c9cool
Janvier 12, 2025, 3:14
1
J'essaye de faire fonctionner une caméra esp32-cam sous HA. Mais, à chaque fois, le capteur se met en inactif.
Je n'arrive pas non plus à atteindre le esp32_camera_web_server d'ailleurs.
Le ESP32-CAM
Mon code:
esphome:
friendly_name: esptest
esp32:
board: esp32dev
framework:
type: arduino
# Enable logging
logger:
# Enable Home Assistant API
api:
encryption:
key: "lUnfmPuG28AF*******OuFs1IDMgk8jlRWnK1SLI="
ota:
- platform: esphome
password: "672dcb6*******3ef89442709"
wifi:
ssid: ********
password: ********
ap:
ssid: "Esptest Fallback Hotspot"
password: "Omq3vb06RTuK"
captive_portal:
esp32_camera:
external_clock:
pin: GPIO0
frequency: 20MHz
i2c_pins:
sda: GPIO26
scl: GPIO27
data_pins: [GPIO5, GPIO18, GPIO19, GPIO21, GPIO36, GPIO39, GPIO34, GPIO35]
vsync_pin: GPIO25
href_pin: GPIO23
pixel_clock_pin: GPIO22
power_down_pin: GPIO32
#Image settings
name: My ESP32-CAM
#Flashlight
light:
- platform: binary
output: flash
output:
- id: flash
platform: gpio
pin: GPIO4
esp32_camera_web_server:
- port: 8080
mode: stream
- port: 8081
mode: snapshot
Quelqu'un à une solution?
version
core-2025.1.2
installation_type
Home Assistant OS
dev
false
hassio
true
docker
true
user
root
virtualenv
false
python_version
3.13.1
os_name
Linux
os_version
6.6.62-haos-raspi
arch
aarch64
timezone
Europe/Brussels
config_dir
/config
logged_in
false
can_reach_cert_server
ok
can_reach_cloud_auth
ok
can_reach_cloud
ok
host_os
Home Assistant OS 14.1
update_channel
stable
supervisor_version
supervisor-2024.12.3
agent_version
1.6.0
docker_version
27.2.0
disk_total
122.3 GB
disk_used
7.7 GB
healthy
true
supported
true
host_connectivity
true
supervisor_connectivity
true
ntp_synchronized
true
virtualization
board
rpi5-64
supervisor_api
ok
version_api
ok
installed_addons
ESPHome Device Builder (2024.12.2)
dashboards
2
resources
0
views
0
mode
storage
oldest_recorder_run
12 janvier 2025 à 10:06
current_recorder_run
12 janvier 2025 à 11:06
estimated_db_size
0.56 MiB
database_engine
sqlite
database_version
3.47.1
Bob
Janvier 12, 2025, 3:40
2
Bonjour @c9cool ,
Elle apparait dans tes périphériques WIFI de ta box ?
Bob
c9cool
Janvier 12, 2025, 3:41
3
Hello @Bob ,
Oui, elle apparait bien
Bob
Janvier 12, 2025, 3:46
4
Tu utilises cette carte pour l’affichage ?
« Carte Entité image »
J’ai plus de paramètres que toi ici:
esp32_camera:
external_clock:
pin: GPIO0
frequency: 20MHz
i2c_pins:
sda: GPIO26
scl: GPIO27
vsync_pin: GPIO25
href_pin: GPIO23
test_pattern: false
vertical_flip: false
horizontal_mirror: false
resolution: 1600x1200
max_framerate: 10 fps
idle_framerate: 0.1 fps
Et la déclaration est différente aussi:
esphome:
friendly_name: Espcam32A-Salon
platform: ESP32
board: esp32cam
Teste comme ça:
esphome:
platform: ESP32
board: esp32cam
EDIT: en fait j’ai certaines ESP32Cam configurées aussi comme toi !
friendly_name: Espcam32F-Extérieur 2
esp32:
board: esp32dev
framework:
type: arduino
Bob
c9cool
Janvier 12, 2025, 4:03
5
J’ai testé en modifiant les paramètres mais cela ne changent rien… ça reste en inactif. Pourtant j’arrive à allumer et éteindre la lumière
Bob
Janvier 12, 2025, 4:08
6
Tu aurais une autre caméra à tester sur ton ESPCAM32 ?
Ta caméra c’est bien une OV2640 ?
Ajoute:
web_server:
port: 80
Tu auras dans l’interface ESPHome un lien visit, tu diras si ce lien t’affiche bien « l’interface » de ta CAM.
Bob
c9cool
Janvier 12, 2025, 4:34
7
@Bob
J'ai pas d'autres caméras actuellement. A priori c'est bien un OV2640 selon l'annonce aliexpress. Je peux vérifier ca physiquement?
