":3600,"repChange":[1,1],"manufacturerCode":null}],"meta":{}},"242":{"profId":41440,"epId":242,"devId":97,"inClusterList":[],"outClusterList":[33],"clusters":{},"binds":[],"configuredReportings":[],"meta":{}}},"appVersion":192,"stackVersion":0,"hwVersion":1,"dateCode":"","zclVersion":3,"interviewCompleted":true,"meta":{"configured":-824497014},"lastSeen":1707064371344}
{"id":8,"type":"EndDevice","ieeeAddr":"0x00124b0022d2c4e6","nwkAddr":54581,"manufId":0,"manufName":"eWeLink","powerSource":"Battery","modelId":"TH01","epList":[1],"endpoints":{"1":{"profId":260,"epId":1,"devId":770,"inClusterList":[0,3,1026,1029,1],"outClusterList":[3],"clusters":{"genBasic":{"attributes":{"modelId":"TH01","manufacturerName":"eWeLink"}},"genPowerCfg":{"attributes":{"batteryVoltage":29,"batteryPercentageRemaining":174}},"msTemperatureMeasurement":{"attributes":{"measuredValue":1198}},"msRelativeHumidity":{"attributes":{"measuredValue":6673}}},"binds":[{"cluster":1026,"type":"endpoint","deviceIeeeAddress":"0x00124b0024c8225f","endpointID":1},{"cluster":1029,"type":"endpoint","deviceIeeeAddress":"0x00124b0024c8225f","endpointID":1},{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00124b0024c8225f","endpointID":1}],"configuredReportings":[{"cluster":1026,"attrId":0,"minRepIntval":5,"maxRepIntval":1800,"repChange":20},{"cluster":1029,"attrId":0,"minRepIntval":10,"maxRepIntval":3600,"repChange":100},{"cluster":1,"attrId":32,"minRepIntval":3600,"maxRepIntval":7200,"repChange":0},{"cluster":1,"attrId":33,"minRepIntval":3600,"maxRepIntval":7200,"repChange":0}],"meta":{}}},"appVersion":5,"hwVersion":1,"dateCode":"20211103","zclVersion":1,"interviewCompleted":true,"meta":{"configured":-1904545032},"lastSeen":1707064029436}
{"id":9,"type":"EndDevice","ieeeAddr":"0x00124b002519262c","nwkAddr":17745,"manufId":0,"manufName":"eWeLink","powerSource":"Battery","modelId":"DS01","epList":[1],"endpoints":{"1":{"profId":260,"epId":1,"devId":1026,"inClusterList":[0,3,1280,1],"outClusterList":[3],"clusters":{"genBasic":{"attributes":{"modelId":"DS01","manufacturerName":"eWeLink"}},"ssIasZone":{"attributes":{"iasCieAddr":"0x00124b0024c8225f","zoneState":1}},"genPowerCfg":{"attributes":{"batteryVoltage":30,"batteryPercentageRemaining":200}}},"binds":[{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00124b0024c8225f","endpointID":1}],"configuredReportings":[{"cluster":1,"attrId":32,"minRepIntval":3600,"maxRepIntval":7200,"repChange":0,"manufacturerCode":null},{"cluster":1,"attrId":33,"minRepIntval":3600,"maxRepIntval":7200,"repChange":0,"manufacturerCode":null}],"meta":{}}},"appVersion":5,"hwVersion":1,"dateCode":"20211103","zclVersion":1,"interviewCompleted":true,"meta":{"configured":1635589808},"lastSeen":1707063859270}
{"id":10,"type":"EndDevice","ieeeAddr":"0x00124b00252bf95c","nwkAddr":38366,"manufId":0,"manufName":"eWeLink","powerSource":"Battery","modelId":"TH01","epList":[1],"endpoints":{"1":{"profId":260,"epId":1,"devId":770,"inClusterList":[0,3,1026,1029,1],"outClusterList":[3],"clusters":{"genBasic":{"attributes":{"modelId":"TH01","manufacturerName":"eWeLink","powerSource":3,"zclVersion":1,"appVersion":5,"hwVersion":1,"dateCode":"20211103"}},"msTemperatureMeasurement":{"attributes":{"measuredValue":1753}},"genPowerCfg":{"attributes":{"batteryVoltage":30,"batteryPercentageRemaining":200}},"msRelativeHumidity":{"attributes":{"measuredValue":6810}}},"binds":[{"cluster":1026,"type":"endpoint","deviceIeeeAddress":"0x00124b0024c8225f","endpointID":1},{"cluster":1029,"type":"endpoint","deviceIeeeAddress":"0x00124b0024c8225f","endpointID":1},{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00124b0024c8225f","endpointID":1}],"configuredReportings":[{"cluster":1026,"attrId":0,"minRepIntval":5,"maxRepIntval":1800,"repChange":20},{"cluster":1029,"attrId":0,"minRepIntval":10,"maxRepIntval":3600,"repChange":100},{"cluster":1,"attrId":32,"minRepIntval":3600,"maxRepIntval":7200,"repChange":0},{"cluster":1,"attrId":33,"minRepIntval":3600,"maxRepIntval":7200,"repChange":0}],"meta":{}}},"appVersion":5,"hwVersion":1,"dateCode":"20211103","zclVersion":1,"interviewCompleted":true,"meta":{"configured":-1904545032},"lastSeen":1707063715280}
{"id":11,"type":"EndDevice","ieeeAddr":"0x540f57fffe8d5e30","nwkAddr":12279,"manufId":4098,"manufName":"_TZ3210_eymunffl","powerSource":"Battery","modelId":"TS0101","epList":[1],"endpoints":{"1":{"profId":260,"epId":1,"devId":81,"inClusterList":[0,4,5,6,61184,1],"outClusterList":[25,10],"clusters":{"genBasic":{"attributes":{"65503":"��b,\u0011�7i,\u0012","65506":31,"65508":0,"65534":0,"modelId":"TS0101","manufacturerName":"_TZ3210_eymunffl","powerSource":3,"zclVersion":3,"appVersion":69,"stackVersion":0,"hwVersion":1,"dateCode":""}},"genOnOff":{"attributes":{"onOff":0,"offWaitTime":0,"onTime":0}}},"binds":[],"configuredReportings":[],"meta":{}}},"appVersion":69,"stackVersion":0,"hwVersion":1,"dateCode":"","zclVersion":3,"interviewCompleted":true,"meta":{"configured":-708457359},"lastSeen":1707053548432}
{"id":12,"type":"Router","ieeeAddr":"0x00158d0005d2a08a","nwkAddr":33908,"manufId":4151,"manufName":"LiXee","powerSource":"Mains (single phase)","modelId":"ZLinky_TIC\u0000","epList":[1,242],"endpoints":{"1":{"profId":260,"epId":1,"devId":83,"inClusterList":[0,3,1794,2820,2817,65382,1],"outClusterList":[25],"clusters":{"genBasic":{"attributes":{"modelId":"ZLinky_TIC\u0000","manufacturerName":"LiXee","powerSource":1,"zclVersion":3,"appVersion":12,"stackVersion":2,"hwVersion":1,"dateCode":"20230214","swBuildId":"4000-0013"}},"liXeePrivate":{"attributes":{"linkyMode":0,"currentTarif":"BASE\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000","warnDPS":0}},"haElectricalMeasurement":{"attributes":{"rmsCurrentMax":90,"rmsCurrent":10,"apparentPower":2420}},"seMetering":{"attributes":{"meterSerialNumber":{"type":"Buffer","data":[48,50,50,50,54,52,48,54,52,56,50,57]},"activeRegisterTierDelivered":"TH..","currentSummDelivered":[0,12653072]}},"haMeterIdentification":{"attributes":{"availablePower":45}}},"binds":[{"cluster":1794,"type":"endpoint","deviceIeeeAddress":"0x00124b0024c8225f","endpointID":1},{"cluster":2817,"type":"endpoint","deviceIeeeAddress":"0x00124b0024c8225f","endpointID":1},{"cluster":2820,"type":"endpoint","deviceIeeeAddress":"0x00124b0024c8225f","endpointID":1},{"cluster":65382,"type":"endpoint","deviceIeeeAddress":"0x00124b0024c8225f","endpointID":1}],"configuredReportings":[{"cluster":1794,"attrId":0,"minRepIntval":60,"maxRepIntval":900,"repChange":100},{"cluster":2820,"attrId":1288,"minRepIntval":60,"maxRepIntval":900,"repChange":1},{"cluster":2820,"attrId":1295,"minRepIntval":60,"maxRepIntval":900,"repChange":1},{"cluster":65382,"attrId":5,"minRepIntval":60,"maxRepIntval":900,"repChange":1},{"cluster":1794,"attrId":0,"minRepIntval":60,"maxRepIntval":900,"repChange":100,"manufacturerCode":null},{"cluster":2820,"attrId":1295,"minRepIntval":60,"maxRepIntval":900,"repChange":1,"manufacturerCode":null},{"cluster":2820,"attrId":1288,"minRepIntval":60,"maxRepIntval":900,"repChange":1,"manufacturerCode":null},{"cluster":65382,"attrId":5,"minRepIntval":60,"maxRepIntval":900,"repChange":1,"manufacturerCode":null}],"meta":{}},"242":{"profId":41440,"epId":242,"devId":97,"inClusterList":[33],"outClusterList":[33],"clusters":{},"binds":[],"configuredReportings":[],"meta":{}}},"appVersion":12,"stackVersion":2,"hwVersion":1,"dateCode":"20230214","swBuildId":"4000-0013","zclVersion":3,"interviewCompleted":true,"meta":{"configured":-1468580210},"lastSeen":1707064388554}
