ppj
1
Je n’arrive à installer Alexa mediaplayer. Je bloque sur la dernière étape.
[center]## System Information
version |
core-2024.3.3 |
installation_type |
Home Assistant OS |
dev |
false |
hassio |
true |
docker |
true |
user |
root |
virtualenv |
false |
python_version |
3.12.2 |
os_name |
Linux |
os_version |
6.1.73-haos-raspi |
arch |
aarch64 |
timezone |
Europe/Paris |
config_dir |
/config |
GitHub API |
ok |
GitHub Content |
ok |
GitHub Web |
ok |
GitHub API Calls Remaining |
4995 |
Installed Version |
1.34.0 |
Stage |
running |
Available Repositories |
1404 |
Downloaded Repositories |
11 |
HACS Data |
ok |
logged_in |
true |
subscription_expiration |
13 novembre 2024 à 01:00 |
relayer_connected |
true |
relayer_region |
eu-central-1 |
remote_enabled |
true |
remote_connected |
true |
alexa_enabled |
true |
google_enabled |
false |
remote_server |
eu-central-1-1.ui.nabu.casa |
certificate_status |
ready |
instance_id |
4c01e6d159264cc4998284f1d917b64e |
can_reach_cert_server |
ok |
can_reach_cloud_auth |
ok |
can_reach_cloud |
ok |
host_os |
Home Assistant OS 12.1 |
update_channel |
stable |
supervisor_version |
supervisor-2024.03.0 |
agent_version |
1.6.0 |
docker_version |
24.0.7 |
disk_total |
234.0 GB |
disk_used |
7.1 GB |
healthy |
true |
supported |
true |
board |
rpi5-64 |
supervisor_api |
ok |
version_api |
ok |
installed_addons |
Advanced SSH & Web Terminal (17.2.0), File editor (5.8.0), Samba share (12.3.1), Samba Backup (5.2.0), Mosquitto broker (6.4.0), Zigbee2MQTT (1.36.0-1) |
dashboards |
3 |
resources |
7 |
views |
16 |
mode |
storage |
oldest_recorder_run |
17 mars 2024 à 06:35 |
current_recorder_run |
27 mars 2024 à 10:07 |
estimated_db_size |
325.50 MiB |
database_engine |
sqlite |
database_version |
3.44.2 |
Sonoff
version |
3.6.0 (8dd8af9) |
cloud_online |
5 / 5 |
local_online |
0 / 0 |
[/center]
BBE
2
Essaie de changer de navigateur. Moi ça avait marché…
Je n’utilise pas Nabucasa, mais Tu as peut être le même type de souci que moi avec la double authentification.
Regarde ce sujet
ppj
4
J’ai essayé mais j’ai toujours la même erreur.
ppj
5
Merci, cela fonctionne.
Il fallait simplement activer la double authentification.
