### Did you read the instructions?
- [X] I have read the [README](https://git…hub.com/iMicknl/ha-tahoma/blob/master/README.md), including the [advanced debugging](https://github.com/iMicknl/ha-tahoma/blob/master/README.md#advanced) section.
### The problem
Hi everyone
I have Two new error since last update
when i change more than one temperature in same time or in short delay. On same or different device.
Logger: custom_components.tahoma.climate_devices.atlantic_electrical_heater_with_adjustable_temperature_setpoint
Source: custom_components/tahoma/climate_devices/atlantic_electrical_heater_with_adjustable_temperature_setpoint.py:158
Integration: Overkiz (by Somfy)
First occurred: 09:51:16 (4 occurrences)
Last logged: 09:51:16
Unable to update from sensor: could not convert string to float: 'unavailable'`
Source: helpers/update_coordinator.py:219
First occurred: 09:51:16 (1 occurrences)
Error fetching device events data: Too many requests, try again later.
### What version of this integration (ha-tahoma) has the issue?
2.10.1
### What version of Home Assistant Core has the issue?
core-2021.12.1
### Which gateway / hub do you use?
Cozytouch
### Device model
Malao par Atlantic Group Firmware: 2d202020ffffff240000
### Home Assistant log
```shell
<DataType.STRING: 3>, value='2d202020ffffff240000'), State(name='core:Manufacturer', type=<DataType.STRING: 3>, value='Atlantic Group'), State(name='core:MeasuredValueType', type=<DataType.STRING: 3>, value='core:TemperatureInCelcius'), State(name='core:PowerSourceType', type=<DataType.STRING: 3>, value='mainSupply')]), available=True, enabled=True, label='IO (7328532#2)', device_url=io://****-****-5049/7328532#2, controllable_name='io:TemperatureInCelciusIOSystemDeviceSensor', definition=Definition(commands=CommandDefinitions(_commands=[]), states=[StateDefinition(qualified_name='core:StatusState', type='DiscreteState', values=['available', 'unavailable']), StateDefinition(qualified_name='core:TemperatureState', type='ContinuousState', values=None)], widget_name='TemperatureSensor', ui_class='TemperatureSensor', qualified_name='io:TemperatureInCelciusIOSystemDeviceSensor'), data_properties=None, widget='TemperatureSensor', ui_class='TemperatureSensor', states=States(_states=[State(name='core:StatusState', type=<DataType.STRING: 3>, value='available'), State(name='core:TemperatureState', type=<DataType.FLOAT: 2>, value=16.75)]), type=<ProductType.SENSOR: 2>, place_oid='a2da94ef-e7fa-45ca-a7d9-7d1f83c15e8c'))
2021-12-14 14:28:59 DEBUG (MainThread) [custom_components.tahoma] Unsupported device detected (Device(attributes=States(_states=[State(name='core:FirmwareRevision', type=<DataType.STRING: 3>, value='2d202020ffffff240000'), State(name='core:Manufacturer', type=<DataType.STRING: 3>, value='Atlantic Group'), State(name='core:PowerSourceType', type=<DataType.STRING: 3>, value='mainSupply')]), available=True, enabled=True, label='IO (7328532#3)', device_url=io://****-****-5049/7328532#3, controllable_name='io:ContactIOSystemDeviceSensor', definition=Definition(commands=CommandDefinitions(_commands=[]), states=[StateDefinition(qualified_name='core:ContactState', type='DiscreteState', values=['closed', 'open']), StateDefinition(qualified_name='core:StatusState', type='DiscreteState', values=['available', 'unavailable'])], widget_name='ContactSensor', ui_class='ContactSensor', qualified_name='io:ContactIOSystemDeviceSensor'), data_properties=None, widget='ContactSensor', ui_class='ContactSensor', states=States(_states=[State(name='core:StatusState', type=<DataType.STRING: 3>, value='available'), State(name='core:ContactState', type=<DataType.STRING: 3>, value='closed')]), type=<ProductType.SENSOR: 2>, place_oid='a2da94ef-e7fa-45ca-a7d9-7d1f83c15e8c'))