{"id":13,"type":"Router","ieeeAddr":"0x00124b0024c05735","nwkAddr":61917,"manufId":4742,"manufName":"SONOFF","powerSource":"Mains (single phase)","modelId":"S26R2ZB","epList":[1,13,242],"endpoints":{"1":{"profId":260,"epId":1,"devId":9,"inClusterList":[0,3,4,5,6,64599],"outClusterList":[25],"clusters":{"genOnOff":{"attributes":{"onOff":0}},"genBasic":{"attributes":{}}},"binds":[{"cluster":6,"type":"endpoint","deviceIeeeAddress":"0x00124b0024c8225f","endpointID":1}],"configuredReportings":[{"cluster":6,"attrId":0,"minRepIntval":0,"maxRepIntval":65000,"repChange":1,"manufacturerCode":null}],"meta":{}},"13":{"profId":49246,"epId":13,"devId":57694,"inClusterList":[4096],"outClusterList":[4096],"clusters":{},"binds":[],"configuredReportings":[],"meta":{}},"242":{"profId":41440,"epId":242,"devId":97,"inClusterList":[],"outClusterList":[33],"clusters":{},"binds":[],"configuredReportings":[],"meta":{}}},"hwVersion":1,"dateCode":"20210923","swBuildId":"2.0.1","zclVersion":3,"interviewCompleted":true,"meta":{"configured":1324213189},"lastSeen":1707057208706}
{"id":14,"type":"EndDevice","ieeeAddr":"0x00124b00251c764b","nwkAddr":63071,"manufId":0,"manufName":"eWeLink","powerSource":"Battery","modelId":"TH01","epList":[1],"endpoints":{"1":{"profId":260,"epId":1,"devId":770,"inClusterList":[0,3,1026,1029,1],"outClusterList":[3],"clusters":{"genBasic":{"attributes":{"modelId":"TH01","manufacturerName":"eWeLink"}},"msTemperatureMeasurement":{"attributes":{"measuredValue":1228}},"msRelativeHumidity":{"attributes":{"measuredValue":6558}},"genPowerCfg":{"attributes":{"batteryVoltage":29,"batteryPercentageRemaining":123}}},"binds":[{"cluster":1026,"type":"endpoint","deviceIeeeAddress":"0x00124b0024c8225f","endpointID":1},{"cluster":1029,"type":"endpoint","deviceIeeeAddress":"0x00124b0024c8225f","endpointID":1},{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00124b0024c8225f","endpointID":1}],"configuredReportings":[{"cluster":1026,"attrId":0,"minRepIntval":5,"maxRepIntval":1800,"repChange":20,"manufacturerCode":null},{"cluster":1029,"attrId":0,"minRepIntval":10,"maxRepIntval":3600,"repChange":100,"manufacturerCode":null},{"cluster":1,"attrId":32,"minRepIntval":3600,"maxRepIntval":7200,"repChange":0,"manufacturerCode":null},{"cluster":1,"attrId":33,"minRepIntval":3600,"maxRepIntval":7200,"repChange":0,"manufacturerCode":null}],"meta":{}}},"appVersion":5,"hwVersion":1,"dateCode":"20201026","zclVersion":1,"interviewCompleted":true,"meta":{"configured":-1904545032},"lastSeen":1707063401979}
{"id":15,"type":"EndDevice","ieeeAddr":"0x00124b002513ca82","nwkAddr":60915,"manufId":0,"manufName":"eWeLink","powerSource":"Battery","modelId":"DS01","epList":[1],"endpoints":{"1":{"profId":260,"epId":1,"devId":1026,"inClusterList":[0,3,1280,1],"outClusterList":[3],"clusters":{"genBasic":{"attributes":{"modelId":"DS01","manufacturerName":"eWeLink"}},"ssIasZone":{"attributes":{"iasCieAddr":"0x00124b0024c8225f","zoneState":1}},"genPowerCfg":{"attributes":{"batteryVoltage":25,"batteryPercentageRemaining":10}}},"binds":[{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00124b0024c8225f","endpointID":1}],"configuredReportings":[{"cluster":1,"attrId":32,"minRepIntval":3600,"maxRepIntval":7200,"repChange":0},{"cluster":1,"attrId":32,"minRepIntval":3600,"maxRepIntval":7200,"repChange":0,"manufacturerCode":null},{"cluster":1,"attrId":33,"minRepIntval":3600,"maxRepIntval":7200,"repChange":0,"manufacturerCode":null}],"meta":{}}},"appVersion":5,"hwVersion":1,"dateCode":"20211103","zclVersion":1,"interviewCompleted":true,"meta":{"configured":1635589808},"lastSeen":1706976653692}
{"id":16,"type":"EndDevice","ieeeAddr":"0x00124b002508cabc","nwkAddr":50551,"manufId":0,"manufName":"eWeLink","powerSource":"Battery","modelId":"MS01","epList":[1],"endpoints":{"1":{"profId":260,"epId":1,"devId":1026,"inClusterList":[0,3,1280,1],"outClusterList":[3],"clusters":{"genBasic":{"attributes":{"modelId":"MS01","manufacturerName":"eWeLink"}},"ssIasZone":{"attributes":{"iasCieAddr":"0x00124b0024c8225f","zoneState":1}},"genPowerCfg":{"attributes":{"batteryVoltage":30,"batteryPercentageRemaining":200}}},"binds":[{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00124b0024c8225f","endpointID":1}],"configuredReportings":[{"cluster":1,"attrId":32,"minRepIntval":3600,"maxRepIntval":7200,"repChange":0},{"cluster":1,"attrId":33,"minRepIntval":3600,"maxRepIntval":7200,"repChange":0}],"meta":{}}},"appVersion":5,"hwVersion":1,"dateCode":"20211103","zclVersion":1,"interviewCompleted":true,"meta":{"configured":-1949790169},"lastSeen":1696612284403}
{"id":17,"type":"Router","ieeeAddr":"0xa4c13830779d26da","nwkAddr":54979,"manufId":4417,"manufName":"_TZ3000_2putqrmw","powerSource":"Mains (single phase)","modelId":"TS011F","epList":[1,242],"endpoints":{"1":{"profId":260,"epId":1,"devId":266,"inClusterList":[3,4,5,6,1794,2820,57344,57345,0],"outClusterList":[25,10],"clusters":{"genBasic":{"attributes":{"65503":"�%y+\u0012","65506":54,"65508":0,"65534":0,"stackVersion":0,"dateCode":"","manufacturerName":"_TZ3000_2putqrmw","zclVersion":3,"appVersion":192,"modelId":"TS011F","powerSource":1}},"haElectricalMeasurement":{"attributes":{"acCurrentDivisor":1000,"acCurrentMultiplier":1,"rmsVoltage":222,"rmsCurrent":111,"activePower":18}},"seMetering":{"attributes":{"divisor":100,"multiplier":1,"currentSummDelivered":[0,1308]}},"genOnOff":{"attributes":{"32768":0,"onOff":1,"onTime":0,"offWaitTime":0,"tuyaBacklightMode":1,"moesStartUpOnOff":1,"tuyaBacklightSwitch":1}},"manuSpecificTuya_3":{"attributes":{"53248":0,"53249":0,"53250":0,"53251":0,"53252":0,"53253":0,"powerOnBehavior":1,"switchType":0}}},"binds":[{"cluster":6,"type":"endpoint","deviceIeeeAddress":"0x00124b0024c8225f","endpointID":1},{"cluster":2820,"type":"endpoint","deviceIeeeAddress":"0x00124b0024c8225f","endpointID":1},{"cluster":1794,"type":"endpoint","deviceIeeeAddress":"0x00124b0024c8225f","endpointID":1}],"configuredReportings":[{"cluster":2820,"attrId":1285,"minRepIntval":5,"maxRepIntval":3600,"repChange":5,"manufacturerCode":null},{"cluster":2820,"attrId":1288,"minRepIntval":5,"maxRepIntval":3600,"repChange":50,"manufacturerCode":null},{"cluster":2820,"attrId":1291,"minRepIntval":5,"maxRepIntval":3600,"repChange":10,"manufacturerCode":null},{"cluster":1794,"attrId":0,"minRepIntval":5,"maxRepIntval":3600,"repChange":[1,1],"manufacturerCode":null}],"meta":{}},"242":{"profId":41440,"epId":242,"devId":97,"inClusterList":[],"outClusterList":[33],"clusters":{},"binds":[],"configuredReportings":[],"meta":{}}},"appVersion":192,"stackVersion":0,"hwVersion":1,"dateCode":"","zclVersion":3,"interviewCompleted":true,"meta":{"configured":-824497014},"lastSeen":1707064366240}
{"id":18,"type":"Router","ieeeAddr":"0xc4988600000691a3","nwkAddr":15512,"manufId":4454,"manufName":"innr","powerSource":"Mains (single phase)","modelId":"RS 226","epList":[1,242],"endpoints":{"1":{"profId":260,"epId":1,"devId":257,"inClusterList":[0,3,4,5,6,8,4096,64599,64642],"outClusterList":[25],"clusters":{"genOnOff":{"attributes":{"onOff":1}},"genLevelCtrl":{"attributes":{"currentLevel":229}},"genBasic":{"attributes":{"dateCode":"20230810","swBuildId":"2.04.03"}}},"binds":[],"configuredReportings":[],"meta":{}},"242":{"profId":41440,"epId":242,"devId":97,"inClusterList":[],"outClusterList":[33],"clusters":{},"binds":[],"configuredReportings":[],"meta":{}}},"appVersion":35,"stackVersion":21,"hwVersion":2,"dateCode":"20230810","swBuildId":"2.04.03","zclVersion":3,"interviewCompleted":true,"meta":{"configured":1324213189},"lastSeen":1707061615580}
