Erreur suite coupure EDF
Aujourd’hui edf à fait des travaux et une longue panne de courant à perturbé mon installation.
Voici mon log après un redémarrage, mais plusieurs truc ne fonctionne pas…
2021-07-27 21:03:52 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration start_time which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2021-07-27 21:03:52 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration lovelace_gen which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2021-07-27 21:03:52 WARNING (SyncWorker_1) [homeassistant.loader] We found a custom integration sonoff which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2021-07-27 21:03:52 WARNING (SyncWorker_2) [homeassistant.loader] We found a custom integration ical which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2021-07-27 21:03:52 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration awox which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2021-07-27 21:03:52 WARNING (SyncWorker_1) [homeassistant.loader] We found a custom integration xiaomi_cloud_map_extractor which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2021-07-27 21:03:52 WARNING (SyncWorker_1) [homeassistant.loader] We found a custom integration alexa_media which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2021-07-27 21:03:52 WARNING (SyncWorker_1) [homeassistant.loader] We found a custom integration nodered which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2021-07-27 21:03:52 WARNING (SyncWorker_3) [homeassistant.loader] We found a custom integration ytube_music_player which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2021-07-27 21:03:52 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration monitor_docker which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2021-07-27 21:03:52 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration homewizard_energy which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2021-07-27 21:03:52 WARNING (SyncWorker_1) [homeassistant.loader] We found a custom integration ble_monitor which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2021-07-27 21:03:52 WARNING (SyncWorker_1) [homeassistant.loader] We found a custom integration attributes which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2021-07-27 21:03:52 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration fontawesome which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2021-07-27 21:03:52 ERROR (SyncWorker_0) [homeassistant.loader] The custom integration 'fontawesome' does not have a valid version key (None) in the manifest file and was blocked from loading. See https://developers.home-assistant.io/blog/2021/01/29/custom-integration-changes#versions for more details
2021-07-27 21:03:52 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration remote_homeassistant which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2021-07-27 21:03:52 WARNING (SyncWorker_4) [homeassistant.loader] We found a custom integration iphonedetect which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2021-07-27 21:03:52 WARNING (SyncWorker_3) [homeassistant.loader] We found a custom integration anniversaries which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2021-07-27 21:03:52 WARNING (SyncWorker_4) [homeassistant.loader] We found a custom integration androidtv which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2021-07-27 21:03:52 ERROR (SyncWorker_4) [homeassistant.loader] The custom integration 'androidtv' does not have a valid version key (None) in the manifest file and was blocked from loading. See https://developers.home-assistant.io/blog/2021/01/29/custom-integration-changes#versions for more details
2021-07-27 21:03:52 WARNING (SyncWorker_3) [homeassistant.loader] We found a custom integration netgear_enhanced which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2021-07-27 21:03:52 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration xiaomi_miot_raw which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2021-07-27 21:03:52 WARNING (SyncWorker_1) [homeassistant.loader] We found a custom integration hacs which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2021-07-27 21:03:52 WARNING (SyncWorker_5) [homeassistant.loader] We found a custom integration xiaomi_miot which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2021-07-27 21:04:07 ERROR (SyncWorker_2) [pynetgear_enhanced] Connection error: HTTPConnectionPool(host='192.168.0.9', port=5000): Max retries exceeded with url: /soap/server_sa/ (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x7f94ea0910>: Failed to establish a new connection: [Errno 111] Connection refused'))
  File "/usr/local/lib/python3.9/site-packages/urllib3/connection.py", line 169, in _new_conn
    conn = connection.create_connection(
  File "/usr/local/lib/python3.9/site-packages/urllib3/util/connection.py", line 96, in create_connection
    raise err
  File "/usr/local/lib/python3.9/site-packages/urllib3/util/connection.py", line 86, in create_connection
    sock.connect(sa)
ConnectionRefusedError: [Errno 111] Connection refused
  File "/usr/local/lib/python3.9/site-packages/urllib3/connectionpool.py", line 699, in urlopen
    httplib_response = self._make_request(
  File "/usr/local/lib/python3.9/site-packages/urllib3/connectionpool.py", line 394, in _make_request
    conn.request(method, url, **httplib_request_kw)
  File "/usr/local/lib/python3.9/site-packages/urllib3/connection.py", line 234, in request