2021-12-14 14:28:59 DEBUG (MainThread) [custom_components.tahoma] Unsupported device detected (Device(attributes=States(_states=[State(name='core:FirmwareRevision', type=<DataType.STRING: 3>, value='2d202020ffffff240000'), State(name='core:Manufacturer', type=<DataType.STRING: 3>, value='Atlantic Group'), State(name='core:PowerSourceType', type=<DataType.STRING: 3>, value='mainSupply')]), available=True, enabled=True, label='IO (7328532#4)', device_url=io://****-****-5049/7328532#4, controllable_name='io:OccupancyIOSystemDeviceSensor', definition=Definition(commands=CommandDefinitions(_commands=[]), states=[StateDefinition(qualified_name='core:OccupancyState', type='DiscreteState', values=['noPersonInside', 'personInside']), StateDefinition(qualified_name='core:StatusState', type='DiscreteState', values=['available', 'unavailable'])], widget_name='OccupancySensor', ui_class='OccupancySensor', qualified_name='io:OccupancyIOSystemDeviceSensor'), data_properties=None, widget='OccupancySensor', ui_class='OccupancySensor', states=States(_states=[State(name='core:StatusState', type=<DataType.STRING: 3>, value='available')]), type=<ProductType.SENSOR: 2>, place_oid='a2da94ef-e7fa-45ca-a7d9-7d1f83c15e8c'))
2021-12-14 14:28:59 DEBUG (MainThread) [custom_components.tahoma] Unsupported device detected (Device(attributes=States(_states=[State(name='core:FirmwareRevision', type=<DataType.STRING: 3>, value='2d202020ffffff240000'), State(name='core:Manufacturer', type=<DataType.STRING: 3>, value='Atlantic Group'), State(name='core:PowerSourceType', type=<DataType.STRING: 3>, value='mainSupply'), State(name='core:MeasuredValueType', type=<DataType.STRING: 3>, value='core:ElectricalEnergyInWh')]), available=True, enabled=True, label='IO (7328532#5)', device_url=io://****-****-5049/7328532#5, controllable_name='io:CumulatedElectricalEnergyConsumptionIOSystemDeviceSensor', definition=Definition(commands=CommandDefinitions(_commands=[]), states=[StateDefinition(qualified_name='core:ConsumptionTariff0State', type='ContinuousState', values=None), StateDefinition(qualified_name='core:ConsumptionTariff1State', type='ContinuousState', values=None), StateDefinition(qualified_name='core:ConsumptionTariff2State', type='ContinuousState', values=None), StateDefinition(qualified_name='core:ConsumptionTariff3State', type='ContinuousState', values=None), StateDefinition(qualified_name='core:ConsumptionTariff4State', type='ContinuousState', values=None), StateDefinition(qualified_name='core:ConsumptionTariff5State', type='ContinuousState', values=None), StateDefinition(qualified_name='core:ConsumptionTariff6State', type='ContinuousState', values=None), StateDefinition(qualified_name='core:ConsumptionTariff7State', type='ContinuousState', values=None), StateDefinition(qualified_name='core:ConsumptionTariff8State', type='ContinuousState', values=None), StateDefinition(qualified_name='core:ConsumptionTariff9State', type='ContinuousState', values=None), StateDefinition(qualified_name='core:ElectricEnergyConsumptionState', type='ContinuousState', values=None), StateDefinition(qualified_name='core:StatusState', type='DiscreteState', values=['available', 'unavailable'])], widget_name='CumulativeElectricPowerConsumptionSensor', ui_class='ElectricitySensor', qualified_name='io:CumulatedElectricalEnergyConsumptionIOSystemDeviceSensor'), data_properties=None, widget='CumulativeElectricPowerConsumptionSensor', ui_class='ElectricitySensor', states=States(_states=[State(name='core:StatusState', type=<DataType.STRING: 3>, value='available'), State(name='core:ElectricEnergyConsumptionState', type=<DataType.INTEGER: 1>, value=486000), State(name='core:ConsumptionTariff0State', type=<DataType.INTEGER: 1>, value=486000)]), type=<ProductType.SENSOR: 2>, place_oid='a2da94ef-e7fa-45ca-a7d9-7d1f83c15e8c'))
