Heu… désolé mais là je sèche ^^ tu peux mettre tout le détail de la carte ?
Le voila
title: vertical-stack EDF MAJ
type: vertical-stack
cards:
- type: custom:mushroom-entity-card
entity: sensor.myelectricaldata_last_update
name: EDF - Maj le
icon: mdi:keyboard-backspace
icon_color: light-blue
tap_action:
action: navigate
navigation_path: /lovelace/conso
hold_action:
action: none
double_tap_action:
action: none
icon_type: icon
- type: horizontal-stack
cards:
entity: sensor.myelectricaldata_yesterday
icon: mdi:flash
icon_color: blue
layout: vertical
tap_action:
action: more-info
hold_action:
action: none
double_tap_action:
action: none
primary_info: name
secondary_info: state
icon_type: icon
entity: sensor.myelectricaldata_current_week
icon: mdi:flash
icon_color: amber
layout: vertical
tap_action:
action: more-info
hold_action:
action: none
double_tap_action:
action: none
primary_info: name
icon_type: icon
entity: sensor.myelectricaldata_current_month
icon: mdi:flash
icon_color: green
layout: vertical
tap_action:
action: more-info
hold_action:
action: none
double_tap_action:
action: none
primary_info: name
icon_type: icon
cards:
icon: mdi:flash
icon_color: pink
layout: vertical
tap_action:
action: more-info
hold_action:
action: none
double_tap_action:
action: none
entity: sensor.myelectricaldata_current_year
primary_info: name
icon_type: icon
icon: mdi:flash
icon_color: red
layout: vertical
tap_action:
action: more-info
hold_action:
action: none
double_tap_action:
action: none
entity: sensor.myelectricaldata_subscribed_power
primary_info: name
icon_type: icon
icon: mdi:flash
icon_color: purple
layout: vertical
tap_action:
action: more-info
hold_action:
action: none
double_tap_action:
action: none
entity: sensor.myelectricaldata_yesterdayconsumptionmaxpower
name: P. Max hier
primary_info: name
icon_type: icon
- type: custom:apexcharts-card
graph_span: 6d
span:
start: day
offset: '-7d'
header:
show: true
title: Conso des 6 derniers jours
show_states: true
colorize_states: true
series:
- entity: sensor.linky_PDL_consumption
yaxis_id: gauche
unit: KWh
color: deepskyblue
type: column
group_by:
duration: 1d
func: max
opacity: 0.8
stroke_width: 4
show:
datalabels: true
data_generator: |
return entity.attributes.dailyweek.map((dailyweek, index) => {
return [new Date(dailyweek).getTime(), entity.attributes.dailyweek_HP[index]];
yaxis_id: gauche
unit: KWh
color: orange
type: column
group_by:
duration: 1d
func: max
opacity: 0.8
stroke_width: 4
show:
datalabels: true
data_generator: |
return [new Date(dailyweek).getTime(), entity.attributes.dailyweek_HC[index]];
yaxis_id: droite
unit: KWh
color: red
type: line
group_by:
duration: 1d
func: max
opacity: 0.8
stroke_width: 1
show:
datalabels: true
data_generator: |
return [new Date(dailyweek).getTime(), entity.attributes.daily[index]];
apex_config:
xaxis:
labels:
show: true
yaxis:
- id: gauche
min: 0
max: 25
opposite: false
labels:
show: false
- id: droite
min: 0
max: 25
opposite: true
labels:
show: false
legend:
show: false
chart:
stacked: true
graph_span: 6d
span:
start: day
offset: '-7d'
header:
show: true
title: Coût des 6 derniers jours et résumé d'hier
show_states: true
series:
yaxis_id: gauche
unit: €
color: deepskyblue
type: column
group_by:
duration: 1d
func: max
opacity: 0.8
stroke_width: 4
show:
datalabels: true
data_generator: |
return [new Date(dailyweek).getTime(), entity.attributes.dailyweek_costHP[index]];
yaxis_id: gauche
unit: €
color: orange
type: column
group_by:
duration: 1d
func: max
opacity: 0.8
stroke_width: 4
show:
datalabels: true
data_generator: |
return [new Date(dailyweek).getTime(), entity.attributes.dailyweek_costHC[index]];
yaxis_id: droite
name: Coût total (Base)
unit: €
color: green
type: line
group_by:
duration: 1d
func: max
opacity: 0.8
stroke_width: 1
show:
datalabels: true
data_generator: |
return [new Date(dailyweek).getTime(), entity.attributes.dailyweek_cost[index]];
apex_config:
xaxis:
labels:
show: true
yaxis:
- id: gauche
min: 0
max: 5
opposite: false
labels:
show: false
- id: droite
min: 0
max: 5
opposite: true
labels:
show: false
legend:
show: false
chart:
stacked: true
ok!
