C’est un Raspberry Pi 3.
Regarde le log maintenant ?
2023-03-07 14:44:58.349 WARNING (SyncWorker_2) [homeassistant.loader] We found a custom integration google_photos which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2023-03-07 14:44:58.357 WARNING (SyncWorker_2) [homeassistant.loader] We found a custom integration hacs which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2023-03-07 14:44:58.362 WARNING (SyncWorker_2) [homeassistant.loader] We found a custom integration google_home which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2023-03-07 14:44:58.367 WARNING (SyncWorker_2) [homeassistant.loader] We found a custom integration redback which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2023-03-07 14:44:58.372 WARNING (SyncWorker_2) [homeassistant.loader] We found a custom integration meross_lan which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2023-03-07 14:44:58.377 WARNING (SyncWorker_2) [homeassistant.loader] We found a custom integration dwains_dashboard which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2023-03-07 14:44:58.382 WARNING (SyncWorker_2) [homeassistant.loader] We found a custom integration meross_cloud which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2023-03-07 14:44:58.386 WARNING (SyncWorker_2) [homeassistant.loader] We found a custom integration ipx800v4 which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2023-03-07 14:44:58.390 WARNING (SyncWorker_2) [homeassistant.loader] We found a custom integration rfplayer which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2023-03-07 14:44:58.395 WARNING (SyncWorker_2) [homeassistant.loader] We found a custom integration oralb_ble which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2023-03-07 14:45:22.506 WARNING (MainThread) [homeassistant.helpers.frame] Detected integration that called async_setup_platforms instead of awaiting async_forward_entry_setups; this will fail in version 2023.3. Please report issue to the custom integration author for rfplayer using this method at custom_components/rfplayer/__init__.py, line 234: hass.config_entries.async_setup_platforms(entry, PLATFORMS)
2023-03-07 14:45:22.787 WARNING (MainThread) [custom_components.rfplayer.rflib.rfpprotocol] dropping invalid data:
ZIA--Welcome to Ziblue Dongle RFPLAYER (RFP1000, Firmware=V1.39 F=433Mhz & 868Mhz EU)!
2023-03-07 14:45:35.726 WARNING (MainThread) [homeassistant.components.media_player] Setup of media_player platform dlna_dmr is taking over 10 seconds.
2023-03-07 14:45:55.899 WARNING (SyncWorker_3) [homeassistant.components.rpi_power.binary_sensor] Under-voltage was detected. Consider getting a uninterruptible power supply for your Raspberry Pi.
2023-03-07 14:46:37.742 WARNING (MainThread) [homeassistant.bootstrap] Waiting on integrations to complete setup: zha
2023-03-07 14:47:06.258 ERROR (MainThread) [homeassistant.components.ipp.coordinator] Error fetching ipp data: Invalid response from API: Timeout occurred while connecting to IPP server.
2023-03-07 14:47:06.280 ERROR (MainThread) [homeassistant.components.ipp.coordinator] Error fetching ipp data: Invalid response from API: Timeout occurred while connecting to IPP server.
2023-03-07 14:47:06.334 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
File "/usr/src/homeassistant/homeassistant/components/freebox/router.py", line 76, in update_all
await self.update_device_trackers()
File "/usr/src/homeassistant/homeassistant/components/freebox/router.py", line 82, in update_device_trackers
fbx_devices: list[dict[str, Any]] = await self._api.lan.get_hosts_list()
File "/usr/local/lib/python3.10/site-packages/freebox_api/api/lan.py", line 64, in get_hosts_list
return await self._access.get(f"lan/browser/{interface}")
File "/usr/local/lib/python3.10/site-packages/freebox_api/access.py", line 122, in get
return await self._perform_request(self.session.get, end_url)
File "/usr/local/lib/python3.10/site-packages/freebox_api/access.py", line 94, in _perform_request
r = await verb(url, **request_params)
File "/usr/local/lib/python3.10/site-packages/aiohttp/client.py", line 560, in _request
await resp.start(conn)
File "/usr/local/lib/python3.10/site-packages/aiohttp/client_reqrep.py", line 894, in start
with self._timer:
File "/usr/local/lib/python3.10/site-packages/aiohttp/helpers.py", line 721, in __exit__
raise asyncio.TimeoutError from None
asyncio.exceptions.TimeoutError
2023-03-07 14:52:06.274 WARNING (SyncWorker_4) [homeassistant.components.rpi_power.binary_sensor] Under-voltage was detected. Consider getting a uninterruptible power supply for your Raspberry Pi.
2023-03-07 14:58:06.309 WARNING (SyncWorker_0) [homeassistant.components.rpi_power.binary_sensor] Under-voltage was detected. Consider getting a uninterruptible power supply for your Raspberry Pi.
2023-03-07 15:00:06.325 WARNING (SyncWorker_0) [homeassistant.components.rpi_power.binary_sensor] Under-voltage was detected. Consider getting a uninterruptible power supply for your Raspberry Pi.