2021-12-14 14:28:59 DEBUG (MainThread) [custom_components.tahoma] Added device (Device(attributes=States(_states=[State(name='core:Manufacturer', type=<DataType.STRING: 3>, value='Atlantic Group'), State(name='core:FirmwareRevision', type=<DataType.STRING: 3>, value='2d202020ffffff240000')]), available=True, enabled=True, label='Radiateur', device_url=io://****-****-5049/7740708#1, controllable_name='io:AtlanticElectricalHeaterWithAdjustableTemperatureSetpointIOComponent', definition=Definition(commands=CommandDefinitions(_commands=[CommandDefinition(command_name='advancedRefresh', nparams=1), CommandDefinition(command_name='cancelHeatingLevel', nparams=1), CommandDefinition(command_name='delayedStopIdentify', nparams=1), CommandDefinition(command_name='getName', nparams=0), CommandDefinition(command_name='identify', nparams=0), CommandDefinition(command_name='noPersonInside', nparams=0), CommandDefinition(command_name='off', nparams=0), CommandDefinition(command_name='personInside', nparams=0), CommandDefinition(command_name='refreshComfortTemperature', nparams=0), CommandDefinition(command_name='refreshDateTime', nparams=0), CommandDefinition(command_name='refreshDerogatedTargetTemperature', nparams=0), CommandDefinition(command_name='refreshEcoTemperature', nparams=0), CommandDefinition(command_name='refreshHeatingLevel', nparams=0), CommandDefinition(command_name='refreshIdentifier', nparams=0), CommandDefinition(command_name='refreshManufacturerName', nparams=0), CommandDefinition(command_name='refreshMaximumHeatingTargetTemperature', nparams=0), CommandDefinition(command_name='refreshMaximumTargetTemperature', nparams=0), CommandDefinition(command_name='refreshOperatingMode', nparams=0), CommandDefinition(command_name='refreshTargetTemperature', nparams=0), CommandDefinition(command_name='refreshTemperature', nparams=0), CommandDefinition(command_name='refreshTimeProgram', nparams=0), CommandDefinition(command_name='setComfortTemperature', nparams=1), CommandDefinition(command_name='setDateTime', nparams=1), CommandDefinition(command_name='setDerogatedTargetTemperature', nparams=1), CommandDefinition(command_name='setEcoTemperature', nparams=1), CommandDefinition(command_name='setHeatingLevel', nparams=1), CommandDefinition(command_name='setHeatingLevelWithTimer', nparams=2), CommandDefinition(command_name='setHolidays', nparams=1), CommandDefinition(command_name='setHolidaysTargetTemperature', nparams=1), CommandDefinition(command_name='setName', nparams=1), CommandDefinition(command_name='setOccupancyActivation', nparams=1), CommandDefinition(command_name='setOccupancy', nparams=1), CommandDefinition(command_name='setOpenWindowDetectionActivation', nparams=1), CommandDefinition(command_name='setOperatingMode', nparams=1), CommandDefinition(command_name='setPreviousTargetTemperature', nparams=1), CommandDefinition(command_name='setSchedulingType', nparams=1), CommandDefinition(command_name='setTargetTemperature', nparams=1), CommandDefinition(command_name='setTimeProgram', nparams=1), CommandDefinition(command_name='startIdentify', nparams=0), CommandDefinition(command_name='stopIdentify', nparams=0), CommandDefinition(command_name='wink', nparams=1), CommandDefinition(command_name='pairOneWayController', nparams=2), CommandDefinition(command_name='refreshAutoProgram', nparams=0), CommandDefinition(command_name='refreshControllerAddress', nparams=0), CommandDefinition(command_name='refreshCumulatedLowering', nparams=0), CommandDefinition(command_name='refreshCurrentWorkingRate', nparams=0), CommandDefinition(command_name='refreshDeletionCancelation', nparams=0), CommandDefinition(command_name='refreshEffectiveTemperatureSetpoint', nparams=0), CommandDefinition(command_name='refreshLocalLeadTime', nparams=0), CommandDefinition(command_name='refreshModel', nparams=0), CommandDefinition(command_name='refreshNativeFunctionalLevel', nparams=0), CommandDefinition(command_name='refreshPeakNotice', nparams=0), CommandDefinition(command_name='refreshPeakWarning', nparams=0), CommandDefinition(command_name='refreshPowerAndTension', nparams=0), CommandDefinition(command_name='refreshRoomDeletionThreshold', nparams=0), CommandDefinition(command_name='refreshSetpointLoweringTemperatureInProgMode', nparams=0), CommandDefinition(command_name='refreshSynchronisationRequest', nparams=0), CommandDefinition(command_name='refreshTemperatureProbeCalibrationOffset', nparams=0), CommandDefinition(command_name='setCommunicationTest', nparams=1), CommandDefinition(command_name='setDeletionCancelation', nparams=1), CommandDefinition(command_name='setExpectedPresence', nparams=1), CommandDefinition(command_name='setHeatingLevelForTrigger', nparams=1), CommandDefinition(command_name='setNativeLevelsList', nparams=1), CommandDefinition(command_name='setPeakNotice', nparams=1), CommandDefinition(command_name='setPeakWarning', nparams=1), CommandDefinition(command_name='setRoomDeletionThreshold', nparams=1), CommandDefinition(command_name='setSetpointLoweringTemperatureInProgMode', nparams=1), CommandDefinition(command_name='setTemperatureProbeCalibrationOffset', nparams=1), CommandDefinition(command_name='setTwinningExit', nparams=1), CommandDefinition(command_name='unpairAllOneWayControllers', nparams=0), CommandDefinition(command_name='unpairOneWayController', nparams=2)]), states=[StateDefinition(qualified_name='core:ComfortRoomTemperatureState', type='ContinuousState', values=None), StateDefinition(qualified_name='core:DateTimeState', type='DataState', values=None), StateDefinition(qualified_name='core:DerogatedTargetTemperatureState', type='ContinuousState', values=None), StateDefinition(qualified_name='core:DiscreteRSSILevelState', type='DiscreteState', values=['good', 'low', 'normal', 'verylow']), StateDefinition(qualified_name='core:EcoRoomTemperatureState', type='ContinuousState', values=None), StateDefinition(qualified_name='core:HolidaysModeState', type='DiscreteState', values=['off', 'on']), StateDefinition(qualified_name='core:HolidaysTargetTemperatureState', type='ContinuousState', values=None), StateDefinition(qualified_name='core:IdentifierState', type='DataState', values=None), StateDefinition(qualified_name='core:ManufacturerNameState', type='DataState', values=None), StateDefinition(qualified_name='core:MaximumHeatingTargetTemperatureState', type='ContinuousState', values=None), StateDefinition(qualified_name='core:MaximumTargetTemperatureState', type='ContinuousState', values=None), StateDefinition(qualified_name='core:NameState', type='DataState', values=None), StateDefinition(qualified_name='core:OccupancyActivationState', type='DiscreteState', values=['active', 'inactive']), StateDefinition(qualified_name='core:OnOffState', type='DiscreteState', values=['off', 'on']), StateDefinition(qualified_name='core:OpenWindowDetectionActivationState', type='DiscreteState', values=['active', 'inactive']), StateDefinition(qualified_name='core:OperatingModeState', type='DiscreteState', values=['antifreeze', 'auto', 'away', 'eco', 'frostprotection', 'manual', 'max', 'normal', 'off', 'on', 'prog', 'program', 'boost']), StateDefinition(qualified_name='core:PreviousTargetTemperatureState', type='ContinuousState', values=None), StateDefinition(qualified_name='core:PriorityLockTimerState', type='ContinuousState', values=None), StateDefinition(qualified_name='core:RSSILevelState', type='ContinuousState', values=None), StateDefinition(qualified_name='core:RegulationModeState', type='DiscreteState', values=['increase', 'none', 'standby']), StateDefinition(qualified_name='core:StatusState', type='DiscreteState', values=['available', 