    super(HTTPConnection, self).request(method, url, body=body, headers=headers)
  File "/usr/local/lib/python3.9/http/client.py", line 1253, in request
    self._send_request(method, url, body, headers, encode_chunked)
  File "/usr/local/lib/python3.9/http/client.py", line 1299, in _send_request
    self.endheaders(body, encode_chunked=encode_chunked)
  File "/usr/local/lib/python3.9/http/client.py", line 1248, in endheaders
    self._send_output(message_body, encode_chunked=encode_chunked)
  File "/usr/local/lib/python3.9/http/client.py", line 1008, in _send_output
    self.send(msg)
  File "/usr/local/lib/python3.9/http/client.py", line 948, in send
    self.connect()
  File "/usr/local/lib/python3.9/site-packages/urllib3/connection.py", line 200, in connect
    conn = self._new_conn()
  File "/usr/local/lib/python3.9/site-packages/urllib3/connection.py", line 181, in _new_conn
    raise NewConnectionError(
urllib3.exceptions.NewConnectionError: <urllib3.connection.HTTPConnection object at 0x7f94ea0910>: Failed to establish a new connection: [Errno 111] Connection refused
  File "/usr/local/lib/python3.9/site-packages/requests/adapters.py", line 439, in send
    resp = conn.urlopen(
  File "/usr/local/lib/python3.9/site-packages/urllib3/connectionpool.py", line 755, in urlopen
    retries = retries.increment(
  File "/usr/local/lib/python3.9/site-packages/urllib3/util/retry.py", line 574, in increment
    raise MaxRetryError(_pool, url, error or ResponseError(cause))
urllib3.exceptions.MaxRetryError: HTTPConnectionPool(host='192.168.0.9', port=5000): Max retries exceeded with url: /soap/server_sa/ (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x7f94ea0910>: Failed to establish a new connection: [Errno 111] Connection refused'))
  File "/usr/local/lib/python3.9/site-packages/pynetgear_enhanced/__init__.py", line 102, in _make_request
    response = requests.post(self.soap_url, headers=headers,
  File "/usr/local/lib/python3.9/site-packages/requests/api.py", line 119, in post
    return request('post', url, data=data, json=json, **kwargs)
  File "/usr/local/lib/python3.9/site-packages/requests/api.py", line 61, in request
    return session.request(method=method, url=url, **kwargs)
  File "/usr/local/lib/python3.9/site-packages/requests/sessions.py", line 542, in request
    resp = self.send(prep, **send_kwargs)
  File "/usr/local/lib/python3.9/site-packages/requests/sessions.py", line 655, in send
    r = adapter.send(request, **kwargs)
  File "/usr/local/lib/python3.9/site-packages/requests/adapters.py", line 516, in send
    raise ConnectionError(e, request=request)
requests.exceptions.ConnectionError: HTTPConnectionPool(host='192.168.0.9', port=5000): Max retries exceeded with url: /soap/server_sa/ (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x7f94ea0910>: Failed to establish a new connection: [Errno 111] Connection refused'))
2021-07-27 21:04:07 ERROR (SyncWorker_2) [pynetgear_enhanced] Connection error: HTTPConnectionPool(host='192.168.0.9', port=5000): Max retries exceeded with url: /soap/server_sa/ (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x7f94744af0>: Failed to establish a new connection: [Errno 111] Connection refused'))
    raise err
    sock.connect(sa)
    self.send(msg)
    self.connect()
urllib3.exceptions.NewConnectionError: <urllib3.connection.HTTPConnection object at 0x7f94744af0>: Failed to establish a new connection: [Errno 111] Connection refused
urllib3.exceptions.MaxRetryError: HTTPConnectionPool(host='192.168.0.9', port=5000): Max retries exceeded with url: /soap/server_sa/ (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x7f94744af0>: Failed to establish a new connection: [Errno 111] Connection refused'))
requests.exceptions.ConnectionError: HTTPConnectionPool(host='192.168.0.9', port=5000): Max retries exceeded with url: /soap/server_sa/ (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x7f94744af0>: Failed to establish a new connection: [Errno 111] Connection refused'))
2021-07-27 21:04:07 ERROR (SyncWorker_2) [pynetgear_enhanced] Connection error: HTTPConnectionPool(host='192.168.0.9', port=5000): Max retries exceeded with url: /soap/server_sa/ (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x7f946d8f70>: Failed to establish a new connection: [Errno 111] Connection refused'))
    raise err
    sock.connect(sa)
    self.send(msg)
    self.connect()
urllib3.exceptions.NewConnectionError: <urllib3.connection.HTTPConnection object at 0x7f946d8f70>: Failed to establish a new connection: [Errno 111] Connection refused
urllib3.exceptions.MaxRetryError: HTTPConnectionPool(host='192.168.0.9', port=5000): Max retries exceeded with url: /soap/server_sa/ (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x7f946d8f70>: Failed to establish a new connection: [Errno 111] Connection refused'))
requests.exceptions.ConnectionError: HTTPConnectionPool(host='192.168.0.9', port=5000): Max retries exceeded with url: /soap/server_sa/ (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x7f946d8f70>: Failed to establish a new connection: [Errno 111] Connection refused'))
2021-07-27 21:04:07 ERROR (SyncWorker_2) [pynetgear_enhanced] Connection error: HTTPConnectionPool(host='192.168.0.9', port=5000): Max retries exceeded with url: /soap/server_sa/ (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x7f946c3ee0>: Failed to establish a new connection: [Errno 111] Connection refused'))
    raise err
