je viens de recevoir une clef bluetooth sena 100
j’ai redemarré le raspberry completement. clef usb branchée sur le port usb3 avec une rallonge usb3 d’environ 1m
je vais dans https://192.168.10.11:8123/config/integrations/integration/bluetooth
acttiver les journaux de debug : https://termbin.com/285t
et j’ai une serie d’erreurs liées au programme python
j’ai lancé lsub
Bus 001 Device 006: ID 10c4:ea60
Bus 001 Device 001: ID 1d6b:0002
Bus 001 Device 003: ID 0a12:4010
Bus 001 Device 002: ID 2109:3431
Bus 002 Device 002: ID 174c:55aa
Bus 002 Device 001: ID 1d6b:0003
Bus 001 Device 004: ID 1a40:0101
Bus 001 Device 005: ID 0a12:4007
puis bluetoothctl en ssh sur home assistant
~ # bluetoothctl
Agent registered
[CHG] Controller DC:A6:32:22:E4:B0 Pairable: yes
AdvertisementMonitor path registered
https://termbin.com/dv7j1
version | core-2023.7.1
dev | false
hassio | true
docker | true
user | root
virtualenv | false
python_version | 3.11.4
os_name | Linux
os_version | 6.1.21-v8
arch | aarch64
timezone | Europe/Paris
config_dir | /config
GitHub API | ok
GitHub Content | ok
GitHub Web | ok
GitHub API Calls Remaining | 4740
Installed Version | 1.32.1
Stage | running
Available Repositories | 1333
Downloaded Repositories | 7
</details>
logged_in | false
can_reach_cert_server | ok
can_reach_cloud_auth | ok
can_reach_cloud | ok
</details>
host_os | Home Assistant OS 10.3
update_channel | stable
supervisor_version | supervisor-2023.07.1
agent_version | 1.5.1
docker_version | 23.0.6
disk_total | 109.3 GB
disk_used | 7.7 GB
healthy | true
supported | true
board | rpi4-64
supervisor_api | ok
version_api | ok
installed_addons | Mosquitto broker (6.2.1), Samba share (10.0.2), Node-RED (14.3.0), Advanced SSH & Web Terminal (15.0.2), File editor (5.6.0), ESPHome (2023.6.4), Duck DNS (1.15.0), Studio Code Server (5.8.1), Zigbee2MQTT (1.32.0-2), Home Assistant Google Drive Backup (0.111.1), AppDaemon (0.13.1)
</details>
dashboards | 2
resources | 1
views | 6
mode | storage
</details>
oldest_recorder_run | 29 juin 2023 à 16:07
current_recorder_run | 7 juillet 2023 à 13:27
estimated_db_size | 25.41 MiB
database_engine | sqlite
database_version | 3.41.2
</details>`
Giga77
Juillet 7, 2023, 12:56
2
ce sont des erreurs avec ESPHome et avec un template
Corrige ton template avec:
states('sensor.alimentation_esp82266_2') | float(0)
Il n’y a pas de logs dans ce fichier.
Poste les sur le forum dans du texte préformaté.
merci de votre réponse.
lsusb du raspberry pi et bluetoothctl
# lsusb
~ # bluetoothctl
Agent registered
[NEW] Device 53:4D:A3:20:EE:95 53-4D-A3-20-EE-95
[DEL] Device 53:4D:A3:20:EE:95 53-4D-A3-20-EE-95
[NEW] Device 7D:B9:E1:02:7B:42 7D-B9-E1-02-7B-42
[DEL] Device 7D:B9:E1:02:7B:42 7D-B9-E1-02-7B-42
haos reconnait la clef bluetooth sur le raspberry pi 4 mais pas la sena branchée sur le raspberry pi
lorsque je veux ajouter un dongle bluetooth ca affiche
Bluetooth
Aucun adaptateur Bluetooth non configuré n'a été trouvé. Il y a des adaptateurs ignorés 0.
Giga77
Juillet 7, 2023, 1:41
4
Il n’y a pas d’erreur dans les logs et Je n’ai pas cette clé.
As-tu regardé ce sujet :
bonjour
J ai donc acheté la clé Sena ud , et installé via hac le
Passive blé monitor integration.
Après dans paramètres -<>intégration ->je retrouve le bleutooth low energy, je configuré (via l interface, pas de modification du .yaml) mais il ne retrouve aucun appareil…
[Screenshot_20230203-183319]
[Screenshot_20230203-183310]
Home Assistant 2023.2.1
Supervisor 2023.01.1
Operating System 9.5
Interface utilisateur : 20230202.0 - latest
les clé zigbee, bluetooth et zware n’apprécie pas l’USB3. C’est recommander de les utiliser sur un USB2.
In case someone else runs into the same problem, I just wanted to report my recent experience: I was setting up a second Home Assistant instance (for my cabin) on an RPi4 with the data partition on a USB3.0 SSD (the RPi4 booting from the SD card,...
Reading time: 1 mins 🕑
Likes: 3 ❤
j’ai commandé une clef mais qui sert uniquement en audio. j’attends ma livraison de celle sena ud100 .
je viens de recevoir une clef sena ud100 qui est bien reconnue…
mais mon enceinte anker bluetooth n’est pas reconnue sur google cast ? j’ai ecrit un autre post le 21-7
