Après avoir flashé ma clé Sonoff Zigbee en multiprotocole, chargé et configuré Thread et Matter, j’obtiens l’erreur 502: Bad Gateway
J’ai suivi les tutos de Valentin : https://www.youtube.com/watch?v=a_qCONALg2g
[center]
version
core-2024.3.0
installation_type
Home Assistant OS
dev
false
hassio
true
docker
true
user
root
virtualenv
false
python_version
3.12.2
os_name
Linux
os_version
6.1.73-haos-raspi
arch
aarch64
timezone
Europe/Paris
config_dir
/config
logged_in
false
can_reach_cert_server
ok
can_reach_cloud_auth
ok
can_reach_cloud
ok
host_os
Home Assistant OS 12.0
update_channel
stable
supervisor_version
supervisor-2024.02.1
agent_version
1.6.0
docker_version
24.0.7
disk_total
109.3 GB
disk_used
6.9 GB
healthy
true
supported
true
board
rpi4-64
supervisor_api
ok
version_api
ok
installed_addons
ZeroTier One (0.18.0), ESPHome (2024.2.2), Silicon Labs Multiprotocol (2.4.4), Matter Server (5.4.1), Mosquitto broker (6.4.0), Zigbee2MQTT (1.36.0-1)
dashboards
1
resources
0
views
0
mode
storage
oldest_recorder_run
2 mars 2024 à 20:41
current_recorder_run
9 mars 2024 à 09:58
estimated_db_size
10.59 MiB
database_engine
sqlite
database_version
3.44.2
[/center]
[12:19:53] INFO: Socat not enabled
[12:19:55] INFO: Starting Zigbee2MQTT...
Zigbee2MQTT:info 2024-03-10 12:20:01: Logging to console and directory: '/config/zigbee2mqtt/log/2024-03-10.12-20-01' filename: log.txt
Zigbee2MQTT:info 2024-03-10 12:20:01: Starting Zigbee2MQTT version 1.36.0 (commit #unknown)
Zigbee2MQTT:info 2024-03-10 12:20:01: Starting zigbee-herdsman (0.35.1)
Zigbee2MQTT:error 2024-03-10 12:20:32: Error while starting zigbee-herdsman
Zigbee2MQTT:error 2024-03-10 12:20:32: Failed to start zigbee
Zigbee2MQTT:error 2024-03-10 12:20:32: Check https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start.html for possible solutions
Zigbee2MQTT:error 2024-03-10 12:20:32: Exiting...
Zigbee2MQTT:error 2024-03-10 12:20:32: Error: Failure to connect
at Ezsp.connect (/app/node_modules/zigbee-herdsman/src/adapter/ezsp/driver/ezsp.ts:373:19)
at processTicksAndRejections (node:internal/process/task_queues:95:5)
at Driver.startup (/app/node_modules/zigbee-herdsman/src/adapter/ezsp/driver/driver.ts:163:13)
at Zigbee.start (/app/lib/zigbee.ts:62:27)
at Controller.start (/app/lib/controller.ts:109:27)
at start (/app/index.js:107:5)
Une première avancée grâce à un message qui vient d’être posté dans un autre sujet similaire :
Dans les options de config de Z2M j’ai viré les quatre lignes
Je n’ai plus le message 502 et Zigbee2Mqtt semble démarrer.
Je vais essayer de passer à l’étape suivante, faire correspondre les canaux Thread et Zigbee …
c’est normal, sans configuration de la partie MQTT, au lancement de Z2M ca créera un compte MQTT et remplira les informations du server MQTT automatiquement.
Citation
Si vous n’utilisez pas le module complémentaire du courtier Mosquitto, remplissez vos détails MQTT (laissez vide lorsque vous utilisez le module complémentaire du courtier Mosquitto)
En plus de la température et humidité, j’ai pu activer la tension des piles, le pourcentage restant, la qualité de la liaison. Ce ne sera sans doute pas très utile, mais maintenant que ça marche, je teste