{"id":19,"type":"Router","ieeeAddr":"0xc49886000006ef1e","nwkAddr":58849,"manufId":4454,"manufName":"innr","powerSource":"Mains (single phase)","modelId":"RS 226","epList":[1,242],"endpoints":{"1":{"profId":260,"epId":1,"devId":257,"inClusterList":[0,3,4,5,6,8,4096,64599,64642],"outClusterList":[25],"clusters":{"genOnOff":{"attributes":{"onOff":1}},"genLevelCtrl":{"attributes":{"currentLevel":127}},"genBasic":{"attributes":{"dateCode":"20230810","swBuildId":"2.04.03"}}},"binds":[],"configuredReportings":[],"meta":{}},"242":{"profId":41440,"epId":242,"devId":97,"inClusterList":[],"outClusterList":[33],"clusters":{},"binds":[],"configuredReportings":[],"meta":{}}},"appVersion":35,"stackVersion":21,"hwVersion":2,"dateCode":"20230810","swBuildId":"2.04.03","zclVersion":3,"interviewCompleted":true,"meta":{"configured":1324213189},"lastSeen":1707061615645}
{"id":20,"type":"Router","ieeeAddr":"0xc49886000006a513","nwkAddr":53095,"manufId":4454,"manufName":"innr","powerSource":"Mains (single phase)","modelId":"RS 226","epList":[1,242],"endpoints":{"1":{"profId":260,"epId":1,"devId":257,"inClusterList":[0,3,4,5,6,8,4096,64599,64642],"outClusterList":[25],"clusters":{"genOnOff":{"attributes":{"onOff":1}},"genLevelCtrl":{"attributes":{"currentLevel":229}},"genBasic":{"attributes":{"dateCode":"20230810","swBuildId":"2.04.03"}}},"binds":[],"configuredReportings":[],"meta":{}},"242":{"profId":41440,"epId":242,"devId":97,"inClusterList":[],"outClusterList":[33],"clusters":{},"binds":[],"configuredReportings":[],"meta":{}}},"appVersion":35,"stackVersion":21,"hwVersion":2,"dateCode":"20230810","swBuildId":"2.04.03","zclVersion":3,"interviewCompleted":true,"meta":{"configured":1324213189},"lastSeen":1707061615568}
{"id":21,"type":"EndDevice","ieeeAddr":"0x00124b00252bf0b3","nwkAddr":63745,"manufId":0,"manufName":"eWeLink","powerSource":"Battery","modelId":"TH01","epList":[1],"endpoints":{"1":{"profId":260,"epId":1,"devId":770,"inClusterList":[0,3,1026,1029,1],"outClusterList":[3],"clusters":{"genBasic":{"attributes":{"modelId":"TH01","manufacturerName":"eWeLink","powerSource":3,"zclVersion":1,"appVersion":5,"hwVersion":1,"dateCode":"20211103"}},"genPowerCfg":{"attributes":{"batteryVoltage":29,"batteryPercentageRemaining":172}},"msTemperatureMeasurement":{"attributes":{"measuredValue":1195}},"msRelativeHumidity":{"attributes":{"measuredValue":6458}}},"binds":[{"cluster":1026,"type":"endpoint","deviceIeeeAddress":"0x00124b0024c8225f","endpointID":1},{"cluster":1029,"type":"endpoint","deviceIeeeAddress":"0x00124b0024c8225f","endpointID":1},{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00124b0024c8225f","endpointID":1}],"configuredReportings":[{"cluster":1026,"attrId":0,"minRepIntval":5,"maxRepIntval":1800,"repChange":20},{"cluster":1029,"attrId":0,"minRepIntval":10,"maxRepIntval":3600,"repChange":100},{"cluster":1,"attrId":32,"minRepIntval":3600,"maxRepIntval":7200,"repChange":0},{"cluster":1,"attrId":33,"minRepIntval":3600,"maxRepIntval":7200,"repChange":0}],"meta":{}}},"appVersion":5,"hwVersion":1,"dateCode":"20211103","zclVersion":1,"interviewCompleted":true,"meta":{"configured":-1904545032},"lastSeen":1707063128350}
{"id":22,"type":"EndDevice","ieeeAddr":"0x00124b002558c529","nwkAddr":54625,"manufId":0,"manufName":"eWeLink","powerSource":"Battery","modelId":"TH01","epList":[1],"endpoints":{"1":{"profId":260,"epId":1,"devId":770,"inClusterList":[0,3,1026,1029,1],"outClusterList":[3],"clusters":{"genBasic":{"attributes":{"modelId":"TH01","manufacturerName":"eWeLink"}},"msTemperatureMeasurement":{"attributes":{"measuredValue":1293}},"msRelativeHumidity":{"attributes":{"measuredValue":8924}},"genPowerCfg":{"attributes":{"batteryVoltage":29,"batteryPercentageRemaining":150}}},"binds":[{"cluster":1026,"type":"endpoint","deviceIeeeAddress":"0x00124b0024c8225f","endpointID":1},{"cluster":1029,"type":"endpoint","deviceIeeeAddress":"0x00124b0024c8225f","endpointID":1},{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00124b0024c8225f","endpointID":1}],"configuredReportings":[{"cluster":1026,"attrId":0,"minRepIntval":5,"maxRepIntval":1800,"repChange":20},{"cluster":1029,"attrId":0,"minRepIntval":10,"maxRepIntval":3600,"repChange":100},{"cluster":1,"attrId":32,"minRepIntval":3600,"maxRepIntval":7200,"repChange":0},{"cluster":1,"attrId":33,"minRepIntval":3600,"maxRepIntval":7200,"repChange":0}],"meta":{}}},"appVersion":5,"hwVersion":1,"dateCode":"20211103","zclVersion":1,"interviewCompleted":true,"meta":{"configured":-1904545032},"lastSeen":1706718446309}
{"id":23,"type":"EndDevice","ieeeAddr":"0x00124b00252be357","nwkAddr":36165,"manufId":0,"manufName":"eWeLink","powerSource":"Battery","modelId":"TH01","epList":[1],"endpoints":{"1":{"profId":260,"epId":1,"devId":770,"inClusterList":[0,3,1026,1029,1],"outClusterList":[3],"clusters":{"genBasic":{"attributes":{"modelId":"TH01","manufacturerName":"eWeLink","powerSource":3,"zclVersion":1,"appVersion":5,"hwVersion":1,"dateCode":"20211103"}},"genPowerCfg":{"attributes":{"batteryVoltage":29,"batteryPercentageRemaining":197}},"msTemperatureMeasurement":{"attributes":{"measuredValue":1763}},"msRelativeHumidity":{"attributes":{"measuredValue":6063}}},"binds":[{"cluster":1026,"type":"endpoint","deviceIeeeAddress":"0x00124b0024c8225f","endpointID":1},{"cluster":1029,"type":"endpoint","deviceIeeeAddress":"0x00124b0024c8225f","endpointID":1},{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00124b0024c8225f","endpointID":1}],"configuredReportings":[{"cluster":1026,"attrId":0,"minRepIntval":5,"maxRepIntval":1800,"repChange":20},{"cluster":1029,"attrId":0,"minRepIntval":10,"maxRepIntval":3600,"repChange":100},{"cluster":1,"attrId":32,"minRepIntval":3600,"maxRepIntval":7200,"repChange":0},{"cluster":1,"attrId":33,"minRepIntval":3600,"maxRepIntval":7200,"repChange":0}],"meta":{}}},"appVersion":5,"hwVersion":1,"dateCode":"20211103","zclVersion":1,"interviewCompleted":true,"meta":{"configured":-1904545032},"lastSeen":1707063740353}
{"id":24,"type":"EndDevice","ieeeAddr":"0x00124b00250e11a1","nwkAddr":33853,"manufId":0,"manufName":"eWeLink","powerSource":"Battery","modelId":"TH01","epList":[1],"endpoints":{"1":{"profId":260,"epId":1,"devId":770,"inClusterList":[0,3,1026,1029,1],"outClusterList":[3],"clusters":{"genBasic":{"attributes":{"modelId":"TH01","manufacturerName":"eWeLink","powerSource":3,"zclVersion":1,"appVersion":5,"hwVersion":1,"dateCode":"20211103"}},"msTemperatureMeasurement":{"attributes":{"measuredValue":1735}},"genPowerCfg":{"attributes":{"batteryVoltage":30,"batteryPercentageRemaining":200}},"msRelativeHumidity":{"attributes":{"measuredValue":6427}}},"binds":[{"cluster":1026,"type":"endpoint","deviceIeeeAddress":"0x00124b0024c8225f","endpointID":1},{"cluster":1029,"type":"endpoint","deviceIeeeAddress":"0x00124b0024c8225f","endpointID":1},{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00124b0024c8225f","endpointID":1}],"configuredReportings":[{"cluster":1026,"attrId":0,"minRepIntval":5,"maxRepIntval":1800,"repChange":20},{"cluster":1029,"attrId":0,"minRepIntval":10,"maxRepIntval":3600,"repChange":100},{"cluster":1,"attrId":32,"minRepIntval":3600,"maxRepIntval":7200,"repChange":0},{"cluster":1,"attrId":33,"minRepIntval":3600,"maxRepIntval":7200,"repChange":0}],"meta":{}}},"appVersion":5,"hwVersion":1,"dateCode":"20211103","zclVersion":1,"interviewCompleted":true,"meta":{"configured":-1904545032},"lastSeen":1707062585012}
