Je ne sais pas si je suis sur le bon forum.
Mais j’aimerais savoir si quelqu’un avait essayé et fabriqué des enceintes pour utiliser Home Assistant Voice. Avoir le retour par rapport aux enceintes connectées propriétaires (Alexa, Google, etc…)
A vous relire
version
core-2023.11.3
installation_type
Home Assistant OS
dev
false
hassio
true
docker
true
user
root
virtualenv
false
python_version
3.11.6
os_name
Linux
os_version
6.1.21-v8
arch
aarch64
timezone
Europe/Paris
config_dir
/config
GitHub API
ok
GitHub Content
ok
GitHub Web
ok
GitHub API Calls Remaining
5000
Installed Version
1.33.0
Stage
running
Available Repositories
1418
Downloaded Repositories
25
HACS Data
ok
logged_in
true
subscription_expiration
14 septembre 2024 à 02:00
relayer_connected
true
relayer_region
eu-central-1
remote_enabled
true
remote_connected
true
alexa_enabled
true
google_enabled
false
remote_server
eu-central-1-2.ui.nabu.casa
certificate_status
ready
can_reach_cert_server
ok
can_reach_cloud_auth
ok
can_reach_cloud
ok
host_os
Home Assistant OS 11.1
update_channel
stable
supervisor_version
supervisor-2023.11.3
agent_version
1.6.0
docker_version
24.0.6
disk_total
116.7 GB
disk_used
85.6 GB
healthy
true
supported
true
board
rpi4-64
supervisor_api
ok
version_api
ok
installed_addons
Samba share (12.1.0), File editor (5.7.0), Advanced SSH & Web Terminal (16.0.1), ESPHome (2022.3.1), AppDaemon (0.15.2), room-assistant (2.20.0), Studio Code Server (5.14.2), Zigbee2MQTT (1.33.2-1), CEC Scanner (3.0), eWeLink Smart Home (1.4.3), Zigbee2MQTT Edge (edge), Mosquitto broker (6.4.0), Frigate (Full Access) (0.12.1), Node-RED (16.0.2), go2rtc master (master), Let’s Encrypt (5.0.1), Piper (1.4.0)
dashboards
1
resources
7
views
6
mode
storage
oldest_recorder_run
16 novembre 2023 à 17:18
current_recorder_run
25 novembre 2023 à 18:39
estimated_db_size
3954.57 MiB
database_engine
sqlite
database_version
3.41.2
Sonoff
version
3.5.2 (2ad1cd7)
cloud_online
0 / 17
local_online
17 / 17
debug
failed to load:
Un post évoque le sujet…
j’ai comme projet suite au visionnage d’une vidéo sur le sujet de faire un assistant permettant de contrôler ma domotique.
J’avais pour but de suivre ce tuto cependant la carte n’est plus disponible à la vente, j’ai donc eu pour projet de faire cela moi même.
J’aimerais savoir si quelqu’un à déjà essayé cela de son côté, pour ma part les éléments choisis sont les suivants :
ESP32 / Amplificateur audio / Enceinte / Microphone
Est-ce qu’il me manque quelque chose ? Pensez-vous que ce…