'unavailable']), StateDefinition(qualified_name='core:TargetTemperatureState', type='ContinuousState', values=None), StateDefinition(qualified_name='core:TimeProgramState', type='DataState', values=None), StateDefinition(qualified_name='core:VersionState', type='ContinuousState', values=None), StateDefinition(qualified_name='io:AutoProgramState', type='DataState', values=None), StateDefinition(qualified_name='io:ControllerAddressState', type='DataState', values=None), StateDefinition(qualified_name='io:CumulatedLoweringState', type='ContinuousState', values=None), StateDefinition(qualified_name='io:CurrentWorkingRateState', type='ContinuousState', values=None), StateDefinition(qualified_name='io:DeletionCancelationState', type='DiscreteState', values=['deletion cancelation', 'no deletion cancelation']), StateDefinition(qualified_name='io:EffectiveTemperatureSetpointState', type='ContinuousState', values=None), StateDefinition(qualified_name='io:ExpectedPresenceState', type='ContinuousState', values=None), StateDefinition(qualified_name='io:InternalExternalSchedulingTypeState', type='DiscreteState', values=['external', 'internal']), StateDefinition(qualified_name='io:LocalLeadTimeState', type='ContinuousState', values=None), StateDefinition(qualified_name='io:MaximumHeatingLevelState', type='DiscreteState', values=['boost', 'comfort', 'comfort-1', 'comfort-2', 'eco', 'frostprotection', 'off', 'secured']), StateDefinition(qualified_name='io:ModelState', type='DataState', values=None), StateDefinition(qualified_name='io:NativeFunctionalLevelState', type='DiscreteState', values=['base', 'medium', 'top']), StateDefinition(qualified_name='io:PeakNoticeState', type='DiscreteState', values=['long peak', 'no peak', 'short peak']), StateDefinition(qualified_name='io:PeakWarningState', type='DiscreteState', values=['long peak warning', 'no warning', 'short peak warning']), StateDefinition(qualified_name='io:PowerState', type='DataState', values=None), StateDefinition(qualified_name='io:PriorityLockLevelState', type='DiscreteState', values=['comfortLevel1', 'comfortLevel2', 'comfortLevel3', 'comfortLevel4', 'environmentProtection', 'humanProtection', 'userLevel1', 'userLevel2']), StateDefinition(qualified_name='io:PriorityLockOriginatorState', type='DiscreteState', values=['LSC', 'SAAC', 'SFC', 'UPS', 'externalGateway', 'localUser', 'myself', 'rain', 'security', 'temperature', 'timer', 'user', 'wind']), StateDefinition(qualified_name='io:RoomDeletionThresholdState', type='DataState', values=None), StateDefinition(qualified_name='io:RunningState', type='DiscreteState', values=['kept', 'lost']), StateDefinition(qualified_name='io:SetpointLoweringTemperatureInProgModeState', type='ContinuousState', values=None), StateDefinition(qualified_name='io:TargetHeatingLevelState', type='DiscreteState', values=['boost', 'comfort', 'comfort-1', 'comfort-2', 'eco', 'frostprotection', 'off', 'secured']), StateDefinition(qualified_name='io:TemperatureProbeCalibrationOffsetState', type='ContinuousState', values=None), StateDefinition(qualified_name='io:TensionState', type='DataState', values=None), StateDefinition(qualified_name='io:TimerForTransitoryStateState', type='ContinuousState', values=None), StateDefinition(qualified_name='io:UptimeState', type='ContinuousState', values=None)], widget_name='AtlanticElectricalHeaterWithAdjustableTemperatureSetpoint', ui_class='HeatingSystem', qualified_name='io:AtlanticElectricalHeaterWithAdjustableTemperatureSetpointIOComponent'), data_properties=None, widget='AtlanticElectricalHeaterWithAdjustableTemperatureSetpoint', ui_class='HeatingSystem', states=States(_states=[State(name='core:NameState', type=<DataType.STRING: 3>, value='Radiateur'), State(name='core:VersionState', type=<DataType.STRING: 3>, value='2d202020ffffff240000'), State(name='core:PriorityLockTimerState', type=<DataType.INTEGER: 1>, value=0), State(name='core:OnOffState', type=<DataType.STRING: 3>, value='on'), State(name='io:TargetHeatingLevelState', type=<DataType.STRING: 3>, value='comfort'), State(name='core:StatusState', type=<DataType.STRING: 3>, value='available'), State(name='core:DiscreteRSSILevelState', type=<DataType.STRING: 