Grace à l’intégration zodiac on a le signe astrologique occidental en cours:
Alors j’ai poussé plus loin avec le signe astrologique chinois:
Seul hic, le signe chinois va changer au 1er janvier et pas à la date du jour de l’an chinois.
voici le code, dans fichier sensors :
sensors:
year:
friendly_name: 'Année'
value_template: '{{ now().year }}'
zodiac_chinois:
friendly_name: chinois Zodiac
value_template: >-
{% set x = (states('sensor.year')|float) %}
{% set modulo = (x % 12) %}
{% if modulo == 0 %} Singe
{% elif modulo == 1 %} Coq
{% elif modulo == 2 %} Chien
{% elif modulo == 3 %} Cochon
{% elif modulo == 4 %} Rat
{% elif modulo == 5 %} Buffle
{% elif modulo == 6 %} Tigre
{% elif modulo == 7 %} Lapin
{% elif modulo == 8 %} Dragon
{% elif modulo == 9 %} Serpent
{% elif modulo == 10 %} Cheval
{% elif modulo == 11 %} Chevre
{% else %} Error
icon_template: >
{% set sign = states('sensor.zodiac_chinois') %}
{% if sign in ['Error', 'unavailable', 'unknown'] %}
mdi:alert-circle
zod:{{ sign | lower}}
Et le fichier des icones dans le dossier www en suivant ce tuto :
https://forum.hacf.fr/t/ajouter-creer-des-icones/4190
const ZOD_ICONS_MAP = {
"buffle":
"m 12.132158,11.402912 c 0,-0.493379 0,-0.97853 0,-1.4801286 -0.12453,0.05759 -0.244078,0.1068936 -0.363627,0.1644596 -0.941447,0.431703 -1.8779097,0.86752 -2.8243359,1.291 -0.5678541,0.254912 -1.1755603,0.402926 -1.8280984,0.374147 -0.169359,-0.009 -0.3835481,-0.01649 -0.4233971,-0.164463 -0.01993,-0.07394 0.139473,-0.213795 0.2540381,-0.271357 0.6375941,-0.312473 1.2901292,-0.608497 1.9376854,-0.912747 0.7421951,-0.353588 1.4943539,-0.6989476 2.2166259,-1.0813156 0.40846,-0.21791 0.74718,-0.509824 0.906579,-0.908637 0.0149,-0.04105 0.02497,-0.08639 0.04974,-0.180906 -0.114566,0.04517 -0.174341,0.06986 -0.234116,0.09456 -0.777066,0.345366 -1.544169,0.707172 -2.3311958,1.040206 -0.6176682,0.25902 -1.2652203,0.452258 -1.9625904,0.497486 -0.2191711,0.01226 -0.4433281,-0.01226 -0.6674801,-0.03289 -0.2191741,-0.02062 -0.3686051,-0.139788 -0.4134401,-0.312472 -0.08961,-0.337142 -0.1793221,-0.674282 -0.2191701,-1.015535 -0.03987,-0.324805 -0.01993,-0.657838 -0.02497,-0.986754 -0.01001,-0.39059 0.124529,-0.563274 0.7172912,-0.567383 0.159393,0 0.259015,-0.03289 0.343699,-0.143901 0.3187971,-0.41937 0.6475532,-0.830519 0.9713332,-1.245776 0.06967,-0.08639 0.119547,-0.185019 0.1643781,-0.283692 0.109583,-0.24258 0.02986,-0.398816 -0.2590201,-0.489265 -0.144459,-0.04938 -0.2988731,-0.07811 -0.4483111,-0.115125 -0.244073,-0.05759 -0.3686021,-0.168569 -0.3835461,-0.349472 -0.0149,-0.15624 0.07975,-0.287804 0.3138081,-0.361811 0.4383501,-0.13979 0.9015982,-0.152125 1.3598693,-0.106901 1.2502799,0.131571 1.7782839,0.994977 1.8529999,1.70215 0.01993,0.193243 -0.114565,0.394703 -0.184301,0.592056 -0.01993,0.06168 -0.07975,0.11101 -0.109587,0.172682 -0.05477,0.119231 0.0054,0.185014 0.159396,0.189127 0.468231,0.01647 0.891636,-0.135679 1.324998,-0.238464 0.04491,-0.009 0.09465,-0.06986 0.09962,-0.106901 0.02984,-0.349478 0.08961,-0.703063 0.06967,-1.052534 -0.07471,-1.159437 -0.378572,-2.285982 -0.722273,-3.404305 -0.04491,-0.143903 -0.05477,-0.29603 -0.05477,-0.444045 0.0054,-0.156227 0.169362,-0.27546395 0.373589,-0.263128 0.219173,0.01644 0.443326,0.04519 0.652536,0.102794 0.562874,0.152121 1.080918,0.374135 1.489376,0.744168 0.498119,0.456374 0.727253,1.003202 0.782048,1.603477 0.04974,0.608497 -0.03987,1.204661 -0.254044,1.780267 0.403476,0.160348 0.801973,0.304252 1.185526,0.472821 0.298868,0.135679 0.592763,0.287803 0.861746,0.464596 0.458268,0.296026 0.513063,0.596165 0.229134,1.011425 -0.234115,0.345366 -0.602723,0.583827 -1.001222,0.789401 -0.298868,0.160347 -0.602722,0.320698 -0.921517,0.448153 -0.40846,0.168568 -0.59276,0.415258 -0.49314,0.785293 0.164381,0.604383 -0.0149,1.1799936 -0.214188,1.7514886 -0.01993,0.05351 -0.03484,0.106896 -0.05981,0.180902 0.07975,0.01226 0.149435,0.03697 0.21917,0.03697 0.338724,0.0045 0.677444,-0.0045 1.011181,0.0045 0.722274,0.02062 1.424624,-0.102786 2.136932,-0.160347 0.946427,-0.07806 1.892853,-0.148012 2.854223,-0.09867 0.806953,0.04106 1.394733,0.361807 1.857983,0.871633 0.408457,0.448162 0.697366,0.941565 0.856764,1.488401 0.04491,0.148 -0.01993,0.2138 -0.164379,0.26724 -0.388532,0.14802 -0.79699,0.19734 -1.22039,0.15622 -0.278947,-0.0294 -0.557896,-0.0748 -0.836839,-0.0987 -0.388532,-0.0363 -0.777065,-0.0499 -1.165599,-0.0907 -0.971333,-0.0987 -1.942665,-0.15623 -2.923956,-0.12335 -0.458272,0.0159 -0.916539,0.0408 -1.37481,0.0748 -0.338724,0.0249 -0.677441,0.0658 -1.016166,0.0987 -0.1046,0.009 -0.139473,0.0453 -0.139473,0.13569 0.02984,1.78027 0.03987,3.56054 0.07975,5.34079 0.0149,0.77298 0.01993,1.54591 -0.129512,2.31477 -0.08472,0.44815 -0.194267,0.89221 -0.428384,1.30749 -0.02982,0.0538 -0.0648,0.10684 -0.104606,0.15621 -0.164379,0.20967 -0.433362,0.24669 -0.642574,0.0703 -0.154416,-0.13157 -0.278946,-0.28781 -0.37857,-0.45228 -0.343702,-0.58385 -0.503098,-1.21292 -0.682423,-1.84198 -0.134492,-0.46866 -0.169357,-0.94563 -0.159396,-1.42667 0.01993,-0.7647 0.0149,-1.52944 0.03987,-2.29418 0.0149,-0.44403 0.0747,-0.88396 0.109586,-1.32801 0.02982,-0.43992 0.04974,-0.87984 0.07472,-1.32388 0.01,-0.16447 0.02496,-0.32482 0.0449,-0.50984 -0.518045,0.11102 -1.006203,0.21379 -1.499341,0.32071 -0.8318578,0.17678 -1.658733,0.35768 -2.4905911,0.5386 C 6.8221226,14.82089 5.7959994,15.29782 4.8047492,15.83229 4.4112282,16.04607 4.0027771,16.24347 3.599302,16.44491 3.2954499,16.59293 2.9965699,16.56414 2.7126508,16.40861 2.1497697,16.10434 1.7363287,15.68088 1.3876486,15.21217 1.2531516,15.03126 1.1485565,14.83391 1.0439425,14.63659 c -0.09465,-0.18504 -0.03484,-0.35774 0.1643821,-0.46053 0.209208,-0.10687 0.433358,-0.19734 0.6674761,-0.2508 0.4931451,-0.1151 1.0111812,-0.16446 1.4943613,-0.30011 1.2652212,-0.35359 2.5055395,-0.756508 3.7707577,-1.106012 0.9912632,-0.275485 1.9974594,-0.509849 2.9986793,-0.740092 0.637592,-0.131569 1.30009,-0.242579 1.992475,-0.374143 z",
"cheval":
"m 8.5032464,16.798351 c -0.059332,0.211116 -0.098886,0.431411 -0.1829389,0.637937 -0.1285517,0.316674 -0.4647637,0.44518 -0.77131,0.26619 -0.2323819,-0.133095 -0.4598195,-0.316674 -0.6130926,-0.5232 -0.4103765,-0.569095 -0.7762543,-1.161137 -1.1520207,-1.74859 -0.074165,-0.114737 -0.1483289,-0.2616 -0.039554,-0.390105 0.1038302,-0.119327 0.2669919,-0.07802 0.4054322,-0.04589 0.5933154,0.123916 1.1668536,0.302905 1.6662274,0.633347 0.4301537,0.275369 0.6674798,0.656295 0.687257,1.170316 z M 2.7233656,14.131866 c 0.1087744,0.197348 0.2274375,0.394695 0.3263234,0.596632 0.3362121,0.725137 0.3411564,1.48699 0.2422705,2.248843 -0.093942,0.711369 -0.3164349,1.390611 -0.6427584,2.037727 -0.098886,0.192758 -0.2274375,0.380926 -0.3757664,0.546147 -0.2669919,0.289137 -0.5587053,0.289137 -0.855363,0.03213 -0.385655,-0.335032 -0.44004228,-0.761853 -0.4004879,-1.211622 0.074164,-0.807747 0.3955436,-1.551242 0.7317556,-2.290148 0.266992,-0.582863 0.5339839,-1.165726 0.8009758,-1.74859 0.029666,-0.06884 0.074165,-0.133094 0.1137188,-0.197347 0.014833,-0.0046 0.03461,-0.0092 0.059332,-0.01377 z m 10.3286324,2.225896 c -0.0049,0.243242 -0.06428,0.481895 -0.257104,0.679242 -0.266991,0.270779 -0.642758,0.307495 -1.008636,0.06425 -0.192827,-0.128505 -0.370822,-0.293727 -0.504318,-0.472716 -0.420265,-0.569095 -0.820753,-1.151958 -1.226185,-1.730232 -0.03461,-0.05048 -0.059331,-0.110148 -0.088997,-0.165221 -0.054387,-0.100969 -0.014833,-0.165221 0.10383,-0.1744 0.123607,-0.0092 0.252159,-0.01836 0.375766,0.0092 0.741645,0.151452 1.448679,0.394694 2.096381,0.771031 0.351045,0.206527 0.469708,0.403874 0.509263,1.018864 z m 4.692136,-0.468127 c -0.07417,0.238653 -0.123608,0.481895 -0.222494,0.711369 -0.128551,0.298316 -0.405432,0.408463 -0.716922,0.26619 -0.262048,-0.119327 -0.514207,-0.270779 -0.726812,-0.449769 -0.707034,-0.6104 -1.330015,-1.285053 -1.849166,-2.042316 -0.187883,-0.275369 -0.05933,-0.321264 0.20766,-0.316674 0.63287,0.01377 1.245963,0.156042 1.82939,0.385516 0.321379,0.123916 0.637814,0.289137 0.924583,0.472716 0.3461,0.229473 0.514206,0.559916 0.553761,0.972968 z m -2.2101,3.823033 c 0.281825,0.09179 0.543872,0.169811 0.800976,0.252421 0.301602,0.09638 0.593315,0.206527 0.894917,0.293727 0.435098,0.123915 0.815809,0.01377 1.152021,-0.2616 0.746588,-0.610401 1.191575,-1.381432 1.399235,-2.267201 0.163162,-0.6976 0.262048,-1.413558 0.375767,-2.120338 0.133496,-0.872 0.17305,-1.753179 0.13844,-2.638948 -0.0049,-0.142273 -0.01978,-0.289137 -0.04944,-0.43141 -0.108774,-0.509432 -0.321379,-0.706779 -0.889973,-0.720548 -0.850419,-0.01836 -1.705782,-0.0046 -2.561145,0.01377 -0.578482,0.0092 -1.152021,0.03672 -1.730503,0.07343 -0.820753,0.05507 -1.641506,0.114737 -2.457315,0.197348 -0.825697,0.08261 -1.651394,0.192757 -2.477092,0.302905 C 9.0619517,12.553087 8.0088169,12.773382 7.0001807,13.13595 6.7677989,13.218561 6.5156398,13.264456 6.2733694,13.31494 5.9964888,13.370014 5.7937727,13.255277 5.630611,13.04875 5.2350674,12.562266 5.160903,12.034476 5.3339533,11.451613 5.6948868,10.230813 5.8926586,8.9778861 5.9717674,7.7157804 6.0261546,6.8300118 6.0706533,5.9442431 6.065709,5.0584744 6.065709,4.2644952 6.016266,3.4659266 5.6454439,2.7178422 5.5515023,2.5342632 5.5020593,2.3277368 5.4476721,2.1303894 c -0.054387,-0.1881685 0,-0.2616001 0.2076604,-0.2432422 0.385655,0.032126 0.7811986,0.059663 1.1470764,0.1652211 0.4746523,0.1330948 0.9443604,0.1606316 1.423957,0.1239158 0.6427583,-0.050484 1.290461,-0.1147369 1.9332191,-0.1927579 0.964138,-0.1193264 1.923331,-0.2386527 2.882524,-0.3855159 1.018525,-0.1560422 2.027161,-0.3488001 3.040742,-0.5094318 0.464763,-0.073432 0.94436,-0.15145263 1.409124,-0.00918 0.217549,0.068842 0.435098,0.1652211 0.618037,0.2937264 0.237326,0.1652211 0.222493,0.3350317 -0.04944,0.4405896 -0.296658,0.1193263 -0.608149,0.2157053 -0.924584,0.2661895 -0.870195,0.1376843 -1.740391,0.2478317 -2.610587,0.3717475 -0.370822,0.055074 -0.746589,0.096379 -1.117411,0.1744001 -0.341156,0.068842 -0.469708,0.1927579 -0.479597,0.5140212 -0.01978,0.5094317 -0.01483,1.0234529 0.0049,1.5374741 0.0049,0.2294737 0.07911,0.2524211 0.321379,0.2248843 0.904806,-0.105558 1.794779,-0.3258528 2.714418,-0.2707791 0.484541,0.027537 0.969082,0.078021 1.409124,0.2983159 0.08405,0.041305 0.163162,0.096379 0.232382,0.1560422 0.168106,0.1376842 0.153273,0.270779 -0.05439,0.3442106 -0.247215,0.0872 -0.499374,0.1606316 -0.761422,0.1973474 -0.746588,0.1055579 -1.498121,0.1881685 -2.24471,0.279958 -0.499374,0.064253 -0.998747,0.1239158 -1.493177,0.2019369 -0.06922,0.00918 -0.163162,0.0872 -0.177995,0.1468632 -0.128551,0.4910738 -0.153273,0.9913266 -0.133495,1.4961688 0.0049,0.105558 0.07911,0.1147369 0.163161,0.1101474 0.519151,-0.050484 1.038302,-0.091789 1.552509,-0.1606316 0.87514,-0.1147369 1.755225,-0.1881685 2.630365,-0.013768 0.252159,0.050484 0.494429,0.1606316 0.721867,0.2753685 0.09394,0.045895 0.177995,0.1789895 0.182939,0.2753685 0.0049,0.059663 -0.148329,0.1560421 -0.247215,0.1789895 -0.464764,0.1009685 -0.934472,0.2065264 -1.40418,0.2616001 -1.15202,0.1376842 -2.308985,0.2524211 -3.465951,0.367158 -0.09394,0.00918 -0.143384,0.036716 -0.153273,0.1239158 -0.05439,0.5415581 -0.118663,1.0877057 -0.153273,1.6292637 -0.01978,0.247831 0.03956,0.293726 0.316435,0.284547 0.405432,-0.0092 0.815809,-0.03672 1.221241,-0.06884 0.538928,-0.04589 1.072912,-0.105558 1.61184,-0.156042 0.7367,-0.06884 1.468456,-0.133095 2.205156,-0.192758 0.598259,-0.05048 1.196519,-0.09638 1.794779,-0.142274 0.182939,-0.01377 0.375766,-0.0092 0.553761,-0.0459 0.168106,-0.03213 0.301602,0.02295 0.444986,0.0872 0.553761,0.252422 1.112467,0.500253 1.661283,0.757264 0.138441,0.06425 0.262048,0.156042 0.380711,0.247831 0.262048,0.215706 0.296658,0.408464 0.133496,0.697601 -0.06922,0.119326 -0.148329,0.229473 -0.217549,0.34421 -0.31149,0.536969 -0.459819,1.124422 -0.543872,1.721053 -0.153273,1.101474 -0.271937,2.212127 -0.440043,3.313601 -0.158217,1.05558 -0.425209,2.088211 -0.934471,3.052001 -0.504318,0.96379 -1.275628,1.679748 -2.289209,2.170822 -0.400488,0.192758 -0.682313,0.133095 -0.964137,-0.197348 -0.731756,-0.862821 -1.354737,-1.785305 -1.918387,-2.749095 -0.02472,-0.03672 -0.03955,-0.07802 -0.05933,-0.123916 0,0.0092 0.0049,-0.0092 0.0049,-0.0872 z M 7.0249022,11.883024 c 0.03461,0.0092 0.044499,0.01377 0.054387,0.01377 1.3349597,-0.183579 2.6699193,-0.371747 4.0098238,-0.550737 0.118663,-0.01836 0.118663,-0.08261 0.118663,-0.165221 0,-0.385516 0,-0.771032 0,-1.156548 0,-0.215705 0,-0.4359997 0,-0.6792419 -1.4041802,0.022947 -2.7935271,0.045895 -4.182874,0.068842 0,0.8352849 0,1.6476219 0,2.4691379 z M 7.3858357,5.6413377 c 0.4252094,-0.045895 0.8306416,-0.082611 1.2311295,-0.1285053 0.7515328,-0.0872 1.5030658,-0.1744 2.2545988,-0.2616 0.09394,-0.00918 0.158217,-0.032126 0.153273,-0.1422738 -0.01483,-0.4681264 -0.0099,-0.9362529 -0.03956,-1.4043793 C 10.960561,3.2823476 10.757845,3.0620528 10.307914,3.0391054 9.4822168,2.9978002 8.6515753,3.0023896 7.8209337,2.9932107 c -0.039554,0 -0.1038302,0.064253 -0.1186631,0.1147368 C 7.5292203,3.6036109 7.4155015,4.1130426 7.39078,4.6316532 7.375947,4.9620954 7.38584,5.2925376 7.38584,5.6413377 Z m -0.168106,0.8261055 c -0.029666,0.6287581 -0.059331,1.2299793 -0.084053,1.8312006 -0.00989,0.270779 0.00494,0.2753685 0.2867691,0.2524211 0.019777,0 0.03461,-0.00459 0.054387,-0.00459 0.6922015,-0.059663 1.3893471,-0.1147364 2.0815484,-0.188168 0.4153208,-0.041305 0.8355858,-0.1009684 1.2459628,-0.1698105 0.271936,-0.041305 0.375766,-0.1330948 0.38071,-0.3717475 0,-0.376337 -0.03461,-0.7572634 -0.05933,-1.1336003 -0.0099,-0.1239159 -0.089,-0.2019369 -0.237326,-0.2065264 -0.538929,-0.018358 -1.0778567,-0.055074 -1.6217292,-0.055074 -0.6674798,0 -1.3399039,0.027537 -2.0469381,0.045895 z",
