Bob
Juillet 7, 2022, 11:59
1
Je tente d’installer une ESP32-CAM dont voici le modèle:
Adaptateur FT232RL:
Pour info j’ai déjà un ESP32 avec capteur Température / humidité qui fonctionne bien.
L’installation depuis mon PC via le câble USB vers FT232RL semble bien se passer et l’ESP32-CAM est online:
Mais je vois une erreur dans les logs :
INFO Reading configuration /config/esphome/esp32camsalon.yaml...
WARNING GPIO15 is a Strapping PIN and should be avoided.
Attaching external pullup/down resistors to strapping pins can cause unexpected failures.
See https://esphome.io/guides/faq.html#why-am-i-getting-a-warning-about-strapping-pins
INFO Starting log output from esp32camsalon.local using esphome API
INFO Successfully connected to esp32camsalon.local
[13:55:31][I][app:102]: ESPHome version 2022.6.2 compiled on Jul 7 2022, 13:28:43
[13:55:31][C][wifi:491]: WiFi:
[13:55:31][C][wifi:353]: Local MAC: 0C:B8:15:FE:DF:4C
[13:55:31][C][wifi:354]: SSID: [redacted]
[13:55:31][C][wifi:355]: IP Address: 192.168.1.8
[13:55:31][C][wifi:357]: BSSID: [redacted]
[13:55:31][C][wifi:358]: Hostname: 'esp32camsalon'
[13:55:31][C][wifi:360]: Signal strength: -56 dB ▂▄▆█
[13:55:31][C][wifi:364]: Channel: 11
[13:55:31][C][wifi:365]: Subnet: 255.255.255.0
[13:55:31][C][wifi:366]: Gateway: 192.168.1.254
[13:55:31][C][wifi:367]: DNS1: 192.168.1.254
[13:55:31][C][wifi:368]: DNS2: 0.0.0.0
[13:55:31][C][logger:275]: Logger:
[13:55:31][C][logger:276]: Level: DEBUG
[13:55:31][C][logger:277]: Log Baud Rate: 115200
[13:55:31][C][logger:278]: Hardware UART: UART0
[13:55:31][C][esp32_camera:048]: ESP32 Camera:
[13:55:31][C][esp32_camera:049]: Name: My Camera
[13:55:31][C][esp32_camera:050]: Internal: NO
[13:55:31][C][esp32_camera:052]: Data Pins: D0:17 D1:35 D2:34 D3:5 D4:39 D5:18 D6:36 D7:19
[13:55:31][C][esp32_camera:053]: VSYNC Pin: 22
[13:55:31][C][esp32_camera:054]: HREF Pin: 26
[13:55:31][C][esp32_camera:055]: Pixel Clock Pin: 21
[13:55:31][C][esp32_camera:056]: External Clock: Pin:27 Frequency:20000000
[13:55:31][C][esp32_camera:057]: I2C Pins: SDA:25 SCL:23
[13:55:31][C][esp32_camera:058]: Reset Pin: 15
[13:55:31][C][esp32_camera:076]: Resolution: 640x480 (VGA)
[13:55:31][E][esp32_camera:095]: Setup Failed: ERROR
[13:55:31][C][psram:020]: PSRAM:
[13:55:31][C][psram:021]: Available: YES
[13:55:31][C][captive_portal:088]: Captive Portal:
[13:55:31][C][mdns:084]: mDNS:
[13:55:31][C][mdns:085]: Hostname: esp32camsalon
[13:55:31][C][ota:085]: Over-The-Air Updates:
[13:55:31][C][ota:086]: Address: esp32camsalon.local:3232
[13:55:31][C][ota:089]: Using Password.
[13:55:31][C][api:138]: API Server:
[13:55:31][C][api:139]: Address: esp32camsalon.local:6053
[13:55:31][C][api:141]: Using noise encryption: YES
Mais dans mon board elle est inactive :
Une petite idée ?
