Avez-vous constaté un disfonctionnement de l’intégration Météo France depuis deux jours ?
Ou est-ce un problème venant de chez moi ?
Merci pour vos retours.
version |
core-2023.6.2 |
installation_type |
Home Assistant OS |
dev |
false |
hassio |
true |
docker |
true |
user |
root |
virtualenv |
false |
python_version |
3.11.4 |
os_name |
Linux |
os_version |
6.1.21-v8 |
arch |
aarch64 |
timezone |
Europe/Paris |
config_dir |
/config |
GitHub API |
ok |
GitHub Content |
ok |
GitHub Web |
ok |
GitHub API Calls Remaining |
5000 |
Installed Version |
1.32.1 |
Stage |
running |
Available Repositories |
1356 |
Downloaded Repositories |
24 |
HACS Data |
ok |
logged_in |
true |
subscription_expiration |
14 septembre 2023 à 02:00 |
relayer_connected |
true |
relayer_region |
eu-central-1 |
remote_enabled |
true |
remote_connected |
true |
alexa_enabled |
true |
google_enabled |
false |
remote_server |
eu-central-1-2.ui.nabu.casa |
certificate_status |
ready |
can_reach_cert_server |
ok |
can_reach_cloud_auth |
ok |
can_reach_cloud |
ok |
host_os |
Home Assistant OS 10.3 |
update_channel |
stable |
supervisor_version |
supervisor-2023.06.2 |
agent_version |
1.5.1 |
docker_version |
23.0.6 |
disk_total |
116.7 GB |
disk_used |
57.4 GB |
healthy |
true |
supported |
true |
board |
rpi4-64 |
supervisor_api |
ok |
version_api |
ok |
installed_addons |
Samba share (10.0.2), File editor (5.6.0), Advanced SSH & Web Terminal (15.0.2), ESPHome (2022.3.1), AppDaemon (0.13.1), room-assistant (2.20.0), Studio Code Server (5.6.2), Zigbee2MQTT (1.31.2-1), CEC Scanner (3.0), eWeLink Smart Home (1.4.3), Zigbee2MQTT Edge (edge), Mosquitto broker (6.2.1), Node-RED (14.2.2) |
dashboards |
1 |
resources |
6 |
views |
6 |
mode |
storage |
oldest_recorder_run |
9 juin 2023 à 04:43 |
current_recorder_run |
19 juin 2023 à 13:31 |
estimated_db_size |
3903.46 MiB |
database_engine |
sqlite |
database_version |
3.41.2 |
Sonoff
version |
3.5.1 (122751c) |
cloud_online |
17 / 17 |
local_online |
17 / 17 |
Yes… dans un post en cours :
OK je n’avais pas vu le post
Je vais le suivre.
