oui c’est tjs mieux
juste eviter la mise a jour de home assistant en tout debut de mois elle apporte certaines fois des petites instabilités
genre le mois suivent premier jeudi je crois quelle sort elle s’apellera 2024.7.0 attends la 2024.7.2
Je me permet de réactiver ce sujet car j’ai un peu le même genre de problème. ZHA est désactivé, le dongle est une Zigate+ Voici le log du broker
2024-07-10 09:16:25: New connection from 172.30.32.2:41144 on port 1883.
2024-07-10 09:16:25: Client <unknown> closed its connection.
en boucle
Celui de Z2M
[20:10:14] INFO: Preparing to start...
[20:10:16] INFO: Socat not enabled
[20:10:21] INFO: Starting Zigbee2MQTT...
[2024-07-09 20:10:34] info: z2m: Logging to console, file (filename: log.log)
[2024-07-09 20:10:34] info: z2m: Starting Zigbee2MQTT version 1.39.0 (commit #unknown)
[2024-07-09 20:10:34] info: z2m: Starting zigbee-herdsman (0.50.1)
[2024-07-09 20:10:35] info: zh:zstack:znp: Opening SerialPort with {"path":"/dev/ttyUSB0","baudRate":115200,"rtscts":false,"autoOpen":false}
[2024-07-09 20:10:35] info: zh:zstack:znp: Serialport opened
[2024-07-09 20:10:36] info: zh:zstack:znp: Writing CC2530/CC2531 skip bootloader payload
[2024-07-09 20:10:37] info: zh:zstack:znp: Skip bootloader for CC2652/CC1352
[2024-07-09 20:10:56] error: z2m: Error while starting zigbee-herdsman
[2024-07-09 20:10:56] error: z2m: Failed to start zigbee
[2024-07-09 20:10:56] error: z2m: Check https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start.html for possible solutions
[2024-07-09 20:10:56] error: z2m: Exiting...
[2024-07-09 20:10:56] error: z2m: Error: Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)
at ZStackAdapter.start (/app/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/zStackAdapter.ts:101:27)
at Controller.start (/app/node_modules/zigbee-herdsman/src/controller/controller.ts:129:29)
at Zigbee.start (/app/lib/zigbee.ts:63:27)
at Controller.start (/app/lib/controller.ts:139:27)
at start (/app/index.js:154:5)
et la config de mqtt
Dans le serial j’ai aussi essayé avec
/dev/serial/by-id/usb-FTDI_ZiGate_ZIGATE+-if00-port0
avec les mêmes erreurs.
Merci de votre aide
je n’ai pas de zigate mais je pense que tu as un pb dans ton fichier de conf Z2M, la partie adapter doit être dans serial et non dans socat ![]()
serial:
adapter: zigate
Bonjour @anon21985933 Ce sont les erreurs les plus voyantes qu’on ne voit plus à force de les chercher. Tu as mis le doigt dessus. Ça marche. Merci
tu devrais lire ce tutoriel [TUTO] Installation de Zigbee2mqtt et Broker Mosquitto.
Tu y trouveras la réponse :
Super ![]()
belle journée à toi et amuse toi bien avec ton HA ![]()
Bonjour @WarC0zes
J’en ai lu plusieurs mais je ne suis pas tombé sur celui-ci qui me parait parfait. Merci