Voilà ce que j'obtiens sur l'interface de l'esp32:
Je sais pas si il doit y avoir une mention camera?
Tu devrais voir dans les logs, les envois de ta caméra.
Il semble qu'il manque cette partie sous esp32cam
# Image/Video settings, https://esphome.io/components/esp32_camera.html
max_framerate: 5 fps # default: 10 fps, max 60
idle_framerate: 0.2 fps # default: 0.1 fps - framerate for 'picture' in HA dashboard
resolution: 800X600
jpeg_quality: 10
vertical_flip: True
horizontal_mirror: True
contrast: 0 # default: 0, variable -2 to 2
brightness: 0 # default: 0, variable -2 to 2
saturation: 0 # default: 0, variable -2 to 2
#aec_mode: MANUAL
#aec_value: 100
c9cool
Janvier 12, 2025, 5:51
9
Hello @Jeffodilo ,
J'ai ajouter tes entrées mais ca ne fonctionne toujours pas. Je n'ai pas de retour vidéo.
Voici le nouveau code actuel:
esphome:
esp32:
board: esp32dev
framework:
type: arduino
# Enable logging
logger:
api:
encryption:
key: "******************************"
ota:
- platform: esphome
password: "**************************"
wifi:
ssid: *************
password: ****************
ap:
captive_portal:
esp32_camera:
external_clock:
pin: GPIO0
frequency: 20MHz
i2c_pins:
sda: GPIO26
scl: GPIO27
vsync_pin: GPIO25
href_pin: GPIO23
max_framerate: 10 fps # default: 10 fps, max 60
resolution: 800X600
jpeg_quality: 10
vertical_flip: True
#aec_mode: MANUAL
#aec_value: 100
#Image settings
#Flashlight
light:
- platform: binary
output: flash
output:
- id: flash
platform: gpio
pin: GPIO4
- port: 8080
mode: stream
- port: 8081
mode: snapshot
web_server:
port: 80
voici le retour local de Esp:
c9cool
Janvier 12, 2025, 5:53
10
Je rajoute également les logs:
[18:51:42][I][app:100]: ESPHome version 2024.12.2 compiled on Jan 12 2025, 18:40:07
[18:51:42][C][wifi:600]: WiFi:
[18:51:42][C][wifi:428]: Local MAC: 5C:01:3B:98:3E:28
[18:51:42][C][wifi:433]: SSID: [redacted]
[18:51:42][C][wifi:436]: IP Address: 192.168.0.228
[18:51:42][C][wifi:440]: BSSID: [redacted]
[18:51:42][C][wifi:441]: Hostname: 'esptest'
[18:51:42][C][wifi:443]: Signal strength: -92 dB ▂▄▆█
[18:51:42][C][wifi:447]: Channel: 1
[18:51:42][C][wifi:448]: Subnet: 255.255.255.0
[18:51:42][C][wifi:449]: Gateway: 192.168.0.1
[18:51:42][C][wifi:450]: DNS1: 192.168.0.1
[18:51:42][C][wifi:451]: DNS2: 0.0.0.0
[18:51:42][C][logger:185]: Logger:
[18:51:42][C][logger:186]: Level: DEBUG
[18:51:42][C][logger:188]: Log Baud Rate: 115200
[18:51:42][C][logger:189]: Hardware UART: UART0
[18:51:42][C][gpio.output:010]: GPIO Binary Output:
[18:51:42][C][gpio.output:011]: Pin: GPIO4
[18:51:42][C][light:092]: Light 'flashlight'
[18:51:42][C][esp32_camera:048]: ESP32 Camera:
[18:51:42][C][esp32_camera:049]: Name: esptest
[18:51:42][C][esp32_camera:050]: Internal: NO
[18:51:42][C][esp32_camera:052]: Data Pins: D0:5 D1:18 D2:19 D3:21 D4:36 D5:39 D6:34 D7:35
[18:51:42][C][esp32_camera:053]: VSYNC Pin: 25
[18:51:42][C][esp32_camera:054]: HREF Pin: 23
[18:51:42][C][esp32_camera:055]: Pixel Clock Pin: 22
[18:51:42][C][esp32_camera:056]: External Clock: Pin:0 Frequency:20000000
[18:51:42][C][esp32_camera:060]: I2C Pins: SDA:26 SCL:27
[18:51:42][C][esp32_camera:062]: Reset Pin: -1
[18:51:42][C][esp32_camera:083]: Resolution: 800x600 (SVGA)
[18:51:42][E][esp32_camera:123]: Setup Failed: ESP_ERR_NOT_SUPPORTED
[18:51:42][E][component:082]: Component esp32_camera is marked FAILED
[18:51:42][C][psram:020]: PSRAM:
[18:51:42][C][psram:021]: Available: YES
[18:51:42][C][psram:024]: Size: 4095 KB
[18:51:42][C][captive_portal:089]: Captive Portal:
[18:51:42][C][web_server:153]: Web Server:
