si cela peut vous aider à comprendre mon problème, voila mon log :
2021-12-11 18:00:23 WARNING (SyncWorker_1) [homeassistant.loader] We found a custom integration astroweather which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2021-12-11 18:00:23 WARNING (SyncWorker_2) [homeassistant.loader] We found a custom integration nodered which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2021-12-11 18:00:23 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration hacs which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2021-12-11 18:00:23 WARNING (SyncWorker_3) [homeassistant.loader] We found a custom integration localtuya which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2021-12-11 18:00:23 WARNING (SyncWorker_1) [homeassistant.loader] We found a custom integration zigbee2mqtt_networkmap which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2021-12-11 18:00:23 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration miio_yeelink which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2021-12-11 18:00:23 WARNING (SyncWorker_3) [homeassistant.loader] We found a custom integration scheduler which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2021-12-11 18:00:24 WARNING (Recorder) [homeassistant.components.recorder.util] The system could not validate that the sqlite3 database at //config/home-assistant_v2.db was shutdown cleanly
2021-12-11 18:00:25 WARNING (Recorder) [homeassistant.components.recorder.util] Ended unfinished session (id=5 from 2021-12-11 16:55:37.766007)
2021-12-11 18:00:38 ERROR (MainThread) [homeassistant.setup] Error during setup of component automation
File "/usr/src/homeassistant/homeassistant/components/device_automation/__init__.py", line 109, in async_get_device_automation_platform
integration = await async_get_integration_with_requirements(hass, domain)
File "/usr/src/homeassistant/homeassistant/requirements.py", line 58, in async_get_integration_with_requirements
integration = await async_get_integration(hass, domain)
File "/usr/src/homeassistant/homeassistant/loader.py", line 566, in async_get_integration
integration = await _async_get_integration(hass, domain)
File "/usr/src/homeassistant/homeassistant/loader.py", line 594, in _async_get_integration
raise IntegrationNotFound(domain)
homeassistant.loader.IntegrationNotFound: Integration '' not found.
The above exception was the direct cause of the following exception:
File "/usr/src/homeassistant/homeassistant/setup.py", line 254, in _async_setup_component
result = await task
File "/usr/src/homeassistant/homeassistant/components/automation/__init__.py", line 236, in async_setup
if not await _async_process_config(hass, config, component):
File "/usr/src/homeassistant/homeassistant/components/automation/__init__.py", line 643, in _async_process_config
await async_validate_config_item(hass, raw_config),
File "/usr/src/homeassistant/homeassistant/components/automation/config.py", line 86, in async_validate_config_item
config[CONF_ACTION] = await script.async_validate_actions_config(
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 241, in async_validate_actions_config
return await asyncio.gather(
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 288, in async_validate_action_config
choose_conf[CONF_SEQUENCE] = await async_validate_actions_config(
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 256, in async_validate_action_config
platform = await device_automation.async_get_device_automation_platform(
File "/usr/src/homeassistant/homeassistant/components/device_automation/__init__.py", line 112, in async_get_device_automation_platform
raise InvalidDeviceAutomationConfig(
homeassistant.components.device_automation.exceptions.InvalidDeviceAutomationConfig: Integration '' not found
2021-12-11 18:00:38 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of default_config. Setup failed for dependencies: automation
2021-12-11 18:00:38 ERROR (MainThread) [homeassistant.setup] Setup failed for default_config: Could not set up all dependencies.