3>, value='low'), State(name='core:RSSILevelState', type=<DataType.FLOAT: 2>, value=36.0), State(name='core:IdentifierState', type=<DataType.STRING: 3>, value='00000000'), State(name='io:MaximumHeatingLevelState', type=<DataType.STRING: 3>, value='unknown'), State(name='io:TimerForTransitoryStateState', type=<DataType.INTEGER: 1>, value=65535), State(name='core:ComfortRoomTemperatureState', type=<DataType.INTEGER: 1>, value=20), State(name='core:EcoRoomTemperatureState', type=<DataType.INTEGER: 1>, value=2), State(name='core:OperatingModeState', type=<DataType.STRING: 3>, value='basic'), State(name='core:OccupancyActivationState', type=<DataType.STRING: 3>, value='inactive'), State(name='core:MaximumHeatingTargetTemperatureState', type=<DataType.FLOAT: 2>, value=28.0), State(name='core:MaximumTargetTemperatureState', type=<DataType.FLOAT: 2>, value=28.0), State(name='core:TargetTemperatureState', type=<DataType.FLOAT: 2>, value=20.0), State(name='io:SetpointLoweringTemperatureInProgModeState', type=<DataType.FLOAT: 2>, value=2.0), State(name='core:OpenWindowDetectionActivationState', type=<DataType.STRING: 3>, value='active'), State(name='io:InternalExternalSchedulingTypeState', type=<DataType.STRING: 3>, value='internal'), State(name='core:DateTimeState', type=<DataType.JSON_OBJECT: 11>, value={'month': 12, 'hour': 20, 'year': 2021, 'weekday': 0, 'day': 13, 'minute': 35, 'second': 56}), State(name='io:LocalLeadTimeState', type=<DataType.INTEGER: 1>, value=2320), State(name='core:RegulationModeState', type=<DataType.STRING: 3>, value='standby'), State(name='core:ManufacturerNameState', type=<DataType.STRING: 3>, value='Sauter'), State(name='io:ModelState', type=<DataType.STRING: 3>, value='Malao V'), State(name='io:PowerState', type=<DataType.INTEGER: 1>, value=2000), State(name='io:TensionState', type=<DataType.INTEGER: 1>, value=230), State(name='core:DerogatedTargetTemperatureState', type=<DataType.FLOAT: 2>, value=0.0), State(name='io:NativeFunctionalLevelState', type=<DataType.STRING: 3>, value='Base'), State(name='io:TemperatureProbeCalibrationOffsetState', type=<DataType.FLOAT: 2>, value=0.0), State(name='io:CurrentWorkingRateState', type=<DataType.FLOAT: 2>, value=72.0), State(name='io:CumulatedLoweringState', type=<DataType.FLOAT: 2>, value=0.0), State(name='io:RoomDeletionThresholdState', type=<DataType.STRING: 3>, value='-2°C'), State(name='io:EffectiveTemperatureSetpointState', type=<DataType.FLOAT: 2>, value=20.0), State(name='io:ControllerAddressState', type=<DataType.INTEGER: 1>, value=7740707), State(name='io:AutoProgramState', type=<DataType.JSON_OBJECT: 11>, value={'sunday': ['CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1'], 'saturday': ['CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1'], 'tuesday': ['CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1'], 'wednesday': ['CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1'], 'thursday': ['CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1'], 'friday': ['CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1'], 'anticip_time': 2320, 'anticip_nb': 20, 'monday': ['CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1', 'CONF_NIV1']}), State(name='core:PreviousTargetTemperatureState', type=<DataType.FLOAT: 2>, value=19.5), State(name='core:TimeProgramState', type=<DataType.JSON_ARRAY: 10>, value=[{'monday': [{'start': '06:30', 'end': '08:30'}, {'start': '17:30', 'end': '20:30'}, {'start': '00:00', 'end': '00:00'}]}, {'tuesday': [{'start': '06:30', 'end': '08:30'}, {'start': '17:30', 'end': '20:30'}, {'start': '00:00', 'end': '00:00'}]}, {'wednesday': [{'start': '06:30', 'end': '08:30'}, {'start': '17:30', 'end': '20:30'}, {'start': '00:00', 'end': '00:00'}]}, {'thursday': [{'start': '06:30', 'end': '08:30'}, {'start': '17:30', 'end': '20:30'}, {'start': '00:00', 'end': '00:00'}]}, {'friday': [{'start': '06:30', 'end': '08:30'}, {'start': '17:30', 'end': '20:30'}, {'start': '00:00', 'end': '00:00'}]}, {'saturday': [{'start': '06:30', 'end': '08:30'}, {'start': '17:30', 'end': '20:30'}, {'start': '00:00', 'end': '00:00'}]}, {'sunday': [{'start': '06:30', 'end': '08:30'}, {'start': '17:30', 'end': '20:30'}, {'start': '00:00', 'end': '00:00'}]}])]), type=<ProductType.ACTUATOR: 1>, place_oid='1f1ed723-9b50-4528-a3f3-495fb4dd3f41'))