    sock.connect(sa)
    self.send(msg)
    self.connect()
urllib3.exceptions.NewConnectionError: <urllib3.connection.HTTPConnection object at 0x7f946c3ee0>: Failed to establish a new connection: [Errno 111] Connection refused
urllib3.exceptions.MaxRetryError: HTTPConnectionPool(host='192.168.0.9', port=5000): Max retries exceeded with url: /soap/server_sa/ (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x7f946c3ee0>: Failed to establish a new connection: [Errno 111] Connection refused'))
requests.exceptions.ConnectionError: HTTPConnectionPool(host='192.168.0.9', port=5000): Max retries exceeded with url: /soap/server_sa/ (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x7f946c3ee0>: Failed to establish a new connection: [Errno 111] Connection refused'))
2021-07-27 21:04:08 ERROR (SyncWorker_2) [pynetgear_enhanced] Connection error: HTTPConnectionPool(host='192.168.0.9', port=5000): Max retries exceeded with url: /soap/server_sa/ (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x7f946d3d90>: Failed to establish a new connection: [Errno 111] Connection refused'))
    raise err
    sock.connect(sa)
    self.send(msg)
    self.connect()
urllib3.exceptions.NewConnectionError: <urllib3.connection.HTTPConnection object at 0x7f946d3d90>: Failed to establish a new connection: [Errno 111] Connection refused
urllib3.exceptions.MaxRetryError: HTTPConnectionPool(host='192.168.0.9', port=5000): Max retries exceeded with url: /soap/server_sa/ (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x7f946d3d90>: Failed to establish a new connection: [Errno 111] Connection refused'))
requests.exceptions.ConnectionError: HTTPConnectionPool(host='192.168.0.9', port=5000): Max retries exceeded with url: /soap/server_sa/ (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x7f946d3d90>: Failed to establish a new connection: [Errno 111] Connection refused'))
2021-07-27 21:04:08 ERROR (SyncWorker_2) [pynetgear_enhanced] Connection error: HTTPConnectionPool(host='192.168.0.9', port=5000): Max retries exceeded with url: /soap/server_sa/ (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x7f946d7a30>: Failed to establish a new connection: [Errno 111] Connection refused'))
    raise err
    sock.connect(sa)
    self.send(msg)
    self.connect()
urllib3.exceptions.NewConnectionError: <urllib3.connection.HTTPConnection object at 0x7f946d7a30>: Failed to establish a new connection: [Errno 111] Connection refused
urllib3.exceptions.MaxRetryError: HTTPConnectionPool(host='192.168.0.9', port=5000): Max retries exceeded with url: /soap/server_sa/ (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x7f946d7a30>: Failed to establish a new connection: [Errno 111] Connection refused'))
requests.exceptions.ConnectionError: HTTPConnectionPool(host='192.168.0.9', port=5000): Max retries exceeded with url: /soap/server_sa/ (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x7f946d7a30>: Failed to establish a new connection: [Errno 111] Connection refused'))
2021-07-27 21:04:08 ERROR (SyncWorker_2) [pynetgear_enhanced] Connection error: HTTPConnectionPool(host='192.168.0.9', port=5000): Max retries exceeded with url: /soap/server_sa/ (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x7f947cf160>: Failed to establish a new connection: [Errno 111] Connection refused'))
    raise err
    sock.connect(sa)
    self.send(msg)
    self.connect()
urllib3.exceptions.NewConnectionError: <urllib3.connection.HTTPConnection object at 0x7f947cf160>: Failed to establish a new connection: [Errno 111] Connection refused
urllib3.exceptions.MaxRetryError: HTTPConnectionPool(host='192.168.0.9', port=5000): Max retries exceeded with url: /soap/server_sa/ (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x7f947cf160>: Failed to establish a new connection: [Errno 111] Connection refused'))
requests.exceptions.ConnectionError: HTTPConnectionPool(host='192.168.0.9', port=5000): Max retries exceeded with url: /soap/server_sa/ (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x7f947cf160>: Failed to establish a new connection: [Errno 111] Connection refused'))
2021-07-27 21:04:08 ERROR (SyncWorker_2) [pynetgear_enhanced] Connection error: HTTPConnectionPool(host='192.168.0.9', port=5000): Max retries exceeded with url: /soap/server_sa/ (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x7f9469b730>: Failed to establish a new connection: [Errno 111] Connection refused'))
    raise err
    sock.connect(sa)
    self.send(msg)
    self.connect()
urllib3.exceptions.NewConnectionError: <urllib3.connection.HTTPConnection object at 0x7f9469b730>: Failed to establish a new connection: [Errno 111] Connection refused
urllib3.exceptions.MaxRetryError: HTTPConnectionPool(host='192.168.0.9', port=5000): Max retries exceeded with url: /soap/server_sa/ (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x7f9469b730>: Failed to establish a new connection: [Errno 111] Connection refused'))
requests.exceptions.ConnectionError: HTTPConnectionPool(host='192.168.0.9', port=5000): Max retries exceeded with url: /soap/server_sa/ (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x7f9469b730>: Failed to establish a new connection: [Errno 111] Connection refused'))
2021-07-27 21:04:09 ERROR (MainThread) [homeassistant.components.life360.config_flow] Invalid credentials for frederic.raspail@wanadoo.fr
2021-07-27 21:04:09 ERROR (SyncWorker_6) [homeassistant.components.nut] Failure getting NUT ups alias, Socket error.