"chevre":
"m 10.195499,4.4455163 c -0.01468,0.151247 -0.02934,0.302494 -0.04402,0.4492926 C 10.112348,5.2239936 9.9509377,5.34855 9.584096,5.3263078 9.3493173,5.3129625 9.1683421,5.2017514 9.0069317,5.0682981 8.4248762,4.5923148 7.9651013,4.0184658 7.52,3.4401684 7.2705476,3.1198805 7.0406601,2.781799 6.8156639,2.4481658 6.7716433,2.3858878 6.7765346,2.3013672 6.7569694,2.2257437 6.8401204,2.2079497 6.9281622,2.1768107 7.011313,2.1812597 7.6422807,2.2346407 8.219445,2.4526146 8.7770445,2.7061758 9.0069319,2.80849 9.227037,2.9285979 9.4373595,3.0576028 9.9607204,3.3912359 10.205282,3.8583223 10.195499,4.4455163 Z M 5.3189497,10.926896 c 0.1956489,-0.03559 0.3374944,-0.06673 0.4793398,-0.08007 1.0075919,-0.08897 2.0102926,-0.16904 3.0178845,-0.266906 0.7043361,-0.06673 1.403781,-0.155696 2.103226,-0.235768 0.102715,-0.01335 0.176084,-0.03559 0.156518,-0.160144 -0.07826,-0.5916423 -0.141844,-1.1832851 -0.215213,-1.7704795 -0.0098,-0.075623 -0.02934,-0.151247 -0.04891,-0.2224221 C 10.723751,7.8841639 10.547666,7.7462622 10.20039,7.7551591 9.7993098,7.7685041 9.3933384,7.8129891 8.992258,7.8396791 8.0384696,7.8975091 7.07979,7.9909261 6.1357839,7.7862981 5.9499174,7.7462602 5.764051,7.6706367 5.5928582,7.5861163 5.5292723,7.5549772 5.4705776,7.4571115 5.4754688,7.3948333 c 0,-0.044484 0.1076069,-0.111211 0.1760841,-0.1201079 C 6.204261,7.1902054 6.752078,7.1145815 7.3047862,7.0434064 8.4346587,6.9010562 9.5694224,6.7853968 10.694403,6.6252528 12.010142,6.4384183 13.316099,6.2248931 14.626947,6.002471 15.213894,5.904605 15.80084,5.771152 16.378004,5.6376987 c 0.645642,-0.1467986 1.208133,0.040036 1.736385,0.3469785 0.09783,0.05783 0.205431,0.2046283 0.190757,0.2935972 -0.01468,0.093417 -0.156519,0.2135252 -0.264126,0.2446643 -0.454883,0.1245564 -0.909767,0.2491127 -1.374433,0.3247362 -1.467367,0.231319 -2.939626,0.4403958 -4.411883,0.6583695 -0.0098,0 -0.01957,0.0089 -0.05381,0.031139 0.08315,0.08452 0.156519,0.1734892 0.249453,0.2446643 0.357059,0.2713549 0.44021,0.6005396 0.327712,1.0053479 -0.09783,0.3603238 -0.15652,0.7295444 -0.224997,1.0987651 -0.04402,0.2446643 -0.01957,0.2802523 0.244561,0.2491133 0.782596,-0.08897 1.570083,-0.1779382 2.347787,-0.2847008 0.591838,-0.080072 1.178785,-0.2046283 1.770623,-0.2847003 0.572273,-0.075624 1.076069,0.097866 1.535844,0.4003598 0.04402,0.026691 0.07826,0.066726 0.112498,0.1023143 0.132063,0.146799 0.102716,0.275803 -0.09783,0.315839 -0.503797,0.106763 -1.002701,0.222422 -1.516279,0.289149 -1.188567,0.151247 -2.382026,0.271355 -3.570593,0.40036 -0.234779,0.02669 -0.474449,0.04893 -0.709228,0.06228 -0.107606,0.0044 -0.141844,0.04004 -0.141844,0.137902 0.0049,0.774029 0.0049,1.548058 0,2.322086 0,0.09787 0.02934,0.133454 0.146736,0.120108 1.041831,-0.08452 2.088552,-0.146798 3.125491,-0.253561 1.178785,-0.120108 2.352678,-0.289149 3.531464,-0.422602 0.498904,-0.05783 1.007591,-0.120108 1.506496,-0.111211 0.748356,0.01335 1.389107,0.311391 1.927142,0.774029 0.102715,0.08897 0.166301,0.217974 0.220104,0.34253 0.04402,0.102314 -0.01957,0.177938 -0.141845,0.195732 -0.122281,0.01779 -0.249452,0.03559 -0.371733,0.03559 -1.364651,0.0089 -2.724411,0.0089 -4.089062,0.02669 -1.354869,0.01779 -2.709737,0.04448 -4.069497,0.08452 -0.572274,0.01779 -1.139655,0.07118 -1.707038,0.102314 -0.136954,0.0089 -0.176083,0.05783 -0.180975,0.177938 -0.02446,0.929724 -0.04402,1.859449 -0.08804,2.789173 -0.04402,0.983106 -0.08315,1.966211 -0.176084,2.949317 -0.06848,0.693957 -0.215214,1.379017 -0.342385,2.064077 -0.02934,0.151247 -0.112498,0.298046 -0.195649,0.431499 -0.08315,0.129005 -0.205432,0.129005 -0.303256,0.0089 -0.06847,-0.08897 -0.136954,-0.20018 -0.146737,-0.302494 -0.04891,-0.54271 -0.09783,-1.089868 -0.107606,-1.632578 -0.02446,-1.396811 -0.02446,-2.793622 -0.04891,-4.185984 -0.0098,-0.627231 -0.05381,-1.254461 -0.09293,-1.877243 -0.01468,-0.262458 -0.03424,-0.2847 -0.317929,-0.266906 -0.670098,0.03559 -1.3401955,0.07118 -2.0054018,0.146798 -0.8950937,0.106763 -1.7852963,0.244665 -2.6754989,0.382566 -0.7581395,0.120108 -1.516279,0.271355 -2.2744186,0.395912 -0.4597749,0.07562 -0.9244411,0.08007 -1.3646511,-0.09787 C 1.9195498,15.326405 1.5527081,15.166261 1.1956489,14.997221 1.112498,14.957185 1.0635859,14.859319 0.99999994,14.783695 1.0880419,14.730314 1.176084,14.645794 1.2739084,14.628 c 0.3277119,-0.05783 0.6554239,-0.106763 0.988027,-0.129005 0.7092273,-0.04893 1.4233459,-0.06673 2.1374644,-0.115659 1.0565041,-0.07118 2.108117,-0.155696 3.15973,-0.244665 0.8853113,-0.08007 1.7706226,-0.177937 2.6559342,-0.266906 0.171193,-0.01779 0.342385,-0.04004 0.508687,-0.08452 0.07337,-0.02224 0.166301,-0.09342 0.185866,-0.160143 0.05381,-0.209077 0.09783,-0.427051 0.102716,-0.640576 0.0098,-0.471535 -0.0049,-0.938621 -0.01468,-1.410156 -0.0049,-0.151247 -0.08315,-0.222422 -0.264126,-0.209077 -0.7581402,0.04448 -1.5162797,0.08897 -2.2793104,0.120108 -0.7092274,0.03114 -1.4282371,0.124556 -2.1276819,-0.04893 C 6.028173,11.367301 5.7493733,11.220497 5.4656824,11.100389 5.426553,11.064799 5.3972053,11.006969 5.3189457,10.9269 Z M 12.499265,5.4820032 c 0.07826,-0.1156594 0.146737,-0.2402158 0.229887,-0.3514269 0.474449,-0.6272303 0.978245,-1.2366668 1.428237,-1.8772425 0.332604,-0.4759833 0.606512,-0.9875541 0.885311,-1.4946765 0.08315,-0.1556955 0.112499,-0.3380816 0.146737,-0.5115708 0.03424,-0.1823862 0.112499,-0.26245811 0.322821,-0.2446643 0.146737,0.013345 0.293474,0.044484 0.430428,0.093417 0.484231,0.1645924 0.953788,0.3647723 1.340195,0.6895085 0.07336,0.062278 0.132063,0.1379017 0.180975,0.2179737 0.07336,0.1156595 0.03913,0.2268705 -0.07336,0.3024941 -1.408673,0.9386212 -2.685281,2.0373864 -4.172214,2.8736935 -0.195648,0.111211 -0.40108,0.2046283 -0.606511,0.3069425 -0.02445,0.013345 -0.04891,0.013345 -0.07337,0.022242 -0.01468,-0.0089 -0.02445,-0.017794 -0.03913,-0.026691 z",
"chien":
"m 17.882553,12.225084 c -0.278445,0.340211 -0.552005,0.659803 -0.815794,0.989704 -0.405455,0.505162 -0.71321,1.077335 -0.977,1.675281 -0.02443,0.05155 0,0.154642 0.03908,0.206189 0.131895,0.170105 0.288215,0.314437 0.42011,0.484542 0.1954,0.247426 0.13678,0.396913 -0.16609,0.432996 -0.258905,0.03093 -0.522695,0.02062 -0.7816,0.05155 -0.801139,0.09794 -1.602279,0.201034 -2.403419,0.309283 -0.08304,0.01031 -0.161205,0.04124 -0.24425,0.06186 -0.21494,0.05155 -0.34195,0.18557 -0.356605,0.427841 -0.0049,0.07217 -0.0098,0.159796 -0.04397,0.216498 -0.06839,0.103094 -0.151435,0.237117 -0.244249,0.257735 -0.0977,0.02062 -0.249135,-0.06186 -0.31264,-0.149486 -0.0977,-0.134023 -0.17586,-0.304128 -0.210055,-0.469079 -0.17586,-0.819599 -0.327295,-1.639198 -0.503155,-2.458796 -0.10747,-0.520626 -0.229595,-1.036097 -0.366375,-1.546413 -0.05373,-0.206189 -0.17586,-0.396913 -0.258905,-0.592792 -0.131895,-0.309283 -0.02931,-0.469079 0.288215,-0.417532 0.26379,0.04124 0.51781,0.139178 0.776715,0.18557 0.683899,0.123713 1.353144,0.01031 1.997964,-0.216498 0.42011,-0.144332 0.835335,-0.324747 1.235904,-0.530935 0.3908,-0.201034 0.75229,-0.226807 1.157745,-0.05155 0.620395,0.26289 1.196824,0.582482 1.680439,1.07218 0.02442,0.01031 0.05373,0.03093 0.08793,0.06186 z m -3.209443,0.329902 c -0.376145,0.05155 -0.79137,0.123713 -1.21148,0.170105 -0.34195,0.03608 -0.688785,0.04124 -1.030735,0.07217 -0.214939,0.02062 -0.254019,0.08248 -0.224709,0.283509 0.0635,0.489697 0.122125,0.979395 0.190514,1.469092 0.04885,0.319592 0.10747,0.639184 0.17586,0.953622 0.01954,0.103094 0.07328,0.201033 0.210055,0.170105 0.64482,-0.139177 1.28964,-0.268045 1.93446,-0.407222 0.04885,-0.01031 0.112354,-0.07732 0.122124,-0.128868 0.122125,-0.680421 0.239365,-1.365998 0.34195,-2.051574 0.07328,-0.458769 -0.02442,-0.556709 -0.508039,-0.530935 z M 14.306735,7.3899662 c 0.552004,0.1030942 1.084469,0.067011 1.616934,-0.041238 1.255445,-0.2474261 2.486464,-0.6031011 3.702829,-1.0103232 0.376144,-0.123713 0.737634,-0.123713 1.084469,0.067011 0.571545,0.3144373 1.147975,0.6237199 1.704864,0.9690854 0.190515,0.1185584 0.34195,0.3247468 0.493385,0.5051616 0.10747,0.1288678 0.112355,0.2938185 0.02443,0.4381504 -0.12701,0.2164978 -0.25402,0.4381503 -0.41034,0.6340293 -0.22471,0.2783544 -0.337065,0.587637 -0.327295,0.9433119 0.02443,0.8092894 0.05373,1.6185784 0.07816,2.4227134 0.04397,1.453628 -0.0098,2.907256 -0.127009,4.35573 -0.09282,1.123727 -0.1954,2.247453 -0.52758,3.329943 -0.28333,0.912383 -0.70344,1.742292 -1.40688,2.376321 -0.210055,0.190724 -0.44942,0.35052 -0.683899,0.500007 -0.27356,0.17526 -0.415225,0.154641 -0.630165,-0.09278 -0.571545,-0.659803 -1.14309,-1.324761 -1.699979,-2.000028 -0.239365,-0.288663 -0.44942,-0.597946 -0.67413,-0.902074 -0.04397,-0.0567 -0.07327,-0.123713 -0.131895,-0.221652 0.112355,-0.0052 0.190515,-0.02062 0.268675,-0.01546 0.654589,0.08247 1.309179,0.16495 1.963769,0.247426 0.06839,0.01031 0.141665,0.01031 0.210055,0.02577 0.454305,0.103094 0.727865,-0.139177 0.933034,-0.530935 0.30287,-0.582482 0.434765,-1.216512 0.52758,-1.86085 0.20517,-1.402081 0.25402,-2.819627 0.258905,-4.237172 0.0049,-1.036097 0.01466,-2.067039 -0.01465,-3.103135 -0.01466,-0.530935 -0.07816,-1.0618701 -0.17586,-1.5824959 -0.11724,-0.6288746 -0.45919,-0.9123836 -1.069814,-0.9020742 -0.42988,0.010309 -0.864645,0.072166 -1.28964,0.1443319 -1.328719,0.2268072 -2.667209,0.3350561 -4.010583,0.2938184 -0.180745,-0.00515 -0.307755,0.056702 -0.43965,0.1804149 -0.679015,0.6288746 -1.358029,1.2525945 -2.051699,1.8660049 -0.14655,0.128867 -0.33218,0.216498 -0.50804,0.309282 -0.05374,0.03093 -0.131895,0.01546 -0.200285,0.02062 0.01465,-0.06701 0.0098,-0.149486 0.03908,-0.201034 0.28333,-0.4690777 0.56666,-0.9433111 0.864645,-1.3969255 1.025849,-1.5670319 1.939344,-3.1959202 2.549969,-4.994914 0.249135,-0.7319689 0.41034,-1.4794018 0.42011,-2.257763 0,-0.097939 0.01954,-0.2010337 0.0342,-0.2989732 0.04397,-0.2628902 0.205169,-0.41753151 0.454304,-0.355675 0.70344,0.1701054 1.2701,0.5721728 1.68044,1.2062022 0.1954,0.3041278 0.112355,0.603101 -0.06351,0.8969195 -0.630165,1.0618703 -1.25056,2.1288952 -1.870955,3.1959202 -0.180744,0.3092826 -0.356604,0.6185652 -0.537349,0.9330025 -0.01465,0.041238 -0.03419,0.08763 -0.05862,0.1443319 z M 7.7364124,12.415808 c -0.3907998,0.427841 -0.7815997,0.855682 -1.1723995,1.283523 -0.8792997,0.958776 -1.8367593,1.819613 -2.9554238,2.458797 -0.7376347,0.422686 -1.5143494,0.747433 -2.339914,0.933002 -0.07816,0.01546 -0.15632,0.01546 -0.23448,0.02062 -0.00977,-0.01546 -0.01954,-0.03093 -0.02931,-0.05155 0.053735,-0.06186 0.0977,-0.128868 0.1612049,-0.17526 C 1.5373499,16.606588 1.9232648,16.343697 2.2847546,16.049879 3.4571542,15.085948 4.4830037,13.962221 5.4600033,12.792102 6.0901681,12.039515 6.6665978,11.245689 7.1990626,10.410626 7.6533674,9.6992763 7.7119874,8.9312245 7.6240574,8.1270897 7.6142875,8.0239955 7.5752075,7.926056 7.5361275,7.7920336 7.3407276,7.9209013 7.1697526,8.0239955 7.0134327,8.1373991 5.7384482,9.0446281 4.3413388,9.6786574 2.8709544,10.137427 c -0.112355,0.03608 -0.2295949,0.04124 -0.3419499,0.06186 -0.00977,-0.02062 -0.01954,-0.04124 -0.034195,-0.06186 0.083045,-0.06701 0.161205,-0.1443323 0.2491349,-0.2061888 C 3.3008342,9.5394803 3.877264,9.1734958 4.4194988,8.761119 5.3036834,8.085852 6.168328,7.3796568 7.0427427,6.6889256 7.1502126,6.6064503 7.1111327,6.5445937 7.0525127,6.4569637 6.5444729,5.6940666 5.8801132,5.0961202 5.1962134,4.5187927 4.8689186,4.2404384 4.5416237,3.9569293 4.2192138,3.6734203 c -0.05862,-0.051547 -0.0977,-0.1134036 -0.1514349,-0.1701055 0.00488,-0.020619 0.00977,-0.041238 0.014655,-0.061857 0.1465499,0 0.3028699,-0.030928 0.4396498,0.00515 0.7229797,0.1907243 1.3677995,0.5721728 1.9784242,1.0051685 0.2979849,0.2113431 0.5617748,0.479388 0.8402197,0.7216594 0.1074699,0.092785 0.2002849,0.195879 0.3077548,0.283509 0.14655,0.1185584 0.2393649,0.1082489 0.3517199,-0.041238 C 8.4545071,4.7971471 8.806227,4.12188 8.9576619,3.358983 c 0.092815,-0.4484598 0.0977,-0.9175384 0.1416649,-1.3763076 0.024425,-0.2371167 0.083045,-0.2938185 0.3077549,-0.2989732 0.6838993,-0.00515 1.2163643,0.3350562 1.6755543,0.8299083 0.307755,0.3350562 0.297985,0.3711391 0.02931,0.7422783 -0.84999,1.1495003 -1.6999793,2.3041553 -2.5499689,3.4536557 -0.073275,0.097939 -0.07816,0.1752601 -0.043965,0.283509 0.2393649,0.7525877 0.5080398,1.5000206 0.5422348,2.3041554 0.024425,0.6082558 0.04885,1.2165111 0.053735,1.8247671 0.00488,1.185584 0.014655,2.371167 -0.014655,3.55675 -0.02931,1.376308 -0.092815,2.752615 -0.3468348,4.113459 -0.2442499,1.309296 -0.8255647,2.402095 -1.7781393,3.278395 -0.1025849,0.09794 -0.1709749,0.09794 -0.2686749,0 C 6.0950531,21.421087 5.4795433,20.776748 4.8738036,20.1221 4.6442087,19.874674 4.4341538,19.611784 4.2143288,19.359203 c -0.03908,-0.04124 -0.06839,-0.09278 -0.07816,-0.18557 0.3614898,0.0567 0.7229797,0.128868 1.0844695,0.170106 0.3468349,0.04124 0.6985547,0.07732 1.0453896,0.06701 0.4787298,-0.01031 0.7669447,-0.257736 0.8744146,-0.752588 0.122125,-0.572173 0.229595,-1.154655 0.2882149,-1.737137 0.131895,-1.381462 0.2247099,-2.773234 0.3370649,-4.154696 0.00977,-0.108249 0.014655,-0.216498 0.01954,-0.324747 -0.01954,-0.01546 -0.034195,-0.02062 -0.04885,-0.02577 z",