Merci,
Bob
Voici mon fichier yaml:
esphome:
esp32:
board: esp32dev
# framework:
# type: arduino
#esphome:
# name: esp32camsalon
# platform: ESP32
# board: nodemcu-32s
# Enable logging
logger:
level: DEBUG
# Enable Home Assistant API
api:
encryption:
key: "fl4CJu/nFmJf8sia8w7ImTQd5txxxxxxxxxxW5rJDM8="
ota:
password: "2746018d727b50xxxxxxxxxx001e548d"
wifi:
ssid: !secret wifi_ssid
ap:
ssid: "Esp32Camsalon Fallback Hotspot"
password: "DexxxxxxQ96T"
captive_portal:
# Example configuration entry
esp32_camera:
external_clock:
pin: GPIO27
frequency: 20MHz
i2c_pins:
sda: GPIO25
scl: GPIO23
data_pins: [GPIO17, GPIO35, GPIO34, GPIO5, GPIO39, GPIO18, GPIO36, GPIO19]
vsync_pin: GPIO22
href_pin: GPIO26
pixel_clock_pin: GPIO21
reset_pin: GPIO15
resolution: 640x480
jpeg_quality: 10
System Health
version
core-2022.6.7
installation_type
Home Assistant OS
dev
false
hassio
true
docker
true
user
root
virtualenv
false
python_version
3.9.12
os_name
Linux
os_version
5.15.32-v8
arch
aarch64
timezone
Europe/Paris
GitHub API
ok
GitHub Content
ok
GitHub Web
ok
GitHub API Calls Remaining
5000
Installed Version
1.25.5
Stage
running
Available Repositories
1074
Downloaded Repositories
19
logged_in
false
can_reach_cert_server
ok
can_reach_cloud_auth
ok
can_reach_cloud
ok
host_os
Home Assistant OS 8.2
update_channel
stable
supervisor_version
supervisor-2022.06.2
agent_version
1.2.1
docker_version
20.10.14
disk_total
457.7 GB
disk_used
16.1 GB
healthy
true
supported
true
board
rpi4-64
supervisor_api
ok
version_api
ok
installed_addons
deCONZ (6.14.2), Let’s Encrypt (4.12.5), File editor (5.3.3), Samba share (10.0.0), Network UPS Tools (0.11.0), Spotify Connect (0.12.1), Terminal & SSH (9.4.0), Portainer (2.0.0), InfluxDB (4.5.0), Grafana (7.6.0), Node-RED (12.0.2), Studio Code Server (5.1.2), ESPHome (2022.6.2)
dashboards
2
resources
13
views
10
mode
storage
oldest_recorder_run
29 juin 2022 à 18:46
current_recorder_run
29 juin 2022 à 20:46
estimated_db_size
232.63 MiB
database_engine
sqlite
database_version
3.34.1
Spotify
api_endpoint_reachable
ok
jrvrcd
Juillet 7, 2022, 1:04
2
j’ai un modele de camera identique
il s’agit du modele AI-thinker
Le code a utiliser est le suivant
Configuration for Ai-Thinker Camera
esp32_camera:
external_clock:
pin: GPIO0
frequency: 20MHz
i2c_pins:
sda: GPIO26
scl: GPIO27
data_pins: [GPIO5, GPIO18, GPIO19, GPIO21, GPIO36, GPIO39, GPIO34, GPIO35]
vsync_pin: GPIO25
href_pin: GPIO23
pixel_clock_pin: GPIO22
power_down_pin: GPIO32
le code que tu as utilisé correspond a la configuration d’un M5-stack
qui ressemble plus a cela
Bob
Juillet 7, 2022, 1:15
3
Merci, je testerai ce soir, Ai-Thinker Camera était la première conf que j’avais testé mais depuis j’ai tenté aussi plusieurs conf pour le début de fichier yaml et je n’étais pas revenu en arrière:
esphome:
esp32:
board: esp32dev
Bob
Bob
Juillet 7, 2022, 5:24
4
Pas mieux @jrvrcd
Pourrais-tu me donner le .yaml complet que tu utilises stp, j’ai toujours le même souci.
