Camera Eufy et RTSP
Bonsoir,
Ma camera Eufy fonctionnait avec le code ci-dessous:
type: custom:stack-in-card
cards:
    primary: Caméra
    secondary: >
      Piscine - Batterie: {{ states('sensor.piscine_2_battery_percentage') }}% -
      Wifi {{ states('sensor.piscine_2_wifi_signal_level') }}
    icon: mdi:cctv
    icon_color: blue
  - type: custom:layout-card
    layout_type: masonry
    layout:
      max_cols: 1
      height: auto
      padding: 0px
      card_margin: var(--masonry-view-card-margin, 0px 8px 14px)
    cards:
      - type: custom:webrtc-camera
        entity: camera.piscine_2
        poster: piscine.jpg
        ui: true
        style: ".screenshot {display: none} .pictureinpicture {display: none}"
        shortcuts:
          - name: Play
            icon: mdi:play
            service: camera.turn_on
            service_data:
              entity_id: camera.piscine_2
          - name: Stop
            icon: mdi:stop
            service: camera.turn_off
            service_data:
mais elle ne fonctionne plus. J’ai essayé la carte WEBRTC minimal et flux RTSP:
type: 'custom:webrtc-camera'
url: 'rtsp://rtsp://127.0.0.1:8554/T8134P2024080159/av_stream/ch0'
et j’ai ce message d’erreur:
version core-2025.2.4
python_version 3.13.1
os_version 6.6.73-haos
arch x86_64
timezone Europe/Lisbon
GitHub API Calls Remaining 4994
Installed Version 2.0.5
Available Repositories 1606
Downloaded Repositories 41
AccuWeather
can_reach_server ok
remaining_requests 49
logged_in true
subscription_expiration 19 juillet 2025 à 01:00
relayer_connected true
relayer_region eu-central-1
remote_enabled true
remote_connected true
alexa_enabled true
google_enabled true
remote_server eu-central-1-6.ui.nabu.casa
certificate_status ready
instance_id 412abc55dae643638550d87ca53c578d
host_os Home Assistant OS 14.2
supervisor_version supervisor-2025.02.1
agent_version 1.6.0
docker_version 27.2.0
disk_total 30.8 GB
disk_used 14.7 GB
virtualization kvm
board ova
installed_addons Advanced SSH & Web Terminal (20.0.0), File editor (5.8.0), Matter Server (7.0.0), Zigbee2MQTT (2.1.1-1), Mosquitto broker (6.5.0), ESPHome Device Builder (2024.12.4), go2rtc (1.9.8), eufy-security-ws (1.9.1), TasmoAdmin (0.31.4), Samba Backup (5.2.0)
Instituto Português do Mar e Atmosfera (IPMA)
api_endpoint_reachable ok
dashboards 5
resources 32
views 26
Network Configuration
adapters lo (disabled), enp0s3 (enabled, default, auto), docker0 (disabled), hassio (disabled), veth3df5df9 (disabled), veth26921d2 (disabled), veth8c9ea0e (disabled), vethfa25707 (disabled), vethbd3761f (disabled), vethb8312c0 (disabled), veth50dfc3e (disabled), vethe487280 (disabled), vethd6c0676 (disabled), veth1da21de (disabled)
ipv4_addresses lo (127.0.0.1/8), enp0s3 (192.168.0.118/24), docker0 (172.30.232.1/23), hassio (172.30.32.1/23), veth3df5df9 (), veth26921d2 (), veth8c9ea0e (), vethfa25707 (), vethbd3761f (), vethb8312c0 (), veth50dfc3e (), vethe487280 (), vethd6c0676 (), veth1da21de ()
ipv6_addresses lo (::1/128), enp0s3 (fe80::efeb:607d:e466:c2a0/64), docker0 (fe80::42:5cff:fed6:ec53/64), hassio (fe80::42:79ff:fe83:3a78/64), veth3df5df9 (fe80::2842:aff:fe50:c28f/64), veth26921d2 (fe80::30b5:a4ff:fef8:61f5/64), veth8c9ea0e (fe80::e81e:aeff:fe4b:50d4/64), vethfa25707 (fe80::b81a:f3ff:fe71:1a01/64), vethbd3761f (fe80::e8c8:9dff:fe05:927e/64), vethb8312c0 (fe80::6cf7:edff:fe24:9370/64), veth50dfc3e (fe80::98f6:75ff:fe94:2ee4/64), vethe487280 (fe80::6ccc:8aff:fe4d:f072/64), vethd6c0676 (fe80::f87f:6cff:fe97:2079/64), veth1da21de (fe80::6c77:dcff:fecc:daa2/64)
announce_addresses 192.168.0.118, fe80::efeb:607d:e466:c2a0
oldest_recorder_run 7 février 2025 à 07:06
current_recorder_run 18 février 2025 à 15:04
estimated_db_size 912.23 MiB
database_version 3.47.1
Spotify
Des idées? Pour l'instant je ne trouve pas...
De mémoire les caméras Eufy ne restent pas actives avec le mode RTSP (utilisé pour connecter un NVR externe en général) et ne s’active que lorsque que la caméra se réveille en détectant un mouvement. Donc quand tu active le mode, ca marche pendant quelques minutes, puis le flux s’éteint en attente de se faire réveiller.
Après ta configuration est bizarre : tu pointe sur l’adresse en local ?? Tu as un proxy RTSP qui tourne en local ?
Voilà les réglages…
@Steamerlight : c’était la bonne piste. je cite @Argonaute :
Le live est transmis en RTSP, mais la transmission n’est pas active en permanence.
Pour voir le live, il faut activer le flux. Pour cela, il faut appeler le service : eufy_security.start_rtsp_livestream avant d’accéder la carte qui affiche la caméra
Solution trouvé dans ce sujet: Eufy security et camera.