"cochon":
"M 10.597221,8.2442413 C 9.8637895,9.2937776 9.1169414,10.309143 8.2538176,11.221995 8.048099,11.441666 7.8513247,11.675981 7.6679667,11.915177 c -0.12522,0.165974 -0.1028593,0.209908 0.076027,0.288013 0.5992673,0.263604 1.2030067,0.512564 1.7888576,0.810339 0.2683286,0.136684 0.5008807,0.375881 0.7289597,0.585788 0.362244,0.331946 0.371188,0.78105 0.29069,1.239917 -0.08944,0.527209 -0.281745,0.62484 -0.6752946,0.292894 -0.3667158,-0.31242 -0.6976545,-0.673656 -1.0420096,-1.020247 -0.3354108,-0.336828 -0.6618773,-0.6883 -0.9928159,-1.03001 -0.044721,-0.04881 -0.1028593,-0.0781 -0.1788858,-0.136684 0,0.06346 -0.00894,0.09763 0,0.126921 0.2951615,1.020247 0.4203815,2.069783 0.4785194,3.129083 0.044721,0.854273 0.067082,1.708547 0.058138,2.562821 -0.013416,1.15693 -0.1967744,2.27969 -0.7960416,3.270648 -0.1475808,0.239196 -0.3130501,0.46863 -0.496408,0.678537 C 6.7511772,22.893815 6.6393736,22.903578 6.46496,22.742486 6.1116606,22.415422 5.7628334,22.083475 5.4453112,21.72224 5.1143725,21.346359 4.819211,20.936308 4.5106331,20.536019 4.4524952,20.462796 4.4077738,20.374928 4.3272752,20.243126 c 0.1341643,0.03417 0.2236072,0.0537 0.3085779,0.08299 0.3219944,0.102513 0.6395166,0.224552 0.9659831,0.31242 0.4472144,0.117158 0.7244873,-0.02929 0.8631238,-0.507682 0.1296922,-0.449104 0.2459679,-0.912853 0.2862172,-1.381483 0.080499,-0.849392 0.1028593,-1.703666 0.1475808,-2.557939 0.017889,-0.361236 0.035777,-0.722472 0.049194,-1.083708 0,-0.03417 -0.00447,-0.06834 -0.013416,-0.146447 -0.058138,0.06346 -0.093915,0.09763 -0.1207479,0.141566 -0.7692087,1.054418 -1.6189161,2.035612 -2.5446499,2.928938 -0.8810124,0.849392 -1.8604119,1.537693 -2.9963365,1.928218 -0.080499,0.02929 -0.1654693,0.04882 -0.2459679,0.07322 C 1.0178886,20.018574 1.0089443,20.003929 1,19.994166 1.0581379,19.925824 1.1162758,19.852601 1.1788858,19.78914 1.8720681,19.095958 2.583139,18.422302 3.2539606,17.699831 4.2109994,16.669821 5.1009561,15.571469 5.8209713,14.321788 5.9819685,14.043539 6.1116606,13.740882 6.245825,13.443107 6.4291829,13.037937 6.371045,12.64253 6.2145199,12.242242 6.0490506,11.822428 6.0624671,11.817546 5.7583613,12.129966 c -0.5724345,0.59067 -1.1269803,1.205747 -1.7262476,1.762245 -0.6126838,0.585788 -1.3103382,1.073944 -2.0974356,1.386364 -0.1118036,0.04393 -0.2325515,0.06346 -0.3488272,0.09275 -0.013416,-0.01953 -0.022361,-0.03905 -0.035777,-0.05858 C 1.7513202,15.068668 1.9480946,14.819708 2.1538132,14.580511 2.8872448,13.736001 3.638565,12.911016 4.3496359,12.04698 4.631381,11.70527 4.850516,11.285456 5.0562346,10.880286 5.2306483,10.538576 5.0607068,9.9625518 4.7521289,9.7721708 4.6447974,9.7087105 4.4838002,9.6940658 4.3675245,9.7282368 4.2154716,9.7721708 4.0678908,9.8746837 3.9381987,9.9771965 3.4239021,10.377485 2.8648841,10.685023 2.2745611,10.933983 c -0.080499,0.03417 -0.1609972,0.04882 -0.2683287,0.03417 0.1744137,-0.209907 0.339883,-0.424696 0.5187687,-0.629722 C 3.1332127,9.6306055 3.763785,8.9374234 4.354108,8.2100704 4.8460439,7.6047564 5.284314,6.9506269 5.5660591,6.1939844 5.6152527,6.0621822 5.6420855,5.9206168 5.6689184,5.7839331 5.6957512,5.6472493 5.6420855,5.5593811 5.5123933,5.5593811 c -0.344355,0 -0.6931823,0 -1.0375374,0.019526 C 4.1439173,5.5984336 3.8040343,5.6423677 3.4909843,5.5056839 3.2986821,5.4226973 3.1242684,5.281132 2.9677434,5.134685 2.8380512,5.0126459 2.8648841,4.9247778 3.0348256,4.8808437 3.3791807,4.788094 3.7235357,4.7197521 4.0678908,4.6416471 4.8952375,4.4561476 5.7270563,4.2852929 6.5499307,4.0851488 7.2118081,3.9240572 7.8602689,3.7092684 8.5221463,3.5579399 c 0.2906893,-0.06346 0.6037394,-0.043934 0.903373,-0.029289 0.2996337,0.00976 0.5187687,0.2147888 0.7200157,0.4442223 0.09391,0.112276 0.09391,0.2294335 -0.02236,0.2977754 C 9.9219273,4.3878058 9.7162087,4.5049633 9.5015458,4.5684236 8.8665013,4.7636862 8.2225126,4.9296594 7.5785239,5.1102772 7.4756646,5.1395666 7.3683331,5.1737376 7.2699459,5.2176716 7.1313095,5.281132 7.1223652,5.3445923 7.2162802,5.471513 7.3191395,5.6179599 7.426471,5.7595252 7.5248581,5.9059722 7.5919403,6.0036034 7.582996,6.1012347 7.5069696,6.1939844 7.0150337,6.770009 6.5230979,7.3509151 6.0266899,7.9220581 5.6778627,8.3223463 5.3200911,8.7079899 4.9578475,9.098515 c -0.098387,0.1073944 -0.071554,0.1562101 0.026833,0.2294335 0.5098245,0.3612358 0.992816,0.7517605 1.3774204,1.2692065 0.1744136,0.234315 0.3398829,0.478393 0.5098244,0.71759 0.035777,0.04882 0.084971,0.09275 0.1207479,0.141565 0.098387,0.12204 0.1744136,0.102513 0.2593844,-0.02441 C 7.7305768,10.724076 8.1241254,9.9576703 8.481897,9.1717385 8.7055042,8.6835821 8.8665013,8.180781 8.8754456,7.6291642 8.8799178,7.4290201 8.9514721,7.3899676 9.13483,7.4436648 c 0.1296922,0.039053 0.2638565,0.06346 0.3980208,0.087868 0.2728008,0.053697 0.4874632,0.2245519 0.7021262,0.4002882 0.116276,0.097631 0.237024,0.2050257 0.362244,0.3124203 z M 8.9201671,18.217277 c 0.071554,-0.08787 0.1341643,-0.190381 0.219135,-0.268486 0.5142966,-0.453986 1.0554259,-0.883564 1.5563059,-1.352194 1.618916,-1.527929 3.161806,-3.138845 4.552643,-4.915735 0.107331,-0.136683 0.192302,-0.288012 0.277273,-0.43934 0.01789,-0.03417 0.01342,-0.08787 0.01789,-0.131803 -0.03578,-0.0049 -0.07155,-0.01953 -0.107331,-0.0098 -0.643989,0.131802 -1.287978,0.263605 -1.931966,0.395407 -0.66635,0.131802 -1.332699,0.278249 -1.999049,0.390525 -0.585851,0.09763 -1.086731,-0.151328 -1.5473615,-0.517446 -0.058138,-0.04881 -0.1028593,-0.122039 -0.1833579,-0.229433 0.2817454,-0.06346 0.5098244,-0.122039 0.7423754,-0.165973 1.118036,-0.214789 2.2316,-0.43446 3.349636,-0.624841 0.196775,-0.03417 0.25044,-0.107394 0.25044,-0.288012 0,-0.7224714 0,-1.4449428 0,-2.1869406 -0.192302,0 -0.389076,0.00976 -0.581378,0 -0.482992,-0.024408 -0.961511,-0.06346 -1.444503,-0.097631 -0.0313,0 -0.06261,-0.014645 -0.09391,-0.029289 -0.12522,-0.043934 -0.241496,-0.1171576 -0.241496,-0.2733676 0,-0.1610916 0.138637,-0.1854994 0.245968,-0.2099073 0.389077,-0.078105 0.778153,-0.1415653 1.16723,-0.2147888 0.210191,-0.039053 0.415909,-0.09275 0.621628,-0.1318022 0.178886,-0.034171 0.268329,-0.1513285 0.272801,-0.3368279 0.01789,-0.5809061 0.04025,-1.1618122 0.04025,-1.7427184 0,-0.3905251 -0.01789,-0.7810502 -0.04025,-1.1715753 -0.04025,-0.6541296 -0.0805,-1.3131407 -0.138637,-1.9672703 -0.01789,-0.2147888 -0.08944,-0.4246961 -0.147581,-0.6883005 0.518769,0.082987 1.019649,0.1220391 1.498169,0.2587229 0.652933,0.190381 0.697654,0.5906692 0.639516,1.1813384 -0.07603,0.7761687 -0.156525,1.5523374 -0.219135,2.3333876 -0.03578,0.4491039 -0.04472,0.8982078 -0.06708,1.3521933 -0.0045,0.06346 0,0.1269206 0,0.2050257 0.335411,-0.078105 0.648461,-0.1610917 0.965983,-0.2294336 0.366716,-0.082986 0.742376,-0.1610916 1.109092,-0.048816 0.196774,0.06346 0.37566,0.2050257 0.559018,0.3124201 0.06261,0.034171 0.116276,0.078105 0.196774,0.1318022 0.147581,-0.380762 0.31305,-0.727353 0.424854,-1.0934703 0.143109,-0.4783933 0.241496,-0.9665497 0.362244,-1.4547061 0.01342,-0.058579 0.02236,-0.1171575 0.04025,-0.1708547 0.0805,-0.2294335 0.210191,-0.2928939 0.406965,-0.1708548 0.143109,0.082987 0.277273,0.190381 0.398021,0.3075386 0.326466,0.3124201 0.643989,0.6346033 0.970455,0.9616681 -1.046482,1.4400614 -1.976688,2.9484646 -2.830867,4.5154467 0.01342,0.019526 0.02683,0.034171 0.03578,0.053697 0.174414,-0.029289 0.348827,-0.058579 0.523241,-0.09275 0.715543,-0.146447 1.426614,-0.3075386 2.142157,-0.4344592 0.75132,-0.1366838 1.413197,0.029289 1.914077,0.7175899 0.245968,0.3368279 0.205719,0.5125641 -0.18783,0.5906691 -0.263856,0.04882 -0.541129,0.0537 -0.809458,0.0781 -0.979399,0.07811 -1.958799,0.151329 -2.938198,0.234316 -0.482992,0.03905 -0.961511,0.09763 -1.440031,0.15621 -0.07603,0.0098 -0.169941,0.0537 -0.219135,0.112276 -0.863123,1.054417 -1.717303,2.113717 -2.571482,3.173016 -0.138637,0.170855 -0.268329,0.346591 -0.393549,0.522327 -0.05367,0.07322 -0.08497,0.161092 -0.129692,0.239197 0.0089,0.01953 0.01342,0.03905 0.02236,0.05858 0.214663,-0.01953 0.433798,-0.02441 0.648461,-0.06834 1.019649,-0.205026 2.039298,-0.40517 3.050002,-0.644366 0.809459,-0.190381 1.457919,0.112276 2.052715,0.659011 0.192302,0.180618 0.25044,0.419814 0.165469,0.678537 -0.169942,0.517446 -0.165469,1.064181 -0.178886,1.596272 -0.0313,1.127641 -0.02236,2.255282 -0.05367,3.382923 -0.01342,0.517446 -0.05367,1.044655 -0.152052,1.552338 -0.05814,0.297775 -0.22808,0.585787 -0.402493,0.839629 -0.192303,0.28313 -0.433798,0.248959 -0.60374,-0.0537 -0.111803,-0.195263 -0.18783,-0.414933 -0.272801,-0.624841 -0.03578,-0.09275 -0.07603,-0.136683 -0.178885,-0.131802 -0.867596,0.04882 -1.735192,0.08299 -2.602788,0.136684 -0.491936,0.02929 -0.983872,0.06834 -1.475808,0.117157 -0.263856,0.02929 -0.523241,0.07322 -0.720015,0.317302 -0.09839,0.122039 -0.25044,0.102513 -0.321994,-0.03905 -0.107332,-0.214789 -0.214663,-0.439341 -0.263857,-0.678538 -0.143108,-0.654129 -0.08944,-1.318022 0.0045,-1.977033 0.05367,-0.356354 0.09839,-0.71759 0.107332,-1.078826 0.01789,-0.805458 0.01789,-1.610916 0.01342,-2.416374 -0.0045,-0.346591 -0.05814,-0.370999 -0.326466,-0.170855 -0.491936,0.366117 -0.974928,0.761524 -1.475808,1.112997 -0.576906,0.40517 -1.176174,0.766405 -1.8469953,0.951905 -0.1207478,0.03417 -0.25044,0.02441 -0.37566,0.03417 -0.026833,-0.03417 -0.035777,-0.06346 -0.049194,-0.08787 z m 9.5122499,0.248959 c -0.06708,0.0098 -0.116275,0.01465 -0.165469,0.01953 -0.912317,0.102512 -1.824635,0.209907 -2.741424,0.302657 -0.442743,0.04393 -0.889957,0.06834 -1.332699,0.102512 -0.223607,0.01465 -0.219135,0.01465 -0.223607,0.253842 -0.0089,0.361235 -0.01342,0.722471 -0.04025,1.083707 -0.02236,0.317302 -0.07603,0.634603 -0.107331,0.951905 -0.02236,0.224552 0.02683,0.258723 0.228079,0.234315 0.41591,-0.0537 0.831819,-0.117158 1.247728,-0.131802 0.85418,-0.03417 1.708359,-0.04393 2.558067,-0.06346 0.18783,-0.0049 0.37566,0 0.576906,0 0,-0.93726 0,-1.835468 0,-2.753202 z m 0.0313,-0.634603 c 0.0089,-0.01953 0.01789,-0.02929 0.01789,-0.03905 -0.08497,-0.829865 -0.165469,-1.659731 -0.254912,-2.489597 -0.01342,-0.126921 -0.08944,-0.209907 -0.201247,-0.219671 -0.245968,-0.01953 -0.496408,-0.04881 -0.746848,-0.03905 -1.037537,0.04882 -2.039297,0.322183 -3.054474,0.527209 -0.09839,0.01953 -0.09839,0.08299 -0.09839,0.165973 -0.0045,0.71759 0.02683,1.43518 -0.116276,2.143007 -0.03131,0.146447 0.04472,0.244078 0.183358,0.258723 0.138636,0.01464 0.286217,0.02441 0.420381,0 0.612684,-0.09275 1.220896,-0.209908 1.838052,-0.297776 0.639516,-0.09275 1.283505,-0.21967 1.923021,-0.01953 0.0313,0.0049 0.06261,0.0049 0.08944,0.0098 z m -3.09919,-7.859318 c 0.14758,0 0.277272,0 0.406965,0 0.384604,0 0.715543,-0.1415654 0.934678,-0.4832749 0.491936,-0.7664055 0.961511,-1.5474558 1.435558,-2.328506 0.04472,-0.068342 0.07155,-0.1513285 0.111804,-0.2489598 -0.05367,0 -0.0805,-0.00488 -0.107332,0 -0.809458,0.2147889 -1.623388,0.4295777 -2.432846,0.6541296 -0.04919,0.014645 -0.111804,0.097631 -0.116276,0.1610916 -0.05814,0.4735117 -0.107331,0.951905 -0.156525,1.4302983 -0.0313,0.2636044 -0.04919,0.5272089 -0.07603,0.8152212 z",
"coq":