Le yaml :
esphome:
esp32:
board: esp32dev
# framework:
# type: arduino
# Enable logging
logger:
level: DEBUG
api:
encryption:
key: "makey"
ota:
password: "monpwd"
wifi:
ap:
ssid: "Espcam32A Fallback Hotspot"
password: "monpassword"
captive_portal:
esp32_camera:
external_clock:
pin: GPIO0
frequency: 20MHz
i2c_pins:
sda: GPIO26
scl: GPIO27
vsync_pin: GPIO25
href_pin: GPIO23
resolution: 640x480
jpeg_quality: 10
jrvrcd
Juillet 7, 2022, 5:46
5
comme demandé
esphome:
platform: ESP32
board: esp32cam
wifi:
networks:
- ssid: "Livebox-abcdef"
password: "password"
manual_ip:
static_ip: 192.168.1.xyz
gateway: 192.168.1.254
subnet: 255.255.255.0
dns1: 192.168.1.254
ap:
ssid: "Espcam 001 Fallback Hotspot"
password: "fallback"
captive_portal:
# Enable logging
logger:
api:
ota:
switch:
- platform: restart
time:
- platform: sntp
timezone: Europe/Paris
web_server:
port: 80
binary_sensor:
- platform: status
name: "Espcam 001 Status"
- platform: uptime
update_interval: 60s
unit_of_measurement: s
accuracy_decimals: 0
force_update: false
icon: mdi:timer
internal: True # Hide to HA
- platform: wifi_signal
name: "EspCam 001 WiFi Signal Sensor"
text_sensor:
name: espcam_001 - Uptime
icon: mdi:clock-start
lambda: |-
int seconds = (id(uptime_seconds).state);
int days = seconds / (24 * 3600);
seconds = seconds % (24 * 3600);
int hours = seconds / 3600;
seconds = seconds % 3600;
int minutes = seconds / 60;
seconds = seconds % 60;
if ( days ) {
return { (String(days) +"d " + String(hours) +"h " + String(minutes) +"m "+ String(seconds) +"s").c_str() };
} else if ( hours ) {
return { (String(hours) +"h " + String(minutes) +"m "+ String(seconds) +"s").c_str() };
} else if ( minutes ) {
return { (String(minutes) +"m "+ String(seconds) +"s").c_str() };
} else {
return { (String(seconds) +"s").c_str() };
esp32_camera:
external_clock:
pin: GPIO0
frequency: 20MHz
i2c_pins:
sda: GPIO26
scl: GPIO27
vsync_pin: GPIO25
href_pin: GPIO23
test_pattern: false
vertical_flip: false
horizontal_mirror: true
resolution: 640x480
max_framerate: 10 fps
idle_framerate: 0.1 fps
output:
# Register the LED as a dimmable output ....
- platform: ledc
pin: GPIO4
channel: 2
inverted: false
light:
# ... and then make a light out of it.
- platform: monochromatic
name: "Espcam 001 LED"
output: cam001_led
esp32_camera_web_server:
- port: 8080
mode: stream
Bob
Juillet 7, 2022, 6:25
6
Super @jrvrcd , merci j’ai l’image
Juste une autre question sur le bloc text_sensor: que je n’ai pas mis dans mon .yaml, il sert à quoi ?
Merci encore
Bob
Un horodatage je pense : temps d’uptime au format D H M S
Bob
Juillet 7, 2022, 6:49
8
Merci c’est top, je regarderai plus tard tous les paramètres possibles.
La carte FT232RL ne sert que la première fois ? Une fois le module en wifi on peut le flasher sans ?