{"id":25,"type":"EndDevice","ieeeAddr":"0x00124b00254de159","nwkAddr":33757,"manufId":0,"manufName":"eWeLink","powerSource":"Battery","modelId":"TH01","epList":[1],"endpoints":{"1":{"profId":260,"epId":1,"devId":770,"inClusterList":[0,3,1026,1029,1],"outClusterList":[3],"clusters":{"genBasic":{"attributes":{"modelId":"TH01","manufacturerName":"eWeLink","powerSource":3,"zclVersion":1,"appVersion":5,"hwVersion":1,"dateCode":"20211103"}},"msTemperatureMeasurement":{"attributes":{"measuredValue":1572}},"genPowerCfg":{"attributes":{"batteryVoltage":29,"batteryPercentageRemaining":173}},"msRelativeHumidity":{"attributes":{"measuredValue":5175}}},"binds":[{"cluster":1026,"type":"endpoint","deviceIeeeAddress":"0x00124b0024c8225f","endpointID":1},{"cluster":1029,"type":"endpoint","deviceIeeeAddress":"0x00124b0024c8225f","endpointID":1},{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00124b0024c8225f","endpointID":1}],"configuredReportings":[{"cluster":1026,"attrId":0,"minRepIntval":5,"maxRepIntval":1800,"repChange":20},{"cluster":1029,"attrId":0,"minRepIntval":10,"maxRepIntval":3600,"repChange":100},{"cluster":1,"attrId":32,"minRepIntval":3600,"maxRepIntval":7200,"repChange":0},{"cluster":1,"attrId":33,"minRepIntval":3600,"maxRepIntval":7200,"repChange":0}],"meta":{}}},"appVersion":5,"hwVersion":1,"dateCode":"20211103","zclVersion":1,"interviewCompleted":true,"meta":{"configured":-1904545032},"lastSeen":1707063521317}
{"id":26,"type":"Router","ieeeAddr":"0x04cd15fffe0053a9","nwkAddr":10067,"manufId":4098,"manufName":"_TZ3000_5k5vh43t","powerSource":"Mains (single phase)","modelId":"TS0207","epList":[1],"endpoints":{"1":{"profId":260,"epId":1,"devId":8,"inClusterList":[0,10,3],"outClusterList":[25],"clusters":{"genBasic":{"attributes":{"65503":"\u0000\u0000\u0000\u0000\u0005","65506":22,"modelId":"TS0207","manufacturerName":"_TZ3000_5k5vh43t","powerSource":1,"zclVersion":3,"appVersion":64,"stackVersion":0,"hwVersion":1,"dateCode":""}}},"binds":[],"configuredReportings":[],"meta":{}}},"appVersion":64,"stackVersion":0,"hwVersion":1,"dateCode":"","zclVersion":3,"interviewCompleted":true,"meta":{},"lastSeen":1707064390616}
{"id":27,"type":"Router","ieeeAddr":"0xa4c13854cfb229eb","nwkAddr":7311,"manufId":4417,"manufName":"_TZ3000_2xlvlnez","powerSource":"Mains (single phase)","modelId":"TS011F","epList":[1,2,242],"endpoints":{"1":{"profId":260,"epId":1,"devId":266,"inClusterList":[3,4,5,6,57344,57345,0],"outClusterList":[25,10],"clusters":{"genBasic":{"attributes":{"65503":"��\u0018+\u0017��\u0018+\u0013","65506":48,"65508":0,"65534":0,"modelId":"TS011F","manufacturerName":"_TZ3000_2xlvlnez","powerSource":1,"zclVersion":3,"appVersion":67,"stackVersion":0,"hwVersion":1,"dateCode":""}},"genOnOff":{"attributes":{"32768":0,"onOff":1,"onTime":0,"offWaitTime":0,"tuyaBacklightMode":0,"moesStartUpOnOff":2,"tuyaBacklightSwitch":1}},"manuSpecificTuya_3":{"attributes":{"powerOnBehavior":2,"switchType":0}}},"binds":[{"cluster":6,"type":"endpoint","deviceIeeeAddress":"0x00124b0024c8225f","endpointID":1}],"configuredReportings":[{"cluster":6,"attrId":0,"minRepIntval":0,"maxRepIntval":3600,"repChange":0}],"meta":{}},"2":{"profId":260,"epId":2,"devId":266,"inClusterList":[4,5,6,57345],"outClusterList":[],"clusters":{"genOnOff":{"attributes":{"onOff":0,"onTime":0,"offWaitTime":0}},"manuSpecificTuya_3":{"attributes":{"powerOnBehavior":2}}},"binds":[{"cluster":6,"type":"endpoint","deviceIeeeAddress":"0x00124b0024c8225f","endpointID":1}],"configuredReportings":[{"cluster":6,"attrId":0,"minRepIntval":0,"maxRepIntval":3600,"repChange":0}],"meta":{}},"242":{"profId":41440,"epId":242,"devId":97,"inClusterList":[],"outClusterList":[33],"clusters":{},"binds":[],"configuredReportings":[],"meta":{}}},"appVersion":67,"stackVersion":0,"hwVersion":1,"dateCode":"","zclVersion":3,"interviewCompleted":true,"meta":{"configured":1948765142},"lastSeen":1707064283588}
{"id":28,"type":"EndDevice","ieeeAddr":"0x00124b0025140b30","nwkAddr":28209,"manufId":0,"manufName":"eWeLink","powerSource":"Battery","modelId":"DS01","epList":[1],"endpoints":{"1":{"profId":260,"epId":1,"devId":1026,"inClusterList":[0,3,1280,1],"outClusterList":[3],"clusters":{"genBasic":{"attributes":{"modelId":"DS01","manufacturerName":"eWeLink"}},"ssIasZone":{"attributes":{"iasCieAddr":"0x00124b0024c8225f","zoneState":1}},"genPowerCfg":{"attributes":{"batteryVoltage":30,"batteryPercentageRemaining":200}}},"binds":[{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00124b0024c8225f","endpointID":1}],"configuredReportings":[{"cluster":1,"attrId":32,"minRepIntval":3600,"maxRepIntval":7200,"repChange":0},{"cluster":1,"attrId":33,"minRepIntval":3600,"maxRepIntval":7200,"repChange":0}],"meta":{}}},"appVersion":5,"hwVersion":1,"dateCode":"20211103","zclVersion":1,"interviewCompleted":true,"meta":{"configured":1635589808},"lastSeen":1700045197079}
{"id":29,"type":"Router","ieeeAddr":"0x00124b00258a41b7","nwkAddr":45878,"manufId":4742,"manufName":"SONOFF","powerSource":"Mains (single phase)","modelId":"S26R2ZB","epList":[1,13,242],"endpoints":{"1":{"profId":260,"epId":1,"devId":9,"inClusterList":[0,3,4,5,6,64599],"outClusterList":[25],"clusters":{"genOnOff":{"attributes":{"onOff":0}},"genBasic":{"attributes":{}}},"binds":[{"cluster":6,"type":"endpoint","deviceIeeeAddress":"0x00124b0024c8225f","endpointID":1}],"configuredReportings":[{"cluster":6,"attrId":0,"minRepIntval":0,"maxRepIntval":65000,"repChange":1,"manufacturerCode":null}],"meta":{}},"13":{"profId":49246,"epId":13,"devId":57694,"inClusterList":[4096],"outClusterList":[4096],"clusters":{},"binds":[],"configuredReportings":[],"meta":{}},"242":{"profId":41440,"epId":242,"devId":97,"inClusterList":[],"outClusterList":[33],"clusters":{},"binds":[],"configuredReportings":[],"meta":{}}},"hwVersion":1,"dateCode":"20210923","swBuildId":"2.0.1","zclVersion":3,"interviewCompleted":true,"meta":{"configured":1324213189},"lastSeen":1706942700582}
{"id":30,"type":"EndDevice","ieeeAddr":"0x00124b002513f240","nwkAddr":14753,"manufId":0,"manufName":"eWeLink","powerSource":"Battery","modelId":"DS01","epList":[1],"endpoints":{"1":{"profId":260,"epId":1,"devId":1026,"inClusterList":[0,3,1280,1],"outClusterList":[3],"clusters":{"genBasic":{"attributes":{}},"ssIasZone":{"attributes":{"iasCieAddr":"0x00124b0024c8225f","zoneState":1}},"genPowerCfg":{"attributes":{"batteryVoltage":27,"batteryPercentageRemaining":13}}},"binds":[{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00124b0024c8225f","endpointID":1}],"configuredReportings":[{"cluster":1,"attrId":32,"minRepIntval":3600,"maxRepIntval":7200,"repChange":0,"manufacturerCode":null},{"cluster":1,"attrId":33,"minRepIntval":3600,"maxRepIntval":7200,"repChange":0,"manufacturerCode":null}],"meta":{}}},"appVersion":5,"hwVersion":1,"dateCode":"20211103","zclVersion":1,"interviewCompleted":true,"meta":{"configured":1635589808},"lastSeen":1706376115040}