"M 7.2080579,4.698068 C 7.6705092,4.7390855 8.1189468,4.8262478 8.5160009,5.097989 8.9597673,5.4056205 9.0064796,5.8516862 8.6374528,6.2618615 8.2544123,6.6874185 8.1563166,6.7028 7.7966323,6.24648 7.4883314,5.8568134 7.2080579,5.4415108 6.9464693,5.0210811 6.7829765,4.7647215 6.8343599,4.698068 7.1239759,4.698068 c 0.028027,-0.00513 0.056055,0 0.084082,0 z M 3.6766118,5.4876555 C 4.1904466,5.5491818 4.7556648,5.6824888 5.2928557,5.9337212 5.8907725,6.2157168 6.0075531,6.8566158 5.568458,7.3847166 5.5170745,7.4462429 5.465691,7.4975148 5.4049651,7.5487867 5.1807463,7.7487472 5.0592944,7.7590016 4.8257332,7.5744227 4.2278164,7.102721 3.78405,6.487458 3.4383794,5.7850327 3.3169275,5.5440547 3.3636398,5.4825284 3.6766118,5.4876555 Z M 12.63135,4.9800635 C 12.56128,5.1031161 12.519241,5.2312959 12.435159,5.3030766 12.224954,5.4774012 12.005406,5.6568529 11.767174,5.7799055 11.043134,6.1490633 10.309751,6.4977124 9.576369,6.8463614 9.4736021,6.8925064 9.3381365,6.8719974 9.2213559,6.8771244 9.2727399,6.7643262 9.3101089,6.6310192 9.3801776,6.5336025 9.7445331,6.0260105 10.136916,5.5440545 10.482587,5.0210809 10.711477,4.677559 10.870298,4.277638 11.071161,3.9084802 c 0.135466,-0.2461052 0.158822,-0.2512324 0.369027,-0.087162 0.322314,0.2512325 0.639958,0.5127192 0.948258,0.7895876 0.102767,0.082035 0.158822,0.2307237 0.242904,0.3691577 z M 4.9285001,4.7031952 C 4.8537605,4.6929408 4.760336,4.6929408 4.676254,4.6570504 4.6108568,4.6314145 4.5688158,4.5545066 4.5127611,4.4981075 4.573487,4.4519628 4.6248705,4.3801821 4.6949389,4.3596733 4.9144865,4.2878926 5.1527189,4.2622567 5.3629241,4.16484 6.4933605,3.6264848 7.5257012,2.9138052 8.4459326,2.0114194 8.6047542,1.8524764 8.7495622,1.6781519 8.7775895,1.4217923 8.7916032,1.2782309 8.8990414,1.1910686 9.0204932,1.2115774 9.2120135,1.2372134 9.4175474,1.2679765 9.5903827,1.3551388 9.9780944,1.5448449 10.286395,1.8473492 10.4966,2.2575246 10.655422,2.5702833 10.580682,2.8215157 10.281724,2.9496955 9.3007667,3.3598709 8.3244807,3.7751734 7.334181,4.1545856 6.5961275,4.4365812 5.8347178,4.6365417 5.049952,4.698068 c -0.03737,0 -0.070068,0 -0.1214519,0.00513 z M 16.877494,4.2007304 c 0.705355,0.061526 1.396696,0.1794517 2.036654,0.5383551 0.284945,0.158943 0.532519,0.374285 0.527848,0.7793332 -0.0093,0.6357718 -0.499821,1.1536182 -1.022998,1.04082 C 18.222807,6.5182211 18.003259,6.4054229 17.872465,6.2516072 17.391328,5.687616 16.93822,5.097989 16.485111,4.5083619 16.33096,4.3032742 16.373001,4.2263663 16.620576,4.2058575 c 0.08408,-0.010254 0.168164,-0.00513 0.256918,-0.00513 z M 14.088772,18.182583 c -0.01401,0.579373 -0.01401,1.107473 -0.03737,1.635574 -0.02803,0.758825 -0.05606,1.517649 -0.107439,2.276473 -0.01401,0.199961 -0.07941,0.405049 -0.158821,0.589628 -0.158822,0.369157 -0.476465,0.420429 -0.728711,0.123052 -0.289616,-0.348649 -0.369027,-0.789587 -0.406397,-1.24078 -0.04204,-0.538356 0.0327,-1.066456 0.107438,-1.599684 0.0654,-0.461448 0.126123,-0.922895 0.154151,-1.389469 0.07007,-1.092092 0.130794,-2.189311 0.168164,-3.281403 0.04204,-1.286925 0.0654,-2.578978 0.07941,-3.87103 0.0093,-0.615263 -0.01401,-1.230526 -0.0327,-1.8509164 -0.0093,-0.2717412 -0.116781,-0.3332675 -0.312972,-0.1743246 -0.289616,0.2307237 -0.560547,0.4870833 -0.845492,0.722934 -0.149479,0.123053 -0.317643,0.225597 -0.476465,0.338395 -0.01401,-0.01538 -0.02803,-0.02564 -0.04204,-0.04102 0.01869,-0.07691 0.02336,-0.153816 0.05606,-0.220469 0.294287,-0.6101359 0.597917,-1.2151445 0.896875,-1.8252804 0.752067,-1.522776 1.429395,-3.0865695 1.863819,-4.7580341 0.15415,-0.5896271 0.238232,-1.1895086 0.252246,-1.8047716 0.0047,-0.2050877 0.04204,-0.4101754 0.08408,-0.6101359 0.02803,-0.133307 0.121452,-0.23072361 0.252246,-0.1845789 0.667985,0.2204693 1.233204,0.5947543 1.564861,1.3023068 0.08408,0.1743245 0.0654,0.3435219 -0.01868,0.5178464 -0.453109,0.9382761 -0.892204,1.8868066 -1.354656,2.8250828 -0.336328,0.6819165 -0.705354,1.3535787 -1.055696,2.0252408 -0.04204,0.082035 -0.0981,0.1640702 -0.107439,0.2512324 -0.01401,0.1076711 -0.02803,0.266614 0.02803,0.3332675 0.252246,0.2922499 0.261588,0.6562806 0.284945,1.015184 0.02336,0.3896666 0.01868,0.7844602 0.01868,1.1741272 -0.0047,2.261091 -0.0093,4.52731 -0.01868,6.788402 0,0.12818 -0.01401,0.25636 -0.02336,0.42043 0.196192,-0.03076 0.369027,-0.0564 0.546534,-0.08716 0.72404,-0.123052 1.443408,-0.251232 2.167448,-0.379412 0.07007,-0.01025 0.140137,-0.04102 0.214876,-0.06665 0.200863,-0.07178 0.317644,-0.220469 0.322315,-0.451193 0.0047,-0.543482 0,-1.081838 0,-1.645829 -0.238232,-0.02051 -0.467122,-0.03076 -0.696013,-0.0564 -0.392382,-0.04614 -0.789437,-0.09742 -1.181819,-0.158943 -0.116781,-0.02051 -0.233562,-0.06665 -0.336329,-0.133307 -0.06073,-0.03589 -0.09342,-0.123052 -0.140136,-0.189706 0.05605,-0.04614 0.107438,-0.117925 0.168164,-0.133307 0.373698,-0.08204 0.747396,-0.153816 1.121094,-0.215342 0.397054,-0.06665 0.798779,-0.112798 1.233203,-0.174325 -0.02336,-0.481956 -0.02803,-0.94853 -0.07474,-1.40485 -0.03737,-0.32814 -0.233562,-0.451193 -0.639958,-0.476829 -0.401726,-0.02564 -0.803451,-0.04102 -1.205176,-0.09229 -0.154151,-0.02051 -0.30363,-0.102544 -0.443767,-0.174325 -0.04204,-0.02051 -0.08875,-0.102544 -0.08875,-0.158943 0,-0.04102 0.06073,-0.107671 0.107438,-0.117925 0.30363,-0.07691 0.607259,-0.148689 0.910889,-0.215342 0.308301,-0.06665 0.616602,-0.107671 0.920231,-0.179452 0.270931,-0.06665 0.345671,-0.174325 0.345671,-0.471702 0,-0.522973 -0.15415,-0.994675 -0.462451,-1.3894688 -0.182185,-0.2358528 -0.462459,-0.24098 -0.719376,-0.2819976 -0.289616,-0.046145 -0.583903,-0.092289 -0.873519,-0.1589429 -0.345671,-0.082035 -0.635287,-0.2819956 -0.929574,-0.5434824 0.485808,-0.056399 0.938916,-0.107671 1.392025,-0.1589429 1.279916,-0.1538158 2.559832,-0.3127587 3.807049,-0.6819166 0.355013,-0.1025438 0.710026,-0.2204692 1.074381,-0.2922499 0.168165,-0.030763 0.364356,0.00513 0.527849,0.061526 0.205534,0.071781 0.401725,0.1794517 0.583903,0.2973771 0.233561,0.1538158 0.22889,0.3332675 -0.01869,0.4460657 -0.289616,0.133307 -0.597917,0.2409781 -0.906218,0.3127588 -0.68667,0.1589429 -1.382682,0.2819955 -2.074023,0.4255569 -0.107439,0.020509 -0.214877,0.066654 -0.317644,0.1025438 -0.0047,0.020509 -0.0047,0.03589 -0.0093,0.056399 0.06073,0.041018 0.121452,0.087162 0.186849,0.1230527 0.308301,0.1589429 0.355013,0.2307236 0.326986,0.6101358 -0.02336,0.3025043 -0.0654,0.6050093 -0.0981,0.9075133 -0.0093,0.07691 -0.01401,0.158943 -0.02336,0.25636 0.312972,-0.03589 0.61193,-0.07691 0.910889,-0.102544 0.359684,-0.03076 0.714697,0.0051 1.046354,0.184579 0.130794,0.07178 0.238232,0.174324 0.219548,0.36403 -0.01868,0.184579 -0.135466,0.261487 -0.270932,0.29225 -0.527848,0.123053 -1.055696,0.240978 -1.588216,0.338395 -0.462451,0.08716 -0.462451,0.07178 -0.462451,0.589627 0,0.348649 0,0.697298 0,1.045947 0,0.06665 0.0047,0.133307 0.0093,0.215342 0.383041,-0.04102 0.752067,-0.102544 1.116423,-0.107671 0.294287,0 0.593246,0.07178 0.887533,0.117926 0.06073,0.01025 0.11678,0.04614 0.172835,0.08203 0.126123,0.08716 0.252246,0.194833 0.22889,0.384539 -0.01869,0.179452 -0.177507,0.205088 -0.294287,0.230724 -0.434424,0.09229 -0.868848,0.169197 -1.307943,0.251232 -0.30363,0.05127 -0.607259,0.09742 -0.929574,0.148689 0,0.687044 0,1.363833 0,2.061131 0.04204,-0.01025 0.0981,-0.02051 0.144808,-0.03589 0.644629,-0.22047 1.293929,-0.425557 1.980599,-0.430684 0.56989,-0.0051 1.139779,0.02564 1.667628,0.281995 0.182178,0.08716 0.364355,0.235851 0.490478,0.410175 0.168165,0.230724 0.08408,0.466575 -0.172835,0.54861 -0.214876,0.07178 -0.439095,0.12818 -0.663314,0.148689 -0.653971,0.0564 -1.312614,0.08203 -1.971257,0.133307 -1.284587,0.107671 -2.569174,0.220469 -3.85376,0.338394 -0.392383,0.03589 -0.784766,0.123053 -1.177149,0.174325 -0.252246,0.03589 -0.49515,-0.0051 -0.719369,-0.153816 -0.07474,-0.04614 -0.149479,-0.06153 -0.26626,-0.107671 z M 5.4610198,10.502049 C 5.320883,10.286707 5.1620614,10.071365 5.0312671,9.8406416 4.905144,9.6150451 4.9611987,9.425339 5.1620614,9.2817776 5.2601571,9.2099969 5.3722665,9.158725 5.4797047,9.1023259 6.068279,8.78444 6.544744,8.3178655 6.8857434,7.7026025 6.9464693,7.5898043 6.9791679,7.4513701 6.9978528,7.3180631 7.0352226,7.020686 7.1847018,6.8719974 7.4509616,6.9437781 7.623797,6.9899228 7.7966323,7.0668307 7.9414403,7.1796289 8.1516454,7.3385719 8.3384944,7.5436595 8.5440283,7.7333656 8.0115086,8.2050673 7.4930027,8.6613874 6.9371269,9.1535978 c 0.084082,0.015382 0.1214518,0.025636 0.1541504,0.025636 0.3970541,-0.00513 0.7941083,-0.00513 1.1911624,-0.025636 0.5418621,-0.025636 0.831478,-0.2717412 0.9622723,-0.8459867 0.1588217,-0.7024253 0.4951499,-0.6562805 0.896875,-0.3999209 0.22889,0.1486885 0.439095,0.3332674 0.635287,0.5281007 0.242904,0.2461053 0.214876,0.4563201 -0.07007,0.6460262 -0.57456,0.3794122 -1.1631346,0.7280613 -1.7236816,1.1331099 -0.6773276,0.49221 -1.3266279,1.025438 -1.9852706,1.543284 -0.046712,0.03589 -0.093425,0.08204 -0.1214518,0.169198 0.2475749,-0.04102 0.4951498,-0.07178 0.7427247,-0.117926 0.5698895,-0.107671 1.1397789,-0.215342 1.7096684,-0.32814 0.00467,0 0.00934,0 0.018685,0 0.3456706,-0.107671 0.4110678,-0.174325 0.1821778,-0.487083 -0.023356,-0.03076 -0.046712,-0.06153 -0.056055,-0.09229 -0.028027,-0.112798 -0.051384,-0.230723 -0.07474,-0.348649 0.1121094,-0.02564 0.22889,-0.08204 0.3363282,-0.06665 0.3830399,0.0564 0.7193679,0.261487 1.0416829,0.481956 0.130794,0.08716 0.252246,0.189706 0.369027,0.297377 0.359684,0.333267 0.298958,1.122855 -0.116781,1.36896 -0.09342,0.0564 -0.26626,0.06665 -0.345671,0.0051 -0.196191,-0.148688 -0.373698,-0.338394 -0.532519,-0.538355 -0.0981,-0.123052 -0.1728352,-0.174324 -0.3269857,-0.12818 -0.5371908,0.153816 -1.0790529,0.287123 -1.6162438,0.440939 -0.1074382,0.03076 -0.1961914,0.12818 -0.2896159,0.19996 0.088753,0.06153 0.1728353,0.143562 0.270931,0.189707 0.331657,0.148688 0.4437664,0.440938 0.3176433,0.861368 -0.056055,0.184579 -0.1167806,0.36403 -0.186849,0.5845 0.1401368,-0.02564 0.2569174,-0.04614 0.3643556,-0.07178 0.6212729,-0.133307 1.2425458,-0.29225 1.8731605,-0.394794 0.270931,-0.04615 0.565219,-0.0051 0.840821,0.05127 0.224219,0.04615 0.397054,0.235851 0.513835,0.461447 0.112109,0.215342 0.06072,0.369158 -0.158822,0.410176 -0.658643,0.117925 -1.321957,0.220469 -1.9852703,0.32814 C 9.4082033,15.095992 9.048519,15.152387 8.6935059,15.224168 8.329152,15.301101 8.1049332,15.542079 8.0161799,15.942 7.8153172,16.839259 7.5070164,17.6955 7.1333184,18.526105 6.5727714,19.772012 5.6945811,20.587236 4.489405,20.992284 4.1203782,21.115337 3.742009,21.115337 3.3449549,21.079446 5.1387053,19.725868 6.4840181,18.018513 6.9885104,15.572842 6.4840181,15.706149 6.0215668,15.81382 5.5637868,15.947127 4.7323087,16.193232 3.9008307,16.444465 3.0740238,16.705952 2.6536136,16.839259 2.2518882,16.81875 1.8781902,16.567517 1.6259441,16.39832 1.3830404,16.218868 1.1494791,16.024035 1.0747395,15.962509 1.0467122,15.839456 0.99999993,15.747167 1.084082,15.711276 1.168164,15.654877 1.2569173,15.639496 1.8081219,15.557461 2.3593264,15.495934 2.910531,15.408772 3.7093104,15.285719 4.5034187,15.15754 5.2975269,15.008851 5.8580739,14.906307 6.4092785,14.773 6.9651543,14.655075 7.1006198,14.629439 7.1753594,14.578167 7.1566745,14.403842 7.1239759,14.070575 7.1193047,13.73218 7.0819349,13.398913 7.0679212,13.270733 7.0165377,13.14768 6.9698255,13.029755 6.918442,12.906702 6.83436,12.85543 6.7082369,12.91183 6.1757172,13.163062 5.6385264,13.398913 5.1106779,13.655272 4.9611987,13.727053 4.8771167,13.742435 4.779021,13.573237 4.6248705,13.316878 4.4520352,13.081027 4.2838711,12.834922 4.1904466,12.696487 4.2231452,12.593944 4.3539395,12.517036 4.4240079,12.476018 4.489405,12.424746 4.5641446,12.388856 5.5778004,11.891518 6.4513195,11.153203 7.3295098,10.425141 7.5724135,10.220054 7.810646,10.009839 8.0488785,9.7944968 8.0769058,9.7688609 8.1002619,9.7380977 8.1563166,9.6714442 7.2033867,9.8406416 6.3485526,10.189291 5.4610198,10.502049 Z m 5.0075532,8.987968 c -0.186849,0 -0.336328,-0.09742 -0.439095,-0.251233 C 9.8286152,18.946535 9.6324237,18.64403 9.4642596,18.331272 9.1699725,17.787789 8.889699,17.228925 8.6140967,16.670061 8.558042,16.557263 8.5253434,16.429083 8.4973161,16.300903 c -0.023356,-0.128179 0.028027,-0.210214 0.1588216,-0.189706 0.079411,0.01026 0.1588217,0.03076 0.22889,0.06153 0.6352866,0.287122 1.2285323,0.646026 1.7517093,1.138236 0.415739,0.38454 0.583903,1.112601 0.406397,1.656083 -0.102767,0.328141 -0.317644,0.517847 -0.574561,0.522974 z",
"dragon":
"M 5.7218028,8.8923087 C 5.4313908,7.826197 5.1501983,6.7947959 4.8690059,5.7584362 4.8321282,5.6146351 4.8090796,5.4658753 4.7906407,5.3171155 4.7583727,5.1088519 4.6800076,4.9997614 4.4863997,5.00472 3.9793312,5.0146373 3.6105542,4.7319938 3.2325577,4.365053 4.7030562,4.1072027 6.1597255,3.913815 7.6348337,3.5270396 7.2891052,3.1055536 6.9572058,2.7435715 6.6714036,2.3419201 6.3856014,1.9353101 6.1458964,1.4939894 5.878533,1.0526688 5.92924,1.0229168 5.947679,1.0080408 5.966118,1.0030818 6.7912567,0.9733298 7.5702982,1.1568002 8.2663648,1.6477075 8.5659962,1.8559711 8.7088973,2.148532 8.6766293,2.5353074 8.6581903,2.788199 8.6443613,3.036132 8.6259223,3.3138169 8.9578216,3.2096851 9.2758918,3.1253879 9.5847426,3.0113387 10.114859,2.8080337 10.598879,2.9072069 11.05985,3.2146437 c 0.0461,0.029752 0.09219,0.069421 0.133682,0.1090905 0.152121,0.1537184 0.15673,0.3272715 -0.02766,0.4314033 C 10.903118,3.9038973 10.617316,4.0179465 10.336123,4.127037 10.124077,4.211334 9.898201,4.2658794 9.6446668,4.345218 9.930469,4.6179442 10.193222,4.8658772 10.465195,5.1286861 9.9903953,6.1501698 9.5202046,7.1716536 9.0454041,8.1931373 c 0.013829,0.014876 0.023049,0.029752 0.036878,0.044628 0.2627537,-0.049587 0.5255073,-0.089256 0.7836512,-0.1438011 0.5024587,-0.099173 1.0095277,-0.1636358 1.5212057,-0.1190078 0.31807,0.029752 0.617702,0.1041318 0.838968,0.391734 0.15212,0.1983464 0.138291,0.2826436 -0.101414,0.3421475 C 11.834282,8.7782595 11.54387,8.8328048 11.248849,8.872474 9.7092045,9.0807377 8.1787798,9.3435466 6.6621842,9.6906528 5.5466337,9.9435444 4.4264734,10.206353 3.3063131,10.43941 2.955975,10.51379 2.5964173,10.543542 2.2368597,10.563377 1.8173758,10.583211 1.4532085,10.389824 1.1213092,10.127015 0.94614009,9.9881723 0.95996923,9.8542885 1.1674063,9.77495 1.4439891,9.6708181 1.734401,9.5815623 2.0248129,9.5319757 3.0297304,9.3485053 4.0392575,9.1898282 5.0441749,9.0162751 5.2746606,8.9865232 5.4913171,8.9369366 5.7218028,8.8923087 Z m 0.80209,-0.1338838 C 7.0309613,8.6443757 7.4919326,8.5402439 7.9529039,8.4460294 8.2018284,8.3964428 8.3309003,8.2377657 8.3769974,7.9848741 8.5106791,7.2906618 8.6674094,6.6014082 8.7780425,5.8972786 8.8379687,5.5154619 8.8149202,5.1187692 8.8241396,4.7270351 8.8287493,4.568358 8.7503842,4.4939781 8.5982637,4.5187714 8.5521665,4.5286887 8.5106791,4.5286887 8.464582,4.5386061 7.6440531,4.6675312 