Bob
Juillet 12, 2022, 8:23
21
Ce n’est pas ma journée !
Logger: homeassistant.helpers.template
Source: helpers/template.py:1926
First occurred: 19:45:54 (10 occurrences)
Last logged: 22:18:08
Template variable error: 'camera' is undefined when rendering '/tmp/snapshot_{{ camera.camerasalon }}.jpg'
Template variable error: 'espcam32a' is undefined when rendering '/tmp/snapshot_{{ espcam32a.camerasalon }}.jpg'
Template variable error: 'entity_id' is undefined when rendering 'filename: 'tmp/{{ entity_id.name }}_{{ now().strftime("%Y%m%d-%H%M%S") }}.jpg''
Logger: homeassistant.components.automation.espcammtest
Source: helpers/script.py:1718
Integration: Automatisation (documentation, issues)
EspCammTest: Error executing script. Error for call_service at pos 2: Error rendering data template: UndefinedError: 'camera' is undefined
EspCammTest: Error executing script. Error for call_service at pos 2: Error rendering data template: UndefinedError: 'espcam32a' is undefined
EspCammTest: Error executing script. Error for call_service at pos 2: Error rendering data template: UndefinedError: 'entity_id' is undefined
Source: components/automation/__init__.py:525
Error while executing automation automation.espcammtest: Error rendering data template: UndefinedError: 'camera' is undefined
Error while executing automation automation.espcammtest: Error rendering data template: UndefinedError: 'espcam32a' is undefined
Error while executing automation automation.espcammtest: Error rendering data template: UndefinedError: 'entity_id' is undefined
Merci @Pulpy-Luke , je reprendrai demain.
Bonne soirée
C’est l’heure d’aller au lit
Ligne 4 et 5 ça doit ne faire qu’une ligne …
Et répetition entre ligne 3 et 4 …
Bref: remplace 3 par mon exemple, et tu vire 4 et 5
Bob
Juillet 12, 2022, 8:45
23
Je crois en effet…
alias: EspCammTest
description: ''
- type: motion
platform: device
device_id: c103f6da952202b6f055e6ccde5a07f9
entity_id: binary_sensor.presence_22_salon
domain: binary_sensor
condition: []
- type: turn_on
device_id: 11175eea9941527c81a8beddb75e1a13
entity_id: light.espcam32a_led
domain: light
brightness_pct: 100
flash: short
- service: camera.snapshot
filename: tmp/{{ entity_id.name }}_{{ now().strftime("%Y%m%d-%H%M%S") }}.jpg
area_id: salon
entity_id: camera.camerasalon
Tenté aussi :
filename: /tmp/{{ entity_id.name }}_{{ now().strftime("%Y%m%d-%H%M%S") }}.jpg
Toujours persévérer mais la nuit sera reposante, merci @Pulpy-Luke
Bob
Juillet 13, 2022, 1:21
25
Bonjour @Pulpy-Luke
ça va mieux aujourd’hui
Bon préciser le /config/tmp en plus du /config que j’avais déjà pour tts n’est pas utile je pense mais plus clair.
comme ceci ça fonctionne :
filename: /config/tmp/salon166_{{now().strftime("%Y%m%d-%H%M%S")}}.jpg
Par contre avec le entity_id.name ça plante.
#BLC ajoute
homeassistant:
customize: !include customize.yaml
whitelist_external_dirs:
#allowlist_external_dirs:
#- /config/tts
- /config
- /config/tmp
Merci beaucoup @Pulpy-Luke
Bob
Juillet 26, 2022, 4:34
26
J’ai reçu deux nouveaux ESP32-CAM, même branchement avec le FT232RL mais impossible de m’y connecter, il me propose « USB Serail Port (COM4) associé » mais :
J’ai essayé un deuxième FT232RL qui lui me propose le port (COM5) mais même résultat.
Une petite idée svp
Bob
bentou
Juillet 26, 2022, 5:28
27
tu as bien mis le GPIO00 à la masse ?
Bob
Juillet 26, 2022, 5:58
28
Oui j’ai bien le pont entre GPIO00 et GND, ça m’échappe, pareil avec mes deux cartes ESP32-CAM, avec la première pas eu de souci de connexion.
Bob
Juillet 28, 2022, 9:31
29
Bonsoir,
J’ai pu connecter une nouvelle esp32-cam, pas tout sous les yeux pour expliquer mais je précise demain le problème de branchement gnd.
Bob
Bob
Juillet 29, 2022, 4:30
30
Je trouve ça surprenant mais au lieu de brancher le GND du FT232RL sur le GND de l’ESP32-CAM situé à côté du GPIO1, je l’ai branché sur le GND situé à côté de la pin 5V et ça a fonctionné.
Mystère mais ça fonctionne.
Bob
J’ai eu deux autre esp ou le GND étaient connectés avec ‹ rien ›
Bob
Août 26, 2022, 5:07
32
Bonsoir,
Dans certains tuto sur l’ESP32-CAM je vois cette intervace pour gérer la caméra:
La mienne est bien plus rudimentaire
Bob
Bob
Septembre 17, 2022, 5:05
33
Bonsoir, personne ne dispose de l’interface avec toutes les options ?
Haz
Septembre 17, 2022, 10:36
34
Pour moi la seconde interface est celle d’ESPHOME.
J’ai eu la seconde pour tester l’ESP-CAM mais je ne me souviens plus de ce que j’ai flashé. De mémoire, je l’ai flashé en copiant le code sur plateformio ou alors sur lIDE Arduino…
Le code se trouve très facilement. C’est le premier que j’ai trouvé.
Haz
Septembre 17, 2022, 10:41
35
Je viens d’ouvrir l’IDE Arduino et je vois le code…
Je pense que celui proposé directement sur Arduino
Là
BLG
Mars 20, 2023, 9:50
36
Je suis dans le même cas que les autres.
J’ai installé ma 1er camera avec pas mal de difficulté mais j’y suis arrivé
malheureusement je veux installé la 2eme et la je bloque
![Capture d’écran 2023-03-20 à 10.45.22|416x500]
voici ma capture
(upload://byJZhZvCYGZjvFz40uVyNot6Xn7.jpeg)
quelqu’un aurait une idée , j’ai essayé beaucoup de choses mais rien à faire
merci d’avance
BLG
Mars 20, 2023, 9:54
37
avec la capture c’est mieux
jrvrcd
Mars 20, 2023, 10:05
38
bonjour
il existe plusieurs modele de camera ESP
AITHINKER M5STACK, WROMER…
Le code ESP est a adapter en fonction du modele de carte
sous ESPHOME
il y a 11 modèles de camera présenté avec les firmwares respectifs.
BLG
Mars 20, 2023, 11:10
39
Bonjour jrvrcd
j’ai bien noté les 11 modèles et lu la notice mais ma camera et un modele TZT de shunxingwang dans lequel je n’ai rien d’autre comme info…
a tu d’autres info pour m’aider
BLG
Mars 20, 2023, 11:20
40
Pourquoi a la fin d’avoir flashé avec esphome flasher j’ai ce message…?