{"id":31,"type":"Router","ieeeAddr":"0xa4c1386cac63a174","nwkAddr":13305,"manufId":4417,"manufName":"_TZ3000_2putqrmw","powerSource":"Mains (single phase)","modelId":"TS011F","epList":[1,242],"endpoints":{"1":{"profId":260,"epId":1,"devId":266,"inClusterList":[3,4,5,6,1794,2820,57344,57345,0],"outClusterList":[25,10],"clusters":{"genBasic":{"attributes":{"65503":"\u000bj�+\u0003","65506":54,"65508":0,"65534":0,"modelId":"TS011F","manufacturerName":"_TZ3000_2putqrmw","powerSource":1,"zclVersion":3,"appVersion":192,"stackVersion":0,"hwVersion":1,"dateCode":""}},"haElectricalMeasurement":{"attributes":{"acCurrentDivisor":1000,"acCurrentMultiplier":1,"rmsVoltage":226,"rmsCurrent":0,"activePower":0}},"seMetering":{"attributes":{"divisor":100,"multiplier":1,"currentSummDelivered":[0,270]}},"genOnOff":{"attributes":{"32768":0,"onOff":1,"onTime":0,"offWaitTime":0,"tuyaBacklightMode":3,"moesStartUpOnOff":1,"tuyaBacklightSwitch":1}},"manuSpecificTuya_3":{"attributes":{"53248":0,"53249":0,"53250":0,"53251":0,"53252":0,"53253":0,"powerOnBehavior":1,"switchType":0}}},"binds":[{"cluster":6,"type":"endpoint","deviceIeeeAddress":"0x00124b0024c8225f","endpointID":1},{"cluster":2820,"type":"endpoint","deviceIeeeAddress":"0x00124b0024c8225f","endpointID":1},{"cluster":1794,"type":"endpoint","deviceIeeeAddress":"0x00124b0024c8225f","endpointID":1}],"configuredReportings":[{"cluster":2820,"attrId":1285,"minRepIntval":5,"maxRepIntval":3600,"repChange":5,"manufacturerCode":null},{"cluster":2820,"attrId":1288,"minRepIntval":5,"maxRepIntval":3600,"repChange":50,"manufacturerCode":null},{"cluster":2820,"attrId":1291,"minRepIntval":5,"maxRepIntval":3600,"repChange":10,"manufacturerCode":null},{"cluster":1794,"attrId":0,"minRepIntval":5,"maxRepIntval":3600,"repChange":[1,1],"manufacturerCode":null}],"meta":{}},"242":{"profId":41440,"epId":242,"devId":97,"inClusterList":[],"outClusterList":[33],"clusters":{},"binds":[],"configuredReportings":[],"meta":{}}},"appVersion":192,"stackVersion":0,"hwVersion":1,"dateCode":"","zclVersion":3,"interviewCompleted":true,"meta":{"configured":-824497014},"lastSeen":1707064324035}
{"id":32,"type":"EndDevice","ieeeAddr":"0xa4c1385e2646453f","nwkAddr":4684,"manufId":4417,"manufName":"_TZ3000_ee8nrt2l","powerSource":"Battery","modelId":"TS0044","epList":[1,2,3,4],"endpoints":{"1":{"profId":260,"epId":1,"devId":0,"inClusterList":[6,1,6,0],"outClusterList":[25,10],"clusters":{"genBasic":{"attributes":{"65503":"pb�+\u0012Nb�+\u0012�b�+\u0012","65506":34,"65508":0,"65534":0,"modelId":"TS0044","manufacturerName":"_TZ3000_ee8nrt2l","powerSource":3,"zclVersion":3,"appVersion":65,"stackVersion":0,"hwVersion":1,"dateCode":""}},"genPowerCfg":{"attributes":{"batteryPercentageRemaining":36,"batteryVoltage":25}}},"binds":[],"configuredReportings":[],"meta":{}},"2":{"profId":260,"epId":2,"devId":0,"inClusterList":[1,6,57344],"outClusterList":[],"clusters":{},"binds":[],"configuredReportings":[],"meta":{}},"3":{"profId":260,"epId":3,"devId":0,"inClusterList":[1,6,57344],"outClusterList":[],"clusters":{},"binds":[],"configuredReportings":[],"meta":{}},"4":{"profId":260,"epId":4,"devId":0,"inClusterList":[1,6,57344],"outClusterList":[],"clusters":{},"binds":[],"configuredReportings":[],"meta":{}}},"appVersion":65,"stackVersion":0,"hwVersion":1,"dateCode":"","zclVersion":3,"interviewCompleted":true,"meta":{"configured":-708457359},"lastSeen":1707062929734}
{"id":33,"type":"EndDevice","ieeeAddr":"0xa4c1382f283a8ecb","nwkAddr":25816,"manufId":4417,"manufName":"_TZ3000_vn88ezar","powerSource":"Battery","modelId":"TS0041","epList":[1,2,3,4],"endpoints":{"1":{"profId":260,"epId":1,"devId":0,"inClusterList":[1,6,57344,0],"outClusterList":[25,10],"clusters":{"genBasic":{"attributes":{"65503":"Е/\u0001\u0012","65506":49,"65508":1,"65534":0,"modelId":"TS0041","manufacturerName":"_TZ3000_vn88ezar","powerSource":3,"zclVersion":3,"appVersion":67,"stackVersion":0,"hwVersion":1,"dateCode":""}},"genPowerCfg":{"attributes":{"batteryPercentageRemaining":2,"batteryVoltage":25}}},"binds":[],"configuredReportings":[],"meta":{}},"2":{"profId":260,"epId":2,"devId":0,"inClusterList":[6,1,6],"outClusterList":[],"clusters":{},"binds":[],"configuredReportings":[],"meta":{}},"3":{"profId":260,"epId":3,"devId":0,"inClusterList":[6,1,6],"outClusterList":[],"clusters":{},"binds":[],"configuredReportings":[],"meta":{}},"4":{"profId":260,"epId":4,"devId":0,"inClusterList":[6,1,6],"outClusterList":[],"clusters":{},"binds":[],"configuredReportings":[],"meta":{}}},"appVersion":67,"stackVersion":0,"hwVersion":1,"dateCode":"","zclVersion":3,"interviewCompleted":true,"meta":{"configured":-708457359},"lastSeen":1707062893520}
{"id":34,"type":"EndDevice","ieeeAddr":"0xa4c138ea18a59da8","nwkAddr":61542,"manufId":4417,"manufName":"_TZ3000_ee8nrt2l","powerSource":"Battery","modelId":"TS0044","epList":[1,2,3,4],"endpoints":{"1":{"profId":260,"epId":1,"devId":0,"inClusterList":[6,1,6,0],"outClusterList":[25,10],"clusters":{"genBasic":{"attributes":{"65503":"��\f,\u0011ָ\u0013,\u0012","65506":34,"65508":0,"65534":0,"stackVersion":0,"dateCode":"","manufacturerName":"_TZ3000_ee8nrt2l","zclVersion":3,"appVersion":65,"modelId":"TS0044","powerSource":3}},"genPowerCfg":{"attributes":{"batteryPercentageRemaining":20,"batteryVoltage":25}}},"binds":[],"configuredReportings":[],"meta":{}},"2":{"profId":260,"epId":2,"devId":0,"inClusterList":[1,6,57344],"outClusterList":[],"clusters":{},"binds":[],"configuredReportings":[],"meta":{}},"3":{"profId":260,"epId":3,"devId":0,"inClusterList":[1,6,57344],"outClusterList":[],"clusters":{},"binds":[],"configuredReportings":[],"meta":{}},"4":{"profId":260,"epId":4,"devId":0,"inClusterList":[1,6,57344],"outClusterList":[],"clusters":{},"binds":[],"configuredReportings":[],"meta":{}}},"appVersion":65,"stackVersion":0,"hwVersion":1,"dateCode":"","zclVersion":3,"interviewCompleted":true,"meta":{"configured":-708457359},"lastSeen":1707064109799}
{"id":35,"type":"EndDevice","ieeeAddr":"0xa4c138062fd31a17","nwkAddr":5845,"manufId":4417,"manufName":"_TZ3000_fkvaniuu","powerSource":"Battery","modelId":"TS0042","epList":[1,2,3,4],"endpoints":{"1":{"profId":260,"epId":1,"devId":0,"inClusterList":[1,6,57344,0],"outClusterList":[25,10],"clusters":{"genBasic":{"attributes":{"65503":"�\u001b�+\u0017�\u001b�+\u0013��+\u0012","65506":49,"65508":0,"65534":0,"modelId":"TS0042","manufacturerName":"_TZ3000_fkvaniuu","powerSource":3,"zclVersion":3,"appVersion":67,"stackVersion":0,"hwVersion":1,"dateCode":""}},"genPowerCfg":{"attributes":{"batteryPercentageRemaining":74,"batteryVoltage":26}}},"binds":[],"configuredReportings":[],"meta":{}},"2":{"profId":260,"epId":2,"devId":0,"inClusterList":[6,1,6],"outClusterList":[],"clusters":{},"binds":[],"configuredReportings":[],"meta":{}},"3":{"profId":260,"epId":3,"devId":0,"inClusterList":[6,1,6],"outClusterList":[],"clusters":{},"binds":[],"configuredReportings":[],"meta":{}},"4":{"profId":260,"epId":4,"devId":0,"inClusterList":[6,1,6],"outClusterList":[],"clusters":{},"binds":[],"configuredReportings":[],"meta":{}}},"appVersion":67,"stackVersion":0,"hwVersion":1,"dateCode":"","zclVersion":3,"interviewCompleted":true,"meta":{"configured":-708457359},"lastSeen":1707060778796}
