regarde surtout les logs de MyElectricalData
J’ai redémarré l’add-on, et effectivement, il y a qqch qui ressemble à une erreur, c’est bien ca ?
File "/usr/local/lib/python3.12/site-packages/paho/mqtt/client.py", line 1044, in reconnect
sock = self._create_socket_connection()
File "/usr/local/lib/python3.12/site-packages/paho/mqtt/client.py", line 3685, in _create_socket_connection
return socket.create_connection(addr, timeout=self._connect_timeout, source_address=source)
File "/usr/local/lib/python3.12/socket.py", line 828, in create_connection
for res in getaddrinfo(host, port, 0, SOCK_STREAM):
File "/usr/local/lib/python3.12/socket.py", line 963, in getaddrinfo
for res in _socket.getaddrinfo(host, port, family, type, proto, flags):
socket.gaierror: [Errno -5] No address associated with hostname
2024-04-07 11:50:05.282 - ERROR : Erreur lors de l'exportation des données vers home assistant (via mqtt)
2024-04-07 11:50:05.282 - ERROR : [Errno -5] No address associated with hostname
2024-04-07 11:50:05.282 - INFO : ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ ◦ ❖ ◦ ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━
2024-04-07 11:50:05.282 - INFO : [MON_PDL_2_AVEC_PRODUCTION] IMPORT DES DONNÉES VERS L'ONGLET ENERGY DE HOME ASSISTANT (WEBSOCKET)
2024-04-07 11:50:05.282 - INFO : DÉSACTIVÉ DANS LA CONFIGURATION (EXEMPLE: HTTPS://TINYURL.COM/2KBD62S9)
2024-04-07 11:50:05.283 - INFO : ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ ◦ ❖ ◦ ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━
2024-04-07 11:50:05.283 - INFO : ▌│█║▌║▌║ ___ _ _____ _ _ _ _ _ _ ║▌║▌║█│▌
2024-04-07 11:50:05.283 - INFO : ▌│█║▌║▌║ |_ _| _ __ ___ _ __ ___ _ __ | |_ | ___|(_) _ __ (_) ___ | |__ | || || | ║▌║▌║█│▌
2024-04-07 11:50:05.283 - INFO : ▌│█║▌║▌║ | | | '_ ` _ \ | '_ \ / _ \ | '__|| __| | |_ | || '_ \ | |/ __|| '_ \ | || || | ║▌║▌║█│▌
2024-04-07 11:50:05.283 - INFO : ▌│█║▌║▌║ | | | | | | | || |_) || (_) || | | |_ | _| | || | | || |\__ \| | | ||_||_||_| ║▌║▌║█│▌
2024-04-07 11:50:05.283 - INFO : ▌│█║▌║▌║ |___||_| |_| |_|| .__/ \___/ |_| \__| |_| |_||_| |_||_||___/|_| |_|(_)(_)(_) ║▌║▌║█│▌
2024-04-07 11:50:05.283 - INFO : ▌│█║▌║▌║ |_| ║▌║▌║█│▌
2024-04-07 11:50:07.195 - INFO : 127.0.0.1:33108 - "GET / HTTP/1.1" 200
2024-04-07 11:50:12.241 - INFO : 127.0.0.1:40426 - "GET / HTTP/1.1" 200
si tu utilise l’addon mosquitto broker mets ca en configue dans config.yaml pour MQTT:
mqtt:
enable: true
hostname: core-mosquitto
port: 1883
Sinon met l’ip directe au lieu de core-mosquitto.
C’est bon, je les vois, merci
Je suis passé par l’intégration MQTT pour les voir, car je chercher des entité avec « myelectricaldata » dans le nom
J’ai bien des entités Linky qui sont là (consumption, consumption history et consumption last 5days), mais c’est des valeurs fixent
Par contre, j’ai toujours rien dans InfluxDB (j’ai passé le enable sur « true »
OUI
Si tu veux des entités il faut faire template
(UI), pour récupérer les attributs , ou voir MQTT directement
Résumé pour le mois
{{ states.sensor.linky_TON N° LINKY_consumption.attributes.current_month }}
Tiens question idiote il y a 500 appels API jour mais tous les jours je dépasse le nombre d’appel !
Vous aussi vous êtes dans cette situation ?
Comment voir et comprendre pourquoi ?
Je suis consommateur et producteur.
je suis que consommateur, pas de production. Je dois tourner a une trentaine d’appels /jour.
edit:
a l’instant ( 16h )
je suis a plus de 20
A l’instant !!!
il doit y avoir un paramètre que j’ai oublié quelque part je vais voir ma conf de container
Je n’ai pas un équipement de dingue :
- MyElectricalData uniquement pour les remontées Enedis
- Prises Zigbee avec conso
Associés à :
- Module Energie
- Sensors template
- Imagination
On peut pondre des trucs quand meme complet !
Bonjour pour le dashboard du milieu c’est via le dashboard énergie que tu l’as ou des cartes perso? Je suis très intéressé par le code de tes cartes;)
Bonsoir,
Peut-être demandes tu trop souvent ? Genre toutes les 2h ou moins
Oui au milieu que des cartes natives !
Alors sûrement mais moi je demande rien cela se fait tout seul !
J’ai pas de case fréquence d’appel ou alors j’ai pas vu ça !
Dans ton config.yaml de myelectricaldata j’ai cycle: 18000 peut-être toi moins non ?
Euh alors là cela ne me parle pas du tout
Je vais aller voir ça
C’est genre :
cycle: 18000
Edit :
Je ne vois rien de ce genre dans la configuration !
Je précise que je n’ai pas influxDB
Sur mon github.
Il n’est pas à jour mais les cartes custom y sont.
Celles natives seront simples à mettre en place.
Moi non plus, c’est la première ligne du fichier de config, t’as rien en cycle ?