2021-07-27 21:04:10 ERROR (MainThread) [homeassistant.components.media_player] Error while setting up vlc platform for media_player
  File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 250, in _async_setup_platform
    await asyncio.shield(task)
  File "/usr/local/lib/python3.9/concurrent/futures/thread.py", line 52, in run
    result = self.fn(*self.args, **self.kwargs)
  File "/usr/src/homeassistant/homeassistant/components/vlc/media_player.py", line 46, in setup_platform
    [VlcDevice(config.get(CONF_NAME, DEFAULT_NAME), config.get(CONF_ARGUMENTS))]
  File "/usr/src/homeassistant/homeassistant/components/vlc/media_player.py", line 55, in __init__
    self._instance = vlc.Instance(arguments)
  File "/usr/local/lib/python3.9/site-packages/vlc.py", line 1551, in __new__
    return libvlc_new(len(args), args)
  File "/usr/local/lib/python3.9/site-packages/vlc.py", line 3902, in libvlc_new
    _Cfunction('libvlc_new', ((1,), (1,),), class_result(Instance),
  File "/usr/local/lib/python3.9/site-packages/vlc.py", line 246, in _Cfunction
    raise NameError('no function %r' % (name,))
NameError: no function 'libvlc_new'
2021-07-27 21:04:15 ERROR (MainThread) [homeassistant.components.automation] Platform automation does not generate unique IDs. ID clim_salon_on already exists - ignoring automation.on_clim_salon
2021-07-27 21:04:15 ERROR (MainThread) [homeassistant.components.automation] Platform automation does not generate unique IDs. ID unset_radio_selection_salon already exists - ignoring automation.unset_radio_selection_salon
2021-07-27 21:04:16 ERROR (MainThread) [homeassistant.components.xiaomi_miio.device] DeviceException during setup of xiaomi device with host 192.168.0.37: Unable to discover the device 192.168.0.37
2021-07-27 21:04:20 ERROR (SyncWorker_2) [pynetgear] Error talking to API
    raise err
    sock.connect(sa)
    self.send(msg)
    self.connect()
urllib3.exceptions.NewConnectionError: <urllib3.connection.HTTPConnection object at 0x7f90d94790>: Failed to establish a new connection: [Errno 111] Connection refused
urllib3.exceptions.MaxRetryError: HTTPConnectionPool(host='192.168.0.9', port=5000): Max retries exceeded with url: /soap/server_sa/ (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x7f90d94790>: Failed to establish a new connection: [Errno 111] Connection refused'))
  File "/usr/local/lib/python3.9/site-packages/pynetgear/__init__.py", line 374, in _make_request
requests.exceptions.ConnectionError: HTTPConnectionPool(host='192.168.0.9', port=5000): Max retries exceeded with url: /soap/server_sa/ (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x7f90d94790>: Failed to establish a new connection: [Errno 111] Connection refused'))
    raise err
    sock.connect(sa)
    self.send(msg)
    self.connect()
urllib3.exceptions.NewConnectionError: <urllib3.connection.HTTPConnection object at 0x7f90d98520>: Failed to establish a new connection: [Errno 111] Connection refused
urllib3.exceptions.MaxRetryError: HTTPConnectionPool(host='192.168.0.9', port=5000): Max retries exceeded with url: /soap/server_sa/ (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x7f90d98520>: Failed to establish a new connection: [Errno 111] Connection refused'))
requests.exceptions.ConnectionError: HTTPConnectionPool(host='192.168.0.9', port=5000): Max retries exceeded with url: /soap/server_sa/ (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x7f90d98520>: Failed to establish a new connection: [Errno 111] Connection refused'))
2021-07-27 21:04:20 ERROR (SyncWorker_2) [pynetgear] Get attached devices failed
2021-07-27 21:04:20 ERROR (SyncWorker_2) [homeassistant.components.netgear.device_tracker] Failed to Login
2021-07-27 21:04:21 ERROR (MainThread) [homeassistant.components.device_tracker] Error setting up platform legacy netgear
2021-07-27 21:04:21 ERROR (SyncWorker_4) [pynetgear_enhanced] Connection error: HTTPConnectionPool(host='192.168.0.9', port=5000): Max retries exceeded with url: /soap/server_sa/ (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x7f90747190>: Failed to establish a new connection: [Errno 111] Connection refused'))
    raise err
    sock.connect(sa)
    self.send(msg)
    self.connect()
urllib3.exceptions.NewConnectionError: <urllib3.connection.HTTPConnection object at 0x7f90747190>: Failed to establish a new connection: [Errno 111] Connection refused
urllib3.exceptions.MaxRetryError: HTTPConnectionPool(host='192.168.0.9', port=5000): Max retries exceeded with url: /soap/server_sa/ (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x7f90747190>: Failed to establish a new connection: [Errno 111] Connection refused'))
requests.exceptions.ConnectionError: HTTPConnectionPool(host='192.168.0.9', port=5000): Max retries exceeded with url: /soap/server_sa/ (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x7f90747190>: Failed to establish a new connection: [Errno 111] Connection refused'))