{"id":36,"type":"Router","ieeeAddr":"0xa4c138f429b959f2","nwkAddr":21152,"manufId":4417,"manufName":"_TZE204_t1blo2bj","powerSource":"Mains (single phase)","modelId":"TS0601","epList":[1,242],"endpoints":{"1":{"profId":260,"epId":1,"devId":81,"inClusterList":[4,5,61184,0],"outClusterList":[25,10],"clusters":{"genBasic":{"attributes":{"65503":"6\u0000\u0000\u0000e7\u0000\u0000\u0000\u0012\u001d��+f\u001e��+\u0012%\u0000\u0000\u0000f&\u0000\u0000\u0000\u0012","65506":56,"65508":0,"modelId":"TS0601","manufacturerName":"_TZE204_t1blo2bj","powerSource":1,"zclVersion":3,"appVersion":74,"stackVersion":0,"hwVersion":1,"dateCode":""}}},"binds":[],"configuredReportings":[],"meta":{}},"242":{"profId":41440,"epId":242,"devId":97,"inClusterList":[],"outClusterList":[33],"clusters":{},"binds":[],"configuredReportings":[],"meta":{}}},"appVersion":74,"stackVersion":0,"hwVersion":1,"dateCode":"","zclVersion":3,"interviewCompleted":true,"meta":{"configured":-201703211},"lastSeen":1707064244716}
{"id":37,"type":"EndDevice","ieeeAddr":"0xa4c13835cfc315ba","nwkAddr":24629,"manufId":4417,"manufName":"_TZ3000_vn88ezar","powerSource":"Battery","modelId":"TS0041","epList":[1,2,3,4],"endpoints":{"1":{"profId":260,"epId":1,"devId":0,"inClusterList":[1,6,57344,0],"outClusterList":[25,10],"clusters":{"genBasic":{"attributes":{"65503":"��\f,\u0011\u0000\u0000\u0000\u0000\u0011","65506":49,"65508":1,"65534":0,"modelId":"TS0041","manufacturerName":"_TZ3000_vn88ezar","powerSource":3,"zclVersion":3,"appVersion":67,"stackVersion":0,"hwVersion":1,"dateCode":""}},"genPowerCfg":{"attributes":{"batteryPercentageRemaining":92,"batteryVoltage":27}}},"binds":[],"configuredReportings":[],"meta":{}},"2":{"profId":260,"epId":2,"devId":0,"inClusterList":[6,1,6],"outClusterList":[],"clusters":{},"binds":[],"configuredReportings":[],"meta":{}},"3":{"profId":260,"epId":3,"devId":0,"inClusterList":[6,1,6],"outClusterList":[],"clusters":{},"binds":[],"configuredReportings":[],"meta":{}},"4":{"profId":260,"epId":4,"devId":0,"inClusterList":[6,1,6],"outClusterList":[],"clusters":{},"binds":[],"configuredReportings":[],"meta":{}}},"appVersion":67,"stackVersion":0,"hwVersion":1,"dateCode":"","zclVersion":3,"interviewCompleted":true,"meta":{"configured":-708457359},"lastSeen":1707056956831}
{"id":38,"type":"Router","ieeeAddr":"0xa4c13864887a19e4","nwkAddr":27388,"manufId":4417,"manufName":"_TZ3000_2putqrmw","powerSource":"Mains (single phase)","modelId":"TS011F","epList":[1,242],"endpoints":{"1":{"profId":260,"epId":1,"devId":266,"inClusterList":[3,4,5,6,1794,2820,57344,57345,0],"outClusterList":[25,10],"clusters":{"genBasic":{"attributes":{"65503":"ž�,\u0003","65506":54,"65508":0,"65534":0,"modelId":"TS011F","manufacturerName":"_TZ3000_2putqrmw","powerSource":1,"zclVersion":3,"appVersion":192,"stackVersion":0,"hwVersion":1,"dateCode":""}},"genOnOff":{"attributes":{"32768":0,"onOff":0,"onTime":0,"offWaitTime":0,"tuyaBacklightMode":1,"moesStartUpOnOff":2,"tuyaBacklightSwitch":1}},"manuSpecificTuya_3":{"attributes":{"53248":0,"53249":0,"53250":0,"53251":0,"53252":0,"53253":0,"powerOnBehavior":2,"switchType":0}},"haElectricalMeasurement":{"attributes":{"acCurrentDivisor":1000,"acCurrentMultiplier":1,"rmsVoltage":225,"rmsCurrent":0,"activePower":0}},"seMetering":{"attributes":{"divisor":100,"multiplier":1,"currentSummDelivered":[0,15808]}}},"binds":[{"cluster":6,"type":"endpoint","deviceIeeeAddress":"0x00124b0024c8225f","endpointID":1},{"cluster":2820,"type":"endpoint","deviceIeeeAddress":"0x00124b0024c8225f","endpointID":1},{"cluster":1794,"type":"endpoint","deviceIeeeAddress":"0x00124b0024c8225f","endpointID":1}],"configuredReportings":[{"cluster":2820,"attrId":1285,"minRepIntval":5,"maxRepIntval":3600,"repChange":5,"manufacturerCode":null},{"cluster":2820,"attrId":1288,"minRepIntval":5,"maxRepIntval":3600,"repChange":50,"manufacturerCode":null},{"cluster":2820,"attrId":1291,"minRepIntval":5,"maxRepIntval":3600,"repChange":10,"manufacturerCode":null},{"cluster":1794,"attrId":0,"minRepIntval":5,"maxRepIntval":3600,"repChange":[1,1],"manufacturerCode":null}],"meta":{}},"242":{"profId":41440,"epId":242,"devId":97,"inClusterList":[],"outClusterList":[33],"clusters":{},"binds":[],"configuredReportings":[],"meta":{}}},"appVersion":192,"stackVersion":0,"hwVersion":1,"dateCode":"","zclVersion":3,"interviewCompleted":true,"meta":{"configured":-824497014},"lastSeen":1707064398519}
{"id":39,"type":"Router","ieeeAddr":"0x04cd15fffe0053ca","nwkAddr":40734,"manufId":4098,"manufName":"_TZ3000_5k5vh43t","powerSource":"Mains (single phase)","modelId":"TS0207","epList":[1],"endpoints":{"1":{"profId":260,"epId":1,"devId":8,"inClusterList":[0,10,3],"outClusterList":[25],"clusters":{"genBasic":{"attributes":{"65503":"B96-\u0011","65506":22,"modelId":"TS0207","manufacturerName":"_TZ3000_5k5vh43t","powerSource":1,"zclVersion":3,"appVersion":64,"stackVersion":0,"hwVersion":1,"dateCode":""}}},"binds":[],"configuredReportings":[],"meta":{}}},"appVersion":64,"stackVersion":0,"hwVersion":1,"dateCode":"","zclVersion":3,"interviewCompleted":true,"meta":{},"lastSeen":1706689079039}
{"id":40,"type":"EndDevice","ieeeAddr":"0x9035eafffeeb8d38","nwkAddr":20818,"manufId":4098,"manufName":"_TZ3210_eymunffl","powerSource":"Battery","modelId":"TS0101","epList":[1],"endpoints":{"1":{"profId":260,"epId":1,"devId":81,"inClusterList":[0,4,5,6,61184,1],"outClusterList":[25,10],"clusters":{"genBasic":{"attributes":{"65503":"!�V,\u0011Ҏi,\u0011�Tu,\u0011]�},\u0011�|�,\u0012","65506":31,"65508":0,"65534":0,"modelId":"TS0101","manufacturerName":"_TZ3210_eymunffl","powerSource":3,"zclVersion":3,"appVersion":69,"stackVersion":0,"hwVersion":1,"dateCode":""}},"genOnOff":{"attributes":{"onOff":0,"offWaitTime":0,"onTime":0}}},"binds":[],"configuredReportings":[],"meta":{}}},"appVersion":69,"stackVersion":0,"hwVersion":1,"dateCode":"","zclVersion":3,"interviewCompleted":true,"meta":{"configured":-708457359},"lastSeen":1707051899448}
{"id":41,"type":"EndDevice","ieeeAddr":"0xa4c138fdf0419e61","nwkAddr":38984,"manufId":4417,"manufName":"_TZ3000_vn88ezar","powerSource":"Battery","modelId":"TS0041","epList":[1,2,3,4],"endpoints":{"1":{"profId":260,"epId":1,"devId":0,"inClusterList":[1,6,57344,0],"outClusterList":[25,10],"clusters":{"genBasic":{"attributes":{"65503":":\u001e�\u0000\u0012","65506":49,"65508":1,"65534":0,"modelId":"TS0041","manufacturerName":"_TZ3000_vn88ezar","powerSource":3,"zclVersion":3,"appVersion":67,"stackVersion":0,"hwVersion":1,"dateCode":""}},"genPowerCfg":{"attributes":{"batteryPercentageRemaining":68,"batteryVoltage":26}}},"binds":[],"configuredReportings":[],"meta":{}},"2":{"profId":260,"epId":2,"devId":0,"inClusterList":[6,1,6],"outClusterList":[],"clusters":{},"binds":[],"configuredReportings":[],"meta":{}},"3":{"profId":260,"epId":3,"devId":0,"inClusterList":[6,1,6],"outClusterList":[],"clusters":{},"binds":[],"configuredReportings":[],"meta":{}},"4":{"profId":260,"epId":4,"devId":0,"inClusterList":[6,1,6],"outClusterList":[],"clusters":{},"binds":[],"configuredReportings":[],"meta":{}}},"appVersion":67,"stackVersion":0,"hwVersion":1,"dateCode":"","zclVersion":3,"interviewCompleted":true,"meta":{"configured":-708457359},"lastSeen":1707061615347}
