J’ai le module Frigate installé directement dans Home Assistant OS, j’ai aussi l’add-on Frigate de HACS et Mosquitto MQTT et je voudrais savoir comment on connecte Frigate à Home Assistant pour avoir des fonctions tels que la carte dans le tableau de bord. J’accède à Frigate via Ingress.
La configuration :
version
core-2025.7.2
installation_type
Home Assistant OS
dev
false
hassio
true
docker
true
container_arch
amd64
user
root
virtualenv
false
python_version
3.13.3
os_name
Linux
os_version
6.12.35-haos
arch
x86_64
timezone
Europe/Paris
config_dir
/config
GitHub API
ok
GitHub Content
ok
GitHub Web
ok
HACS Data
ok
GitHub API Calls Remaining
4994
Installed Version
2.0.5
Stage
running
Available Repositories
2108
Downloaded Repositories
3
logged_in
false
can_reach_cert_server
ok
can_reach_cloud_auth
ok
can_reach_cloud
ok
host_os
Home Assistant OS 16.0
update_channel
stable
supervisor_version
supervisor-2025.07.1
agent_version
1.7.2
docker_version
28.3.0
disk_total
984.3 GB
disk_used
311.6 GB
healthy
true
supported
true
host_connectivity
true
supervisor_connectivity
true
ntp_synchronized
true
virtualization
kvm
board
ova
supervisor_api
ok
version_api
ok
installed_addons
VLC (0.3.0), Frigate (Full Access) (0.15.2), File editor (5.8.0), Advanced SSH & Web Terminal (21.0.2), Get HACS (1.3.1), Mosquitto broker (6.5.1), Matter Server (8.0.0)
dashboards
4
resources
1
views
2
mode
storage
Network Configuration
adapters
lo (disabled), enp0s18 (enabled, default, auto), hassio (disabled), docker0 (disabled), vethd4bd280 (disabled), vethf887fdd (disabled), veth9536bd5 (disabled), vethfc4357e (disabled), veth98b3c3a (disabled), vethf2464a2 (disabled), veth6bd9ade (disabled), veth42eb0ec (disabled)
ipv4_addresses
lo (127.0.0.1/8), enp0s18 (192.168.1.82/24), hassio (172.30.32.1/23), docker0 (172.30.232.1/23), vethd4bd280 (), vethf887fdd (), veth9536bd5 (), vethfc4357e (), veth98b3c3a (), vethf2464a2 (), veth6bd9ade (), veth42eb0ec ()
ipv6_addresses
lo (::1/128), enp0s18 (2a01:cb18:c93:6e00:93ed:53dd:7e28:9768/64, fe80::e89b:865:9685:a89d/64), hassio (fe80::102b:1dff:feb5:ba4f/64), docker0 (fe80::d8ce:2bff:fea5:5bc2/64), vethd4bd280 (fe80::bc01:63ff:fead:a67c/64), vethf887fdd (fe80::3c3d:5aff:fe5b:7452/64), veth9536bd5 (fe80::d4d9:baff:fee2:732c/64), vethfc4357e (fe80::4459:6fff:fec1:53cc/64), veth98b3c3a (fe80::e8a9:b9ff:feb0:ea78/64), vethf2464a2 (fe80::7436:4eff:fefb:8a78/64), veth6bd9ade (fe80::b84f:32ff:fec9:a03/64), veth42eb0ec (fe80::f4d5:78ff:fe36:fae9/64)
announce_addresses
192.168.1.82, 2a01:cb18:c93:6e00:93ed:53dd:7e28:9768, fe80::e89b:865:9685:a89d
oldest_recorder_run
6 juillet 2025 à 17:12
current_recorder_run
19 juillet 2025 à 16:36
estimated_db_size
66.74 MiB
database_engine
sqlite
database_version
3.48.0
Bonne journée / bonne soirée.
Salut…
Pour la carte il n’y a rien à faire…
Frigate (Addon) envoie en MQTT
MQTT (Addon Mosquitto) stocke les message
HA lit le MQTT avec l’intégration MQTT et créer les entités
Et toi tu créees les cartes avec les entités
L’ingress ne sert à rien dans ce cas, sauf à ce que toi tu manipules la config/infos de Frigate
Bonjour, merci de votre réponse, doucoup comment faire pour bien connecter MQTT de mosquitto Home Assistant à Frigate ?
Merci de votre réponse, bonne journée / bonne soirée.
C’est l’inverse ! Frigate se connecte à MQTT.
Et tout est dans la config de frigate
Bonjour à tous
Nouveau et débutant, isolé, sous Home Assitant et la domotique, je galère pas mal, mais petit à petit cela avance.