2021-12-14 14:28:59 DEBUG (MainThread) [custom_components.tahoma] Unsupported device detected (Device(attributes=States(_states=[State(name='core:Manufacturer', type=<DataType.STRING: 3>, value='Atlantic Group'), State(name='core:FirmwareRevision', type=<DataType.STRING: 3>, value='2d202020ffffff240000'), State(name='core:MeasuredValueType', type=<DataType.STRING: 3>, value='core:TemperatureInCelcius'), State(name='core:PowerSourceType', type=<DataType.STRING: 3>, value='mainSupply')]), available=True, enabled=True, label='IO (7740708#2)', device_url=io://****-****-5049/7740708#2, controllable_name='io:TemperatureInCelciusIOSystemDeviceSensor', definition=Definition(commands=CommandDefinitions(_commands=[]), states=[StateDefinition(qualified_name='core:StatusState', type='DiscreteState', values=['available', 'unavailable']), StateDefinition(qualified_name='core:TemperatureState', type='ContinuousState', values=None)], widget_name='TemperatureSensor', ui_class='TemperatureSensor', qualified_name='io:TemperatureInCelciusIOSystemDeviceSensor'), data_properties=None, widget='TemperatureSensor', ui_class='TemperatureSensor', states=States(_states=[State(name='core:StatusState', type=<DataType.STRING: 3>, value='available'), State(name='core:TemperatureState', type=<DataType.FLOAT: 2>, value=20.25)]), type=<ProductType.SENSOR: 2>, place_oid='1f1ed723-9b50-4528-a3f3-495fb4dd3f41'))
2021-12-14 14:28:59 DEBUG (MainThread) [custom_components.tahoma] Unsupported device detected (Device(attributes=States(_states=[State(name='core:Manufacturer', type=<DataType.STRING: 3>, value='Atlantic Group'), State(name='core:FirmwareRevision', type=<DataType.STRING: 3>, value='2d202020ffffff240000'), State(name='core:PowerSourceType', type=<DataType.STRING: 3>, value='mainSupply')]), available=True, enabled=True, label='IO (7740708#3)', device_url=io://****-****-5049/7740708#3, controllable_name='io:ContactIOSystemDeviceSensor', definition=Definition(commands=CommandDefinitions(_commands=[]), states=[StateDefinition(qualified_name='core:ContactState', type='DiscreteState', values=['closed', 'open']), StateDefinition(qualified_name='core:StatusState', type='DiscreteState', values=['available', 'unavailable'])], widget_name='ContactSensor', ui_class='ContactSensor', qualified_name='io:ContactIOSystemDeviceSensor'), data_properties=None, widget='ContactSensor', ui_class='ContactSensor', states=States(_states=[State(name='core:StatusState', type=<DataType.STRING: 3>, value='available'), State(name='core:ContactState', type=<DataType.STRING: 3>, value='closed')]), type=<ProductType.SENSOR: 2>, place_oid='1f1ed723-9b50-4528-a3f3-495fb4dd3f41'))
2021-12-14 14:28:59 DEBUG (MainThread) [custom_components.tahoma] Unsupported device detected (Device(attributes=States(_states=[State(name='core:Manufacturer', type=<DataType.STRING: 3>, value='Atlantic Group'), State(name='core:FirmwareRevision', type=<DataType.STRING: 3>, value='2d202020ffffff240000'), State(name='core:PowerSourceType', type=<DataType.STRING: 3>, value='mainSupply')]), available=True, enabled=True, label='IO (7740708#4)', device_url=io://****-****-5049/7740708#4, controllable_name='io:OccupancyIOSystemDeviceSensor', definition=Definition(commands=CommandDefinitions(_commands=[]), states=[StateDefinition(qualified_name='core:OccupancyState', type='DiscreteState', values=['noPersonInside', 'personInside']), StateDefinition(qualified_name='core:StatusState', type='DiscreteState', values=['available', 'unavailable'])], widget_name='OccupancySensor', ui_class='OccupancySensor', qualified_name='io:OccupancyIOSystemDeviceSensor'), data_properties=None, widget='OccupancySensor', ui_class='OccupancySensor', states=States(_states=[State(name='core:StatusState', type=<DataType.STRING: 3>, value='available')]), type=<ProductType.SENSOR: 2>, place_oid='1f1ed723-9b50-4528-a3f3-495fb4dd3f41'))
