Exact:
[GreenCell]
driver = blazer_usb
port = auto
desc = "GreenCell Proof 600"
vendorid = 0001
[Eaton]
driver = usbhid-ups
port = auto
desc = "Eaton 3S 550"
vendorid = 0463
Exact:
[GreenCell]
driver = blazer_usb
port = auto
vendorid = 0001
[Eaton]
driver = usbhid-ups
port = auto
vendorid = 0463
J’essaie d’avancer sans trop vous solliciter, mais je bloque …
A partir de vos derniers messages, je suis allé faire un tour sur le site NUT par le lien de @Jblb. Comme indiqué par @Pulpy-Luke, j’ai tenté de remplacer la ligne driver: usbhid-ups par driver: blazer_usb ou par driver: nutdrv_qx (qui apparait également comme driver possible sur NUT Network UPS Tools - Micropower 600 )
Le journal ne semble plus indiquer l’erreur ‹ No matching HID UPS found ›
Avec NUTDRV_QX, voici les infos
cont-init: info: running /etc/cont-init.d/00-banner.sh
Add-on: Network UPS Tools
Manage battery backup (UPS) devices
Add-on version: 0.11.0
You are running the latest version of this add-on.
System: Home Assistant OS 9.2 (aarch64 / raspberrypi4-64)
Home Assistant Core: 2022.10.3
Home Assistant Supervisor: 2022.10.0
Please, share the above information when looking for help
or support in, e.g., GitHub, forums or the Discord chat.
cont-init: info: /etc/cont-init.d/00-banner.sh exited 0
cont-init: info: running /etc/cont-init.d/01-log-level.sh
cont-init: info: /etc/cont-init.d/01-log-level.sh exited 0
cont-init: info: running /etc/cont-init.d/02-set-timezone.sh
[09:15:17] INFO: Configuring timezone
cont-init: info: /etc/cont-init.d/02-set-timezone.sh exited 0
cont-init: info: running /etc/cont-init.d/nut.sh
[09:15:17] INFO: Setting mode to netserver...
[09:15:17] INFO: Generating /etc/nut/upsd.users...
[09:15:18] INFO: Configuring user: bubule
[09:15:18] INFO: Password is NOT in the Have I Been Pwned database! Nice!
[09:15:20] INFO: Configuring Device named Onduleur_Salon...
[09:15:20] INFO: Starting the UPS drivers...
Using protocol: Q1 0.07
Can't autodetect number of battery packs [-1/13.80]
Battery runtime will not be calculated (runtimecal not set)
Network UPS Tools - UPS driver controller 2.7.4
cont-init: info: /etc/cont-init.d/nut.sh exited 0
cont-init: info: running /etc/cont-init.d/nutclient.sh
cont-init: info: /etc/cont-init.d/nutclient.sh exited 0
services-up: info: copying legacy longrun upsd (no readiness notification)
services-up: info: copying legacy longrun upsmon (no readiness notification)
[09:15:31] INFO: Starting the UPS information server...
0.000000 fopen /run/nut/upsd.pid: No such file or directory
0.087665 listening on 0.0.0.0 port 3493
0.101343 Connected to UPS [Onduleur_Salon]: nutdrv_qx-Onduleur_Salon
[09:15:39] INFO: Starting the UPS monitor and shutdown controller...
0.000000 fopen /run/nut/upsmon.pid: No such file or directory
0.001313 Using power down flag file /etc/killpower
0.001728 UPS: Onduleur_Salon@localhost (master) (power value 1)
0.002487 debug level is '1'
0.002544 Warning: running as one big root process by request (upsmon -p)
0.003259 Init SSL without certificate database
0.024933 Trying to connect to UPS [Onduleur_Salon@localhost]
0.369536 User upsmonmaster@127.0.0.1 logged into UPS [Onduleur_Salon]
0.030136 Logged into UPS Onduleur_Salon@localhost
Avec BLAZER_USB
[09:22:06] INFO: Configuring timezone
[09:22:06] INFO: Setting mode to netserver...
[09:22:07] INFO: Generating /etc/nut/upsd.users...
[09:22:07] INFO: Configuring user: bubule
[09:22:08] INFO: Password is NOT in the Have I Been Pwned database! Nice!
[09:22:09] INFO: Configuring Device named Onduleur_Salon...
[09:22:09] INFO: Starting the UPS drivers...
Supported UPS detected with megatec protocol
Vendor information unavailable
No values provided for battery high/low voltages in ups.conf
Using 'guestimation' (low: 10.400000, high: 13.000000)!
[09:22:11] INFO: Starting the UPS information server...
0.001774 listening on 0.0.0.0 port 3493
0.002784 Connected to UPS [Onduleur_Salon]: blazer_usb-Onduleur_Salon
[09:22:11] INFO: Starting the UPS monitor and shutdown controller...
0.000962 Using power down flag file /etc/killpower
0.001406 UPS: Onduleur_Salon@localhost (master) (power value 1)
0.001913 debug level is '1'
0.001940 Warning: running as one big root process by request (upsmon -p)
0.002909 Init SSL without certificate database
0.010128 Trying to connect to UPS [Onduleur_Salon@localhost]
0.532776 User upsmonmaster@127.0.0.1 logged into UPS [Onduleur_Salon]
0.013117 Logged into UPS Onduleur_Salon@localhost
Ce qui semble indiquer qu’une communication est établie, mais je ne trouve rien dans les sensors
J’ai l’impression de rater cette partie : « Be sure to add the NUT integration after starting the add-on. » qui se trouve dans la marche à suivre de l’Addon
Cela me laisse penser que j’ai autre chose à faire après avoir configuré et démarré l’addon. Mais lorsque je clique sur le bouton ‹ add intergration ›, j’arrive sur la page des intégration avec cette fenêtre à compléter/enregistrer.
