Il faut souvent réactiver la page pour voir le journal et ce qui est rajouté …
Faut il appuyer sur le bouton de la clé RF player ?
Je m insere dans la conversation.
Pour moi l integration est bien la mais il n y a aucun appareils ni d’entites
non rafraichir ta page internet
et ce qu’il montre c’est pas des entités
Il n’ y a pas da capteur qui apparaissent en plus.
Lorsque j’appui sur le bouton appairage de la sonde de temperature blyss, je vois que la RFPLAYER detecte bien un signal car sa led clignote simultanément en bleu mais sans qu’un nouveau sensor n’apparaisse ?
Ok vérifie le log il a du avancé, mais j’espere pas planté chez toi !
Voici:
2023-03-07 15:38:27.939 WARNING (SyncWorker_2) [homeassistant.loader] We found a custom integration google_photos which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2023-03-07 15:38:27.946 WARNING (SyncWorker_2) [homeassistant.loader] We found a custom integration hacs which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2023-03-07 15:38:27.954 WARNING (SyncWorker_2) [homeassistant.loader] We found a custom integration google_home which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2023-03-07 15:38:27.961 WARNING (SyncWorker_2) [homeassistant.loader] We found a custom integration redback which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2023-03-07 15:38:27.972 WARNING (SyncWorker_2) [homeassistant.loader] We found a custom integration meross_lan which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2023-03-07 15:38:27.980 WARNING (SyncWorker_2) [homeassistant.loader] We found a custom integration dwains_dashboard which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2023-03-07 15:38:27.987 WARNING (SyncWorker_2) [homeassistant.loader] We found a custom integration meross_cloud which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2023-03-07 15:38:27.995 WARNING (SyncWorker_2) [homeassistant.loader] We found a custom integration ipx800v4 which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2023-03-07 15:38:28.003 WARNING (SyncWorker_2) [homeassistant.loader] We found a custom integration rfplayer which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2023-03-07 15:38:28.011 WARNING (SyncWorker_2) [homeassistant.loader] We found a custom integration oralb_ble which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2023-03-07 15:39:04.600 WARNING (MainThread) [homeassistant.setup] Setup of input_button is taking over 10 seconds.
2023-03-07 15:39:51.324 WARNING (MainThread) [homeassistant.bootstrap] Waiting on integrations to complete setup: raspberry_pi
2023-03-07 15:40:04.879 WARNING (MainThread) [homeassistant.helpers.frame] Detected integration that called async_setup_platforms instead of awaiting async_forward_entry_setups; this will fail in version 2023.3. Please report issue to the custom integration author for rfplayer using this method at custom_components/rfplayer/__init__.py, line 234: hass.config_entries.async_setup_platforms(entry, PLATFORMS)
2023-03-07 15:40:31.553 WARNING (MainThread) [custom_components.meross_lan] MerossDevice(Prise lampe canapé) ServerDisconnectedError(Server disconnected) in async_http_request GET Appliance.System.All
2023-03-07 15:40:31.578 WARNING (MainThread) [custom_components.meross_lan] MerossDevice(Prise Guirlande exterieure) ServerDisconnectedError(Server disconnected) in async_http_request GET Appliance.System.All
2023-03-07 15:40:31.596 WARNING (MainThread) [custom_components.meross_lan] MerossDevice(Prise Piano) ServerDisconnectedError(Server disconnected) in async_http_request GET Appliance.System.All
2023-03-07 15:40:39.640 WARNING (MainThread) [homeassistant.components.media_player] Setup of media_player platform dlna_dmr is taking over 10 seconds.
2023-03-07 16:06:26.467 WARNING (MainThread) [zigpy_deconz.api] No response to 'Command.aps_data_confirm' command with seq id '0xc9'
Oui !
Est ce que tu sais passer sur ![]()
j’ai cliqué dessus, et après ?
yes, j’y suis, pourquoi doit on mettre au moins 20 caractères dans le tchat ?
tu tapes STATUS sur la ligne commande
puis sur protocole tu mets 1
et après tu passes en bas PASSEZ EN MODE YAML
et tu effaces le 1
c’est fait , 20 caractères
OK après il faut appeler le service (sans rien de sélectionner autres)
tu devrais voir passer en vert si OK
