Merci encore pour votre aide.
Ci-dessous les logs.
Mais j’ai décoché « Chien de garde » pour éviter que ce soit trop long à cause du redémarrage.
[00:06:52] INFO: Preparing to start...
[00:06:52] INFO: Socat not enabled
[00:06:53] INFO: Starting Zigbee2MQTT...
[2026-03-29 00:06:53] info: z2m: Logging to console, file (filename: log.log)
[2026-03-29 00:06:53] info: z2m: Starting Zigbee2MQTT version 2.9.1 (commit #unknown)
[2026-03-29 00:06:53] info: z2m: Starting zigbee-herdsman (9.0.9)
[2026-03-29 00:06:53] info: zh:ember: Using default stack config.
[2026-03-29 00:06:53] info: zh:ember: ======== Ember Adapter Starting ========
[2026-03-29 00:06:53] info: zh:ember:ezsp: ======== EZSP starting ========
[2026-03-29 00:06:53] info: zh:ember:uart:ash: ======== ASH Adapter reset ========
[2026-03-29 00:06:53] info: zh:ember:uart:ash: Socket ready
[2026-03-29 00:06:53] info: zh:ember:uart:ash: ======== ASH starting ========
[2026-03-29 00:06:54] info: zh:ember:uart:ash: ======== ASH connected ========
[2026-03-29 00:06:54] info: zh:ember:uart:ash: ======== ASH started ========
[2026-03-29 00:06:54] info: zh:ember:ezsp: ======== EZSP started ========
[2026-03-29 00:06:55] info: zh:ember: Adapter EZSP protocol version (14) lower than Host. Switched.
[2026-03-29 00:06:55] info: zh:ember: Adapter version info: {"ezsp":14,"revision":"8.0.2 [GA]","build":397,"major":8,"minor":0,"patch":2,"special":0,"type":170}
[2026-03-29 00:06:56] warning: zh:ember:uart:ash: Frame(s) in progress cancelled in [1ac1020b0a527e]
[2026-03-29 00:06:56] error: zh:ember:uart:ash: Received unexpected reset from adapter, with reason=RESET_SOFTWARE.
[2026-03-29 00:06:56] error: zh:ember:uart:ash: ASH disconnected: ASH_ERROR_NCP_RESET | Adapter status: ASH_NCP_FATAL_ERROR
[2026-03-29 00:06:56] error: zh:ember:ezsp: Fatal error, status=HOST_FATAL_ERROR. Last Frame: [FRAME: ID=100:"SET_MULTICAST_TABLE_ENTRY" Seq=19 Len=9]
[2026-03-29 00:06:57] error: zh:ember:ezsp: Fatal error, status=HOST_FATAL_ERROR. Last Frame: [FRAME: ID=100:"SET_MULTICAST_TABLE_ENTRY" Seq=19 Len=9]
[2026-03-29 00:06:58] error: zh:ember:ezsp: Fatal error, status=HOST_FATAL_ERROR. Last Frame: [FRAME: ID=100:"SET_MULTICAST_TABLE_ENTRY" Seq=19 Len=9]
[2026-03-29 00:07:09] error: zh:ember:ezsp: ERROR Transaction failure; status=ASH_ERROR_TIMEOUTS. Last Frame: [FRAME: ID=100:"SET_MULTICAST_TABLE_ENTRY" Seq=19 Len=9].
[2026-03-29 00:07:09] error: z2m: Error while starting zigbee-herdsman
[2026-03-29 00:07:09] error: z2m: Failed to start zigbee-herdsman
[2026-03-29 00:07:09] error: z2m: Check https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start_crashes-runtime.html for possible solutions
[2026-03-29 00:07:09] error: z2m: Exiting...
[2026-03-29 00:07:09] error: z2m: Error: ASH_ERROR_TIMEOUTS
at Ezsp.ezspSetMulticastTableEntry (/app/node_modules/.pnpm/zigbee-herdsman@9.0.9/node_modules/zigbee-herdsman/src/adapter/ember/ezsp/ezsp.ts:5782:19)
at EmberAdapter.registerFixedEndpoints (/app/node_modules/.pnpm/zigbee-herdsman@9.0.9/node_modules/zigbee-herdsman/src/adapter/ember/adapter/emberAdapter.ts:809:32)
at EmberAdapter.initEzsp (/app/node_modules/.pnpm/zigbee-herdsman@9.0.9/node_modules/zigbee-herdsman/src/adapter/ember/adapter/emberAdapter.ts:705:9)
at EmberAdapter.start (/app/node_modules/.pnpm/zigbee-herdsman@9.0.9/node_modules/zigbee-herdsman/src/adapter/ember/adapter/emberAdapter.ts:1538:24)
at Controller.start (/app/node_modules/.pnpm/zigbee-herdsman@9.0.9/node_modules/zigbee-herdsman/src/controller/controller.ts:145:29)
at Zigbee.start (/app/lib/zigbee.ts:70:27)
at Controller.start (/app/lib/controller.ts:111:29)
at start (/app/index.js:156:5)