6.8235242,4.7964563 6.0029953,4.9204228 5.7310222,4.9600921 5.4590491,4.9997614 5.1870761,5.0394306 5.1732471,5.0543066 5.1640271,5.0691826 5.1501981,5.0840586 6.293407,6.0063691 6.694452,7.2509925 6.5238928,8.7584249 Z M 13.63668,16.102199 c 0.31807,-0.04463 0.613092,-0.0843 0.912723,-0.133884 0.829748,-0.133884 1.659497,-0.287602 2.489245,-0.40661 0.562385,-0.07934 1.12938,-0.128925 1.687155,0.02479 0.15673,0.04463 0.313461,0.133884 0.437923,0.247933 0.142901,0.128925 0.115243,0.238016 -0.06454,0.29752 -0.147511,0.04959 -0.304241,0.0843 -0.456362,0.104132 -0.806699,0.10909 -1.613399,0.213222 -2.420099,0.312395 -0.81131,0.09917 -1.627229,0.188429 -2.438538,0.277685 -0.133682,0.01488 -0.16595,0.06942 -0.15673,0.203305 0.01383,0.357024 0.01383,0.709088 0.02305,1.066112 0.0046,0.09421 0.02305,0.193387 0.03688,0.287602 0.02305,0.14876 0.09219,0.203305 0.248924,0.178512 0.885065,-0.143801 1.77013,-0.292561 2.659805,-0.416528 0.534726,-0.07438 1.069453,-0.128925 1.60418,-0.158677 0.345728,-0.01983 0.677628,0.09422 0.977259,0.277685 0.05993,0.03967 0.142901,0.128925 0.133682,0.183471 -0.01383,0.06942 -0.09219,0.158677 -0.16134,0.173553 -0.235096,0.0595 -0.470191,0.10909 -0.709896,0.138842 -1.511986,0.188429 -3.028582,0.3719 -4.540567,0.55537 -0.341119,0.03967 -0.350339,0.07934 -0.147511,0.386775 0.359557,0.545453 0.811309,0.976856 1.405962,1.21983 0.437923,0.178512 0.894285,0.208264 1.355256,0.208264 0.774432,0 1.548863,0.01488 2.318686,-0.01984 1.097111,-0.04463 1.866933,-0.634708 2.267978,-1.725613 0.198218,-0.535535 0.308851,-1.105781 0.470191,-1.656192 0.03227,-0.10909 0.101414,-0.198346 0.15673,-0.29752 0.05532,0.09422 0.133682,0.183471 0.16595,0.287603 0.06915,0.223139 0.124462,0.451238 0.170559,0.679336 0.175169,0.867765 0.47941,1.680985 0.875846,2.454536 0.06915,0.138843 0.05071,0.22314 -0.03227,0.347106 -0.511678,0.798344 -1.2815,1.145451 -2.102029,1.393383 -1.28611,0.391735 -2.604488,0.476032 -3.932085,0.357024 -0.935772,-0.0843 -1.853105,-0.282644 -2.696683,-0.753716 -0.613091,-0.342148 -1.152428,-0.788427 -1.424401,-1.497515 -0.119852,-0.312396 -0.212047,-0.659502 -0.221266,-0.991732 -0.03227,-1.195037 -0.02766,-2.385115 -0.03688,-3.580152 -0.0092,-1.507432 -0.0092,-3.014865 -0.02766,-4.522297 -0.0046,-0.297519 -0.09219,-0.59008 -0.142901,-0.8876 0,-0.0099 -0.0092,-0.02479 -0.0092,-0.03471 -0.02305,-0.153719 -0.07836,-0.317355 0.0461,-0.44628 0.129072,-0.133884 0.290412,-0.07934 0.428704,-0.02479 0.230485,0.08926 0.451752,0.213222 0.686847,0.29752 0.414874,0.148759 0.843578,0.10909 1.267671,0.03967 0.908114,-0.143801 1.811617,-0.312396 2.719731,-0.466114 0.08758,-0.01488 0.142901,-0.03967 0.15673,-0.1487599 0.06915,-0.684295 0.142901,-1.3636313 0.212047,-2.0479262 0.0046,-0.044628 -0.0046,-0.094214 -0.0046,-0.1338838 -1.12938,-0.059504 -2.203443,0.1636357 -3.254457,0.5603285 C 14.355822,8.3914806 14.134556,8.4559427 13.90868,8.5055293 13.327829,8.6245411 12.802322,7.9848741 12.98671,7.374959 13.106563,6.9782663 13.272513,6.5964496 13.346268,6.1947982 13.507608,5.3617435 13.47995,4.5187714 13.378536,3.6757994 13.304781,3.0460497 13.14805,2.4510106 12.866858,1.8906822 c -0.05532,-0.1090905 -0.09219,-0.233057 -0.133682,-0.3520648 -0.08758,-0.2429743 -0.02305,-0.3917341 0.216657,-0.4264447 0.202827,-0.029752 0.419484,-0.049587 0.613092,0 0.31346,0.07438 0.622311,0.188429 0.921942,0.3173542 0.212047,0.089256 0.32268,0.2925609 0.308851,0.5355351 -0.03688,0.5404939 -0.101414,1.076029 -0.147511,1.6165229 -0.01383,0.1785117 -0.02305,0.3570234 -0.03227,0.5752044 0.401045,-0.1090905 0.769822,-0.203305 1.13399,-0.3123955 0.737554,-0.218181 1.475108,-0.451238 2.212662,-0.669419 0.719115,-0.2132223 1.346036,0.019835 1.913031,0.4958659 0.03688,0.029752 0.06454,0.064463 0.09219,0.1041319 0.110633,0.1685944 0.07836,0.2876022 -0.110633,0.3272715 -0.451752,0.094214 -0.903504,0.188429 -1.355256,0.2528916 -0.96804,0.1388424 -1.936079,0.2628089 -2.899509,0.3867754 -0.290412,0.034711 -0.580824,0.059504 -0.871236,0.084297 -0.175169,0.014876 -0.262754,0.1239665 -0.267363,0.3074368 -0.01844,0.5256179 -0.04149,1.0462771 -0.05993,1.5718949 -0.0046,0.084297 0,0.1636358 0,0.2925609 0.368777,-0.024793 0.728335,-0.019835 1.074063,-0.07438 0.792871,-0.1289251 1.576522,-0.2925608 2.364783,-0.4413206 0.562385,-0.1041318 1.106331,-0.049587 1.61801,0.2280983 0.07837,0.044628 0.15673,0.094215 0.230485,0.1487598 0.239705,0.1933877 0.285802,0.436362 0.16595,0.7289229 -0.276583,0.6892536 -0.543946,1.3834658 -0.815919,2.0776781 -0.03227,0.084297 -0.05071,0.173553 -0.07376,0.2578502 -0.05993,0.2181816 0,0.3966926 0.142901,0.5603286 0.08758,0.09917 0.152121,0.228099 0.253535,0.381817 -0.248925,0.04463 -0.447143,0.0843 -0.640751,0.10909 -1.341426,0.173554 -2.682853,0.342148 -4.024279,0.515701 -0.4748,0.0595 -0.48863,0.0595 -0.590043,0.550411 -0.08759,0.436362 -0.138292,0.877683 -0.212047,1.314045 -0.02305,0.138842 0.03227,0.173553 0.147511,0.158677 0.530117,-0.0843 1.064843,-0.163636 1.59496,-0.25785 0.797481,-0.143802 1.585742,-0.317355 2.397051,-0.317355 0.207437,0 0.410265,0.03967 0.613092,0.0843 0.0968,0.01983 0.193608,0.06446 0.271973,0.128925 0.07375,0.0595 0.124462,0.158677 0.188998,0.238015 -0.07837,0.05455 -0.15212,0.143801 -0.239705,0.163636 -0.566994,0.119008 -1.133989,0.228098 -1.700984,0.322313 -0.931162,0.153718 -1.862324,0.292561 -2.793486,0.441321 -0.03688,0.005 -0.07836,0.01488 -0.115243,0.02975 -0.520897,0.163635 -0.626921,0.312395 -0.64075,0.897517 0.01383,0.262809 0.01844,0.540494 0.01844,0.857848 z m -6.8223753,4.408248 c 0.290412,0.02975 0.5485559,0.0595 0.8066998,0.07438 0.3365091,0.01488 0.6730181,0.01488 1.0095272,0.02479 0.1889982,0.005 0.3180702,-0.09421 0.3641673,-0.282644 0.078365,-0.317354 0.1797788,-0.639667 0.1982176,-0.966938 0.055317,-0.937187 0.073755,-1.879332 0.1014137,-2.816518 0.00922,-0.242975 0,-0.490908 0,-0.768593 C 8.994699,16.052609 8.7181162,16.325336 8.4277043,16.573268 7.8468805,17.074093 7.2568372,17.565 6.6806231,18.065825 6.3856014,18.318716 6.1136284,18.264171 5.8416553,18.045985 5.7402416,17.961685 5.6434376,17.867473 5.542024,17.783176 5.3438063,17.604665 5.2930995,17.629458 5.2101246,17.887308 c -0.1613399,0.535535 -0.304241,1.085946 -0.5116781,1.601647 -0.4471422,1.105781 -1.0464049,2.102471 -1.9637378,2.841312 -0.1060234,0.08926 -0.2258759,0.163635 -0.336509,0.242974 -0.018439,-0.01488 -0.036878,-0.02975 -0.055317,-0.03967 0.036878,-0.119008 0.064536,-0.247933 0.1152429,-0.361983 0.2996313,-0.684294 0.6038724,-1.368589 0.9127231,-2.052884 0.562385,-1.2595 0.8205289,-2.608255 0.96343,-3.986762 0.1152429,-1.090905 0.1843886,-2.186769 0.1106332,-3.282632 -0.023049,-0.3719 -0.078365,-0.728923 -0.2719731,-1.066112 -0.1014137,-0.178512 -0.092194,-0.436362 -0.096804,-0.659502 -0.00461,-0.143801 0.1198526,-0.153718 0.225876,-0.133884 0.1797788,0.03471 0.3641673,0.07934 0.5439461,0.109091 0.6730181,0.10909 1.332207,-0.005 1.9821766,-0.158677 0.8251386,-0.198347 1.6410578,-0.426445 2.4661964,-0.62975 0.087585,-0.01983 0.2028274,0 0.2765828,0.04959 0.3226799,0.218181 0.6407503,0.44132 0.9496013,0.684295 0.276583,0.213222 0.373387,0.525618 0.271973,0.867765 -0.304241,1.03636 -0.276583,2.10743 -0.295022,3.173542 -0.02766,1.591729 -0.01844,3.183459 -0.04149,4.775188 -0.0092,0.515701 -0.03688,1.03636 -0.115243,1.547102 -0.07836,0.495866 -0.331899,0.917352 -0.6269212,1.304127 C 9.557084,22.915396 9.3588663,22.955066 9.1376001,22.801347 8.8702367,22.617877 8.6167025,22.404654 8.3816072,22.171597 7.8653193,21.660856 7.3674703,21.130279 6.8604019,20.60962 6.8557919,20.58483 6.8465729,20.56003 6.8143049,20.51045 Z M 5.477488,16.974923 C 5.8324359,16.880708 6.1643352,16.845998 6.4593568,16.712114 7.3766897,16.300545 8.2801935,15.854266 9.1929166,15.422863 9.29894,15.373276 9.3450372,15.318731 9.3358178,15.179888 9.2620623,14.153446 9.1975264,13.127003 9.123771,12.095602 9.0961127, 11.723703 9.0407961,11.674116 8.6904579,11.649323 c -0.7006763,-0.04959 -1.3875236,0.02975 -2.0697611,0.188429 -0.1982177,0.04959 -0.3964353,0.123967 -0.5854336,0.208264 -0.1659496,0.07438 -0.2350953,0.242974 -0.239705,0.421486 -0.00461,0.173553 0.1336816,0.238015 0.2581439,0.297519 0.1198525,0.05455 0.2443148,0.09421 0.3641673,0.128925 0.5024587,0.143802 1.0049175,0.29752 1.4520596,0.590081 0.5808239,0.381817 0.5854336,0.614874 0.4563616,1.274375 -0.059926,0.29752 -0.2581439,0.401652 -0.5070684,0.262809 C 7.6117851,14.907162 7.4089577,14.763361 7.2383983,14.599725 6.8004756,14.178239 6.3809917,13.73196 5.9522884,13.300557 c -0.064536,-0.06446 -0.1429011,-0.11405 -0.2166565,-0.173554 -0.018439,0.005 -0.036878,0.01488 -0.055317,0.01984 -0.059926,1.259499 -0.1290719,2.51404 -0.2028273,3.828085 z",
"lapin":
"m 15.135511,15.10823 c 0.174574,0.01943 0.349148,0.01943 0.518734,0.05828 0.753163,0.174852 1.466423,0.441985 2.119829,0.854828 0.638442,0.403129 0.82798,1.408524 0.688321,1.894221 -0.109733,0.378845 -0.423966,0.534268 -0.803041,0.407986 -0.304258,-0.101996 -0.533698,-0.301132 -0.738199,-0.52941 -0.613504,-0.694548 -1.157177,-1.437665 -1.626034,-2.23421 -0.07482,-0.126281 -0.124695,-0.262276 -0.189537,-0.393415 0.005,-0.01457 0.01496,-0.034 0.02993,-0.05828 z m 6.598902,1.874793 c 0.06484,0.203993 0.139659,0.407986 0.194525,0.616836 0.174574,0.67512 0.319221,1.355096 0.513747,2.025359 0.11472,0.393415 0.309245,0.767403 0.45888,1.151104 0.164599,0.412843 0.139659,0.539124 -0.204501,0.8354 -0.753163,0.650835 -1.631021,1.049107 -2.633575,1.189959 -1.157177,0.16028 -2.319342,0.199136 -3.481507,0.169994 -1.147201,-0.02914 -2.264476,-0.228278 -3.301945,-0.733403 -0.638442,-0.310847 -1.177128,-0.738261 -1.47141,-1.389096 -0.11472,-0.252562 -0.18455,-0.543981 -0.194526,-0.815972 -0.03491,-1.063678 -0.03491,-2.122499 -0.05985,-3.186177 -0.01995,-0.859685 -0.05985,-1.719369 -0.09976,-2.583911 -0.005,-0.121425 -0.05487,-0.237992 -0.09477,-0.35456 -0.07981,-0.223421 0.01,-0.36913 0.249392,-0.36913 0.568612,0.0049 0.997566,0.296276 1.416544,0.645978 0.314233,0.262277 0.354136,0.52941 0.244404,0.917969 -0.204502,0.709118 -0.364112,1.432808 -0.468857,2.156497 -0.104744,0.718833 -0.119708,1.44738 0.02494,2.166212 0.169586,0.845114 0.703284,1.379382 1.546227,1.583375 0.55365,0.135995 1.127251,0.218564 1.695863,0.276847 0.847932,0.08743 1.695863,0.07771 2.533819,-0.08257 0.728223,-0.135996 1.401581,-0.378844 1.890388,-0.966539 0.379076,-0.456556 0.573601,-0.99568 0.718248,-1.554232 0.11472,-0.451699 0.214477,-0.908255 0.324209,-1.359954 0.02993,-0.116567 0.07981,-0.228278 0.124696,-0.344845 0.02494,0.0049 0.04988,0.0049 0.07482,0.0049 z m -4.977857,-4.395564 c -0.199513,0.02914 -0.334185,0.05828 -0.468856,0.07285 -1.446471,0.131139 -2.892943,0.262277 -4.339414,0.398272 -0.234428,0.02428 -0.463868,0.07286 -0.693309,0.121425 -0.339172,0.07285 -0.558637,0.281704 -0.68832,0.597408 -0.249392,0.611979 -0.468857,1.243386 -0.7781016,1.826223 -1.167153,2.224496 -2.872991,3.948723 -5.1823584,5.075541 -1.017517,0.495412 -2.104865,0.806258 -3.222139,1.010251 -0.11472,0.01943 -0.234428,0.0049 -0.349148,0.0049 -0.01,-0.01943 -0.02494,-0.04371 -0.03491,-0.06314 0.07981,-0.068 0.149635,-0.155424 0.239416,-0.199136 0.379075,-0.179708 0.773114,-0.335132 1.147201,-0.524554 1.117274,-0.568266 2.199634,-1.199673 3.187225,-1.976789 1.3965934,-1.102534 2.4340624,-2.462488 3.1523104,-4.055576 0.184549,-0.403129 0.339172,-0.820829 0.488807,-1.238529 0.07482,-0.199136 0.03491,-0.247706 -0.189538,-0.233135 -0.658393,0.03886 -1.316787,0.09228 -1.970193,0.145709 -0.09976,0.0097 -0.204501,0.034 -0.29927,0.07771 -0.06484,0.02914 -0.139659,0.09228 -0.149635,0.155423 -0.02993,0.165137 -0.09477,0.281705 -0.2743314,0.305989 -0.15961,0.01939 -0.349148,-0.08261 -0.41399,-0.257456 C 5.813253,13.568568 5.708508,13.301434 5.638679,13.029443 5.434178,12.223185 5.264591,11.407213 5.050115,10.605812 4.935394,10.173541 4.770796,9.7558409 4.606197,9.3381408 4.521404,9.1292908 4.366782,8.9592966 4.147317,8.8573001 4.057536,8.8135871 4.00267,8.7115908 3.93284,8.6387362 c 0.01,-0.019428 0.02494,-0.043713 0.03491,-0.063141 0.124696,-0.014571 0.249392,-0.038856 0.3691,-0.033999 0.543673,0.019428 1.092335,0.082569 1.631021,0.063141 C 6.6911064,8.5755952 7.4143424,8.4881699 8.1375784,8.4153152 8.5166534,8.3764592 8.8907404,8.2938908 9.2698154,8.250178 9.8733434,8.18218 10.322248,7.8713338 10.701323,7.4293489 11.439522,6.564807 12.11288,5.6565523 12.716407,4.6997278 c 0.05487,-0.092283 0.109733,-0.1845651 0.149635,-0.2817047 0.05985,-0.1408523 0.01496,-0.2282779 -0.144647,-0.2234209 -0.254379,0.00486 -0.508759,0.029142 -0.75815,0.053427 C 11.379668,4.3111702 10.80108,4.3985955 10.212516,4.4471653 9.6838054,4.4908773 9.2199374,4.6414441 8.8308864,5.0008604 8.1325904,5.6468383 7.4043664,6.2685314 6.5913504,6.778514 6.356922,6.9242233 6.10753,7.0505047 5.863126,7.1767861 5.803276,7.2059281 5.728455,7.2107851 5.663613,7.2302131 5.653613,7.2156421 5.638673,7.2010711 5.628703,7.1913571 5.703523,7.0845036 5.768362,6.9679362 5.853155,6.8659397 6.37189,6.2491036 6.9205524,5.6565524 7.4093594,5.0154314 c 0.693309,-0.9131117 1.296836,-1.8845071 1.65596,-2.9773269 0.07981,-0.2379919 0.119708,-0.4905547 0.174574,-0.7382605 0.06484,-0.2914186 0.159611,-0.35455932 0.443917,-0.2574198 0.4090026,0.1408524 