{"id":42,"type":"EndDevice","ieeeAddr":"0x847127fffe75da2d","nwkAddr":11272,"manufId":4619,"manufName":"HEIMAN","powerSource":"Battery","modelId":"SmokeSensor-EF-3.0","epList":[1],"endpoints":{"1":{"profId":260,"epId":1,"devId":1026,"inClusterList":[0,1,3,1280,1282,2821],"outClusterList":[25],"clusters":{"genBasic":{"attributes":{"modelId":"SmokeSensor-EF-3.0","manufacturerName":"HEIMAN","powerSource":3,"zclVersion":2,"appVersion":17,"stackVersion":2,"hwVersion":16,"dateCode":"2019.8.29"}},"ssIasZone":{"attributes":{"iasCieAddr":"0x00124b0024c8225f","zoneState":1}},"genPowerCfg":{"attributes":{"batteryPercentageRemaining":200}}},"binds":[{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00124b0024c8225f","endpointID":1}],"configuredReportings":[{"cluster":1,"attrId":33,"minRepIntval":3600,"maxRepIntval":65000,"repChange":0,"manufacturerCode":null}],"meta":{}}},"appVersion":17,"stackVersion":2,"hwVersion":16,"dateCode":"2019.8.29","zclVersion":2,"interviewCompleted":true,"meta":{"configured":1},"lastSeen":1706945011198}
{"id":43,"type":"EndDevice","ieeeAddr":"0x00124b00252147a2","nwkAddr":29977,"manufId":0,"manufName":"eWeLink","powerSource":"Battery","modelId":"TH01","epList":[1],"endpoints":{"1":{"profId":260,"epId":1,"devId":770,"inClusterList":[0,3,1026,1029,1],"outClusterList":[3],"clusters":{"genBasic":{"attributes":{"modelId":"TH01","manufacturerName":"eWeLink","powerSource":3,"zclVersion":1,"appVersion":5,"hwVersion":1,"dateCode":"20201026"}},"genPowerCfg":{"attributes":{"batteryVoltage":28,"batteryPercentageRemaining":102}},"msTemperatureMeasurement":{"attributes":{"measuredValue":1724}},"msRelativeHumidity":{"attributes":{"measuredValue":5135}}},"binds":[{"cluster":1026,"type":"endpoint","deviceIeeeAddress":"0x00124b0024c8225f","endpointID":1},{"cluster":1029,"type":"endpoint","deviceIeeeAddress":"0x00124b0024c8225f","endpointID":1},{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00124b0024c8225f","endpointID":1}],"configuredReportings":[{"cluster":1026,"attrId":0,"minRepIntval":5,"maxRepIntval":1800,"repChange":20,"manufacturerCode":null},{"cluster":1029,"attrId":0,"minRepIntval":10,"maxRepIntval":3600,"repChange":100,"manufacturerCode":null},{"cluster":1,"attrId":32,"minRepIntval":3600,"maxRepIntval":7200,"repChange":0,"manufacturerCode":null},{"cluster":1,"attrId":33,"minRepIntval":3600,"maxRepIntval":7200,"repChange":0,"manufacturerCode":null}],"meta":{}}},"appVersion":5,"hwVersion":1,"dateCode":"20201026","zclVersion":1,"interviewCompleted":true,"meta":{"configured":-1904545032},"lastSeen":1707063787838}
{"id":44,"type":"Router","ieeeAddr":"0x00124b00258a71a3","nwkAddr":6112,"manufId":4742,"manufName":"SONOFF","powerSource":"Mains (single phase)","modelId":"S26R2ZB","epList":[1,13,242],"endpoints":{"1":{"profId":260,"epId":1,"devId":9,"inClusterList":[0,3,4,5,6,64599],"outClusterList":[25],"clusters":{"genOnOff":{"attributes":{"onOff":0}},"genBasic":{"attributes":{}}},"binds":[{"cluster":6,"type":"endpoint","deviceIeeeAddress":"0x00124b0024c8225f","endpointID":1}],"configuredReportings":[{"cluster":6,"attrId":0,"minRepIntval":0,"maxRepIntval":65000,"repChange":1,"manufacturerCode":null}],"meta":{}},"13":{"profId":49246,"epId":13,"devId":57694,"inClusterList":[4096],"outClusterList":[4096],"clusters":{},"binds":[],"configuredReportings":[],"meta":{}},"242":{"profId":41440,"epId":242,"devId":97,"inClusterList":[],"outClusterList":[33],"clusters":{},"binds":[],"configuredReportings":[],"meta":{}}},"hwVersion":1,"dateCode":"20210923","swBuildId":"2.0.1","zclVersion":3,"interviewCompleted":true,"meta":{"configured":1324213189},"lastSeen":1705770459528}
{"id":45,"type":"Router","ieeeAddr":"0xa4c1381533f3be93","nwkAddr":55168,"manufId":4417,"manufName":"_TZ3000_ynmowqk2","powerSource":"Mains (single phase)","modelId":"TS011F","epList":[1,242],"endpoints":{"1":{"profId":260,"epId":1,"devId":266,"inClusterList":[3,4,5,6,1794,2820,57345,57344,0],"outClusterList":[25,10],"clusters":{"genBasic":{"attributes":{"65503":"��G-\u0003","65506":54,"65508":0,"65534":0,"modelId":"TS011F","manufacturerName":"_TZ3000_ynmowqk2","powerSource":1,"zclVersion":3,"appVersion":192,"stackVersion":0,"hwVersion":1,"dateCode":""}},"genOnOff":{"attributes":{"32768":0,"onOff":0,"onTime":0,"offWaitTime":0,"tuyaBacklightMode":0,"moesStartUpOnOff":0,"tuyaBacklightSwitch":1}},"manuSpecificTuya_3":{"attributes":{"53248":0,"53249":0,"53250":0,"53251":0,"53252":0,"53253":0,"powerOnBehavior":0,"switchType":0}},"haElectricalMeasurement":{"attributes":{"acCurrentDivisor":1000,"acCurrentMultiplier":1,"rmsVoltage":221,"rmsCurrent":0,"activePower":0}},"seMetering":{"attributes":{"divisor":100,"multiplier":1,"currentSummDelivered":[0,54]}}},"binds":[{"cluster":6,"type":"endpoint","deviceIeeeAddress":"0x00124b0024c8225f","endpointID":1},{"cluster":2820,"type":"endpoint","deviceIeeeAddress":"0x00124b0024c8225f","endpointID":1}],"configuredReportings":[{"cluster":2820,"attrId":1285,"minRepIntval":5,"maxRepIntval":3600,"repChange":5,"manufacturerCode":null},{"cluster":2820,"attrId":1288,"minRepIntval":5,"maxRepIntval":3600,"repChange":50,"manufacturerCode":null},{"cluster":2820,"attrId":1291,"minRepIntval":5,"maxRepIntval":3600,"repChange":10,"manufacturerCode":null}],"meta":{}},"242":{"profId":41440,"epId":242,"devId":97,"inClusterList":[],"outClusterList":[33],"clusters":{},"binds":[],"configuredReportings":[],"meta":{}}},"appVersion":192,"stackVersion":0,"hwVersion":1,"dateCode":"","zclVersion":3,"interviewCompleted":true,"meta":{"configured":-1289829400},"lastSeen":1707064358360}
{"id":46,"type":"Router","ieeeAddr":"0xa4c138ed5dcd1c37","nwkAddr":55693,"manufId":4417,"manufName":"_TZ3000_2xlvlnez","powerSource":"Mains (single phase)","modelId":"TS011F","epList":[1,2,242],"endpoints":{"1":{"profId":260,"epId":1,"devId":266,"inClusterList":[3,4,5,6,57344,57345,0],"outClusterList":[25,10],"clusters":{"genBasic":{"attributes":{"65503":"�\u0000\u0000\u0000\u0012\u0012\u0000\u0000\u0000\u0012\u0016\u0000\u0000\u0000\u0016�\n\u0000\u0000\u0012","65506":48,"65508":0,"65534":0,"modelId":"TS011F","manufacturerName":"_TZ3000_2xlvlnez","powerSource":1,"zclVersion":3,"appVersion":67,"stackVersion":0,"hwVersion":1,"dateCode":""}},"genOnOff":{"attributes":{"32768":0,"onOff":0,"onTime":0,"offWaitTime":0,"tuyaBacklightMode":0,"moesStartUpOnOff":0,"tuyaBacklightSwitch":1}},"manuSpecificTuya_3":{"attributes":{"powerOnBehavior":0,"switchType":0}}},"binds":[{"cluster":6,"type":"endpoint","deviceIeeeAddress":"0x00124b0024c8225f","endpointID":1}],"configuredReportings":[{"cluster":6,"attrId":0,"minRepIntval":0,"maxRepIntval":3600,"repChange":0,"manufacturerCode":null}],"meta":{}},"2":{"profId":260,"epId":2,"devId":266,"inClusterList":[4,5,6,57345],"outClusterList":[],"clusters":{"genOnOff":{"attributes":{"onOff":0,"onTime":0,"offWaitTime":0}},"manuSpecificTuya_3":{"attributes":{"powerOnBehavior":0}}},"binds":[{"cluster":6,"type":"endpoint","deviceIeeeAddress":"0x00124b0024c8225f","endpointID":1}],"configuredReportings":[{"cluster":6,"attrId":0,"minRepIntval":0,"maxRepIntval":3600,"repChange":0,"manufacturerCode":null}],"meta":{}},"242":{"profId":41440,"epId":242,"devId":97,"inClusterList":[],"outClusterList":[33],"clusters":{},"binds":[],"configuredReportings":[],"meta":{}}},"appVersion":67,"stackVersion":0,"hwVersion":1,"dateCode":"","zclVersion":3,"interviewCompleted":true,"meta":{"configured":1948765142},"lastSeen":1707053455218}
J’en ai 46 de déclaré hors via l’interface web j’en ai 45
Le 46ème est ton coordinateur (clé zigbee) qui n’apparait pas sur l’interface web de z2m.
Ah oui en effet je l’ai par contre sur l’interface de MQTT.