[18:51:42][C][web_server:154]: Address: esptest.local:80
[18:51:42][C][mdns:116]: mDNS:
[18:51:42][C][mdns:117]: Hostname: esptest
[18:51:42][C][esphome.ota:073]: Over-The-Air updates:
[18:51:42][C][esphome.ota:074]: Address: esptest.local:3232
[18:51:42][C][esphome.ota:075]: Version: 2
[18:51:42][C][esphome.ota:078]: Password configured
[18:51:42][C][safe_mode:018]: Safe Mode:
[18:51:42][C][safe_mode:020]: Boot considered successful after 60 seconds
[18:51:42][C][safe_mode:021]: Invoke after 10 boot attempts
[18:51:42][C][safe_mode:023]: Remain in safe mode for 300 seconds
[18:51:42][C][api:140]: API Server:
[18:51:42][C][api:141]: Address: esptest.local:6053
[18:51:42][C][api:143]: Using noise encryption: YES
[18:51:42][C][esp32_camera_web_server:088]: ESP32 Camera Web Server:
[18:51:42][C][esp32_camera_web_server:089]: Port: 8080
[18:51:42][C][esp32_camera_web_server:091]: Mode: stream
[18:51:42][E][esp32_camera_web_server:097]: Setup Failed
[18:51:42][E][component:082]: Component esp32_camera_web_server is marked FAILED
[18:51:42][C][esp32_camera_web_server:089]: Port: 8081
[18:51:42][C][esp32_camera_web_server:093]: Mode: snapshot
[18:51:43][E][component:082]: Component esp32_camera_web_server is marked FAILED
Il semble qu’un des paramètres ne passe pas.
Essaye de ne mettre que la config mini de base voir si l’erreur persiste
Le dernier truc que j’ai dont je ne suis pas de l’intérêt dans ton cas c’est cela
- port: 8080
mode: stream
- port: 8081
mode: snapshot
c9cool
Janvier 12, 2025, 6:56
13
@Jeffodilo j’ai réduit le code en utilisant la configuration Ai-Thinker Camera :
esp32_camera:
external_clock:
pin: GPIO0
frequency: 20MHz
i2c_pins:
sda: GPIO26
scl: GPIO27
vsync_pin: GPIO25
href_pin: GPIO23
# Image settings
#Flashlight
light:
- platform: binary
output: flash
output:
- id: flash
platform: gpio
pin: GPIO4
- port: 8080
mode: stream
- port: 8081
mode: snapshot
web_server:
port: 80
mais j’ai la même erreur…
Est-ce possible que ca soit à cause des pins (pas les bons gpio)?
Edit: J’ai retiré:
- port: 8080
mode: stream
- port: 8081
mode: snapshot
Edit 2 toujours cette maudite erreur…
[20:09:23][E][esp32_camera:123]: Setup Failed: ESP_ERR_NOT_SUPPORTED
[20:09:23][E][component:082]: Component esp32_camera is marked FAILED
J’ai les même pins que toi.
Tu es sûr que ta nappe est bien mise entre ton esp32cam et ton capteur ?
Tu as une photo de ton esp et ta cam ?
C’est bien une carte de ce type
https://a.aliexpress.com/_Ez0IfCu
c9cool
Janvier 12, 2025, 7:27
15
J'ai replacé la nappe 2-3 fois pour etre sur et c'est bien le même que celui d'aliexpress dont tu m'as envoyé
c9cool
Janvier 12, 2025, 8:09
16
Update, j’ai retrouvé un autre esp32-cam et je l’ai place sur la meme base pour le transfere et l’alimentation et ca me met la même erreur:
21:04:27 [E] [esp32_camera:123]
mais ca retire l’erreur:
Edit:
Ca me remet les memes deux erreurs…
Retires la SD card pour essayer elle ne sert à rien.
Je viens de trouver ceci, ce qui explique sans doute la cause.
https://github.com/prusa3d/Prusa-Firmware-ESP32-Cam/issues/75
J’ai trouvé ceci avec la référence sur la nappe de ta cam
Edit : en faisant une recherche avec RHYX-M21-45 esphome, on voit les mêmes erreurs que toi.
Rachète un vrai capteur OV2640
c9cool
Janvier 13, 2025, 10:47
18
Merci @Jeffodilo , je vais en recommander une et je reviendrais donner la suite.
c9cool
Janvier 24, 2025, 6:43
19
C’était bien la caméra qui ne fonctionnait pas, à peine la ov2640 de branché que ça fonctionnait. Merci beaucoup!
Top, amuse toi bien avec cette caméra
