J’utilise aussi ce capteur pour mon courrier, mais moi j’envoi une photo vers Telegram en guise de notification.
Voici mon flux nodered ci cela peut d’aider,
[{"id":"22546a7c.11623e","type":"tab","label":"Courrier","disabled":false,"info":""},{"id":"d5190af0.13c398","type":"group","z":"22546a7c.11623e","name":"Notification de courrier","style":{"stroke":"#ffC000","fill":"#ffffbf","label":true,"fill-opacity":"0.5"},"nodes":["6af0153f.cdb484","9abd7710.bfd81","7871d413.c0130c","7d261f23.6c69c","ae261ab9.54d698","c7b2c9d7.421e38","caa1d2bf.ec7e5","557fcac7.2c8114","7ce7bd58.e59c84","76f2deda.4f6bf","39b698.3d368168","c04b3c0c.96fb58","3f418e14.965c92","3040da4.eb3f3a6","88c89f8.30abd6","4bb7576e.3d88d","83defe26.a779d8","85a340b1.78a2a","4ce43d96.ac1064","63a2fc3f.ce4b04","67724091.01bac","7930318f.16f83","78694053.a9af6","2028491f.6be7c6"],"x":34,"y":39,"w":1292,"h":682},{"id":"73bf8c77.b36ab4","type":"server-state-changed","z":"22546a7c.11623e","name":"Detection Vibration tilt","server":"7dc501eb.e6c08","version":3,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityidfilter":"sensor.detecteur_de_vibrations_action","entityidfiltertype":"exact","outputinitially":false,"state_type":"str","haltifstate":"tilt","halt_if_type":"str","halt_if_compare":"is","outputs":2,"output_only_on_state_change":true,"for":0,"forType":"num","forUnits":"minutes","ignorePrevStateNull":false,"ignorePrevStateUnknown":false,"ignorePrevStateUnavailable":false,"ignoreCurrentStateUnknown":false,"ignoreCurrentStateUnavailable":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"eventData"},{"property":"topic","propertyType":"msg","value":"","valueType":"triggerId"}],"x":140,"y":800,"wires":[["6422ef30.f8d79"],[]]},{"id":"6af0153f.cdb484","type":"api-call-service","z":"22546a7c.11623e","g":"d5190af0.13c398","name":"Notification vers Hassio","server":"7dc501eb.e6c08","version":3,"debugenabled":false,"service_domain":"notify","service":"persistent_notification","entityId":"","data":"{\"message\":\"Le courrier vient d'être distribué.\",\"title\":\"COURRIER !\"}","dataType":"json","mergecontext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":630,"y":500,"wires":[[]]},{"id":"9abd7710.bfd81","type":"api-call-service","z":"22546a7c.11623e","g":"d5190af0.13c398","name":"Notification vers Portable Didier","server":"7dc501eb.e6c08","version":3,"debugenabled":false,"service_domain":"notify","service":"mobile_app_sm_a530f","entityId":"","data":"{\"message\":\"Le courrier vient d'être distribué.\",\"title\":\"COURRIER !\"}","dataType":"json","mergecontext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":1070,"y":660,"wires":[[]]},{"id":"7871d413.c0130c","type":"api-call-service","z":"22546a7c.11623e","g":"d5190af0.13c398","name":"","server":"7dc501eb.e6c08","version":3,"debugenabled":false,"service_domain":"input_boolean","service":"toggle","entityId":"input_boolean.boite_aux_lettres","data":"","dataType":"jsonata","mergecontext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":630,"y":300,"wires":[["7d261f23.6c69c"]],"info":"change l'état de input boolean boite aux lettres"},{"id":"7d261f23.6c69c","type":"api-current-state","z":"22546a7c.11623e","g":"d5190af0.13c398","name":"","server":"7dc501eb.e6c08","version":2,"outputs":2,"halt_if":"on","halt_if_type":"str","halt_if_compare":"is","entity_id":"input_boolean.boite_aux_lettres","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":960,"y":300,"wires":[["78694053.a9af6"],[]]},{"id":"ff74c455.0298b8","type":"server-state-changed","z":"22546a7c.11623e","name":"Detection Vibration drop","server":"7dc501eb.e6c08","version":3,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityidfilter":"sensor.detecteur_de_vibrations_action","entityidfiltertype":"exact","outputinitially":false,"state_type":"str","haltifstate":"drop","halt_if_type":"str","halt_if_compare":"is","outputs":2,"output_only_on_state_change":true,"for":0,"forType":"num","forUnits":"minutes","ignorePrevStateNull":false,"ignorePrevStateUnknown":false,"ignorePrevStateUnavailable":false,"ignoreCurrentStateUnknown":false,"ignoreCurrentStateUnavailable":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"eventData"},{"property":"topic","propertyType":"msg","value":"","valueType":"triggerId"}],"x":140,"y":880,"wires":[["2c327d4f.99a092"],[]]},{"id":"99d0194b.462b48","type":"server-state-changed","z":"22546a7c.11623e","name":"Detection