Custom bar-card customisations non fonctionnelles sur PC
Bonjour à tous ,
Depuis quelques jours j’ai les cartes custom bar-card qui fonctionnent différemment entre application smartphone et PC quelque soit le navigateur !
Voici l’exemple concret :
Sur le téléphone :
et sur le PC :
voici le code associé :
type: custom:config-template-card
variables:
  - entity: sensor.disjoncteur_prises_power
  - entity: sensor.sonoff_1000fd09b5_power
  - entity: sensor.sonoff_1000e7de36_power
  - entity: sensor.sonoff_1000fcfa16_power
  - entity: sensor.sonoff_1000bd9b3b_power
  - entity: sensor.sonoff_1000fd0bbf_power
  - entity: sensor.sonoff_100178b0f6_power
    name: Prise Ordi & NVR
  - entity: sensor.sonoff_100178b097_power
    name: Prise PDG Ext
  - entity: sensor.sonoff_100178b0c0_power
    name: Prise PDG Int
  - entity: sensor.sonoff_1000fcfd9e_power
  - entity: sensor.sonoff_1000e7dc7f_power
  - entity: sensor.sonoff_1000bd9abe_power
  - entity: sensor.sonoff_1000bdb28c_power
    name: Frigo Katy & Dyson
  - entity: sensor.prise_machine_a_laver_le_linge_power
  - sensor.disjoncteur_prises_power
  - sensor.sonoff_1000fd09b5_power
  - sensor.sonoff_1000e7de36_power
  - sensor.sonoff_100178b0f6_power
  - sensor.sonoff_1000fcfa16_power
  - sensor.sonoff_1000bd9b3b_power
  - sensor.sonoff_1000fd0bbf_power
  - sensor.sonoff_100178b097_power
  - sensor.sonoff_100178b0c0_power
  - sensor.sonoff_1000fcfd9e_power
  - sensor.sonoff_1000e7dc7f_power
  - sensor.sonoff_1000bd9abe_power
  - sensor.sonoff_1000bdb28c_power
  - sensor.prise_machine_a_laver_le_linge_power
element:
  type: custom:bar-card
  entities: >-
    ${vars.filter(v => states[v.entity] && states[v.entity].state &&
    states[v.entity].state >= 1).sort((v1,v2) =>
    states[v2.entity].state-states[v1.entity].state)}
  direction: right
  entity_row: false
  min: 0
  max: >-
    ${ Math.max(...vars.map(v => states[v.entity].state).filter(v => v !=
    'unavailable'))}
  height: 30px
  stack: vertical
  decimal: 0
  icon: mdi:flash
  positions:
    icon: 'off'
    indicator: outside
    value: inside
  style: >
    #states > *  {
      margin: 2px;
    bar-card-name {
      font-size: 0.9rem;
      color: #808080;
      font-weight: bold;}
     bar-card-value {
      font-size: 0.9rem;
      color: white;
      font-weight: bold; }
     bar-card-value {
      font-weight: bolder;}
     bar-card-indicator  {
      margin-top: 4px;
      transform: scaleY(-1); }
     bar-card-backgroundbar {
      background: linear-gradient(to right, green 15%,
    orange 40%, red 75%); border-radius: 10px }
     bar-card-currentbar {
      background: linear-gradient(to right, #00FF1A,yellow
    35%, orange 60%, red 85%); clip-path: polygon(0 0, var(--bar-percent) 0,
    var(--bar-percent) 100%, 0 100%); border-radius: 30px }
Avez vous idée du problème ??? je rappelle que ce code fonctionnait encore il y a peu ( moins d’un mois )
merci d’avance
Cyril
Certainement lié à l’évolution de Card_mod.
Rajoute Card_mod: sur la ligne avant Style, et indente le tout de 2 espaces…
Salut @Cyril_81
@Gilles2 a sûrement la bonne réponse.
Pour plus d’info :
Ca sert de s’être fait avoir aussi par ce changement :wink:
Je suis bien d’accord :wink:
D’ailleurs grâce à ce topic, je me suis aperçu que j’avais oublié de faire la modif sur une de mes cartes de ce même type :stuck_out_tongue:
Il faut dire qu’il y a rapidement du Card_mod un peu partout dans les dashboards…
les gars, je vous dit MERCI !!! c’est parfaitement ça la solution !!! :star_struck:
Je reviens très vite sur le sujet du dernier update de card_mod.
L’ajout de card_mod: dans le code solutionne bien mon problème , MAIS , dès lors qu’une carte apexcharts est placée sur la même page de celle utilisant le card_mod , à chaque refresh de l’apexcharts on aperçois pendant une très courte période la carte utilisant le card_mod MAIS sans l’option card mod activée … je sais pas si c’est clair mon explication en fait … j’ai une video mais pas sur que je puisse la publier … avez vous remarqué cela vous aussi ??
Salut @Cyril_81
De mon côté je ne constate pas ce phénomène.
Pour la publication de vidéo, tu peux faire une capture en .gif avec :
licecap ou peek screen recorder
@Herbs merci pour les infos concernant les gifs , donc voici le problème :
card_mod default
Dans ton configuration.yaml t’as déjà des settings pour le frontend du style :
frontend:
en fait j’ai que ça :
frontend:
extra_module_url:
- /hacsfiles/lovelace-card-mod/card-mod.js
Pour écarter l’hypothèse de la « surcharge » de cet onglet, tu pourrais en créer un vierge avec seulement 2 cartes :
  • bar-card
  • apex
Et voir si ça fait la même chose ?
Je viens de faire cela , et rien ne change , même avec seulement deux cartes le problème persiste
là je suis un peu « sec » …
Tu devrais peut-être créer un thread dédié à ce problème pour plus de visibilité ???
j’ai essayé de laisser un message sur github pour signaler le problème
j’ai également lu beaucoup de problèmes depuis le passage en v3.4.0 et les suivantes …
je laisse ci dessous le code source de ma carte pour que si quelques un veulent essayer et me renvoyer leurs résultats :
variables:
  - entity: XXXXXX
  - entity: YYYYYY
  - sensor.XXXXX
  - sensor.YYYYY
 element:
  entities: >-
  direction: right
  entity_row: false
  min: 0
  max: >-
    'unavailable'))}
  height: 30px
  stack: vertical
  decimal: 0
  icon: mdi:flash
  positions:
    icon: 'off'
    indicator: outside
    value: inside
  card_mod:
    style: >
      states > *  {
        margin: 2px;
       bar-card-name {
        font-size: 0.9rem;
        color: #808080;
        font-weight: bold;
       bar-card-value {
        font-size: 0.9rem;
        color: white;
        font-weight: bold;
       bar-card-value {
        margin-top: 4px;
Faudra juste remplacer par des capteurs de conso les XXXXX et YYYYY.
Merci d’avance pour vos retours
