j’ai oublié de dire que j’avais aussi un thermomètre Sonoff en Zigbee dans cette pièce, qui lui, aussi, est injoignable.
Euh ?
J’ai ça :
Info 2024-03-23 12:24:24MQTT publish: topic 'zigbee2mqtt/Capteur luminosité', payload '{"brightness_state":"high","illuminance_lux":1947,"last_seen":"2024-03-23T11:24:24.081Z","linkquality":180}'
Info 2024-03-23 12:24:24MQTT publish: topic 'zigbee2mqtt/Capteur luminosité', payload '{"brightness_state":"high","illuminance_lux":1947,"last_seen":"2024-03-23T11:24:24.194Z","linkquality":176}'
Info 2024-03-23 12:24:39MQTT publish: topic 'zigbee2mqtt/Capteur luminosité', payload '{"brightness_state":"high","illuminance_lux":1958,"last_seen":"2024-03-23T11:24:39.209Z","linkquality":180}'
Info 2024-03-23 12:24:39MQTT publish: topic 'zigbee2mqtt/Capteur luminosité', payload '{"brightness_state":"high","illuminance_lux":1958,"last_seen":"2024-03-23T11:24:39.314Z","linkquality":180}'
Info 2024-03-23 12:24:43MQTT publish: topic 'zigbee2mqtt/Va et Vient Salon', payload '{"last_seen":"2024-03-23T11:24:43.794Z","linkquality":148,"state":"OFF"}'
Info 2024-03-23 12:24:54MQTT publish: topic 'zigbee2mqtt/Capteur luminosité', payload '{"brightness_state":"high","illuminance_lux":1958,"last_seen":"2024-03-23T11:24:54.323Z","linkquality":180}'
Info 2024-03-23 12:24:54MQTT publish: topic 'zigbee2mqtt/Capteur luminosité', payload '{"brightness_state":"high","illuminance_lux":1958,"last_seen":"2024-03-23T11:24:54.434Z","linkquality":180}'
Info 2024-03-23 12:25:09MQTT publish: topic 'zigbee2mqtt/Capteur luminosité', payload '{"brightness_state":"high","illuminance_lux":1947,"last_seen":"2024-03-23T11:25:09.444Z","linkquality":180}'
Info 2024-03-23 12:25:09MQTT publish: topic 'zigbee2mqtt/Capteur luminosité', payload '{"brightness_state":"high","illuminance_lux":1947,"last_seen":"2024-03-23T11:25:09.557Z","linkquality":180}'
Info 2024-03-23 12:25:24MQTT publish: topic 'zigbee2mqtt/Capteur luminosité', payload '{"brightness_state":"high","illuminance_lux":1947,"last_seen":"2024-03-23T11:25:24.562Z","linkquality":180}'
Info 2024-03-23 12:25:24MQTT publish: topic 'zigbee2mqtt/Capteur luminosité', payload '{"brightness_state":"high","illuminance_lux":1947,"last_seen":"2024-03-23T11:25:24.676Z","linkquality":180}'
Info 2024-03-23 12:25:39MQTT publish: topic 'zigbee2mqtt/Capteur luminosité', payload '{"brightness_state":"high","illuminance_lux":1947,"last_seen":"2024-03-23T11:25:39.682Z","linkquality":184}'
Info 2024-03-23 12:25:39MQTT publish: topic 'zigbee2mqtt/Capteur luminosité', payload '{"brightness_state":"high","illuminance_lux":1947,"last_seen":"2024-03-23T11:25:39.798Z","linkquality":184}'
Info 2024-03-23 12:25:54MQTT publish: topic 'zigbee2mqtt/Capteur luminosité', payload '{"brightness_state":"high","illuminance_lux":1947,"last_seen":"2024-03-23T11:25:54.807Z","linkquality":164}'
Info 2024-03-23 12:25:55MQTT publish: topic 'zigbee2mqtt/Capteur luminosité', payload '{"brightness_state":"high","illuminance_lux":1947,"last_seen":"2024-03-23T11:25:54.920Z","linkquality":180}'
Info 2024-03-23 12:26:02MQTT publish: topic 'zigbee2mqtt/Capteur luminosité', payload '{"brightness_state":"high","illuminance_lux":1947,"last_seen":"2024-03-23T11:26:02.393Z","linkquality":176}'
Info 2024-03-23 12:26:10MQTT publish: topic 'zigbee2mqtt/Capteur luminosité', payload '{"brightness_state":"high","illuminance_lux":1947,"last_seen":"2024-03-23T11:26:09.935Z","linkquality":180}'
Info 2024-03-23 12:26:10MQTT publish: topic 'zigbee2mqtt/Capteur luminosité', payload '{"brightness_state":"high","illuminance_lux":1947,"last_seen":"2024-03-23T11:26:10.044Z","linkquality":180}'
Info 2024-03-23 12:26:25MQTT publish: topic 'zigbee2mqtt/Capteur luminosité', payload '{"brightness_state":"high","illuminance_lux":1947,"last_seen":"2024-03-23T11:26:25.053Z","linkquality":176}'
Info 2024-03-23 12:26:25MQTT publish: topic 'zigbee2mqtt/Capteur luminosité', payload '{"brightness_state":"high","illuminance_lux":1947,"last_seen":"2024-03-23T11:26:25.167Z","linkquality":180}'
Info 2024-03-23 12:26:40MQTT publish: topic 'zigbee2mqtt/Capteur luminosité', payload '{"brightness_state":"high","illuminance_lux":1947,"last_seen":"2024-03-23T11:26:40.180Z","linkquality":176}'
Info 2024-03-23 12:26:40MQTT publish: topic 'zigbee2mqtt/Capteur luminosité', payload '{"brightness_state":"high","illuminance_lux":1947,"last_seen":"2024-03-23T11:26:40.292Z","linkquality":176}'
Info 2024-03-23 12:26:54MQTT publish: topic 'zigbee2mqtt/Thermomètre Salon', payload '{"battery":100,"humidity":55.6,"last_seen":"2024-03-23T11:26:54.281Z","linkquality":148,"temperature":20.4}'
Info 2024-03-23 12:26:55MQTT publish: topic 'zigbee2mqtt/Capteur luminosité', payload '{"brightness_state":"high","illuminance_lux":1936,"last_seen":"2024-03-23T11:26:55.302Z","linkquality":180}'
Info 2024-03-23 12:26:55MQTT publish: topic 'zigbee2mqtt/Capteur luminosité', payload '{"brightness_state":"high","illuminance_lux":1936,"last_seen":"2024-03-23T11:26:55.416Z","linkquality":180}'
Info 2024-03-23 12:27:10MQTT publish: topic 'zigbee2mqtt/Capteur luminosité', payload '{"brightness_state":"high","illuminance_lux":1925,"last_seen":"2024-03-23T11:27:10.422Z","linkquality":176}'
Info 2024-03-23 12:27:10MQTT publish: topic 'zigbee2mqtt/Capteur luminosité', payload '{"brightness_state":"high","illuminance_lux":1925,"last_seen":"2024-03-23T11:27:10.536Z","linkquality":164}'