Vibration","server":"7dc501eb.e6c08","version":3,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityidfilter":"sensor.detecteur_de_vibrations_action","entityidfiltertype":"exact","outputinitially":false,"state_type":"str","haltifstate":"vibration","halt_if_type":"str","halt_if_compare":"is","outputs":2,"output_only_on_state_change":true,"for":0,"forType":"num","forUnits":"minutes","ignorePrevStateNull":false,"ignorePrevStateUnknown":false,"ignorePrevStateUnavailable":false,"ignoreCurrentStateUnknown":false,"ignoreCurrentStateUnavailable":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"eventData"},{"property":"topic","propertyType":"msg","value":"","valueType":"triggerId"}],"x":130,"y":960,"wires":[["5aea6e27.d7b34"],[]]},{"id":"ae261ab9.54d698","type":"mqtt in","z":"22546a7c.11623e","g":"d5190af0.13c398","name":"","topic":"zigbee2mqtt/Détecteur de Vibrations","qos":"0","datatype":"auto","broker":"1eb4fa04.85f54e","nl":false,"rap":true,"rh":0,"x":200,"y":140,"wires":[["c04b3c0c.96fb58","83defe26.a779d8"]]},{"id":"2c327d4f.99a092","type":"debug","z":"22546a7c.11623e","name":"Vibration drop","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":380,"y":880,"wires":[]},{"id":"5aea6e27.d7b34","type":"debug","z":"22546a7c.11623e","name":"Vibration","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":360,"y":960,"wires":[]},{"id":"6422ef30.f8d79","type":"debug","z":"22546a7c.11623e","name":"vibration tilt","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":370,"y":800,"wires":[]},{"id":"c7b2c9d7.421e38","type":"function","z":"22546a7c.11623e","g":"d5190af0.13c398","name":"Filtre Vibration","func":"if (msg.payload == \"tilt\") {\n return [msg];\n} else if (msg.payload == \"drop\") {\n return [msg];\n} else if (msg.payload == \"vibration\") {\n return [msg];\n} else {\n return [null];\n}","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":340,"y":260,"wires":[["557fcac7.2c8114","7871d413.c0130c"]]},{"id":"caa1d2bf.ec7e5","type":"inject","z":"22546a7c.11623e","g":"d5190af0.13c398","name":"tilt","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"tilt","payloadType":"str","x":130,"y":280,"wires":[["c7b2c9d7.421e38"]]},{"id":"557fcac7.2c8114","type":"debug","z":"22546a7c.11623e","g":"d5190af0.13c398","name":"filtre vibration","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":590,"y":240,"wires":[]},{"id":"7ce7bd58.e59c84","type":"inject","z":"22546a7c.11623e","g":"d5190af0.13c398","name":"drop","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"drop","payloadType":"str","x":130,"y":340,"wires":[["c7b2c9d7.421e38"]]},{"id":"76f2deda.4f6bf","type":"inject","z":"22546a7c.11623e","g":"d5190af0.13c398","name":"vibration","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"vibration","payloadType":"str","x":140,"y":220,"wires":[["c7b2c9d7.421e38"]]},{"id":"39b698.3d368168","type":"inject","z":"22546a7c.11623e","g":"d5190af0.13c398","name":"envoi notification","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":780,"y":660,"wires":[["9abd7710.bfd81"]]},{"id":"c04b3c0c.96fb58","type":"debug","z":"22546a7c.11623e","g":"d5190af0.13c398","name":"entrée vibration","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":480,"y":80,"wires":[]},{"id":"3f418e14.965c92","type":"json","z":"22546a7c.11623e","g":"d5190af0.13c398","name":"","property":"payload","action":"","pretty":false,"x":650,"y":140,"wires":[["88c89f8.30abd6","4bb7576e.3d88d"]]},{"id":"3040da4.eb3f3a6","type":"debug","z":"22546a7c.11623e","g":"d5190af0.13c398","name":"Filtre action","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":1070,"y":80,"wires":[]},{"id":"88c89f8.30abd6","type":"change","z":"22546a7c.11623e","g":"d5190af0.13c398","name":"Filtre payload action","rules":[{"t":"set","p":"payload","pt":"msg","to":"payload.action","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":860,"y":140,"wires":[["3040da4.eb3f3a6","c7b2c9d7.421e38"]]},{"id":"4bb7576e.3d88d","type":"debug","z":"22546a7c.11623e","g":"d5190af0.13c398","name":"Filtre json","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":820,"y":80,"wires":[]},{"id":"83defe26.a779d8","type":"delay","z":"22546a7c.11623e","g":"d5190af0.13c398","name":"","pauseType":"delay","timeout":"1","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"x":460,"y":140,"wires":[["3f418e14.965c92"]]},{"id":"85a340b1.78a2a","type":"comment","z":"22546a7c.11623e","g":"d5190af0.13c398","name":"Notification de courrier","info":"Automatisation Hassio\n\n# alias: 'Notification de Distribution du Courrier '\ndescription: |-\n envoi notification si détection de vibration et boolean à on.