Impossible d installer le fichier Yaml du capteur LD2450 sur mon ESP32miniS2
moi non plus
je suis deg !
j ai essayé sur sur 3 esp32S2 et sa bloque !
Dire que j avais le code correct; je suis oUF :face_with_spiral_eyes:
Bon j ai du réinstaller flash download tools afin de pouvoir flasher les ESP32miniS2 car impossible d utiliser Adafruits !
Je viens de tester le capteur de présence par contre il ne détecte qu une cible alors que nous sommes 3 !
J ai activer le button « select target multiple » !
19:23:37	[D]	[binary_sensor:036]
'Last Command Success': Sending state OFF
'Config Mode': Sending state ON
'Config Mode': Sending state OFF
19:23:37	[W]	[component:237]
Component web_server took a long time for an operation (60 ms).
19:23:37	[W]	[component:238]
Components should block for at most 30 ms.
'Last Command Success': Sending state ON
19:23:37	[D]	[text_sensor:064]
'Tracking Mode': Sending state 'Multiple'
19:23:37	[D]	[sensor:094]
'Target1 X': Sending state -31.00000 cm with 0 decimals of accuracy
'Target1 Y': Sending state 71.00000 cm with 0 decimals of accuracy
19:23:39	[D]	[sensor:094]
'Target1 X': Sending state 0.00000 cm with 0 decimals of accuracy
'Target1 Y': Sending state 0.00000 cm with 0 decimals of accuracy
'Target1 Resolution': Sending state 0.00000 nm with 0 decimals of accuracy
'Targets': Sending state 0.00000  with 0 decimals of accuracy
19:23:40	[D]	[sensor:094]
'Target1 Y': Sending state 79.00000 cm with 0 decimals of accuracy
'Target1 Resolution': Sending state 360.00000 nm with 0 decimals of accuracy
'Targets': Sending state 1.00000  with 0 decimals of accuracy
19:23:41	[D]	[sensor:094]
'Target1 Y': Sending state 72.00000 cm with 0 decimals of accuracy
19:23:42	[D]	[sensor:094]
'Target1 Y': Sending state 66.00000 cm with 0 decimals of accuracy
19:23:43	[D]	[sensor:094]
'Target1 X': Sending state -27.00000 cm with 0 decimals of accuracy
'Target1 Y': Sending state 64.00000 cm with 0 decimals of accuracy
19:23:44	[D]	[sensor:094]
Je ne connais pas le LD2450, je n’en ai pas. Tu devrais demander de l’aide sur le sujet que je t’ai joint où t’a pris le code.
Je viens de poster !
Merci beaucoup pour tes précieux conseils et ta patience !
Passes une bonne journée
Salut Forhorse
As tu réalisé ce capteur et l utilisés tu sur jeedom ?
As tu des soucis de réactivité important ?
En te remerciant par avance pour ton aide
Bonne journée
Non j’ai pas de 2450, uniquement un 2410 qui fonctionne passablement bien (trop sensible aux courant d’air)
