pour Cyber
il faut que tu Install le module esphome si ce n’est pas déjà fait !
après tu connectes ESP32 a ton pc et tu l’Install
jusque là Youtube est ton ami
une fois installé tu peux le brancher a coté de ta piscine
et pour finir tu retournes dans esphome et tu « edit » ton ESPhome
# JustSalt
substitutions:
mac_justsalt: "94:DE:B8:A1:1A:AC"
esphome:
friendly_name: ESPHome Web ecc470
esp32:
board: esp32dev
framework:
type: arduino
# Enable logging
logger:
baud_rate: 0
# Enable Home Assistant API
api:
encryption:
key: "xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx"
ota:
wifi:
ssid: !secret wifi_ssid
ap:
ssid: "Esphome-Web-Ecc470"
password: "eEzs1d6LU1bH"
captive_portal:
esp32_ble_tracker:
on_ble_advertise:
- mac_address:
- ${mac_justsalt}
then:
- lambda: |-
ESP_LOGD("ble_adv", "New BLE device");
ESP_LOGD("ble_adv", " address: %s", x.address_str().c_str());
ESP_LOGD("ble_adv", " name: %s", x.get_name().c_str());
id(ble_name2).publish_state(x.get_name().c_str());
ble_client:
- mac_address: ${mac_justsalt}
auto_connect: true
on_connect:
then:
- ble_client.numeric_comparison_reply:
accept: True
binary_sensor:
- platform: ble_presence
text_sensor:
- platform: version
- platform: wifi_info
ssid:
- id: ble_name
platform: template
- id: ble_name2
platform: template
- id: ble_valeur
platform: template
- platform: wifi_signal
update_interval: 10s
- platform: uptime
- platform: ble_rssi
name: "JustSalt Temperature"
unit_of_measurement: "°C"
accuracy_decimals: 1
state_class: measurement
device_class: temperature
unit_of_measurement: "pH"
accuracy_decimals: 2
icon: mdi:ph
unit_of_measurement: "mV"
accuracy_decimals: 0
device_class: voltage
unit_of_measurement: "g/L"
icon: mdi:water-opacity
- platform: ble_client
ble_client_id: JustSaltPro
service_uuid: '1800' # Generic Access Profile
characteristic_uuid: '2a00' # Device Name
type: characteristic
lambda: |-
std::string data_string(x.begin(), x.end());
id(ble_name).publish_state(data_string.c_str());
return (float)x.size();
service_uuid: '09912756-7b32-4629-aeb1-b309d9a338ae'
characteristic_uuid: 'ef785c24-22bb-463d-b651-0b7445ba091c'
#update_interval: 30s
notify: true
lambda: |-
ESP_LOGD("ble_client.receive", "start - value received with %d bytes: [%.*s]", x.size(), x.size(), &x[0]);
std::string value2(x.begin(), x.end());
std::string rawhex = format_hex_pretty((uint8_t *) value2.c_str(), value2.size()).c_str();
ESP_LOGD("raw_hex", "%s", rawhex.c_str());
rawhex.erase(std::remove(rawhex.begin(), rawhex.end(), '.'), rawhex.end());
//ESP_LOGD("raw_hex_stripped", "%s", rawhex.c_str());
ESP_LOGD("raw_hex_stripped", "value received with %d bytes: [%.*s]", rawhex.size(), rawhex.c_str());
id(ble_valeur).publish_state(rawhex.c_str());
switch (x.size()) {
case 6:
//id(ble_valeur6).publish_state(rawhex.c_str());
break;
case 9:
//id(ble_valeur9).publish_state(rawhex.c_str());
break;
case 10:{
}break;
case 12: {
std::string temppart1 = rawhex.substr(8, 4);
ESP_LOGD("chaine 10", "%s", temppart1.c_str());
uint16_t orphex = (x[8] << 8) & x[9];
float orp = static_cast<float>(orphex);
id(JustSalt_orp_sensor).publish_state(orp);
}break;
case 21:{
std::string temppart1 = rawhex.substr(6, 4);
uint16_t orphex = (x[6] << 8) & x[7];
}break;
case 76:{
std::string temppart2 = rawhex.substr(10, 2);
ESP_LOGD("chaine 76", "%s", temppart2.c_str());
uint8_t phhex = x[5];
float ph = static_cast<float>(phhex)/10;
id(JustSalt_ph_sensor).publish_state(ph);
std::string temppart3 = rawhex.substr(44, 4);
ESP_LOGD("chaine 76", "%s", temppart3.c_str());
uint16_t tempeauhex = x[22] << 8 & x[23];
float tempeau = static_cast<float>(tempeauhex);
id(JustSalt_temperature_sensor).publish_state(tempeau);
std::string temppart1 = rawhex.substr(52, 2);
ESP_LOGD("chaine 76", "%s", temppart1.c_str());
uint8_t selhex = x[26] ;
float sel = static_cast<float>(selhex)/10;
id(JustSalt_tds_sensor).publish_state(sel);
}break;
case 80:
//id(ble_valeur80).publish_state(rawhex.c_str());
break;
return 0;
switch:
- platform: restart
fait bien attention de garder tous ce qui ce trouve entre « esphome: » et « captive portal: »
pense a mettre @ mac de ton epool dans « mac_justsalt » tout en haut du code
ensuite tu clic sur install , pour qu’il compile et pousse le code en Wifi dans ESP32
une fois fait-tu vas dans ton Epool
Menu > communication Bluetooth appairage et tu attends que ce soit inscrit « reussi »
Les modifications de récupération des valeurs ne sont pas probantes du tout pour moi !
mais on va trouver
si tu as tout bien fait tu devrais avoir un truc du genre
pour récupérer les logs rien de rien compliqué
tu va dans ton module ESPhome et tu clic sur le bouton Logs de ton ESP32 tu verras les tram passer en temps réel
ça ressemble a ça
pour résumer a ce stade ,
il faut ,fiabiliser l interrogation du Epool , la récupération des trames reste aléatoire
la Position de toutes les valeurs
- PH,ORP, température ,sel
- consigne ORP, Production ORP
- consigne PH, taux acide , correcteur: acide
- date , heure langue, vol piscine , version logiciel , slave
- ID code, SN , température local
et pour le moment on ne sait pas si l’on travaille sur les bonnes Caractéristiques !
Pour le Sel ça me paraît bien !