2021-12-11 18:00:41 WARNING (MainThread) [homeassistant.config_entries] Config entry 'kotone' for tplink integration not ready yet: Unable to connect to the device: None; Retrying in background
2021-12-11 18:01:25 WARNING (MainThread) [homeassistant.components.zha.core.channels.base] [0x0807:1:0x0500]: async_initialize: all attempts have failed: [DeliveryError('[0x0807:1:0x0500]: Message send failure'), DeliveryError('[0x0807:1:0x0500]: Message send failure'), DeliveryError('[0x0807:1:0x0500]: Message send failure'), DeliveryError('[0x0807:1:0x0500]: Message send failure')]
2021-12-11 18:01:25 WARNING (MainThread) [homeassistant.components.zha.core.channels.base] [0x86F2:3:0x0006]: async_initialize: all attempts have failed: [DeliveryError('[0x86f2:3:0x0006]: Message send failure'), DeliveryError('[0x86f2:3:0x0006]: Message send failure'), DeliveryError('[0x86f2:3:0x0006]: Message send failure'), DeliveryError('[0x86f2:3:0x0006]: Message send failure')]
2021-12-11 18:04:45 WARNING (MainThread) [homeassistant.helpers.entity] Update of light.yeelink_radio is taking over 10 seconds
2021-12-11 18:04:45 ERROR (MainThread) [custom_components.miio_yeelink] Got exception while fetching the state for Yeelink radio: Unable to discover the device 192.168.0.16
2021-12-11 18:05:59 ERROR (MainThread) [homeassistant.components.upnp] Timeout fetching SAGEM F@ST3686 data
2021-12-11 18:15:39 ERROR (MainThread) [homeassistant.components.upnp] Timeout fetching SAGEM F@ST3686 data
2021-12-11 18:40:34 ERROR (MainThread) [homeassistant.components.upnp] Timeout fetching SAGEM F@ST3686 data
2021-12-11 18:55:34 ERROR (MainThread) [homeassistant.components.upnp] Timeout fetching SAGEM F@ST3686 data
2021-12-11 18:58:02 WARNING (MainThread) [zigpy_deconz.api] No response to 'Command.aps_data_indication' command with seq id '0x28'
2021-12-11 19:15:34 ERROR (MainThread) [homeassistant.components.upnp] Timeout fetching SAGEM F@ST3686 data
2021-12-11 19:25:34 ERROR (MainThread) [homeassistant.components.upnp] Timeout fetching SAGEM F@ST3686 data
2021-12-11 19:52:27 ERROR (MainThread) [homeassistant.components.tplink.coordinator] Error fetching 192.168.0.19 data: Unable to connect to the device: 192.168.0.19
2021-12-11 20:05:34 ERROR (MainThread) [homeassistant.components.upnp] Timeout fetching SAGEM F@ST3686 data
2021-12-11 20:25:34 ERROR (MainThread) [homeassistant.components.upnp] Timeout fetching SAGEM F@ST3686 data
2021-12-11 20:51:10 WARNING (MainThread) [zigpy_deconz.api] No response to 'Command.aps_data_indication' command with seq id '0x99'
2021-12-11 21:05:34 ERROR (MainThread) [homeassistant.components.upnp] Timeout fetching SAGEM F@ST3686 data
2021-12-11 21:20:34 ERROR (MainThread) [homeassistant.components.upnp] Timeout fetching SAGEM F@ST3686 data
2021-12-11 21:45:34 ERROR (MainThread) [homeassistant.components.upnp] Timeout fetching SAGEM F@ST3686 data
2021-12-11 22:05:34 ERROR (MainThread) [homeassistant.components.upnp] Timeout fetching SAGEM F@ST3686 data
2021-12-11 22:10:34 ERROR (MainThread) [homeassistant.components.upnp] Timeout fetching SAGEM F@ST3686 data
2021-12-11 22:50:34 ERROR (MainThread) [homeassistant.components.upnp] Timeout fetching SAGEM F@ST3686 data
2021-12-11 23:05:34 ERROR (MainThread) [homeassistant.components.upnp] Timeout fetching SAGEM F@ST3686 data
2021-12-11 23:15:34 ERROR (MainThread) [homeassistant.components.upnp] Timeout fetching SAGEM F@ST3686 data
2021-12-11 23:35:33 ERROR (MainThread) [homeassistant.components.tplink.coordinator] Error fetching 192.168.0.19 data: Unable to connect to the device: 192.168.0.19
2021-12-11 23:40:52 WARNING (MainThread) [zigpy_deconz.api] No response to 'Command.aps_data_indication' command with seq id '0xfa'
2021-12-12 00:20:34 ERROR (MainThread) [homeassistant.components.upnp] Timeout fetching SAGEM F@ST3686 data
2021-12-12 00:45:34 ERROR (MainThread) [homeassistant.components.upnp] Timeout fetching SAGEM F@ST3686 data
2021-12-12 01:15:34 ERROR (MainThread) [homeassistant.components.upnp] Timeout fetching SAGEM F@ST3686 data
2021-12-12 01:25:34 ERROR (MainThread) [homeassistant.components.upnp] Timeout fetching SAGEM F@ST3686 data