0.7781016,0.3545593 1.0823596,0.6605489 0.199513,0.203993 0.22944,0.3594163 0.08479,0.6071221 C 10.711301,2.5578011 10.531739,2.786079 10.377116,3.0240708 10.25242,3.2183499 10.1377,3.422343 10.017992,3.626336 c 0.01496,0.019428 0.03491,0.038856 0.04988,0.058284 0.224453,-0.043713 0.448905,-0.072855 0.66837,-0.1262814 1.162165,-0.2817047 2.279439,-0.6848337 3.38175,-1.1316756 0.05985,-0.024285 0.149635,-0.043713 0.204501,-0.019428 0.473844,0.2234209 0.957664,0.4274139 1.411557,0.6896907 0.41399,0.2428488 0.428953,0.3205605 0.06983,0.6605489 -0.493795,0.4614128 -1.037469,0.8742558 -1.526276,1.3405256 -0.78309,0.7479745 -1.546228,1.5202338 -2.314354,2.2827792 -0.07981,0.077712 -0.149635,0.1699942 -0.209489,0.2671337 -0.02993,0.04857 -0.03491,0.1165675 -0.04988,0.1748512 0.06983,0.014571 0.13966,0.053427 0.204501,0.04857 0.239416,-0.014571 0.48382,-0.033999 0.723236,-0.072855 1.08236,-0.1748511 2.159731,-0.3399884 3.237103,-0.5391244 0.578589,-0.1068535 1.102311,-0.024285 1.586131,0.2671337 0.359124,0.213707 0.703284,0.4614128 1.027493,0.7236896 0.274331,0.2282779 0.259367,0.4662698 -0.02494,0.6848338 -0.917761,0.7236895 -1.476398,1.709656 -2.054987,2.676194 -0.129684,0.223421 -0.134671,0.432271 0.06983,0.62655 0.09477,0.07771 0.164598,0.194279 0.284306,0.349703 z m -5.52153,-3.9778647 c 0.07981,0.092283 0.119708,0.1602802 0.174574,0.20885 0.154623,0.1408523 0.319222,0.2671337 0.478832,0.4079861 0.219465,0.1894221 0.234428,0.2622767 0.09477,0.5196965 -0.384063,0.6945481 -0.623479,1.4425221 -0.847931,2.1953541 -0.07482,0.247705 -0.04489,0.276847 0.224452,0.247705 0.339173,-0.03885 0.673357,-0.07285 1.007542,-0.135995 0.738199,-0.131138 1.47141,-0.276848 2.20961,-0.422557 0.07981,-0.01457 0.184549,-0.08742 0.214476,-0.16028 0.359124,-0.854828 0.708273,-1.7145131 1.042457,-2.579055 0.104745,-0.2719908 -0.01,-0.4614129 -0.304257,-0.5294105 -0.239416,-0.053427 -0.493796,-0.09714 -0.733212,-0.082569 -0.947688,0.063141 -1.895376,0.1457093 -2.843064,0.2282779 -0.22944,0.019428 -0.448905,0.063141 -0.718248,0.1019965 z M 9.8883124,10.634954 C 9.8334424,10.144399 9.8035224,9.7121281 9.7287014,9.2798571 9.6638614,8.891299 9.6139814,8.8621571 9.2249304,8.9350118 8.3121574,9.100149 7.3943964,9.2750001 6.4866104,9.4595653 6.102547,9.5372773 6.102547,9.5518473 6.172377,9.935549 c 0.15961,0.879113 0.3242094,1.763083 0.4838194,2.642196 0.01496,0.09228 0.05487,0.121424 0.13966,0.11171 0.144647,-0.01457 0.289294,-0.01943 0.433941,-0.034 0.698297,-0.07771 1.391605,-0.165137 2.089902,-0.242849 0.209489,-0.02429 0.34416,-0.121424 0.374087,-0.339988 0.06983,-0.490555 0.134672,-0.985966 0.194526,-1.437664 z",
"rat":
"m 6.2554909,15.480138 c 0.6533318,0 1.0483697,0.299611 1.1395323,0.866567 0.045581,0.295001 -0.1418085,0.502424 -0.4659421,0.525471 C 6.6302704,16.895223 6.3415889,16.835301 6.0984887,16.69241 5.71358,16.471159 5.3388005,16.222251 4.9842793,15.959515 4.7563728,15.793577 4.7816958,15.710608 5.0602481,15.650686 c 0.3899733,-0.08758 0.7900757,-0.142892 1.1851136,-0.212033 0.00506,0.01383 0.00506,0.02766 0.010129,0.04148 z m -0.075969,-2.784076 c 0.3849087,-0.01383 0.7444944,0.05992 1.0584989,0.276564 0.2886815,0.202813 0.405167,0.470158 0.3595857,0.797425 -0.025323,0.170548 -0.1570022,0.299611 -0.3545212,0.341096 -0.3140044,0.06914 -0.6128151,-0.0092 -0.896432,-0.119845 -0.526717,-0.202813 -0.9774653,-0.511643 -1.4028907,-0.857348 -0.1620668,-0.129063 -0.1519376,-0.216641 0.05571,-0.267345 0.3849086,-0.09219 0.7748819,-0.1475 1.1648552,-0.216641 0.010129,0.01383 0.015194,0.02766 0.015194,0.04609 z m 6.4573501,0.502424 c -0.18739,-0.04149 -0.384909,-0.07375 -0.567234,-0.129063 -0.531782,-0.165938 -1.017982,-0.414846 -1.463666,-0.728285 -0.07597,-0.05531 -0.162067,-0.161329 -0.151938,-0.225861 0.01013,-0.06453 0.136744,-0.138281 0.227907,-0.156719 0.653332,-0.161329 1.311728,-0.244298 1.980254,-0.0968 0.111421,0.02305 0.222842,0.06453 0.329198,0.110625 0.319069,0.147501 0.460877,0.405627 0.384909,0.6868 -0.09623,0.359533 -0.319069,0.520862 -0.73943,0.5393 z m -0.967337,1.387429 c 0.450749,0.02766 0.901497,0.02766 1.321858,0.193595 0.465942,0.179766 0.73943,0.691409 0.622944,1.138521 -0.05065,0.184376 -0.212712,0.322658 -0.425425,0.30422 -0.227907,-0.01844 -0.465942,-0.05531 -0.678655,-0.129063 -0.698913,-0.244298 -1.342116,-0.576175 -1.934673,-0.99563 -0.01519,-0.0092 -0.03545,-0.01844 -0.04052,-0.03227 -0.05065,-0.07836 -0.141809,-0.170548 -0.126615,-0.239688 0.02026,-0.06453 0.146873,-0.129064 0.238036,-0.142892 0.339327,-0.04148 0.683719,-0.06453 1.023046,-0.0968 z m -2.0460931,4.507991 c 0.5925571,-0.22586 1.1496611,-0.447112 1.7168951,-0.645316 0.476072,-0.165938 0.957207,-0.308829 1.443408,-0.45633 0.09623,-0.02766 0.202583,-0.01844 0.303875,-0.02766 0.01013,0.01844 0.02532,0.03226 0.03545,0.0507 -0.0709,0.07836 -0.126614,0.170548 -0.207648,0.23047 -0.440619,0.318048 -0.891367,0.631487 -1.337051,0.949536 -0.896432,0.626878 -1.7928643,1.258365 -2.6943609,1.880634 -0.2127127,0.147501 -0.4456838,0.281173 -0.6685257,0.414846 -0.1164855,0.07375 -0.2279064,0.06453 -0.3342628,-0.02305 -0.344392,-0.285783 -0.5874922,-0.636097 -0.7039777,-1.041724 -0.035452,-0.119844 0.020258,-0.271954 0.06584,-0.405627 0.030388,-0.08758 0.096227,-0.170548 0.1671314,-0.239689 0.4254254,-0.419455 0.5824277,-0.935707 0.6735903,-1.479616 0.1620668,-0.972583 0.1772605,-1.949776 0.1873897,-2.931578 0.00506,-0.691409 0.00506,-1.37821 -0.010129,-2.069619 C 8.2560031,13.037157 8.245874,12.769812 8.1749697,12.516295 8.1192593,12.304263 7.9774508,12.110668 7.8660299,11.917073 7.7647381,11.746526 7.6279942,11.589806 7.5368316,11.414649 7.4507337,11.25332 7.5064441,11.17957 7.6988985,11.138085 c 0.5621692,-0.119844 1.4737951,0.235079 1.7371536,0.700629 0.081034,0.1475 0.1215502,0.331876 0.1215502,0.502424 0.010129,1.355163 0,2.710326 0,4.065489 0,0.76516 0.00506,1.53493 0.010129,2.30009 -0.00506,0.129063 0.030388,0.253517 0.055711,0.387189 z m -5.8698575,0.331877 c 0.4760713,-0.165939 0.9065613,-0.322658 1.3471804,-0.465549 0.6229443,-0.202814 1.2509533,-0.396409 1.8789622,-0.594613 0.035452,-0.0092 0.075969,-0.02766 0.1063563,-0.01844 0.070904,0.01383 0.1671314,0.02305 0.1924544,0.06453 0.025323,0.04148 0.00506,0.142891 -0.035452,0.184376 -0.1823251,0.184376 -0.3646503,0.38258 -0.5824276,0.53469 -0.7191715,0.497815 -1.4636659,0.967974 -2.187902,1.461179 C 3.9511035,20.94688 3.4497093,21.32946 2.9381859,21.693603 2.8166358,21.781183 2.6849565,21.850322 2.5482127,21.910244 2.2038207,22.066964 1.90501,22.030089 1.646716,21.767353 1.459326,21.578372 1.2972592,21.366339 1.140257,21.149698 0.96299642,20.905399 0.95286725,20.638054 1.1149341,20.384537 1.2770009,20.140239 1.4390677,19.891332 1.6416512,19.6793 2.1025287,19.204532 2.320306,18.646794 2.3760165,18.029135 2.4317269,17.439132 2.4671791,16.84452 2.492502,16.254517 2.5178249,15.655295 2.5279541,15.056073 2.5127604,14.456852 2.5026312,13.977474 2.4621145,13.498097 2.406404,13.018719 2.3912102,12.871219 2.2848539,12.728327 2.2139497,12.590045 2.14811,12.460982 2.0518828,12.336529 2.001237,12.202856 1.90501,11.963167 2.041754,11.79262 2.3253706,11.783401 c 0.3038753,-0.0092 0.5824276,0.09219 0.835657,0.23047 0.2937461,0.161329 0.5722985,0.350314 0.8457862,0.539299 0.2127127,0.142892 0.2785524,0.350315 0.2481648,0.580784 -0.1063563,0.912661 -0.2431002,1.820713 -0.3140044,2.737983 -0.091163,1.110865 -0.1266147,2.226339 -0.1873898,3.337204 0,0.05992 0,0.119844 0,0.216642 z M 21.778453,17.771009 c 0.06584,0.235079 0.157002,0.465549 0.192454,0.705238 0.182326,1.138521 0.481136,2.249386 0.86098,3.341813 0.08103,0.239689 0.13168,0.488596 0.162067,0.737504 0.03545,0.336486 -0.0861,0.391799 -0.334263,0.414846 -0.638138,0.0507 -1.271211,0.01844 -1.884026,-0.129063 -1.04837,-0.253517 -2.000513,-0.69141 -2.805782,-1.359773 C 17.357068,20.969931 16.906319,20.338444 16.506217,19.6793 15.731335,18.402496 15.194489,17.042724 14.93113,15.599982 14.789322,14.820994 14.682965,14.042006 14.546221,13.263018 14.44493,12.677624 14.31325,12.09684 14.201829,11.511446 c -0.03545,-0.184376 -0.05064,-0.37797 -0.05571,-0.566956 -0.0051,-0.22586 0.151938,-0.331876 0.384909,-0.253516 0.238035,0.08297 0.481136,0.179766 0.703977,0.295001 0.324134,0.165938 0.643203,0.354924 0.952143,0.543909 0.05571,0.03227 0.09623,0.124454 0.09623,0.188985 0.01013,0.760551 -0.01013,1.525711 0.01519,2.286262 0.04052,1.203053 0.202583,2.387668 0.693848,3.51697 0.511524,1.170787 1.220566,2.212511 2.410744,2.917749 0.273488,0.161329 0.567234,0.295002 0.86098,0.414846 0.278553,0.110626 0.43049,0.06453 0.526717,-0.193595 0.177261,-0.474768 0.334263,-0.958754 0.476072,-1.442741 0.116485,-0.405627 0.202583,-0.815864 0.30894,-1.2261 0.02026,-0.08297 0.07597,-0.15672 0.111421,-0.235079 0.02532,0.01383 0.05571,0.01383 0.09116,0.01383 z M 5.4755443,7.4321291 C 5.5819007,7.9483817 5.6730633,8.4600249 5.799678,8.9670586 5.885776,9.3035447 6.032649,9.3865139 6.4023639,9.3358105 7.3494419,9.2113567 8.3015844,9.086903 9.2435978,8.9347929 10.14003,8.7872921 11.021268,8.589088 11.912636,8.4415873 c 0.29881,-0.050703 0.612815,-0.046094 0.91669,-0.00922 0.172196,0.018438 0.334263,0.1428913 0.491265,0.2304699 0.06077,0.032266 0.106356,0.087578 0.162067,0.1336725 0.116485,0.096797 0.212713,0.07375 0.283617,-0.046094 0.157002,-0.2627356 0.334263,-0.5254713 0.465942,-0.7974258 0.217777,-0.4563304 0.410232,-0.9218796 0.628009,-1.424304 C 14.68803,6.5425139 14.56648,6.5517329 14.44493,6.5609519 13.563691,6.6208739 12.682453,6.6946244 11.79615,6.736109 11.375789,6.754547 10.965558,6.65314 10.580649,6.4918109 10.484419,6.4503259 10.413518,6.3581384 10.32742,6.2889974 c 0.09116,-0.055313 0.17726,-0.1428913 0.278552,-0.1567195 0.531782,-0.087579 1.063563,-0.1659383 1.60041,-0.2350793 0.567234,-0.069141 1.134467,-0.138282 1.701701,-0.1843759 0.273488,-0.023047 0.55204,-0.00922 0.825528,0.00461 0.162067,0.00922 0.25323,-0.050703 0.283617,-0.184376 0.05571,-0.2304699 0.101292,-0.4609398 0.131679,-0.6914097 0.03039,-0.2350793 0.05065,-0.4701586 0.05065,-0.7052379 0,-0.4010176 -0.212712,-0.5853935 -0.648267,-0.5485183 -0.693849,0.059922 -1.377568,0.1567195 -2.071416,0.1982041 -0.612816,0.036875 -1.225631,0.023047 -1.838446,0.018438 -0.141808,0 -0.288681,-0.050703 -0.36465,-0.2442981 0.248165,-0.064532 0.481136,-0.1521101 0.724236,-0.1889853 1.448472,-0.2304699 2.871621,-0.5531278 4.274512,-0.9449266 0.06077,-0.018438 0.151938,-0.023047 0.207648,0.00461 0.648267,0.2996109 1.29147,0.6038311 1.929608,0.9172702 0.126615,0.064532 0.248165,0.1475007 0.354521,0.2350793 0.268424,0.2212511 0.293747,0.428674 0.07597,0.6914097 -0.111421,0.1382819 -0.2431,0.2673451 -0.374779,0.3917988 C 16.886066,5.2334469 16.511287,5.906419 16.242863,6.6393133 15.928854,7.4874419 15.635108,8.3447899 15.164101,9.132997 15.002034,9.4049515 14.804515,9.6722965 14.581674,9.9027664 14.292992,10.197768 13.943535,10.174721 13.690306,9.8566725 13.472529,9.5801086 13.199041,9.469483 12.839455,9.4879206 11.887313,9.5432334 10.93517,9.561671 9.9880922,9.6584683 8.9042704,9.7690939 7.8255132,9.944251 6.7467559,10.100971 6.5593662,10.128627 6.3719764,10.170112 6.1947158,10.234643 6.0427782,10.289956 5.8908405,10.372925 5.7692904,10.474332 5.5768361,10.631051 5.3185421,10.658708 5.1362169,10.455894 4.9640209,10.271518 4.791825,10.059486 4.7209207,9.8336255 4.4828851,9.0546372 4.275237,8.2664302 4.0827826,7.4782231 3.9055221,6.7499382 3.7637136,6.0216533 3.4598383,5.3256342 3.2927069,4.9430542 3.1002526,4.5789118 2.750796,4.2977385 2.6596334,4.2239881 2.6140521,4.0995344 2.5482125,3.9981276 2.6748272,3.9612524 2.7963773,3.9059396 2.922992,3.8967208 3.4497091,3.8690645 3.9612325,3.9059396 4.4626267,4.0857062 4.619629,4.1410189 4.8475354,4.1410189 4.9944085,4.0764874 6.1440699,3.5464066 7.1417938,2.8549969 7.7495443,1.7810072 7.8255132,1.6427252 7.8710945,1.4906151 7.9470633,1.3477238 8.1192593,1.0250659 8.3015844,0.92365914 8.6561056,1.0573317 9.1878873,1.2555358 9.7095399,1.4860057 10.210934,1.7487414 10.540132,1.9192891 10.550262,2.149759 10.241322,2.3479631 9.8108317,2.6199176 9.3550187,2.8734345 8.8840121,3.0854668 7.7444798,3.59711 6.5897537,4.0857062 5.4400922,4.5789118 c -0.00506,0.00461 -0.010129,0.00922 -0.015194,0.00922 -0.4456838,0.087579 -0.4710067,0.115235 -0.3849087,0.6268782 0.075969,0.4609398 0.232971,0.9126608 0.3545211,1.3689912 0.040517,0.1567195 0.1266147,0.1935947 0.3089399,0.1567195 0.7039777,-0.1521101 1.41302,-0.2950015 2.1220624,-0.428674 0.2785523,-0.050703 0.5520401,-0.032266 0.810334,0.082969 0.091163,0.041485 0.1873898,0.092188 0.2633586,0.1567195 0.2127127,0.1751571 0.172196,0.3641424 -0.096227,0.4425022 C 8.4991034,7.0772055 8.1850989,7.1463464 7.876159,7.2062686 7.1316646,7.34916 6.3821056,7.4275197 5.6224174,7.4044727 c -0.050646,0.00922 -0.086098,0.018438 -0.1468731,0.027656 z",
"serpent":
