### What happened?
With a Legrand Remote Switch ([067773](https://www.zigbee2mq…tt.io/devices/067773.html#legrand-067773), after a certain period of time when the light is off, pressing the button once will not send a message with the proper format, i.e. the action attribute is missing from the payload resulting in the light not being toggled on.
If button is pressed twice in a row, send message will include the correct payload.
If button is not pressed twice in a row, but then pressed a minute after, same wrong behavior is observed (wrong payload)
### What did you expect to happen?
Switch to toggle "on" my light after a single press on the button (i.e. first press after a long period of time to send message with the "action" payload)
### How to reproduce it (minimal and precise)
Press the switch to toggle off the light
Wait a few minutes
Press the switch to toggle on the light
### Zigbee2MQTT version
1.27.2 commit: 7dc48fb
### Adapter firmware version
20220219
### Adapter
zStack3x0
### Debug log
info 2022-09-30 05:50:31: MQTT publish: topic 'zigbee2mqtt/bridge/event', payload '{"data":{"friendly_name":"0x0004740000a93387","ieee_address":"0x0004740000a93387"},"type":"device_announce"}'
info 2022-09-30 05:50:31: MQTT publish: topic 'zigbee2mqtt/0x0004740000a93387', payload '{"battery":100,"linkquality":102,"voltage":3000}'
info 2022-09-30 05:51:35: MQTT publish: topic 'zigbee2mqtt/bridge/event', payload '{"data":{"friendly_name":"0x0004740000a93387","ieee_address":"0x0004740000a93387"},"type":"device_announce"}'
info 2022-09-30 05:51:35: MQTT publish: topic 'zigbee2mqtt/0x0004740000a93387', payload '{"battery":100,"linkquality":91,"voltage":3000}'
info 2022-09-30 05:51:39: MQTT publish: topic 'zigbee2mqtt/0x0004740000a93387', payload '{"action":"toggle","battery":100,"linkquality":94,"voltage":3000}'
info 2022-09-30 05:51:39: MQTT publish: topic 'zigbee2mqtt/0x0004740000a93387/action', payload 'toggle'
info 2022-09-30 05:57:34: MQTT publish: topic 'zigbee2mqtt/bridge/event', payload '{"data":{"friendly_name":"0x0004740000a93387","ieee_address":"0x0004740000a93387"},"type":"device_announce"}'
info 2022-09-30 05:57:34: MQTT publish: topic 'zigbee2mqtt/0x0004740000a93387', payload '{"action":"brightness_move_down","action_rate":100,"battery":100,"linkquality":43,"voltage":3000}'
info 2022-09-30 05:57:34: MQTT publish: topic 'zigbee2mqtt/0x0004740000a93387/action', payload 'brightness_move_down'
info 2022-09-30 05:57:35: MQTT publish: topic 'zigbee2mqtt/0x0004740000a93387', payload '{"battery":100,"linkquality":29,"voltage":3000}'
info 2022-09-30 05:57:36: MQTT publish: topic 'zigbee2mqtt/0x0004740000a93387', payload '{"action":"brightness_stop","battery":100,"linkquality":54,"voltage":3000}'
info 2022-09-30 05:57:36: MQTT publish: topic 'zigbee2mqtt/0x0004740000a93387/action', payload 'brightness_stop'
info 2022-09-30 06:13:36: MQTT publish: topic 'zigbee2mqtt/0x0004740000a93387', payload '{"action":"toggle","battery":100,"linkquality":65,"voltage":3000}'
info 2022-09-30 06:13:36: MQTT publish: topic 'zigbee2mqtt/0x0004740000a93387/action', payload 'toggle'
info 2022-09-30 06:13:37: MQTT publish: topic 'zigbee2mqtt/bridge/event', payload '{"data":{"friendly_name":"0x0004740000a93387","ieee_address":"0x0004740000a93387"},"type":"device_announce"}'
info 2022-09-30 06:13:37: MQTT publish: topic 'zigbee2mqtt/0x0004740000a93387', payload '{"battery":80,"linkquality":65,"voltage":2900}'
info 2022-09-30 06:21:18: MQTT publish: topic 'zigbee2mqtt/bridge/event', payload '{"data":{"friendly_name":"0x0004740000a93387","ieee_address":"0x0004740000a93387"},"type":"device_announce"}'
info 2022-09-30 06:21:18: MQTT publish: topic 'zigbee2mqtt/0x0004740000a93387', payload '{"battery":80,"linkquality":87,"voltage":2900}'
info 2022-09-30 06:22:04: MQTT publish: topic 'zigbee2mqtt/bridge/event', payload '{"data":{"friendly_name":"0x0004740000a93387","ieee_address":"0x0004740000a93387"},"type":"device_announce"}'
info 2022-09-30 06:22:04: MQTT publish: topic 'zigbee2mqtt/0x0004740000a93387', payload '{"battery":100,"linkquality":98,"voltage":3000}'
info 2022-09-30 06:29:29: MQTT publish: topic 'zigbee2mqtt/bridge/event', payload '{"data":{"friendly_name":"0x0004740000a93387","ieee_address":"0x0004740000a93387"},"type":"device_announce"}'
info 2022-09-30 06:29:29: MQTT publish: topic 'zigbee2mqtt/0x0004740000a93387', payload '{"battery":100,"linkquality":54,"voltage":3000}'
info 2022-09-30 06:36:02: MQTT publish: topic 'zigbee2mqtt/bridge/event', payload '{"data":{"friendly_name":"0x0004740000a93387","ieee_address":"0x0004740000a93387"},"type":"device_announce"}'
info 2022-09-30 06:36:04: MQTT publish: topic 'zigbee2mqtt/0x0004740000a93387', payload '{"action":"toggle","battery":100,"linkquality":94,"voltage":3000}'
info 2022-09-30 06:36:04: MQTT publish: topic 'zigbee2mqtt/0x0004740000a93387/action', payload 'toggle'