\n ou\n si boolean passe de off à on\ntrigger:\n - platform: device\n domain: mqtt\n device_id: 7b9c1af6e7ca0b6f858301a492b15065\n type: action\n subtype: vibration\n discovery_id: 0x00158d00056e4169 action_vibration\n - platform: device\n domain: mqtt\n device_id: 7b9c1af6e7ca0b6f858301a492b15065\n type: action\n subtype: tilt\n discovery_id: 0x00158d00056e4169 action_tilt\n - platform: device\n domain: mqtt\n device_id: 7b9c1af6e7ca0b6f858301a492b15065\n type: action\n subtype: drop\n discovery_id: 0x00158d00056e4169 action_drop\ncondition: []\naction:\n - service: input_boolean.toggle\n target:\n entity_id: input_boolean.boite_aux_lettres\n - condition: state\n entity_id: input_boolean.boite_aux_lettres\n state: 'on'\n - service: notify.mobile_app_sm_a530f\n data:\n message: Le courrier vient d'être distribué.\n title: COURRIER !\n - service: notify.persistent_notification\n data:\n message: Le courrier vient d'être distribué.\n title: COURRIER !\nmode: single\n","x":180,"y":680,"wires":[]},{"id":"4ce43d96.ac1064","type":"api-call-service","z":"22546a7c.11623e","g":"d5190af0.13c398","name":"Take Snapshot","server":"7dc501eb.e6c08","version":3,"debugenabled":false,"service_domain":"camera","service":"snapshot","entityId":"camera.diskstation_3_facade_rue","data":"{\"filename\":\"/config/www/tmp/snapshot_courrier_camera.facade_rue.jpg\"}","dataType":"json","mergecontext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":600,"y":420,"wires":[["63a2fc3f.ce4b04"]]},{"id":"63a2fc3f.ce4b04","type":"delay","z":"22546a7c.11623e","g":"d5190af0.13c398","name":"1sec delay","pauseType":"delay","timeout":"1","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"x":770,"y":420,"wires":[["67724091.01bac"]]},{"id":"67724091.01bac","type":"api-call-service","z":"22546a7c.11623e","g":"d5190af0.13c398","name":"Envoi Photo sur Telegram","server":"7dc501eb.e6c08","version":3,"debugenabled":false,"service_domain":"telegram_bot","service":"send_photo","entityId":"","data":"{\"file\":\"/config/www/tmp/snapshot_courrier_camera.facade_rue.jpg\",\"caption\":\"Le courrier est distribué.\"}","dataType":"json","mergecontext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":970,"y":420,"wires":[["7930318f.16f83"]]},{"id":"7930318f.16f83","type":"telegram sender","z":"22546a7c.11623e","g":"d5190af0.13c398","name":"","bot":"605cd2b9.ffd0ec","haserroroutput":false,"outputs":1,"x":1210,"y":420,"wires":[[]]},{"id":"78694053.a9af6","type":"link out","z":"22546a7c.11623e","g":"d5190af0.13c398","name":"Vers Notification","links":["2028491f.6be7c6"],"x":1195,"y":280,"wires":[]},{"id":"2028491f.6be7c6","type":"link in","z":"22546a7c.11623e","g":"d5190af0.13c398","name":"De Courrier distribué","links":["78694053.a9af6"],"x":455,"y":420,"wires":[["4ce43d96.ac1064","6af0153f.cdb484"]]},{"id":"7dc501eb.e6c08","type":"server","name":"Home Assistant","version":1,"legacy":false,"addon":true,"rejectUnauthorizedCerts":true,"ha_boolean":"y|yes|true|on|home|open","connectionDelay":true,"cacheJson":true},{"id":"1eb4fa04.85f54e","type":"mqtt-broker","name":"","broker":"localhost","port":"1883","clientid":"","usetls":false,"protocolVersion":"4","keepalive":"60","cleansession":true,"birthTopic":"","birthQos":"0","birthPayload":"","birthMsg":{},"closeTopic":"","closeQos":"0","closePayload":"","closeMsg":{},"willTopic":"","willQos":"0","willPayload":"","willMsg":{},"sessionExpiry":""},{"id":"605cd2b9.ffd0ec","type":"telegram bot","botname":"Hassio_didier_bot","usernames":"@Hassio_didier_bot","chatids":"","baseapiurl":"","updatemode":"polling","pollinterval":"300","usesocks":false,"sockshost":"","socksport":"6667","socksusername":"anonymous","sockspassword":"","bothost":"","botpath":"","localbotport":"8443","publicbotport":"8443","privatekey":"","certificate":"","useselfsignedcertificate":false,"sslterminated":false,"verboselogging":false}]