Donc pour ce nouveau sujet, j’essaie d’installer Frigate, en décrivant un maximum pour que cela puisse aider les autres si besoin.
J’ai installé HA sur une VM et sur la Freebox Delta.
Hyper simple quand on pas par l’installation de l’image HAos.
Souhaitant intégrer mes cameras DAHUA, je me lance à installer FRIGATE pour utiliser comme NVR.
En premier il install…
et chaque caméra est eligible ou non
https://docs.frigate.video/integrations/mqtt/
bonjour, je test pleins de choses dans la parte login de mosquitto mqtt mais sa fait que des erreurs du style:
Échec de l’enregistrement de la configuration du module complémentaire, Invalid list for option ‹ logins › in Mosquitto broker (core_mosquitto). Got {‹ logins ›: {‹ logins ›: [{‹ username ›: ‹ censure ›, ‹ password ›: ‹ mdpcensure ›}], ‹ anonymous ›: False, ‹ customize ›: {‹ active ›: False, ‹ folder ›: ‹ mosquitto ›}, ‹ require_certificate ›: False, ‹ certfile ›: ‹ fullchain.pem ›, ‹ keyfile ›: ‹ privkey.pem ›}, ‹ require_certificate ›: False, ‹ certfile ›: ‹ fullchain.pem ›, ‹ keyfile ›: ‹ privkey.pem ›, ‹ customize ›: {‹ active ›: False, ‹ folder ›: ‹ mosquitto ›}}
Tu veux pas plutôt partager la config ?
C’est plus facile que de tenter de deviner à partir de l’erreur…
ET à priori tu n’utilises pas Frigate en addon, donc core-mosquitto ça n’existe pas de l’exterieur de ha
Bonjour, voici ma config :
version
core-2025.7.2
installation_type
Home Assistant OS
dev
false
hassio
true
docker
true
container_arch
amd64
user
root
virtualenv
false
python_version
3.13.3
os_name
Linux
os_version
6.12.35-haos
arch
x86_64
timezone
Europe/Paris
config_dir
/config
GitHub API
ok
GitHub Content
ok
GitHub Web
ok
HACS Data
ok
5000
Installed Version
2.0.5
Stage
running
2108
3
logged_in
false
ok
ok
can_reach_cloud
ok
host_os
update_channel
stable
supervisor_version
agent_version
1.7.2
docker_version
28.3.0
disk_total
984.3 GB
disk_used
318.2 GB
healthy
true
supported
true
host_connectivity
true
true
ntp_synchronized
true
virtualization
kvm
board
ova
supervisor_api
ok
version_api
ok
installed_addons
dashboards
4
resources
1
views
2
mode
storage
adapters
ipv4_addresses
ipv6_addresses
announce_addresses
oldest_recorder_run
estimated_db_size
67.95 MiB
database_engine
sqlite
database_version
3.48.0
Avec Frigate ajouté comme module complémentaire et aussi comme add-on HACS (les deux) il apparait d’ailleurs à gauche :
J’ai également Mosquitto broker et j’ai eu l’erreur dans la partie login de Mosquitto, je me demande comment mettre en page ça pour que sa fonctionne.
Le tout est sur Home Assistant OS qui lui même est sur Proxmox.
Tu as bien rempli la partie MQTT de Frigate ?
C’est ça qui est important
Oui mais faut mettre nom d’utilisateur et mot de passe faut donc avoir les mêmes dans Mosquitto ? Non ?
Le même pas forcement mais un qui est valable oui
Bonjour, merci ça a fonctionné, maintenant, il y a un autre problème : j’ai pas vu d’autres entités apparaitre.
Regarde les logs, de frigate, de HA , de MQTT. Vérifie l’integration Frigate. L’autodiscovery…
Là moi j’ai rien sous les yeux
Bonjour, justement j’ai été dans modules complémentaires > Frigate (full access) > journaux ensuite rechercher avec Google Chrome MQTT et sa n’a rien trouvé à propos de MQTT dans la page.
Je t’ai donné toutes les pistes à suivre (pas juste une). A toi de pointer ou ça cloche … Là je ne peux rien de plus tant que tu n’as pas au moins 1 indice… Le souci c’est pas non plus forcément MQTT.
Une fois que tu as bien configuré la liaison mqtt frigate vers le broker de HA as tu pensé à faire « recharger » dans l’intégration Frigate ?
A noter aussi que les entités apparaissant dans l’ intégration Frigate dépendent des éléments configurés dans ta conf Frigate.
Bonjour, c’est bon j’ai réussi à le faire fonctionner en utilisant l’intégration Frigate HACS.
system
A fermé ce sujet ()
Juillet 22, 2025, 5:24
17