Sinon une dernière question pour ce sujet, je vois un onglet « visit »
Qui pointe sur « http://espcam32a.local/ » mais inaccessible, j’ai la vidéo dans le board donc pas gênant…
Reste à regarder les détections de personnes ou de « chose » mais déjà très content
Merci beaucoup
Bob
jrvrcd
Juillet 7, 2022, 7:05
9
Hello again
Contant que ce soit tombé en marche
Comme le suggère @Pulpy-Luke le text sensor permet de remonter le temps de fonctionnement depuis le dernier reboot de l’esp
Pour repondre a ta derniere question
L’avantage d’esphome c’estqu’une fois qu’un firmwre de base est chargé tout ce fait over the air le fameux OTA
Bob
Juillet 7, 2022, 7:33
10
Génial, merci encore pour ton aide, je souhaite explorer tous les aspects de HA, premier ESP32 semaine dernière avec LED pour rire et AHT10, NFC cette semaine et ESP32-CAM, je reste très soft et dans la « norme » dans mes board mais j’ai franchement un système qui tient la route.
Bonne soirée @jrvrcd @Pulpy-Luke
Bob
jrvrcd
Juillet 7, 2022, 7:47
11
C’est le but de ce forum de partage
Avec ton premier esp on a patachoné
Là ça a ete plus efficace
Bob
Juillet 7, 2022, 8:22
12
Je mets mon yaml si ça peu aider :
esphome:
platform: ESP32
board: esp32cam
#esp32:
# board: esp32cam
# framework:
# type: arduino
wifi:
ap:
password: "mypassword"
captive_portal:
# Enable logging
logger:
api:
encryption:
key: "mykey"
ota:
time:
- platform: sntp
web_server:
port: 80
binary_sensor:
- platform: status
- platform: uptime
force_update: false
icon: mdi:timer
name: "EspCam32a WiFi Signal Sensor"
update_interval: 5s
esp32_camera:
external_clock:
pin: GPIO0
frequency: 20MHz
i2c_pins:
sda: GPIO26
scl: GPIO27
vsync_pin: GPIO25
href_pin: GPIO23
test_pattern: false
horizontal_mirror: false
resolution: 1600x1200
output:
- platform: ledc
pin: GPIO4
channel: 2
inverted: false
light:
output: espcam32a_led
- port: 8080
mode: stream
Oui trop bien le forum, j’hésite parfois mais quand c’est nouveau pour moi, je demande.
Bob
Bob
Juillet 12, 2022, 6:49
13
Bonsoir,
Dans la continuité, je me dis, si détection de présence au salon avec un capteur Aqara, j’allume la LED de l’ESP32-CAM (ça fonctionne) et je fais un snapshot ?
L’interface me propose bien l’option:
Mais quand je rentre le filename :
Logger: homeassistant.helpers.template
Source: helpers/template.py:1926
First occurred: 19:45:54 (6 occurrences)
Last logged: 20:35:40
Template variable error: 'camera' is undefined when rendering '/tmp/snapshot_{{ camera.camerasalon }}.jpg'
Logger: homeassistant.components.automation.espcammtest
Source: helpers/script.py:1718
Integration: Automatisation (documentation, issues)
EspCammTest: Error executing script. Error for call_service at pos 2: Error rendering data template: UndefinedError: 'camera' is undefined
Source: components/automation/__init__.py:525
Error while executing automation automation.espcammtest: Error rendering data template: UndefinedError: 'camera' is undefined
Bob
C’est tout ecrit dans la doc
Donc
{{ entity_id.name }} et pas
Bob
Juillet 12, 2022, 7:23
15
Trop fatigué ce soir je crois, désolé :
Bob
Juillet 12, 2022, 7:42
16
Désolé @Pulpy-Luke , je me couche, demain j’'y verrai peut être clair.
Bob
Bob
Juillet 12, 2022, 7:55
17
Difficile de s’arrêter…
Le /tmp doit être à quel niveau ?
Essaye tmp/ (sans / devant) ça devrait arriver dans /config/tmp (à creer)
Bob
Juillet 12, 2022, 8:06
19
Mais je ne vois pas par quoi remplacer « yourcamera_ » dans:
filename: '/tmp/yourcamera_{{ now().strftime("%Y%m%d-%H%M%S") }}.jpg'
Suis nul ce soir
C’est marqué plus haut
Donc :
filename: 'tmp/{{ entity_id.name }}_{{ now().strftime("%Y%m%d-%H%M%S") }}.jpg'
