suite a ma décision de supprimer proxmox avec ha en vm, et d’installer ha en direct sur le mini pc.
mes integrations ( file editor zigbeemqtt par exemple) ne demarre plus…je suis au tout debut de home assisistant. je viens tout juste de recevoir ma cles sonoff.
merci pour votre aide!!!
tu as fait une restauration de sauvegarde sur ta nouvelle installation ?
oui, j’ai creer une sauvegarde avant la réinstallation.
elle a bien marché apparement
Ok, faut que tu arrête proprement HA ( arrêt systeme ). Tu débranche ta machine du secteur quelque seconde et rebranche.
Et rédémarre HA.
C'est un soucis qui existe depuis 2 ans presque et j'ai vu que ca été fixer sur le supervisor 2024.6.1 ( pas sortie , la 2024.6.2 est release mais pas déployer).
main ← addon-not-started-restore
ouvert 08:58PM - 28 May 24 UTC
## Proposed change
Full restore currently stops the docker events listener be… fore it begins as part of `shutdown`. It is not restarted afterwards leaving the addons in completely unknown states beyond that point. This PR fixes that issue, the docker monitor is no longer stopped.
It also fixes a minor possible issue where addons were not loaded prior to being restarted during a restore due to an exception. The first is the real cause of these "unknown state after restore" issues though.
## Type of change
- [ ] Dependency upgrade
- [x] Bugfix (non-breaking change which fixes an issue)
- [ ] New feature (which adds functionality to the supervisor)
- [ ] Breaking change (fix/feature causing existing functionality to break)
- [ ] Code quality improvements to existing code or addition of tests
## Additional information
- This PR fixes or closes issue: fixes #
- This PR is related to issue:
- Link to documentation pull request:
- Link to cli pull request:
## Checklist
- [ ] The code change is tested and works locally.
- [ ] Local tests pass. **Your PR cannot be merged unless tests pass**
- [ ] There is no commented out code in this PR.
- [ ] I have followed the [development checklist][dev-checklist]
- [ ] The code has been formatted using Ruff (`ruff format supervisor tests`)
- [ ] Tests have been added to verify that the new code works.
If API endpoints of add-on configuration are added/changed:
- [ ] Documentation added/updated for [developers.home-assistant.io][docs-repository]
[dev-checklist]: https://developers.home-assistant.io/docs/en/development_checklist.html
[docs-repository]: https://github.com/home-assistant/developers.home-assistant
## Summary by CodeRabbit
- **Bug Fixes**
- Ensured add-ons are properly loaded before running by moving the check to a `finally` block.
- **Improvements**
- Improved system shutdown process by removing unnecessary stopping of docker monitoring.
- **Tests**
- Added tests to verify addon state monitoring after full and partial restore operations.
edit:
@anon21985933 , enfin c'est fixer
edit2:
le jour ou j'ai eu ce soucis. aout 2022
ok ca marche…je vais faire ca
bon j’ai fais le malin…je dois retrouver mon mp…sauf que je m’apercois que je ne l’ai pas noté…la loose.ca va m’apprendre tiens…