2021-07-27 21:04:21 ERROR (SyncWorker_4) [pynetgear_enhanced] Connection error: HTTPConnectionPool(host='192.168.0.9', port=5000): Max retries exceeded with url: /soap/server_sa/ (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x7f906b9ca0>: Failed to establish a new connection: [Errno 111] Connection refused'))
    raise err
    sock.connect(sa)
    self.send(msg)
    self.connect()
urllib3.exceptions.NewConnectionError: <urllib3.connection.HTTPConnection object at 0x7f906b9ca0>: Failed to establish a new connection: [Errno 111] Connection refused
urllib3.exceptions.MaxRetryError: HTTPConnectionPool(host='192.168.0.9', port=5000): Max retries exceeded with url: /soap/server_sa/ (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x7f906b9ca0>: Failed to establish a new connection: [Errno 111] Connection refused'))
requests.exceptions.ConnectionError: HTTPConnectionPool(host='192.168.0.9', port=5000): Max retries exceeded with url: /soap/server_sa/ (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x7f906b9ca0>: Failed to establish a new connection: [Errno 111] Connection refused'))
2021-07-27 21:04:21 ERROR (SyncWorker_4) [pynetgear_enhanced] Connection error: HTTPConnectionPool(host='192.168.0.9', port=5000): Max retries exceeded with url: /soap/server_sa/ (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x7f906cd1f0>: Failed to establish a new connection: [Errno 111] Connection refused'))
    raise err
    sock.connect(sa)
    self.send(msg)
    self.connect()
urllib3.exceptions.NewConnectionError: <urllib3.connection.HTTPConnection object at 0x7f906cd1f0>: Failed to establish a new connection: [Errno 111] Connection refused
urllib3.exceptions.MaxRetryError: HTTPConnectionPool(host='192.168.0.9', port=5000): Max retries exceeded with url: /soap/server_sa/ (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x7f906cd1f0>: Failed to establish a new connection: [Errno 111] Connection refused'))
requests.exceptions.ConnectionError: HTTPConnectionPool(host='192.168.0.9', port=5000): Max retries exceeded with url: /soap/server_sa/ (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x7f906cd1f0>: Failed to establish a new connection: [Errno 111] Connection refused'))
2021-07-27 21:04:21 ERROR (SyncWorker_4) [pynetgear_enhanced] Connection error: HTTPConnectionPool(host='192.168.0.9', port=5000): Max retries exceeded with url: /soap/server_sa/ (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x7f906b9be0>: Failed to establish a new connection: [Errno 111] Connection refused'))
    raise err
    sock.connect(sa)
    self.send(msg)
    self.connect()
urllib3.exceptions.NewConnectionError: <urllib3.connection.HTTPConnection object at 0x7f906b9be0>: Failed to establish a new connection: [Errno 111] Connection refused
urllib3.exceptions.MaxRetryError: HTTPConnectionPool(host='192.168.0.9', port=5000): Max retries exceeded with url: /soap/server_sa/ (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x7f906b9be0>: Failed to establish a new connection: [Errno 111] Connection refused'))
requests.exceptions.ConnectionError: HTTPConnectionPool(host='192.168.0.9', port=5000): Max retries exceeded with url: /soap/server_sa/ (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x7f906b9be0>: Failed to establish a new connection: [Errno 111] Connection refused'))
2021-07-27 21:04:21 ERROR (SyncWorker_4) [pynetgear_enhanced] Connection error: HTTPConnectionPool(host='192.168.0.9', port=5000): Max retries exceeded with url: /soap/server_sa/ (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x7f906d5460>: Failed to establish a new connection: [Errno 111] Connection refused'))
    raise err
    sock.connect(sa)
    self.send(msg)
    self.connect()
urllib3.exceptions.NewConnectionError: <urllib3.connection.HTTPConnection object at 0x7f906d5460>: Failed to establish a new connection: [Errno 111] Connection refused
urllib3.exceptions.MaxRetryError: HTTPConnectionPool(host='192.168.0.9', port=5000): Max retries exceeded with url: /soap/server_sa/ (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x7f906d5460>: Failed to establish a new connection: [Errno 111] Connection refused'))
requests.exceptions.ConnectionError: HTTPConnectionPool(host='192.168.0.9', port=5000): Max retries exceeded with url: /soap/server_sa/ (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x7f906d5460>: Failed to establish a new connection: [Errno 111] Connection refused'))
2021-07-27 21:04:21 ERROR (SyncWorker_4) [pynetgear_enhanced] Connection error: HTTPConnectionPool(host='192.168.0.9', port=5000): Max retries exceeded with url: /soap/server_sa/ (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x7f9076d1c0>: Failed to establish a new connection: [Errno 111] Connection refused'))
    raise err
    sock.connect(sa)
    self.send(msg)
    self.connect()
urllib3.exceptions.NewConnectionError: <urllib3.connection.HTTPConnection object at 0x7f9076d1c0>: Failed to establish a new connection: [Errno 111] Connection refused
urllib3.exceptions.MaxRetryError: HTTPConnectionPool(host='192.168.0.9', port=5000): Max retries exceeded with url: /soap/server_sa/ (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x7f9076d1c0>: Failed to establish a new connection: [Errno 111] Connection refused'))
