Suite au passage de HA Core en version 2023.11.3, j’étais en 2023.10.0 précédemment la clé Sonoff n’est plus détectée dans l’intégration ZHA et j’ai un échec de la configuration :
Ma configuration :
Sonoff
Mes logs :
Logger: homeassistant.config_entries
Source: config_entries.py:402
First occurred: 16:36:28 (1 occurrences)
Last logged: 16:36:28
Error setting up entry SONOFF Zigbee 3.0 USB Dongle Plus V2 for zha
File "/usr/local/lib/python3.11/site-packages/serial/serialposix.py", line 322, in open
self.fd = os.open(self.portstr, os.O_RDWR | os.O_NOCTTY | os.O_NONBLOCK)
FileNotFoundError: [Errno 2] No such file or directory: '/dev/ttyACM0'
File "/usr/src/homeassistant/homeassistant/config_entries.py", line 402, in async_setup
result = await component.async_setup_entry(hass, self)
File "/usr/src/homeassistant/homeassistant/components/zha/__init__.py", line 164, in async_setup_entry
await zha_gateway.async_initialize()
File "/usr/src/homeassistant/homeassistant/components/zha/core/gateway.py", line 224, in async_initialize
raise exc
File "/usr/src/homeassistant/homeassistant/components/zha/core/gateway.py", line 209, in async_initialize
await self.application_controller.startup(auto_form=True)
File "/usr/local/lib/python3.11/site-packages/zigpy/application.py", line 213, in startup
await self.connect()
File "/usr/local/lib/python3.11/site-packages/bellows/zigbee/application.py", line 139, in connect
await ezsp.connect(use_thread=self.config[CONF_USE_THREAD])
File "/usr/local/lib/python3.11/site-packages/bellows/ezsp/__init__.py", line 179, in connect
self._gw = await bellows.uart.connect(self._config, self, use_thread=use_thread)
File "/usr/local/lib/python3.11/site-packages/bellows/uart.py", line 405, in connect
protocol, connection_done = await thread.run_coroutine_threadsafe(
File "/usr/local/lib/python3.11/site-packages/bellows/uart.py", line 384, in _connect
transport, protocol = await zigpy.serial.create_serial_connection(
File "/usr/local/lib/python3.11/site-packages/zigpy/serial.py", line 48, in create_serial_connection
transport, protocol = await pyserial_asyncio.create_serial_connection(
File "/usr/local/lib/python3.11/site-packages/serial_asyncio_fast/__init__.py", line 508, in create_serial_connection
serial_instance = await loop.run_in_executor(None, callback)
File "/usr/local/lib/python3.11/concurrent/futures/thread.py", line 58, in run
result = self.fn(*self.args, **self.kwargs)
File "/usr/local/lib/python3.11/site-packages/serial/__init__.py", line 90, in serial_for_url
instance.open()
File "/usr/local/lib/python3.11/site-packages/serial/serialposix.py", line 325, in open
raise SerialException(msg.errno, "could not open port {}: {}".format(self._port, msg))
serial.serialutil.SerialException: [Errno 2] could not open port /dev/ttyACM0: [Errno 2] No such file or directory: '/dev/ttyACM0'
Merci de votre aide.