2021-12-14 14:28:59 DEBUG (MainThread) [custom_components.tahoma] Unsupported device detected (Device(attributes=States(_states=[State(name='core:Manufacturer', type=<DataType.STRING: 3>, value='Atlantic Group'), State(name='core:FirmwareRevision', type=<DataType.STRING: 3>, value='2d202020ffffff240000'), State(name='core:PowerSourceType', type=<DataType.STRING: 3>, value='mainSupply'), State(name='core:MeasuredValueType', type=<DataType.STRING: 3>, value='core:ElectricalEnergyInWh')]), available=True, enabled=True, label='IO (7740708#5)', device_url=io://****-****-5049/7740708#5, controllable_name='io:CumulatedElectricalEnergyConsumptionIOSystemDeviceSensor', definition=Definition(commands=CommandDefinitions(_commands=[]), states=[StateDefinition(qualified_name='core:ConsumptionTariff0State', type='ContinuousState', values=None), StateDefinition(qualified_name='core:ConsumptionTariff1State', type='ContinuousState', values=None), StateDefinition(qualified_name='core:ConsumptionTariff2State', type='ContinuousState', values=None), StateDefinition(qualified_name='core:ConsumptionTariff3State', type='ContinuousState', values=None), StateDefinition(qualified_name='core:ConsumptionTariff4State', type='ContinuousState', values=None), StateDefinition(qualified_name='core:ConsumptionTariff5State', type='ContinuousState', values=None), StateDefinition(qualified_name='core:ConsumptionTariff6State', type='ContinuousState', values=None), StateDefinition(qualified_name='core:ConsumptionTariff7State', type='ContinuousState', values=None), StateDefinition(qualified_name='core:ConsumptionTariff8State', type='ContinuousState', values=None), StateDefinition(qualified_name='core:ConsumptionTariff9State', type='ContinuousState', values=None), StateDefinition(qualified_name='core:ElectricEnergyConsumptionState', type='ContinuousState', values=None), StateDefinition(qualified_name='core:StatusState', type='DiscreteState', values=['available', 'unavailable'])], widget_name='CumulativeElectricPowerConsumptionSensor', ui_class='ElectricitySensor', qualified_name='io:CumulatedElectricalEnergyConsumptionIOSystemDeviceSensor'), data_properties=None, widget='CumulativeElectricPowerConsumptionSensor', ui_class='ElectricitySensor', states=States(_states=[State(name='core:StatusState', type=<DataType.STRING: 3>, value='available'), State(name='core:ElectricEnergyConsumptionState', type=<DataType.INTEGER: 1>, value=823000), State(name='core:ConsumptionTariff0State', type=<DataType.INTEGER: 1>, value=823000)]), type=<ProductType.SENSOR: 2>, place_oid='1f1ed723-9b50-4528-a3f3-495fb4dd3f41'))
2021-12-14 14:28:59 DEBUG (MainThread) [custom_components.tahoma] Added gateway (Gateway(partners=[Partner(activated=True, name='Leroy Merlin', id=leroy-merlin, status='DELEGATE'), Partner(activated=True, name='Atlantic', id=atlantic, status='OWNER')], functions='INTERNET_AUTHORIZATION,SCENARIO_DOWNLOAD,SCENARIO_AUTO_LAUNCHING,SCENARIO_TELECO_LAUNCHING,INTERNET_UPLOAD,INTERNET_UPDATE,TRIGGERS_SENSORS', sub_type=None, id=****-****-5049, gateway_id=NOTHING, alive=True, mode='ACTIVE', place_oid='e078510e-ee9e-487e-8d99-46d8be0122d2', time_reliable=True, connectivity=Connectivity(status='OK', protocol_version='2021.5.4'), up_to_date=True, update_status=<UpdateBoxStatus.UP_TO_DATE: 'UP_TO_DATE'>, sync_in_progress=False, type=<GatewayType.COZYTOUCH: 32>))
### Additional information
_No response_