requests.exceptions.ConnectionError: HTTPConnectionPool(host='192.168.0.9', port=5000): Max retries exceeded with url: /soap/server_sa/ (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x7f9076d1c0>: Failed to establish a new connection: [Errno 111] Connection refused'))
2021-07-27 21:04:21 ERROR (SyncWorker_4) [pynetgear_enhanced] Connection error: HTTPConnectionPool(host='192.168.0.9', port=5000): Max retries exceeded with url: /soap/server_sa/ (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x7f906d5c70>: Failed to establish a new connection: [Errno 111] Connection refused'))
    raise err
    sock.connect(sa)
    self.send(msg)
    self.connect()
urllib3.exceptions.NewConnectionError: <urllib3.connection.HTTPConnection object at 0x7f906d5c70>: Failed to establish a new connection: [Errno 111] Connection refused
urllib3.exceptions.MaxRetryError: HTTPConnectionPool(host='192.168.0.9', port=5000): Max retries exceeded with url: /soap/server_sa/ (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x7f906d5c70>: Failed to establish a new connection: [Errno 111] Connection refused'))
requests.exceptions.ConnectionError: HTTPConnectionPool(host='192.168.0.9', port=5000): Max retries exceeded with url: /soap/server_sa/ (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x7f906d5c70>: Failed to establish a new connection: [Errno 111] Connection refused'))
2021-07-27 21:04:21 ERROR (SyncWorker_4) [pynetgear_enhanced] Connection error: HTTPConnectionPool(host='192.168.0.9', port=5000): Max retries exceeded with url: /soap/server_sa/ (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x7f906de4c0>: Failed to establish a new connection: [Errno 111] Connection refused'))
    raise err
    sock.connect(sa)
    self.send(msg)
    self.connect()
urllib3.exceptions.NewConnectionError: <urllib3.connection.HTTPConnection object at 0x7f906de4c0>: Failed to establish a new connection: [Errno 111] Connection refused
urllib3.exceptions.MaxRetryError: HTTPConnectionPool(host='192.168.0.9', port=5000): Max retries exceeded with url: /soap/server_sa/ (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x7f906de4c0>: Failed to establish a new connection: [Errno 111] Connection refused'))
requests.exceptions.ConnectionError: HTTPConnectionPool(host='192.168.0.9', port=5000): Max retries exceeded with url: /soap/server_sa/ (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x7f906de4c0>: Failed to establish a new connection: [Errno 111] Connection refused'))
2021-07-27 21:04:21 ERROR (SyncWorker_4) [pynetgear_enhanced] Connection error: HTTPConnectionPool(host='192.168.0.9', port=5000): Max retries exceeded with url: /soap/server_sa/ (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x7f906f2850>: Failed to establish a new connection: [Errno 111] Connection refused'))
    raise err
    sock.connect(sa)
    self.send(msg)
    self.connect()
urllib3.exceptions.NewConnectionError: <urllib3.connection.HTTPConnection object at 0x7f906f2850>: Failed to establish a new connection: [Errno 111] Connection refused
urllib3.exceptions.MaxRetryError: HTTPConnectionPool(host='192.168.0.9', port=5000): Max retries exceeded with url: /soap/server_sa/ (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x7f906f2850>: Failed to establish a new connection: [Errno 111] Connection refused'))
requests.exceptions.ConnectionError: HTTPConnectionPool(host='192.168.0.9', port=5000): Max retries exceeded with url: /soap/server_sa/ (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x7f906f2850>: Failed to establish a new connection: [Errno 111] Connection refused'))
2021-07-27 21:04:21 ERROR (SyncWorker_4) [pynetgear_enhanced] Connection error: HTTPConnectionPool(host='192.168.0.9', port=5000): Max retries exceeded with url: /soap/server_sa/ (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x7f9063bb20>: Failed to establish a new connection: [Errno 111] Connection refused'))
    raise err
    sock.connect(sa)
    self.send(msg)
    self.connect()
urllib3.exceptions.NewConnectionError: <urllib3.connection.HTTPConnection object at 0x7f9063bb20>: Failed to establish a new connection: [Errno 111] Connection refused
urllib3.exceptions.MaxRetryError: HTTPConnectionPool(host='192.168.0.9', port=5000): Max retries exceeded with url: /soap/server_sa/ (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x7f9063bb20>: Failed to establish a new connection: [Errno 111] Connection refused'))
requests.exceptions.ConnectionError: HTTPConnectionPool(host='192.168.0.9', port=5000): Max retries exceeded with url: /soap/server_sa/ (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x7f9063bb20>: Failed to establish a new connection: [Errno 111] Connection refused'))
2021-07-27 21:04:23 ERROR (MainThread) [homeassistant.components.sensor] Error while setting up netgear_enhanced platform for sensor
  File "/config/custom_components/netgear-enhanced-integration-master/sensor.py", line 169, in setup_platform