2023-03-07 15:01:06.323 WARNING (SyncWorker_8) [homeassistant.components.rpi_power.binary_sensor] Under-voltage was detected. Consider getting a uninterruptible power supply for your Raspberry Pi.
2023-03-07 15:01:46.533 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
File "/usr/local/lib/python3.10/site-packages/zigpy/device.py", line 131, in group_membership_scan
await ep.group_membership_scan()
File "/usr/local/lib/python3.10/site-packages/zigpy/endpoint.py", line 170, in group_membership_scan
groups = {group for group in res[1]}
TypeError: 'Status' object is not iterable
2023-03-07 15:03:06.331 WARNING (SyncWorker_0) [homeassistant.components.rpi_power.binary_sensor] Under-voltage was detected. Consider getting a uninterruptible power supply for your Raspberry Pi.
Tu as pas mal d’erreur auquel il faut remédier !
Essaie de désactiver celle de la freebox ! Montre ta page intégrations
dans
Puis
Je n’y connais pas grand chose pour l’instant mais ce message
« Under-voltage was detected. Consider getting a uninterruptible power supply for your Raspberry Pi. » ne serait-ce pas mon alim du RPI qui serait un peu faible?
je vais regarder sur celui que j’ai en RPI 3
J’ai mis une nouvelle version de Test du RFplayer !
Mais essaie sur freebox server de désactiver l’intégration avec les points verticaux
Je viens de desactiver freebox server
Il faut que je telecharge une nouvelle version de RF PLAYER ?
Si tu veux tester en avant première , c’est possible.
Mais pour l’instant il faut que les erreurs soient trouvées !
regarde ton sensor
binary_sensor.rpi_power_status
on dirait que le fichier log est mieux ?
2023-03-07 15:38:27.939 WARNING (SyncWorker_2) [homeassistant.loader] We found a custom integration google_photos which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2023-03-07 15:38:27.946 WARNING (SyncWorker_2) [homeassistant.loader] We found a custom integration hacs which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2023-03-07 15:38:27.954 WARNING (SyncWorker_2) [homeassistant.loader] We found a custom integration google_home which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2023-03-07 15:38:27.961 WARNING (SyncWorker_2) [homeassistant.loader] We found a custom integration redback which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2023-03-07 15:38:27.972 WARNING (SyncWorker_2) [homeassistant.loader] We found a custom integration meross_lan which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2023-03-07 15:38:27.980 WARNING (SyncWorker_2) [homeassistant.loader] We found a custom integration dwains_dashboard which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2023-03-07 15:38:27.987 WARNING (SyncWorker_2) [homeassistant.loader] We found a custom integration meross_cloud which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2023-03-07 15:38:27.995 WARNING (SyncWorker_2) [homeassistant.loader] We found a custom integration ipx800v4 which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2023-03-07 15:38:28.003 WARNING (SyncWorker_2) [homeassistant.loader] We found a custom integration rfplayer which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2023-03-07 15:38:28.011 WARNING (SyncWorker_2) [homeassistant.loader] We found a custom integration oralb_ble which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2023-03-07 15:39:04.600 WARNING (MainThread) [homeassistant.setup] Setup of input_button is taking over 10 seconds.
2023-03-07 15:39:51.324 WARNING (MainThread) [homeassistant.bootstrap] Waiting on integrations to complete setup: raspberry_pi
2023-03-07 15:40:04.879 WARNING (MainThread) [homeassistant.helpers.frame] Detected integration that called async_setup_platforms instead of awaiting async_forward_entry_setups; this will fail in version 2023.3. Please report issue to the custom integration author for rfplayer using this method at custom_components/rfplayer/__init__.py, line 234: hass.config_entries.async_setup_platforms(entry, PLATFORMS)
2023-03-07 15:40:31.553 WARNING (MainThread) [custom_components.meross_lan] MerossDevice(Prise lampe canapé) ServerDisconnectedError(Server disconnected) in async_http_request GET Appliance.System.All
2023-03-07 15:40:31.578 WARNING (MainThread) [custom_components.meross_lan] MerossDevice(Prise Guirlande exterieure) ServerDisconnectedError(Server disconnected) in async_http_request GET Appliance.System.All
2023-03-07 15:40:31.596 WARNING (MainThread) [custom_components.meross_lan] MerossDevice(Prise Piano) ServerDisconnectedError(Server disconnected) in async_http_request GET Appliance.System.All
2023-03-07 15:40:39.640 WARNING (MainThread) [homeassistant.components.media_player] Setup of media_player platform dlna_dmr is taking over 10 seconds.
C’est vrai que s itu as x choses sur USB cela peut surcharger ce RPI.
Laisse tourner un peu regarde les entités qui remonte sur le Rfplayer dans Appareils et service.
Maintenant, je fais quoi ?
regarde si tu as d’autres entités remontées dans le Rfplayer !
Vérifie que l’otion ajout automatique est bien configuré
AINSI que dans Options Système
oui c’est bien le cas
Donc montre moi les logs ! que tu as maintenant …
Cest le cas aussi, une 5 entité vient d’apparaitre !
Cela dépend des sensors!