Lorsque je valide, que j’ai rempli ou non les champs nom d’utilisateur et mdp, j’ai toujours ce message d’erreur
Là je sèche …
J’utilise NUT sur une raspberry et mon serveur proxmox + l’Addon. J’ai suivi en partie ce tuto :
Il faut bien que tu renseignes ta dernière fenêtre avec le user que tu as déclaré dans NUT. C’est ceci qui va te générer les sensor.
Normalement dans la partie NUT tu dois avoir déclaré un User/Password pour la partie uspd.user.
C’est celui-ci que tu dois utiliser dans ta fenêtre d’intégration.
Toujours pas mieux
Il continue à me jeter avec l’erreur vu au-dessus (Échec de connexion). J’ai même tenté de remplacer mon mot de passe en imaginant qu’il n’était pas assez ou trop dur.
J’ai essayé sans mot de passe ni user également.
PS :
C’est assez perturbant ces deux parties qui portent le même nom (NUT addon et NUT integration). J’ai cru pendant 2 jours que c’était la même chose…
dans hôte j’ai mis a0d7b954-nut valeur que je trouve dans l’add-on sous Nom d'hôte
Peut-être que je me trompe mais pour moi le username et le password du code ci-dessus n’ont rien à voir avec ceux qui existe déjà sur ton pi. Ceci est propre au serveur NUT que tu es en train de configurer.
Je pense que tu dois juste en inventer un qui sera celui que tu devra utiliser quand tu ajouteras l’intégration ensuite.
C’était bien çà !
Il fallait mettre a0d7b954-nut sous Nom d’hôte
Bravo !
Et un grand merci
J’avance …
Je ne suis pas certain de ce que j’avance mais pour moi cela fonctionne comme ceci :
L’add-on NUT est en fait un seveur sur lequel tu déclare ton Onduleur et L’utilisateur qui pourra utiliser les infos de l’onduleur.
Ensuite il y a l’intégration NUT qui est en fait un client NUT qui se connecte au serveur NUT précédemment défini. Ce client doit donc utiliser les infos en concordance avec ce que tu as déclaré dans le serveur.
Pour résumer :
Ce qui équivaut à
Du coup tu veux dire que localhost ne fonctionne pas, j’ai bien compris ?
Oui tout à fait. Cela ne fonctionne pas avec localhost.
Je vais essayer de revenir aux autres driver pour voir si cela change quelque chose.
EDIT : Les deux drivers nutdrv_qx et blazer_usb fonctionnent et retournent à priori les mêmes informations. Le driver usbhid-ups ne fonctionne pas (pour le GreenCell 800VA)
Bizarrement, j’ai perdu l’accès distant. Obligé de me reconnecter en local… A suivre
C’est bon à savoir ça !
Petite nouvelle.
Après seulement 1an et demi la batterie du Greencell est HS. Obligé de la remplacer.
(Bien entendu je m’en suis rendu compte après une demi journée d’absence sans électricité à la maison. Et la domotique indisponible à distance comme ça arrive parfois. Forcément. L’onduleur se coupe presque instantanément. Pas le temps d’envoyer l’alerte programmée dans HA).
Vos Greencell tiennent le coup chez vous ?
J’i plus ou moins le même set-up (NAS Syno + son disque de backup + box + swich POE + Access Points Wifi POE) branchés sur un Eaton Ellipse PRO 1600.
Rien à dire, ça fonctionne, et les infos de l’onduleur remontent sur HA par l’intégration NUT (Network UPS Tool) native de HA.
En fonction de la puissance, tu pourras absorber des coupures de courant plus ou moins longues…
À mon avis, c’était la batterie, pour moi aussi, dès que je coupais l’électricité, l’onduleur s’éteignez dessuite.
Tente le coup, ta rien à perdre. Le SAV sur battery empire a été top.
En effet, les batteries ont une durée de vie limitée.
Malheureusement, on s’en rend compte en général lorsqu’il y a une coupure de courant et que tout s’arrête alors que l’on pensait que l’onduleur prendrai le relais.
Je ne sais pas si certains modèles d’onduleur ont un moyen de test régulier des batteries, mais ce serait utile.
Il y a aussi un piège à éviter: sur certains onduleurs, il y a une prise « maître », qui arrête tout lorsque la charge branchée dessus s’éteint. Si l’on veut faire des arrêts propres, il vaut mieux éviter d’utiliser cette prise.
Tous les onduleurs qui utilisent des batteries plomb/gel (c’est à dire 99.9% des onduleurs « informatique » vendu) verront leur batterie mourir assez rapidement, quelque soit la marque, et quelque soit le prix qui vous y mettez. C’est une limitation de cette technologie de batterie et de l’environnement dans lequel elles travaillent (souvent trop chaud)
Si vous avez beaucoup de chance, elles tiendront 3 ans, mais la durée de vie moyenne c’est 18 mois.
Dans les applications « critiques » on les change préventivement tous les ans.
Petite actualité avec coupure de courant hier 40 bonnes secondes, le greencell n’est pas reparti
Même sur la prise de courant.
Avec le testeur, la batterie est morte… Elle a quasi 4 ans, donc au dessus de la moyenne.
J’ai acheté mes deux onduleurs Eaton en 2021 …
Les autonomies remontée sont très théoriques, fonction de la conso des équipements à l’instant T, mais pour l’instant ça tiens pour les coupures brèves, on verra cet hiver, j’ai parfois des coupures de courant plus importantes.