    sensors.append(NetgearEnhancedSensor(
  File "/config/custom_components/netgear-enhanced-integration-master/sensor.py", line 199, in __init__
    self.update()
  File "/config/custom_components/netgear-enhanced-integration-master/sensor.py", line 231, in update
    self.response = getattr(self._api, self._function)()
  File "/usr/local/lib/python3.9/site-packages/pynetgear_enhanced/__init__.py", line 479, in get_traffic_meter_statistics
    return {t: h.parse_text(value) for t, value in theInfo.items()}
AttributeError: 'NoneType' object has no attribute 'items'
2021-07-27 21:04:40 ERROR (zeroconf-ServiceBrowser-_googlecast._tcp-261) [root] Uncaught thread exception
  File "/usr/local/lib/python3.9/threading.py", line 954, in _bootstrap_inner
    self.run()
  File "/usr/local/lib/python3.9/site-packages/zeroconf/_services/browser.py", line 536, in run
    self._fire_service_state_changed_event(event)
  File "/usr/local/lib/python3.9/site-packages/zeroconf/_services/browser.py", line 423, in _fire_service_state_changed_event
    self._service_state_changed.fire(
  File "/usr/local/lib/python3.9/site-packages/zeroconf/_services/__init__.py", line 56, in fire
    h(**kwargs)
  File "/usr/local/lib/python3.9/site-packages/zeroconf/_services/browser.py", line 179, in on_change
    getattr(listener, _ON_CHANGE_DISPATCH[state_change])(zeroconf, service_type, name)
  File "/usr/local/lib/python3.9/site-packages/pychromecast/discovery.py", line 120, in add_service
    self._add_update_service(zconf, typ, name, self._cast_listener.add_cast)
  File "/usr/local/lib/python3.9/site-packages/pychromecast/discovery.py", line 195, in _add_update_service
    callback(uuid, name)
  File "/usr/src/homeassistant/homeassistant/components/cast/discovery.py", line 66, in add_cast
    discover_chromecast(hass, browser.devices[uuid])
  File "/usr/src/homeassistant/homeassistant/components/cast/discovery.py", line 39, in discover_chromecast
    info = info.fill_out_missing_chromecast_info()
  File "/usr/src/homeassistant/homeassistant/components/cast/helpers.py", line 89, in fill_out_missing_chromecast_info
    http_device_status = dial.get_device_status(
  File "/usr/local/lib/python3.9/site-packages/pychromecast/dial.py", line 109, in get_device_status
    status = _get_status(
  File "/usr/local/lib/python3.9/site-packages/pychromecast/dial.py", line 71, in _get_status
    host, _, _ = get_host_from_service(service, zconf)
  File "/usr/local/lib/python3.9/site-packages/pychromecast/dial.py", line 32, in get_host_from_service
    service_info = zconf.get_service_info("_googlecast._tcp.local.", service.data)
  File "/usr/local/lib/python3.9/site-packages/zeroconf/_core.py", line 452, in get_service_info
    if info.request(self, timeout, question_type):
  File "/usr/local/lib/python3.9/site-packages/zeroconf/_services/info.py", line 429, in request
    return asyncio.run_coroutine_threadsafe(
  File "/usr/local/lib/python3.9/concurrent/futures/_base.py", line 447, in result
    raise TimeoutError()
concurrent.futures._base.TimeoutError
2021-07-27 21:04:41 ERROR (MainThread) [custom_components.ical] Exception can't compare datetime.datetime to datetime.date in starts/ends: RASPAIL's Birthday - Start: 2004-03-04 00:00:00+01:00 - End: 2004-03-05 00:00:00+01:00, RRule: vRecur({'FREQ': ['YEARLY']})
2021-07-27 21:04:41 ERROR (MainThread) [homeassistant.components.cert_expiry] Error fetching mondiy.freeboxos.fr data: Connection timeout with server: mondiy.freeboxos.fr:443
2021-07-27 21:04:41 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
  File "/usr/src/homeassistant/homeassistant/components/hassio/ingress.py", line 246, in _websocket_forward
    await ws_to.send_bytes(msg.data)
  File "/usr/local/lib/python3.9/site-packages/aiohttp/client_ws.py", line 155, in send_bytes
    await self._writer.send(data, binary=True, compress=compress)
  File "/usr/local/lib/python3.9/site-packages/aiohttp/http_websocket.py", line 685, in send
    await self._send_frame(message, WSMsgType.BINARY, compress)
  File "/usr/local/lib/python3.9/site-packages/aiohttp/http_websocket.py", line 643, in _send_frame
    self._write(header + mask + message)
  File "/usr/local/lib/python3.9/site-packages/aiohttp/http_websocket.py", line 660, in _write
    raise ConnectionResetError("Cannot write to closing transport")
ConnectionResetError: Cannot write to closing transport
2021-07-27 21:04:41 ERROR (MainThread) [homeassistant.components.rest.data] Error fetching data: https://jokes-de-papa.com/blagues-courtes/blague-du-jour/?quotes_page={{states("sensor.random")| float |round(0)}} failed with
2021-07-27 21:04:45 ERROR (MainThread) [homeassistant.components.scrape.sensor] Unable to extract data from HTML for Dicton
2021-07-27 21:05:31 ERROR (MainThread) [homeassistant.components.scrape.sensor] Unable to extract data from HTML for Dicton
2021-07-27 21:05:59 ERROR (MainThread) [homeassistant.components.scrape.sensor] Unable to extract data from HTML for Dicton
