Renseigner votre problème
version |
core-2025.3.4 |
installation_type |
Home Assistant OS |
dev |
false |
hassio |
true |
docker |
true |
user |
root |
virtualenv |
false |
python_version |
3.13.2 |
os_name |
Linux |
os_version |
6.12.18-haos |
arch |
x86_64 |
timezone |
Europe/Paris |
config_dir |
/config |
GitHub API |
ok |
GitHub Content |
ok |
GitHub Web |
ok |
HACS Data |
ok |
GitHub API Calls Remaining |
5000 |
Installed Version |
2.0.5 |
Stage |
running |
Available Repositories |
1608 |
Downloaded Repositories |
48 |
logged_in |
false |
can_reach_cert_server |
ok |
can_reach_cloud_auth |
ok |
can_reach_cloud |
ok |
host_os |
Home Assistant OS 15.0 |
update_channel |
stable |
supervisor_version |
supervisor-2025.03.3 |
agent_version |
1.7.2 |
docker_version |
28.0.1 |
disk_total |
30.8 GB |
disk_used |
19.0 GB |
healthy |
true |
supported |
true |
host_connectivity |
true |
supervisor_connectivity |
true |
ntp_synchronized |
true |
virtualization |
kvm |
board |
ova |
supervisor_api |
ok |
version_api |
ok |
installed_addons |
Mosquitto broker (6.5.0), Samba share (12.5.0), ESPHome Device Builder (2025.3.0), Node-RED (19.0.2), UniFi Network Application (4.0.2), Grafana (10.4.2), Advanced SSH & Web Terminal (20.0.2), Zigbee2MQTT (2.1.3-1), File editor (5.8.0), AdGuard Home (5.2.6), Frigate (0.15.0), Duck DNS (1.18.0), WireGuard (0.11.0), Matter Server (7.0.0), Studio Code Server (5.18.3), PS5 MQTT (1.4.0), OpenThread Border Router (2.13.0), Silicon Labs Flasher (0.3.2), ZigStar Silicon Labs FW Flasher (0.1.1), ZigStar TI CC2652P/P7 FW Flasher (0.4.1) |
dashboards |
3 |
resources |
24 |
views |
10 |
mode |
storage |
Network Configuration
adapters |
lo (disabled), enp0s18 (enabled, default, auto), hassio (disabled), docker0 (disabled), veth5990223 (disabled), vethbadee5f (disabled), vethea20a47 (disabled), veth3e2d10f (disabled), veth6590b2b (disabled), veth8e292c5 (disabled), vethdd436b1 (disabled), veth67ab123 (disabled), veth385d992 (disabled), veth337d775 (disabled), veth1a8c146 (disabled), veth1318b4b (disabled), vetha2b16f8 (disabled), veth7aa7f70 (disabled) |
ipv4_addresses |
lo (127.0.0.1/8), enp0s18 (192.168.1.28/24), hassio (172.30.32.1/23), docker0 (172.30.232.1/23), veth5990223 (), vethbadee5f (), vethea20a47 (), veth3e2d10f (), veth6590b2b (), veth8e292c5 (), vethdd436b1 (), veth67ab123 (), veth385d992 (), veth337d775 (), veth1a8c146 (), veth1318b4b (), vetha2b16f8 (), veth7aa7f70 () |
ipv6_addresses |
lo (::1/128), enp0s18 (2a01:cb00:8552:4a00:e161:9054:df14:c400/64, fe80::a1fc:33b3:dca9:81c0/64), hassio (fe80::8ca9:c2ff:fe90:45eb/64), docker0 (fe80::b089:abff:fe84:553c/64), veth5990223 (fe80::1892:2aff:fe57:4007/64), vethbadee5f (fe80::d0ac:a2ff:fe23:ff4a/64), vethea20a47 (fe80::4410:4dff:fe3d:bd9f/64), veth3e2d10f (fe80::3c63:b2ff:feda:6f42/64), veth6590b2b (fe80::3c56:3bff:fe63:4873/64), veth8e292c5 (fe80::983d:90ff:fe66:dac2/64), vethdd436b1 (fe80::d840:b1ff:fedb:2530/64), veth67ab123 (fe80::e4bd:4fff:fe03:ac7c/64), veth385d992 (fe80::1055:ddff:fe42:4ca7/64), veth337d775 (fe80::f09c:ff:fe08:3269/64), veth1a8c146 (fe80::6c51:d8ff:fe9f:dcfa/64), veth1318b4b (fe80::a0d9:76ff:fe3c:1656/64), vetha2b16f8 (fe80::704f:b4ff:feff:7b1f/64), veth7aa7f70 (fe80::a01f:bfff:fe3d:6eb0/64) |
announce_addresses |
192.168.1.28, 2a01:cb00:8552:4a00:e161:9054:df14:c400, fe80::a1fc:33b3:dca9:81c0 |
oldest_recorder_run |
11 mars 2025 à 19:18 |
current_recorder_run |
22 mars 2025 à 08:22 |
estimated_db_size |
330.46 MiB |
database_engine |
sqlite |
database_version |
3.48.0 |
J aimerai savoir s il était possible de créer une connexion ssh de HA vers un rpi ( HA vers un pihole par exemple) depuis un bouton ou autre? et si quelqu un avait déjà essayé?
J aimerai pouvoir faire les mises du noyau/ sécurité depuis mon HA.
Merci d avance et bon samedi à toutes et à tous
Olivier
Si tu cherches sur le forum… tu trouveras 2 posts tutoriels expliquant comment se connecter à un raspberry distant à partir de HA avec ssh
Command Line avec ssh sur raspberry-pi distant
Shell_command comment lancer un processus sur une machine distante en YAML (tuto)
Ah cool merci beaucoup. je vais me lire ça tranquillement avec un café;
Merci bonne journée