Voici le fichier state.json
    "0x9035eafffe2c2729": {
        "child_lock": "UNLOCK",
        "sensor": "AL",
        "program": {
            "weekdays_p1_hour": 5,
            "weekdays_p1_minute": 30,
            "weekdays_p1_temperature": 20,
            "weekdays_p2_hour": 8,
            "weekdays_p2_minute": 0,
            "weekdays_p2_temperature": 16.5,
            "weekdays_p3_hour": 17,
            "weekdays_p3_minute": 0,
            "weekdays_p3_temperature": 20,
            "weekdays_p4_hour": 22,
            "weekdays_p4_minute": 30,
            "weekdays_p4_temperature": 16,
            "saturday_p1_hour": 7,
            "saturday_p1_minute": 0,
            "saturday_p1_temperature": 20,
            "saturday_p2_hour": 11,
            "saturday_p2_minute": 0,
            "saturday_p2_temperature": 17,
            "saturday_p3_hour": 17,
            "saturday_p3_minute": 0,
            "saturday_p3_temperature": 20,
            "saturday_p4_hour": 22,
            "saturday_p4_minute": 45,
            "saturday_p4_temperature": 16,
            "sunday_p1_hour": 7,
            "sunday_p1_minute": 30,
            "sunday_p1_temperature": 20,
            "sunday_p2_hour": 11,
            "sunday_p2_minute": 0,
            "sunday_p2_temperature": 17,
            "sunday_p3_hour": 17,
            "sunday_p3_minute": 0,
            "sunday_p3_temperature": 20,
            "sunday_p4_hour": 22,
            "sunday_p4_minute": 30,
            "sunday_p4_temperature": 16
        "current_heating_setpoint": 23,
        "heat": "OFF",
        "running_state": "idle",
        "local_temperature": 16,
        "linkquality": 69,
        "system_mode": "off",
        "local_temperature_calibration": -10,
        "preset_mode": "hold",
        "preset": "hold",
        "max_temperature_limit": 35,
        "min_temperature_limit": 2,
        "deadzone_temperature": 1
    "0x00124b002510d784": {
        "voltage": 3000,
        "battery": 100,
        "temperature": 18.16,
        "humidity": 61.56,
        "linkquality": 54
    "0x00124b0022d2c4e6": {
        "voltage": 2900,
        "battery": 87,
        "temperature": 11.98,
        "humidity": 66.73,
        "linkquality": 0
    "0x00158d0005d2a08a": {
        "current_tarif": "BASE",
        "linkquality": 10,
        "rms_current_max": 90,
        "meter_serial_number": "022264064829",
        "active_register_tier_delivered": "TH..",
        "available_power": 45,
        "rms_current": 12,
        "current_summ_delivered": 12653.706,
        "apparent_power": 2790,
        "update": {
            "state": "idle",
            "installed_version": 13,
            "latest_version": 13
        "warn_d_p_s": 0
    "0xa4c138880764bcec": {
        "state": "OFF",
        "power_outage_memory": "on",
        "indicator_mode": "off/on",
        "voltage": 221,
        "power": 0,
        "current": 0,
        "energy": 56.83,
        "linkquality": 21,
        "update": {
            "state": "idle",
            "installed_version": 192,
            "latest_version": 192
    "0x00124b002519262c": {
        "contact": true,
        "tamper": false,
        "battery_low": false,
        "voltage": 3000,
        "battery": 100,
        "linkquality": 72
    "0xa4c13830779d26da": {
        "state": "ON",
        "voltage": 223,
        "power": 18,
        "current": 0.11,
        "energy": 13.08,
        "linkquality": 149,
        "update": {
            "state": "idle",
    "0xc4988600000691a3": {
        "brightness": 229,
        "state": "OFF",
        "power_on_behavior": "on",
        "linkquality": 7,
        "update": {
            "state": "idle",
            "installed_version": 604181777,
            "latest_version": 604181777
    "0xc49886000006ef1e": {
        "state": "OFF",
        "linkquality": 72,
        "brightness": 127,
        "update": {
            "state": "idle",
    "0xc49886000006a513": {
        "state": "OFF",
        "linkquality": 65,
        "brightness": 229,
        "update": {
            "state": "idle",
    "0x00124b00252bf0b3": {
        "voltage": 2900,
        "temperature": 11.99,
        "humidity": 64.58,
        "battery": 86,
        "linkquality": 40
    "0x00124b00252be357": {
        "voltage": 2900,
        "battery": 98.5,
        "temperature": 17.7,
        "humidity": 60.63,
        "linkquality": 72
    "0x00124b00250e11a1": {
        "temperature": 17.35,
        "voltage": 3000,
        "battery": 100,
        "humidity": 64.27,
        "linkquality": 47
    "0x00124b00254de159": {
        "temperature": 15.51,
        "voltage": 2900,
        "battery": 86.5,
        "humidity": 53.8,
        "linkquality": 0
    "0x00124b002558c529": {
        "temperature": 12.93,
        "humidity": 89.24,
        "voltage": 2900,
        "battery": 75,
        "linkquality": 76
    "0x04cd15fffe0053a9": {
        "linkquality": 7
    "0xa4c13854cfb229eb": {
        "state_l1": "ON",
        "power_outage_memory_l1": "restore",
        "indicator_mode": "off",
        "state_l2": "OFF",
        "power_outage_memory": "restore",
        "linkquality": 32
    "0x00124b00252bf95c": {
        "temperature": 17.38,
        "voltage": 3000,
        "battery": 100,
        "humidity": 68.1,
        "linkquality": 72
    "0xa4c1386cac63a174": {
        "state": "ON",
        "indicator_mode": "on",
        "voltage": 225,
        "current": 0,
        "power": 0,
        "energy": 2.7,
        "linkquality": 40,
        "update": {
            "state": "idle",
    "0x00124b002508cabc": {
        "occupancy": false,
        "tamper": false,
        "voltage": 3000,
        "battery": 100,
        "linkquality": 69
    "0xa4c1385e2646453f": {
        "linkquality": 51,
        "battery": 18,
        "voltage": 2500
    "0x00124b0025140b30": {
        "contact": true,
        "tamper": false,
        "voltage": 3000,
        "battery": 100,
        "linkquality": 21
    "0x00124b002513ca82": {
        "contact": true,
        "tamper": false,
        "linkquality": 7,
        "voltage": 2500,
        "battery": 5
    "0xa4c138ea18a59da8": {
        "linkquality": 87,
        "battery": 10,
        "voltage": 2500
    "0xa4c138062fd31a17": {
        "linkquality": 65,
        "battery": 37,
        "voltage": 2600
    "0xa4c138f429b959f2": {
        "volume": "high",
        "battpercentage": 100,
        "melody": 2,
        "alarm": false,
        "linkquality": 174
    "0xa4c13835cfc315ba": {
        "battery": 46,
        "voltage": 2700,
        "linkquality": 0
    "0xa4c13864887a19e4": {
        "state": "OFF",
        "voltage": 224,
        "power": 0,
        "current": 0,
        "energy": 158.08,
        "linkquality": 40,
        "update": {
            "state": "idle",
    "0x540f57fffe8d5e30": {
        "state": "OFF",
        "battery": 80,
        "linkquality": 40
    "0x04cd15fffe0053ca": {
        "linkquality": 123
    "0x9035eafffeeb8d38": {
        "state": "OFF",
        "linkquality": 61,
        "battery": 82
    "0xa4c138fdf0419e61": {
        "linkquality": 61,
        "battery": 34,
        "voltage": 2600
    "0xa4c1382f283a8ecb": {
        "battery": 1,
        "voltage": 2500,
        "linkquality": 80
    "0x00124b00252147a2": {
        "voltage": 2800,
        "battery": 51.5,
        "temperature": 17.24,
        "humidity": 53.37,
        "linkquality": 18
    "0x00124b002513f240": {
        "contact": true,
        "tamper": false,
        "voltage": 2700,
        "battery": 6.5,
        "linkquality": 127
    "0x00124b00251bfcf6": {
        "voltage": 2900,
        "temperature": 20.02,
        "humidity": 56.61,
        "battery": 75,
        "linkquality": 36
    "0xa4c13898f601d11e": {
        "state": "OFF",
        "power_outage_memory": "off",
        "voltage": 224,
        "power": 0,
        "current": 0,
        "energy": 37.42,
        "linkquality": 29,
        "update": {
            "state": "idle",
    "0x847127fffe75da2d": {
        "battery": 100,
        "linkquality": 43,
        "smoke": false,
        "tamper": false,
        "supervision_reports": true,
        "restore_reports": true,
        "trouble": false,
        "ac_status": false,
        "test": false,
        "battery_defect": false
    "0x00124b0024c05735": {
        "state": "OFF",
        "linkquality": 40
    "0x00124b00258a41b7": {
        "state": "OFF",
        "linkquality": 47
    "0x00124b00258a71a3": {
        "state": "OFF",
        "linkquality": 43
    "0xa4c13877b250cdd9": {
        "state": "OFF",
        "voltage": 218,
        "power": 0,
        "current": 0,
        "energy": 78.58,
        "linkquality": 7,
        "update": {
            "state": "idle",
    "0xa4c1381533f3be93": {
        "state": "OFF",
        "voltage": 222,
        "update": {
            "state": "idle",
        "energy": 0.54,
        "power": 0,
        "current": 0,
        "linkquality": 36
    "0x00124b00251c764b": {
        "temperature": 12.28,
        "humidity": 65.68,
        "voltage": 2900,
        "battery": 61.5,
        "linkquality": 47
    "0xa4c138ed5dcd1c37": {
        "state_l1": "ON",
        "power_outage_memory_l1": "off",
        "state_l2": "ON",
        "linkquality": 58
Je viens de réappairer la télécommande et j’ai bien dans le database.db un 47ᵉ équipements, mais rien dans le state.json.
Il faudrait que je copie mon image virtuelle de HA qui est hébergé sur mon NAS pour tester en réinstallant totalement Z2M pour voir si j’ai toujours le problème.
Tu as une ligne « permit_join: true » dans ton fichier configuration.yaml (avant dernière ligne). Je ne pense pas que ça vienne de la mais on ne sait jamais. Tu devrais supprimer cette ligne.