2021-07-27 21:06:20 ERROR (MainThread) [homeassistant.helpers.event] Error while processing template: Template("{{ (state_attr('binary_sensor.xpar_af', 'valj') |round(3)) - (state_attr('binary_sensor.xpar_af', 'vala') |round(3)) }}")
  File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 389, in async_render
    render_result = _render_with_context(self.template, compiled, **kwargs)
  File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 1358, in _render_with_context
    return template.render(**kwargs)
  File "/usr/local/lib/python3.9/site-packages/jinja2/environment.py", line 1304, in render
    self.environment.handle_exception()
  File "/usr/local/lib/python3.9/site-packages/jinja2/environment.py", line 925, in handle_exception
    raise rewrite_traceback_stack(source=source)
  File "<template>", line 1, in top-level template code
TypeError: unsupported operand type(s) for -: 'NoneType' and 'NoneType'
The above exception was the direct cause of the following exception:
  File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 505, in async_render_to_info
    render_info._result = self.async_render(variables, strict=strict, **kwargs)
  File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 391, in async_render
    raise TemplateError(err) from err
homeassistant.exceptions.TemplateError: TypeError: unsupported operand type(s) for -: 'NoneType' and 'NoneType'
2021-07-27 21:06:20 ERROR (MainThread) [homeassistant.helpers.event] Error while processing template: Template("{{ ((state_attr('binary_sensor.xpar_af', 'valj') |round(3) * 0.005)) |round(2) }}")
TypeError: unsupported operand type(s) for *: 'NoneType' and 'float'
homeassistant.exceptions.TemplateError: TypeError: unsupported operand type(s) for *: 'NoneType' and 'float'
2021-07-27 21:06:20 ERROR (MainThread) [homeassistant.components.template.template_entity] TemplateError('TypeError: unsupported operand type(s) for -: 'NoneType' and 'NoneType'') while processing template 'Template("{{ (state_attr('binary_sensor.xpar_af', 'valj') |round(3)) - (state_attr('binary_sensor.xpar_af', 'vala') |round(3)) }}")' for attribute 'moinplus' in entity 'binary_sensor.xpar_af'
2021-07-27 21:06:20 ERROR (MainThread) [homeassistant.components.template.template_entity] TemplateError('TypeError: unsupported operand type(s) for *: 'NoneType' and 'float'') while processing template 'Template("{{ ((state_attr('binary_sensor.xpar_af', 'valj') |round(3) * 0.005)) |round(2) }}")' for attribute 'frais' in entity 'binary_sensor.xpar_af'
2021-07-27 21:06:20 ERROR (MainThread) [homeassistant.helpers.event] Error while processing template: Template("{{ (state_attr('binary_sensor.xpar_alcrb', 'valj') |round(3)) - (state_attr('binary_sensor.xpar_alcrb', 'vala') |round(3)) }}")
2021-07-27 21:06:20 ERROR (MainThread) [homeassistant.helpers.event] Error while processing template: Template("{{ ((state_attr('binary_sensor.xpar_alcrb', 'valj') |round(3) * 0.005)) |round(2) }}")
2021-07-27 21:06:20 ERROR (MainThread) [homeassistant.components.template.template_entity] TemplateError('TypeError: unsupported operand type(s) for -: 'NoneType' and 'NoneType'') while processing template 'Template("{{ (state_attr('binary_sensor.xpar_alcrb', 'valj') |round(3)) - (state_attr('binary_sensor.xpar_alcrb', 'vala') |round(3)) }}")' for attribute 'moinplus' in entity 'binary_sensor.xpar_alcrb'
2021-07-27 21:06:20 ERROR (MainThread) [homeassistant.components.template.template_entity] TemplateError('TypeError: unsupported operand type(s) for *: 'NoneType' and 'float'') while processing template 'Template("{{ ((state_attr('binary_sensor.xpar_alcrb', 'valj') |round(3) * 0.005)) |round(2) }}")' for attribute 'frais' in entity 'binary_sensor.xpar_alcrb'
2021-07-27 21:06:20 ERROR (MainThread) [homeassistant.helpers.event] Error while processing template: Template("{{ (state_attr('binary_sensor.xpar_alter', 'valj') |round(3)) - (state_attr('binary_sensor.xpar_alter', 'vala') |round(3)) }}")
ça c’est pas très grave… c’est un warning
    raise err
    sock.connect(sa)
c’est la bonne adresse ip ?
Sans rapport avec ce sujet sur l’aspirateur =>pynetgear_enhanced
c’est pas un problème d’ip, 192.168.0.37
Cet ip est l’adresse du switch netgear
Oui, on est bien d’accord : c’est marqué dans les logs et dans mon message au dessus…
Il y a pas de trace d’anomalie avec l’aspirateur, c’est la partie netgear qui marche pas.
Tu cherches pas du bon coté et c’est pas le sujet du post. A mon avis, il vaudrait mieux ouvrir un sujet dédié
EDIT:
Contenu des logs :
  • Erreur netgear : 20 fois
  • Erreur syntax template binary_sensor.xpar_alcrb: 8 fois
  • Erreur id uniques : 2 fois (clim_salon_on et unset_radio_selection_salon)
  • Erreur roborock : 1 fois (not discovered)
  • Erreur syntax template blagues-courtes : 1 fois
Suite à la longueur de la coupure le switch netgear à perdu l’heure, il est en 1970.
ça explique probablement les dysfonctionnements.
A suivre…
Carrément. Une fois que ça sera corrigé, un redémarrage de ha permettra de faire le tri dans les anomalies résiduelles.
C’est pas le seul souci