2021-12-12 01:40:34 ERROR (MainThread) [homeassistant.components.upnp] Timeout fetching SAGEM F@ST3686 data
2021-12-12 01:50:34 ERROR (MainThread) [homeassistant.components.upnp] Timeout fetching SAGEM F@ST3686 data
2021-12-12 02:05:34 ERROR (MainThread) [homeassistant.components.upnp] Timeout fetching SAGEM F@ST3686 data
2021-12-12 02:30:34 ERROR (MainThread) [homeassistant.components.upnp] Timeout fetching SAGEM F@ST3686 data
2021-12-12 02:30:34 WARNING (MainThread) [zigpy_deconz.api] No response to 'Command.aps_data_indication' command with seq id '0x49'
2021-12-12 03:05:34 ERROR (MainThread) [homeassistant.components.upnp] Timeout fetching SAGEM F@ST3686 data
2021-12-12 03:25:34 ERROR (MainThread) [homeassistant.components.upnp] Timeout fetching SAGEM F@ST3686 data
2021-12-12 03:27:08 WARNING (MainThread) [zigpy_deconz.api] No response to 'Command.aps_data_indication' command with seq id '0x05'
2021-12-12 03:40:34 ERROR (MainThread) [homeassistant.components.upnp] Timeout fetching SAGEM F@ST3686 data
2021-12-12 03:45:34 ERROR (MainThread) [homeassistant.components.upnp] Timeout fetching SAGEM F@ST3686 data
2021-12-12 03:50:34 ERROR (MainThread) [homeassistant.components.upnp] Timeout fetching SAGEM F@ST3686 data
2021-12-12 04:15:35 ERROR (MainThread) [homeassistant.components.upnp] Timeout fetching SAGEM F@ST3686 data
2021-12-12 04:23:42 WARNING (MainThread) [zigpy_deconz.api] No response to 'Command.aps_data_indication' command with seq id '0xbb'
2021-12-12 04:35:35 ERROR (MainThread) [homeassistant.components.upnp] Timeout fetching SAGEM F@ST3686 data
2021-12-12 04:46:00 ERROR (MainThread) [homeassistant.components.upnp] Timeout fetching SAGEM F@ST3686 data
2021-12-12 05:20:16 WARNING (MainThread) [zigpy_deconz.api] No response to 'Command.aps_data_indication' command with seq id '0x65'
2021-12-12 05:30:40 ERROR (MainThread) [homeassistant.components.upnp] Timeout fetching SAGEM F@ST3686 data
2021-12-12 05:40:35 ERROR (MainThread) [homeassistant.components.upnp] Timeout fetching SAGEM F@ST3686 data
2021-12-12 05:50:35 ERROR (MainThread) [homeassistant.components.upnp] Timeout fetching SAGEM F@ST3686 data
2021-12-12 06:16:50 WARNING (MainThread) [zigpy_deconz.api] No response to 'Command.aps_data_indication' command with seq id '0x3d'
2021-12-12 06:40:38 ERROR (MainThread) [homeassistant.components.upnp] Timeout fetching SAGEM F@ST3686 data
2021-12-12 07:45:40 ERROR (MainThread) [homeassistant.components.tplink.coordinator] Error fetching 192.168.0.19 data: Unable to connect to the device: 192.168.0.19
2021-12-12 08:20:33 ERROR (MainThread) [homeassistant.components.upnp] Timeout fetching SAGEM F@ST3686 data
2021-12-12 08:25:23 ERROR (MainThread) [homeassistant.components.tplink.coordinator] Error fetching 192.168.0.19 data: Unable to connect to the device: 192.168.0.19
2021-12-12 09:30:34 ERROR (MainThread) [homeassistant.components.upnp] Timeout fetching SAGEM F@ST3686 data
2021-12-12 09:50:34 ERROR (MainThread) [homeassistant.components.upnp] Timeout fetching SAGEM F@ST3686 data
2021-12-12 09:55:34 ERROR (MainThread) [homeassistant.components.upnp] Timeout fetching SAGEM F@ST3686 data
2021-12-12 10:19:31 ERROR (Thread-7) [pychromecast.socket_client] [SHIELD(192.168.0.11):8009] Error reading from socket.
2021-12-12 10:19:31 WARNING (Thread-7) [pychromecast.socket_client] [SHIELD(192.168.0.11):8009] Error communicating with socket, resetting connection
2021-12-12 10:59:40 WARNING (MainThread) [zigpy_deconz.api] No response to 'Command.aps_data_indication' command with seq id '0x3e'
2021-12-12 11:05:35 ERROR (MainThread) [homeassistant.components.upnp] Timeout fetching SAGEM F@ST3686 data
2021-12-12 11:55:35 ERROR (MainThread) [homeassistant.components.upnp] Timeout fetching SAGEM F@ST3686 data
2021-12-12 11:56:14 WARNING (MainThread) [zigpy_deconz.api] No response to 'Command.aps_data_indication' command with seq id '0xf9'
2021-12-12 12:37:25 ERROR (MainThread) [homeassistant.components.hassio] Failed to to call /backups/new/partial - Unknown error, see supervisor
2021-12-12 12:37:27 ERROR (MainThread) [homeassistant.components.hassio] Failed to to call /backups/new/partial - Unknown error, see supervisor