"m 19.037528,8.4337205 c 0.03566,-0.1077128 0.06484,-0.2154256 0.106982,-0.3191491 0.282043,-0.6781919 0.50249,-1.38032 0.609472,-2.1303204 0.02269,-0.1675533 0.02918,-0.3430853 0.03566,-0.5146279 0.0097,-0.1835108 -0.06808,-0.2792555 -0.217206,-0.2553193 -0.50249,0.071809 -1.011464,0.1117022 -1.507471,0.2393618 -1.270814,0.3231385 -2.535145,0.7021281 -3.805959,1.0292559 -0.489523,0.1276597 -0.988771,0.1954789 -1.484778,0.2672874 -0.220447,0.031915 -0.366331,0.1396277 -0.440894,0.394947 C 12.167998,7.7116456 12.01563,8.286114 11.834085,8.8486144 11.756285,9.0919656 11.65254,9.3353168 11.516382,9.534785 11.25379,9.9337214 10.83883,9.8738809 10.624867,9.435051 10.469257,9.1119125 10.420629,8.7728166 10.530857,8.4057951 c 0.356606,-1.204788 0.703487,-2.4095759 1.056851,-3.6143638 0.04863,-0.1675533 0.110224,-0.3311172 0.178303,-0.4906918 0.05187,-0.1236703 0.136159,-0.1276596 0.204238,-0.015957 0.181545,0.2912235 0.333913,0.6023939 0.36309,0.9813835 0.02594,0.3271278 0.158851,0.4747343 0.414959,0.43883 C 13.863503,5.5494108 14.96574,5.2901022 16.058251,4.958985 16.184684,4.919091 16.204135,4.8353147 16.152261,4.7156338 15.938297,4.2010053 15.740543,3.6783986 15.503886,3.1837175 15.205634,2.5693554 14.90414,1.951004 14.469729,1.4603122 c -0.01621,-0.015957 -0.03242,-0.039894 -0.0389,-0.05984 -0.02594,-0.095745 -0.09077,-0.2154257 -0.06484,-0.2832449 0.02593,-0.067819 0.145884,-0.12765961 0.213964,-0.1156915 0.291768,0.05984 0.586779,0.1196809 0.862338,0.2393618 0.641891,0.2792555 1.235154,0.6582451 1.718193,1.2726071 0.226931,0.2872342 0.337154,0.6063834 0.278801,1.0093091 -0.02594,0.1875001 -0.04215,0.382979 -0.04863,0.5744684 -0.0097,0.2593087 0.0778,0.3550534 0.291768,0.3031917 0.233415,-0.055851 0.460346,-0.1356384 0.690519,-0.2074469 0.408476,-0.1276597 0.810468,-0.2752661 1.222186,-0.3789896 0.615956,-0.1555852 1.196251,-0.00399 1.714951,0.4308513 0.356606,0.2992023 0.700245,0.6223408 1.02119,0.9734048 0.307978,0.3351066 0.265834,0.5625004 -0.09401,0.8337771 -0.67431,0.514628 -1.348619,1.0292559 -2.019687,1.5438839 C 19.838273,7.887178 19.465457,8.1863803 19.0894,8.4815933 19.07319,8.4576573 19.05698,8.4456893 19.03753,8.4337213 Z M 4.8575756,7.8632415 c 0,-0.5066493 0.00648,-0.997341 0,-1.4880328 C 4.8381243,5.294091 4.8283987,4.208984 4.7830125,3.1278664 4.770045,2.8286641 4.6565794,2.5294618 4.5852582,2.2342489 4.5431139,2.0706849 4.4717927,1.9150997 4.4458577,1.7515358 4.4004715,1.4802591 4.5171789,1.2768015 4.7376263,1.260844 5.2563259,1.2289291 5.7458488,1.3845143 6.1964691,1.6956847 6.4817539,1.8951529 6.5012052,2.2821212 6.4979633,2.6331853 6.4914795,3.3831857 6.4493352,4.1331861 6.429884,4.8831866 6.4071908,5.6451551 6.3909815,6.411113 6.3682884,7.1730815 6.3618046,7.332656 6.4234002,7.3725497 6.5336239,7.3446241 6.8999555,7.2608475 7.2727709,7.2089858 7.629377,7.0853155 c 0.96932,-0.3430853 1.7149508,0.131649 2.379535,0.9335112 0.126433,0.1515958 0.126433,0.3231384 0.04863,0.5106385 -0.4668299,1.1090432 -0.7845334,2.2819158 -1.0082227,3.4946828 -0.025935,0.139628 -0.032419,0.291224 -0.012967,0.430851 0.025935,0.195479 -0.032419,0.303192 -0.1750612,0.335107 -0.2528661,0.05585 -0.5122159,0.09973 -0.7683239,0.135638 -0.3760573,0.05585 -0.7521145,0.09575 -1.1249299,0.159575 -0.4473785,0.0758 -0.6224396,0.291224 -0.6548584,0.841756 -0.055112,0.985373 -0.08753,1.974735 -0.1296749,2.964097 0,0.02793 0,0.05186 0,0.07979 0.00973,0.267288 0.035661,0.307181 0.2431405,0.227394 0.6840352,-0.263298 1.3648285,-0.534575 2.0391381,-0.825798 0.2852848,-0.12367 0.3177036,-0.263298 0.1977543,-0.598405 -0.10374,-0.291223 -0.230173,-0.570479 -0.3371548,-0.861702 -0.058354,-0.163564 -0.1004981,-0.335107 -0.1458843,-0.50665 -0.035661,-0.143617 0.019451,-0.203457 0.1296749,-0.191489 0.064838,0.008 0.1296749,0.02792 0.1847868,0.05984 0.8104682,0.478724 1.4912615,1.156916 1.9613325,2.102395 0.288527,0.574469 0.262592,1.220746 0.106982,1.851065 -0.02918,0.12367 -0.09726,0.239362 -0.165335,0.339096 -0.126434,0.1875 -0.298253,0.227394 -0.4408948,0.05984 C 9.7852225,18.423088 9.6393382,18.179737 9.5031796,17.936386 9.3540534,17.661119 9.2276204,17.365907 9.0947036,17.078672 9.0201405,16.923087 8.9358518,16.90314 8.802935,16.994896 7.3376084,18.012183 5.8722818,19.029471 4.4004715,20.030802 3.9044649,20.365908 3.392249,20.665111 2.8897586,20.98027 2.6628275,21.123887 2.4488639,21.087983 2.2284166,20.93639 1.8037312,20.649156 1.4568508,20.262188 1.1488728,19.81139 c -0.048628,-0.07181 -0.08753,-0.151596 -0.1167074,-0.235373 -0.0778049,-0.215425 -0.012968,-0.378989 0.178303,-0.406915 1.1573487,-0.167553 2.2304087,-0.702128 3.3358873,-1.113033 0.025935,-0.008 0.05187,-0.01995 0.077805,-0.03191 0.3274292,-0.12766 0.3241873,-0.12766 0.3274292,-0.558511 0.012968,-1.117022 0.029177,-2.234044 0.038902,-3.347077 0.00324,-0.478723 -0.045386,-0.550532 -0.4376528,-0.534575 -0.2950104,0.01197 -0.586779,0.08777 -0.8753057,0.147607 -0.1102237,0.02394 -0.1847868,0.103723 -0.204238,0.267287 -0.022693,0.179522 -0.1102237,0.323139 -0.2690755,0.355054 C 3.0421267,14.385852 2.9383867,14.242234 2.8930005,14.090639 2.7665675,13.667766 2.6368926,13.240904 2.5655713,12.806063 2.4132033,11.896488 2.3094634,10.974945 2.1635791,10.06537 2.0695648,9.4709552 1.936648,8.8924974 1.5735582,8.4337205 1.4017389,8.2143055 1.476302,7.9909011 1.7226844,7.9629756 1.8815361,7.9470181 2.0533554,7.9470181 2.2024816,8.0028692 2.8184374,8.2302629 3.4311514,8.1504757 4.0471073,8.022816 4.2999734,7.978933 4.5560814,7.9270713 4.8575756,7.8632415 Z m 1.4361497,0.4507981 c -0.00324,0.035904 -0.00648,0.067819 -0.00648,0.1037235 0,0.8976069 -0.00324,1.7912239 0.00324,2.6888309 0.00324,0.303192 0.032419,0.606384 0.048628,0.909575 0.00973,0.171543 0.081047,0.207447 0.2107218,0.163564 0.2528661,-0.09176 0.5057321,-0.175532 0.7618401,-0.25133 C 7.551572,11.856595 7.7071819,11.689042 7.7460844,11.38585 7.8011962,10.927073 7.85955,10.468296 7.8952106,10.009519 7.9308712,9.578668 7.9503224,9.1478167 7.960048,8.7169654 7.9697736,8.3499439 7.8757593,8.2063268 7.5872326,8.1584544 7.1495798,8.0906352 6.7184107,8.1624438 6.2937253,8.3140396 Z M 4.8510918,12.614574 c 0.00324,-0.06383 0.00973,-0.111702 0.00973,-0.155585 0,-0.809841 0.00324,-1.623671 -0.00324,-2.433512 C 4.8543337,9.7222851 4.8413662,9.4151041 4.821915,9.1119124 4.79598,8.756859 4.666305,8.6052632 4.4037133,8.6730824 4.0730423,8.756859 3.7456131,8.8725506 3.4214258,9.0002102 c -0.1912705,0.075798 -0.2269311,0.175532 -0.204238,0.4308513 0.032419,0.3430853 0.077805,0.6821815 0.1102237,1.0252665 0.058354,0.62633 0.1037399,1.25665 0.1685774,1.878991 0.045386,0.430851 0.1880286,0.546542 0.5316672,0.470744 0.2690754,-0.06383 0.5413928,-0.127659 0.8234357,-0.191489 z m 9.1907102,3.107715 c 0.91745,-0.730054 1.705225,-1.587767 2.463823,-2.489364 0.343639,-0.410904 0.67431,-0.841755 1.004981,-1.272607 0.278801,-0.367021 0.453862,-0.797873 0.534909,-1.296543 0.09077,-0.546543 0.158852,-0.594415 0.577053,-0.390958 0.41496,0.203458 0.816952,0.44282 1.215703,0.69016 0.129675,0.07979 0.236656,0.231383 0.333913,0.367022 0.126433,0.175532 0.113465,0.263298 -0.04539,0.406915 -0.142642,0.131649 -0.291768,0.25133 -0.437652,0.378989 -0.791017,0.69415 -1.572309,1.404257 -2.36981,2.082448 -0.868822,0.738033 -1.799239,1.336437 -2.755592,1.88298 -0.06808,0.03989 -0.136158,0.07979 -0.204238,0.123671 -0.337154,0.207447 -0.333913,0.207447 -0.304736,0.678191 0.03566,0.57048 0.05835,1.140959 0.106982,1.707448 0.110224,1.252661 0.690519,2.00665 1.663081,2.329789 1.163832,0.386968 2.330907,0.414894 3.507707,0.0758 0.596504,-0.171543 1.017948,-0.594415 1.293507,-1.268618 0.369573,-0.893618 0.570569,-1.843086 0.664584,-2.836438 0.02918,-0.31516 0.09401,-0.62633 0.152368,-0.933511 0.01297,-0.06782 0.07456,-0.119681 0.110224,-0.179521 0.04214,0.05585 0.103739,0.103723 0.119949,0.167553 0.08429,0.375 0.168577,0.75399 0.233415,1.136969 0.178303,1.045213 0.486281,2.034575 0.833161,3.00798 0.09401,0.267288 0.171819,0.546543 0.233415,0.825798 0.07456,0.331118 -0.0065,0.614363 -0.239899,0.825799 -0.496006,0.446809 -1.063334,0.666224 -1.653355,0.821809 -1.491262,0.394947 -2.998732,0.558511 -4.519171,0.335106 -0.839645,-0.12367 -1.637146,-0.43883 -2.311455,-1.093085 -0.580296,-0.562501 -0.907725,-1.32048 -1.034158,-2.210108 -0.162093,-1.121011 -0.194512,-2.25798 -0.236657,-3.390959 -0.07132,-1.930853 -0.142642,-3.861705 -0.220447,-5.792557 -0.01297,-0.283245 -0.05511,-0.5664896 -0.09077,-0.8457451 -0.03566,-0.2792555 0.04863,-0.4029258 0.275559,-0.3470747 0.50249,0.1276597 0.962836,0.3869683 1.38428,0.7420217 0.168577,0.1396281 0.252866,0.3590431 0.230173,0.6023941 -0.04214,0.446809 -0.113466,0.889628 -0.162094,1.336437 -0.09726,0.893617 -0.191271,1.787235 -0.278801,2.684842 -0.03242,0.367021 -0.04863,0.738032 -0.07456,1.136969 z",
"singe":
"m 17.390172,6.7509614 c 0.419392,-0.1361865 0.812975,-0.2801551 1.209785,-0.3929953 0.358096,-0.1011671 0.722644,-0.2101163 1.087193,-0.2451357 0.270991,-0.027237 0.554888,0.03891 0.829105,0.097276 0.141948,0.031128 0.293575,0.1050581 0.296801,0.3424117 0.0065,0.3151745 -0.04517,0.44747 -0.274218,0.5447461 C 20.267846,7.2139956 19.993629,7.3346179 19.712959,7.4085477 18.2096,7.793761 16.706241,8.1789742 15.199656,8.5369502 14.447976,8.7159382 13.689845,8.883253 12.918809,8.8443426 12.609104,8.8287784 12.299399,8.7781948 11.99292,8.7315023 11.841294,8.7081561 11.728381,8.6069889 11.644502,8.4474562 c -0.129043,-0.2373536 -0.0871,-0.3968864 0.145175,-0.44747 0.235504,-0.054475 0.477461,-0.07393 0.716192,-0.1167312 0.63554,-0.1206224 1.27108,-0.2334626 1.903394,-0.3696491 0.574245,-0.1245134 1.142037,-0.2801551 1.716281,-0.4124506 0.145174,-0.035019 0.20647,-0.1011671 0.241957,-0.2879372 0.125818,-0.6420221 0.28067,-1.272371 0.416166,-1.9105021 0.05807,-0.2645909 -0.01613,-0.3540849 -0.232279,-0.2529178 -0.56134,0.2606999 -1.142036,0.2762641 -1.725959,0.2334626 -0.335513,-0.023346 -0.629088,-0.2062253 -0.880723,-0.4708162 -0.177435,-0.1867701 -0.1484,-0.3774312 0.08065,-0.455252 0.241957,-0.077821 0.493592,-0.1128403 0.742001,-0.1634238 0.654897,-0.1322955 1.309794,-0.2801551 1.903395,-0.6653684 0.258087,-0.1673148 0.509722,-0.357976 0.758131,-0.544746 0.11614,-0.085603 0.235505,-0.1089492 0.351644,-0.035019 0.351644,0.2295715 0.709741,0.455252 1.045254,0.7159519 0.209696,0.1634238 0.283896,0.4396879 0.05162,0.7159519 -0.267766,0.3151745 -0.538758,0.63424 -0.764584,0.996107 -0.319383,0.5252908 -0.519401,1.1400756 -0.722645,1.7743152 z M 10.079848,9.0038753 C 9.6862646,9.4941468 9.315264,9.968854 8.931359,10.431888 8.7506979,10.649787 8.5474541,10.84823 8.3538886,11.054455 c -0.032261,0.03502 -0.067748,0.08171 -0.1064611,0.0856 -0.077426,0.01167 -0.1580785,0 -0.2387308,-0.0039 0.00645,-0.0856 -0.01613,-0.194552 0.019357,-0.2607 C 8.4926105,9.968854 8.9700721,9.0700231 9.4346294,8.159519 10.179857,6.7042689 10.760553,5.1517428 11.254145,3.5525241 11.463841,2.8832647 11.476746,2.186768 11.408998,1.4863803 c -0.03226,-0.3268477 0.06775,-0.48638042 0.341965,-0.48638042 0.135496,0 0.28067,0.0428015 0.400036,0.11284022 0.41294,0.2412447 0.790392,0.5486371 1.032349,1.0427996 0.09356,0.1906611 0.09678,0.369649 -0.0065,0.5408549 -0.764584,1.260698 -1.251724,2.708166 -1.877585,4.0622489 -0.229053,0.4902714 -0.454879,0.9805429 -0.674254,1.4785964 -0.03226,0.07393 -0.04194,0.18677 -0.01936,0.2645909 0.287122,0.9221772 0.400035,1.8793742 0.400035,2.8521342 0,1.105057 -0.02904,2.214004 -0.06775,3.31906 -0.04839,1.369647 -0.116139,2.739294 -0.187113,4.108941 -0.04194,0.774318 -0.08711,1.552527 -0.170983,2.319062 -0.05162,0.470816 -0.174209,0.929959 -0.287122,1.389102 -0.05162,0.214008 -0.106461,0.494163 -0.3419659,0.501945 -0.2484091,0.0078 -0.3451918,-0.264591 -0.4161659,-0.501945 -0.28067,-0.929959 -0.387131,-1.879373 -0.1387219,-2.852134 0.2742178,-1.054473 0.3839049,-2.143965 0.4871399,-3.237348 0.2258268,-2.381318 0.2355048,-4.770419 0.2096958,-7.1634101 0.0032,-0.070039 -0.0065,-0.1439686 -0.0129,-0.2334626 z M 6.7763296,5.7509634 C 6.7989122,5.6964888 6.8118166,5.6575784 6.8279471,5.62645 7.2247564,4.9260623 7.6054352,4.2101104 7.8151312,3.3929913 c 0.05807,-0.2295715 0.012904,-0.4941624 0.016131,-0.7431892 0,-0.081712 -0.00645,-0.1673148 0.00968,-0.2490267 0.051617,-0.2606999 0.1871134,-0.3657581 0.3935833,-0.268482 0.4419746,0.2101163 0.8581404,0.4902714 1.1839757,0.9105041 0.1161393,0.1517506 0.174209,0.3813222 0.2322787,0.5836564 0.019357,0.070039 -0.025809,0.1906611 -0.070974,0.2568088 C 9.3475249,4.2140014 9.0991158,4.5291759 8.8700633,4.8638056 8.3280798,5.6614694 7.7957747,6.4630243 7.2602434,7.2684702 7.2279825,7.3151627 7.211852,7.3968746 7.2183042,7.4591313 7.4247741,9.24512 7.4828437,11.042782 7.4828437,12.844335 c 0.00323,1.167313 0,2.330735 -0.041939,3.498047 -0.035487,1.050582 -0.090331,2.108946 -0.316157,3.136181 -0.2032438,0.914395 -0.6032792,1.708168 -1.0678364,2.459139 -0.138722,0.22179 -0.3064788,0.22179 -0.4419746,0.01167 -0.5484357,-0.852138 -1.225915,-1.517506 -2.0227597,-2.003887 -0.041939,-0.02724 -0.096783,-0.05058 -0.1161393,-0.09728 -0.032261,-0.07004 -0.067748,-0.159533 -0.054844,-0.229571 0.00968,-0.04669 0.1000089,-0.09339 0.1516263,-0.09728 0.245183,-0.0039 0.4935921,0 0.7387751,0.01167 0.3645484,0.01556 0.7258707,0.07782 1.087193,-0.05058 0.2516352,-0.08949 0.4452007,-0.252918 0.4968182,-0.568092 0.087104,-0.505836 0.1903394,-1.011671 0.2193742,-1.521398 0.0742,-1.357974 0.1129132,-2.715948 0.1645307,-4.073922 0.00323,-0.08171 0,-0.163424 0,-0.29961 -0.070974,0.07004 -0.1161393,0.108949 -0.1548524,0.155641 -0.7516794,0.863812 -1.506585,1.71595 -2.3550472,2.443575 -0.7323228,0.638131 -1.5356197,1.151749 -2.4098907,1.494161 -0.1096871,0.0428 -0.2516352,0.159533 -0.3355135,-0.01167 -0.0806524,-0.175097 0.05807,-0.287937 0.1548524,-0.381322 0.4129397,-0.392996 0.8387839,-0.766536 1.2484976,-1.159531 0.7774881,-0.743189 1.474324,-1.587546 2.1130902,-2.49805 0.6000531,-0.852138 1.1517149,-1.75486 1.7259593,-2.634236 0.029035,-0.0428 0.05807,-0.101167 0.05807,-0.151751 C 6.3182245,9.7781929 6.3117723,9.2801394 6.2924158,8.7820859 6.2891897,8.6653546 6.2472505,8.5486233 6.2246679,8.431892 5.8181803,8.7626307 5.4278231,9.0894783 5.0277877,9.4007617 c -0.667801,0.5136177 -1.40335,0.8754843 -2.1550294,1.1828773 -0.1064611,0.0428 -0.1806612,0.01946 -0.2387308,-0.11284 -0.05807,-0.132296 0.00645,-0.194553 0.077426,-0.252918 C 3.0985847,9.87936 3.4889418,9.5486214 3.8696207,9.2023185 4.6148479,8.517495 5.2858751,7.7315043 5.9246413,6.9066032 5.9891631,6.8210002 5.985937,6.7665256 5.9472239,6.6692495 5.5955799,5.7820917 5.0987617,5.0233383 4.4954825,4.3657521 4.3632128,4.2217835 4.2438474,4.0661418 4.1180298,3.9143911 4.0857689,3.8715896 4.0406036,3.8287881 4.0309253,3.7782046 4.0115687,3.6536912 3.9728556,3.4941584 4.0147948,3.4046645 4.0793167,3.27626 4.2051343,3.3540809 4.301917,3.4085555 c 0.9420189,0.5097266 1.7549941,1.2140054 2.3744037,2.2256766 0.022583,0.019455 0.041939,0.042801 0.1000089,0.1167313 z m 9.2750144,9.2995926 c 0.596827,0.976652 1.225915,1.867701 1.945334,2.661474 0.880723,0.97276 1.809837,1.871591 2.858317,2.568088 0.587149,0.389104 1.19688,0.723734 1.83242,0.980543 0.0871,0.03502 0.177435,0.09728 0.245183,0.175097 0.04194,0.05058 0.0742,0.155641 0.0613,0.221789 -0.0097,0.05058 -0.09356,0.105058 -0.1484,0.11284 -0.245183,0.03113 -0.493592,0.05058 -0.738775,0.06615 -0.906532,0.06615 -1.803386,-0.02335 -2.690561,-0.237353 -0.393583,-0.09339 -0.703288,-0.377432 -0.935567,-0.747081 -0.464557,-0.727625 -0.906531,-1.474705 -1.332376,-2.237349 -0.422618,-0.754863 -0.816201,-1.533071 -1.225915,-2.303498 -0.02903,-0.05448 -0.06452,-0.108949 -0.112913,-0.18677 -0.02903,0.07004 -0.04839,0.108949 -0.0613,0.14786 -0.251635,0.824901 -0.50327,1.645911 -0.758131,2.470812 -0.241957,0.789882 -0.716193,1.338519 -1.300115,1.762642 -0.667801,0.486381 -1.406576,0.750972 -2.15503,0.988325 -0.135496,0.0428 -0.267765,0.09339 -0.406487,0.112841 -0.05484,0.0078 -0.151627,-0.03502 -0.170983,-0.0856 -0.02258,-0.05837 0,-0.171206 0.03871,-0.225681 0.06452,-0.08949 0.151626,-0.163424 0.235505,-0.229571 0.451653,-0.357976 0.912984,-0.696497 1.351732,-1.073928 0.880723,-0.762645 1.416255,-1.840464 1.803386,-3.035014 0.16453,-0.505835 0.293574,-1.023344 0.438748,-1.536962 0.0097,-0.02724 0.0097,-0.06226 0.01936,-0.124513 -0.283896,0.08171 -0.554888,0.151751 -0.819428,0.237353 -0.322609,0.101168 -0.638766,0.22179 -0.961375,0.311284 -0.664575,0.178988 -1.248498,0.01556 -1.687246,-0.653695 -0.05162,-0.08171 -0.122592,-0.229572 -0.09678,-0.280155 0.04517,-0.08949 0.154852,-0.159533 0.245183,-0.175097 0.612957,-0.08949 1.229141,-0.151751 1.838872,-0.245136 0.477462,-0.07393 0.954924,-0.175097 1.429159,-0.268482 0.03871,-0.0078 0.09356,-0.06615 0.100009,-0.11284 0.103235,-0.661478 0.183887,-1.326846 0.174209,-2.019452 -0.196792,0 -0.390357,0.01167 -0.580697,-0.0039 -0.196791,-0.01556 -0.393583,-0.05058 -0.587148,-0.101167 -0.11614,-0.03113 -0.19034,0 -0.267766,0.09728 -0.390357,0.48249 -0.78394,0.961088 -1.277532,1.295718 -0.05484,0.03891 -0.112914,0.09338 -0.170983,0.09338 -0.06775,0 -0.154853,-0.02724 -0.193566,-0.0856 -0.03549,-0.05448 -0.03871,-0.178988 -0.0097,-0.237354 0.167757,-0.322956 0.35487,-0.63424 0.525853,-0.953305 0.332287,-0.626458 0.674253,-1.249025 0.829106,-1.980541 0.04194,-0.194552 0.01936,-0.4046688 0.02258,-0.607003 0,-0.070039 -0.02258,-0.1400775 -0.01613,-0.2101163 0.03871,-0.4046685 0.203244,-0.5291819 0.522627,-0.3852133 0.183887,0.081712 0.361322,0.1945522 0.538757,0.2996103 0.26454,0.1517507 0.425844,0.4085595 0.419392,0.7587533 -0.0032,0.151751 -0.08388,0.311284 -0.158078,0.44747 -0.106462,0.18677 -0.238731,0.350194 -0.358097,0.525291 -0.03549,0.05447 -0.07097,0.11284 -0.132269,0.210116 0.277443,-0.07393 0.516174,-0.128404 0.751679,-0.202334 1.029123,-0.33463 2.055021,-0.680933 3.084144,-1.011671 0.177435,-0.058366 0.364548,-0.093385 0.548436,-0.093385 0.1484,0 0.316157,0.058365 0.348418,0.276264 0.03871,0.245136 0.01936,0.501944 -0.174209,0.642022 -0.225827,0.167315 -0.461332,0.342412 -0.712967,0.431906 -0.671027,0.237353 -1.354958,0.428014 -2.035664,0.638131 -0.05162,0.01556 -0.103235,0.03113 -0.203244,0.06226 0.09678,0.04669 0.154853,0.07393 0.212922,0.105059 0.329062,0.163423 0.409714,0.350193 0.348418,0.774317 -0.02258,0.167315 -0.03871,0.33463 -0.05807,0.498054 -0.01936,0.159532 -0.03871,0.319065 -0.0613,0.517508 0.180661,-0.03891 0.33874,-0.07004 0.496818,-0.108949 0.99041,-0.245136 1.984047,-0.490271 2.974457,-0.735407 0.358096,-0.08949 0.719418,-0.128404 1.083967,-0.02335 0.335513,0.09338 0.519401,0.369649 0.641992,0.723734 0.05807,0.167315 -0.03871,0.37354 -0.2226,0.451361 -0.164531,0.07004 -0.341966,0.116731 -0.516175,0.140077 -0.987184,0.140078 -1.974368,0.256809 -2.958326,0.404669 -0.548436,0.07004 -1.093645,0.194552 -1.671116,0.307392 z",
"tigre":
"m 9.4483461,14.762428 c 0.4412943,0.103663 0.8531699,0.162903 1.2405289,0.306065 0.475617,0.172778 0.603102,0.43442 0.505037,0.883647 -0.28439,1.303251 -0.563876,2.616367 -1.122851,3.835695 -0.5050369,1.100857 -1.2895605,1.949947 -2.432024,2.418915 -0.3873585,0.15797 -0.9904609,0.227085 -1.5249178,0.162903 0.1814211,-0.13822 0.338326,-0.266566 0.5001342,-0.389987 1.0394943,-0.804658 1.8975666,-1.762344 2.4369268,-2.981672 0.4118756,-0.942887 0.5834903,-1.930198 0.5001341,-2.96194 -0.029416,-0.404796 -0.063745,-0.804658 -0.1029682,-1.273626 z m 12.1846379,2.142465 c 0.03922,0.07894 0.08826,0.153028 0.117679,0.236951 l 0.897299,2.502838 c 0.09316,0.266575 0.196131,0.528208 0.2991,0.78985 0.09807,0.23695 0.05394,0.444285 -0.08335,0.656553 -0.666844,1.036685 -1.676919,1.510586 -2.829189,1.737671 -0.77962,0.153037 -1.573951,0.182652 -2.368281,0.167845 -0.804138,-0.01485 -1.603371,-0.04933 -2.382992,-0.301133 -0.8973,-0.291257 -1.456273,-0.893513 -1.701437,-1.801843 -0.220647,-0.819465 -0.22555,-1.658681 -0.205937,-2.502829 0.0098,-0.409737 0.02942,-0.814532 0.05394,-1.22427 0.03922,-0.720735 -0.04413,-1.421721 -0.318712,-2.098033 -0.02451,-0.06418 -0.04413,-0.133287 -0.07845,-0.2567 0.225551,0.01971 0.416779,0.01971 0.603103,0.04933 0.431488,0.07409 0.838459,0.21721 1.196399,0.488718 0.220647,0.167845 0.274583,0.261642 0.171614,0.523275 -0.210841,0.53315 -0.333422,1.086041 -0.387358,1.653748 -0.07845,0.765168 -0.147099,1.530326 -0.01471,2.295494 0.117679,0.681245 0.58349,1.12554 1.358207,1.26376 0.86788,0.15797 1.745566,0.148095 2.618349,0.08389 0.34323,-0.02466 0.686459,-0.07408 1.019882,-0.148095 0.907105,-0.202403 1.417046,-0.794783 1.578854,-1.693238 0.112775,-0.641755 0.191228,-1.293376 0.289293,-1.935131 0.02452,-0.162903 0.07355,-0.320873 0.107872,-0.483785 0.01471,-0.0046 0.03922,-0.0046 0.05884,-0.0046 z M 1.0000037,22.621421 C 1.1372946,22.438768 1.26478,22.270923 1.3971687,22.10802 2.0493045,21.29842 2.7308589,20.50858 3.348672,19.674297 4.422489,18.227884 5.0648184,16.588953 5.3933379,14.816726 5.633598,13.50361 5.7757932,12.185542 5.8395354,10.852677 5.8934724,9.7863765 5.7905024,8.7348937 5.4521769,7.7130259 5.3884319,7.5155657 5.3639199,7.3032886 5.3197882,7.1008955 5.2903722,6.9626752 5.3443002,6.8836856 5.4864996,6.859003 5.9670208,6.7751081 6.4328322,6.8635875 6.8594168,7.071271 7.2467753,7.2588655 7.6292305,7.3477208 8.0509127,7.2934229 8.5804664,7.2242898 9.1100201,7.1502606 9.6395737,7.071271 10.080868,7.0070891 10.522163,6.9281178 10.963457,6.8688779 11.095846,6.8491649 11.154686,6.8096472 11.144879,6.6714177 11.086039,5.4866379 11.027201,4.3018672 10.978167,3.1121546 10.953647,2.5197739 10.791843,1.9718162 10.556486,1.4337334 c -0.147098,-0.3356897 -0.04903,-0.45910242 0.31381,-0.429487 0.583489,0.049328 1.127753,0.2270847 1.63279,0.5232751 0.264777,0.15797 0.362842,0.37518 0.31381,0.6763123 -0.06374,0.4146702 -0.112776,0.8293404 -0.166712,1.2489434 -0.0098,0.064182 0,0.1283547 0,0.2418925 0.289294,-0.093797 0.55407,-0.1777106 0.813944,-0.266575 0.622716,-0.2023931 1.235626,-0.4344107 1.868147,-0.6022556 0.2991,-0.079035 0.637426,-0.064182 0.951236,-0.024664 0.397165,0.049328 0.617812,0.4788429 0.465811,0.8490901 -0.03922,0.093788 -0.161807,0.1925182 -0.259873,0.2172007 -0.431488,0.1036721 -0.872783,0.1875946 -1.309175,0.2616422 -0.799234,0.1332875 -1.598468,0.2517673 -2.397701,0.3850456 -0.259874,0.044469 -0.323616,0.1234218 -0.343229,0.3949297 -0.01962,0.2813826 -0.02451,0.5627653 -0.03922,0.844148 -0.01471,0.1925274 -0.02942,0.3850548 -0.06865,0.5726402 -0.02942,0.1431623 0.01471,0.2024022 0.147099,0.1826526 0.353036,-0.049328 0.710975,-0.078944 1.054204,-0.1678449 1.436659,-0.3603631 2.868415,-0.7355431 4.305076,-1.105781 0.06375,-0.014854 0.147098,-0.024664 0.201034,0 0.622715,0.310998 1.250335,0.6170632 1.85834,0.9576858 0.205939,0.113547 0.38736,0.3011324 0.544265,0.4837849 0.201034,0.2369505 0.16671,0.3949205 -0.112776,0.5183423 -0.264777,0.1184707 -0.55407,0.1777106 -0.82375,0.2863155 -0.661943,0.266575 -1.318981,0.5528906 -1.97602,0.8244076 -0.107872,0.044469 -0.230454,0.064182 -0.392262,0.1036629 0.112775,-0.310998 0.210841,-0.5676982 0.299099,-0.8243983 0.03922,-0.108605 0.06375,-0.21721 0.08826,-0.3307569 0.06865,-0.3455555 -0.05394,-0.5430157 -0.411875,-0.5578234 -0.35794,-0.014854 -0.715879,-0.0099 -1.068914,0.039518 -1.211108,0.1727778 -2.422217,0.370238 -3.633326,0.5627654 -0.137292,0.024664 -0.279487,0.069133 -0.411876,0.1184798 -0.132388,0.049328 -0.147099,0.1480952 -0.05884,0.2567002 0.09316,0.1086049 0.191228,0.2172099 0.28439,0.3208729 0.147098,0.162912 0.161808,0.3455645 0.09807,0.5528996 -0.117679,0.370238 -0.22555,0.7454177 -0.323616,1.1205976 -0.06374,0.2567002 0.0049,0.3060652 0.254971,0.2369505 0.706071,-0.1974603 1.40724,-0.4097374 2.118214,-0.5825151 0.460909,-0.1135375 0.931622,-0.1826522 1.402337,-0.2418922 0.181421,-0.024664 0.377552,0.019713 0.563877,0.064182 0.171614,0.039518 0.274583,0.1629026 0.28439,0.3455551 0.0098,0.1925274 -0.102969,0.2912575 -0.264777,0.3356898 -0.514844,0.1480951 -1.029688,0.2961907 -1.544532,0.4344107 -0.799234,0.207336 -1.603371,0.399863 -2.402604,0.617073 -0.196131,0.05428 -0.436392,0.103663 -0.465812,0.35543 -0.03922,0.301133 0.04413,0.597323 0.31381,0.755293 0.24026,0.143162 0.514844,0.261642 0.789427,0.306065 1.019881,0.162912 2.044666,0.13823 3.059644,-0.03952 0.710975,-0.123412 1.162075,-0.597322 1.436659,-1.248952 0.06865,-0.15797 0.09807,-0.330748 0.147099,-0.498584 0.02452,-0.0839 0.03922,-0.177719 0.08335,-0.256709 0.04903,-0.0839 0.122582,-0.148095 0.186325,-0.222143 0.05394,0.07904 0.122582,0.148096 0.166711,0.232018 0.186324,0.39493 0.367745,0.78985 0.544263,1.189713 0.07846,0.177719 0.152002,0.365305 0.215745,0.547957 0.08335,0.251768 0.0098,0.478843 -0.196131,0.626938 -0.725685,0.523275 -1.490596,0.977445 -2.417314,1.011993 -0.912009,0.03457 -1.824019,0.07409 -2.736028,0.05923 -0.465812,-0.0046 -0.936525,-0.09379 -1.39253,-0.19746 -0.691362,-0.162903 -1.044398,-0.671371 -1.18169,-1.342741 -0.05394,-0.2567 -0.102968,-0.518342 -0.132388,-0.779975 -0.01471,-0.15797 -0.07846,-0.172778 -0.215744,-0.15797 -0.578586,0.04447 -1.1620759,0.08885 -1.7455662,0.108605 -0.2010342,0.0046 -0.4118748,-0.05923 -0.6080057,-0.113547 -0.073544,-0.01971 -0.1274854,-0.108596 -0.1912276,-0.162903 0.063745,-0.04933 0.1176789,-0.123413 0.1912276,-0.143162 0.5001342,-0.153028 1.0002684,-0.301124 1.5053058,-0.439353 0.3334221,-0.08885 0.6717481,-0.162903 1.0100741,-0.236951 0.112775,-0.02466 0.156905,-0.06418 0.156905,-0.187594 -0.01962,-0.6911115 -0.02452,-1.3822312 -0.04413,-2.0684092 -0.0049,-0.2764499 -0.04903,-0.3208821 -0.318713,-0.266575 C 9.5954472,7.9006297 8.6245983,8.1030227 7.6488462,8.2955501 7.5115552,8.3202143 7.4723283,8.3843963 7.4625218,8.5226349 7.3840738,9.7123381 7.3203276,10.906984 7.1977454,12.091763 7.0114211,13.839299 6.7074178,15.567095 6.1386381,17.23565 5.6630202,18.642564 5.0059811,19.940881 3.8978413,20.962749 3.118221,21.683484 2.2209209,22.201827 1.250073,22.596747 c -0.053937,0.01971 -0.1127757,0.03457 -0.1716147,0.04933 -0.00981,0 -0.029416,-0.01485 -0.078448,-0.02467 z"
// Iconset API (Home Assistant 0.110 and up):
async function getIcon(name) {
return { path: ZOD_ICONS_MAP[name] };
window.customIconsets = window.customIconsets || {};
window.customIconsets["zod"] = getIcon;
if (!window.frontendVersion || window.frontendVersion < 20200519.0) {
// ha-iconset-svg (Up to Home Assistant 0.109):
const iconset = document.createElement("ha-iconset-svg");
iconset.name = "zod";
iconset.size = "24";
let iconsetHTML = "";
for (let key in ZOD_ICONS_MAP) {
iconsetHTML += `<g id="${key}"><path d="${ZOD_ICONS_MAP[key]}" /></g>`;
iconset.innerHTML = `<svg><defs>${iconsetHTML}</defs></svg>`;
document.body.appendChild(iconset);
Et pour finir l’affichage :
- type: 'custom:hui-glance-card'
show_icon: true
show_state: true
show_name: false
columns: 2
state_color: false
- entity: sensor.zodiac
- entity: sensor.zodiac_chinois
Voila…