Comme je l’explique dans le tuto etau moment de sa rédaction il y avait des deltas dans la remontée d’infos…
J’avais ‹ triché › un peu sur les paramètres :
Si mes souvenirs sont ok, remplace -7d par -6d et cela devrait être ok, a condition que les datas d’hier soient bien dispo
hth
Merci @FROlCi c’était bien ça
Vais essayer d’adapté les calculs de coûts pour prendre en compte les tarifs TEMPO…
Salut à tous, je me suis pris la tête, et j’ai trouvé une erreur dans le tuto (que j’ai reproduit bêtement avec un copie collé), @FROlCi → au début du tuto tu a mis :
« installez Influxdb (normalement la version proposée par défaut est celle < 2.0), créez une database my**l**electricaldata », il a un petit L miniscule qui se balade entre le my et le electrical.
Je ne comprenais pas pourquoi mon script ne se connectait pas à la base. Merci en tout cas pour toute les infos que l’on retrouve ici !!
database mylelectricaldata . bien joué !
Merci @bertrand_34160
ca change rien pour moi MED fonctionne tres bien , mais je n ai aucunes remontée d infos dans influxdb
bises du nord
Une dernière question, si j’ai bien compris le système, on ne peut récuperer que les données de la veille ? Pas de data en direct ou même léger différé ?
Donc je continue a faire un mix avec mon ecojoko et ma pince tuya pour avoir les données en direct
hello, oui 24 heures de delta pour la remontée des infos. A moins que qque chose ai changé ?!?
et @bertrand_34160 oh zut!!! je vais regarde tt de suite et" Ko Riz Get" cette coquille ^^
J’ai installé Myelectricaldata, mais je n’ai qu’une entité qui a été créée, « Myelectricaldata Update ».
Quelqu’un aurait une idée de la cause ?
Je vous envoie ma config
cycle: 14400
debug: true
home_assistant:
discovery: true
enable: true
influxdb:
batching_options:
batch_size: 1000
exponential_base: 2
flush_interval: 1000
jitter_interval: 0
max_retries: 5
max_retry_delay: 125000
max_retry_time: 180000
retry_interval: 5000
bucket: myelectricaldata
enable: false
hostname: influxdb
method: synchronous
org: myelectricaldata
port: 8086
token: myelectricaldata
log2file: true
mqtt:
client_id: myelectricaldata
enable: true
hostname: xxx
password: xxx
port: 1883
prefix: myelectricaldata
qos: 0
retain: true
username: xxx
myelectricaldata:
"xxx":
addresses: "true"
cache: "true"
consumption: "true"
consumption_detail: "true"
consumption_detail_max_date: "2021-06-01"
consumption_max_date: "2021-06-01"
consumption_max_power: "true"
consumption_price_base: "0.145907"
consumption_price_hc: "0.124364"
consumption_price_hp: "0.164915"
enable: "true"
offpeak_hours_0: 22H00-6H00
offpeak_hours_1: 22H00-6H00
offpeak_hours_2: 22H00-6H00
offpeak_hours_3: 22H00-6H00
offpeak_hours_4: 22H00-6H00
offpeak_hours_5: 22H00-6H00;12H00-14H00
offpeak_hours_6: 22H00-6H00;12H00-14H00
plan: BASE
production: "false"
production_detail: "false"
production_detail_max_date: "2021-06-01"
production_max_date: "2021-06-01"
production_price: "0.0"
refresh_addresse: "true"
refresh_contract: "true"
token: xxx
MON_PDL_2_AVEC_PRODUCTION:
cache: "true"
consumption: "true"
consumption_price_base: "0.175"
consumption_price_hc: "0.175"
consumption_price_hp: "0.175"
enable: "true"
name: Maison de vacances
offpeak_hours_0: ""
offpeak_hours_1: ""
offpeak_hours_2: ""
offpeak_hours_3: ""
offpeak_hours_4: ""
offpeak_hours_5: ""
offpeak_hours_6: ""
plan: BASE
production: "true"
production_detail: "true"
production_price: "0.10"
refresh_addresse: "false"
refresh_contract: "false"
token: TOKEN_DE_MON_PDL_2
tempo:
enable: true
price_blue_hc: 0.097
price_blue_hp: 0.1249
price_red_hc: 0.1216
price_red_hp: 0.6712
price_white_hc: 0.114
price_white_hp: 0.1508
wipe_influxdb: false
Slt…
mettre la config dans les balises </> ci-dessus !
debug: false
home_assistant:
discovery: true
enable: true
home_assistant_ws:
enable: true
ssl: false
token: e**** # -< Ici il faut créé un jeton longue durée dans ton profil de HA
url: 192.168.0.42:8123 # <- adresse de ton HA et port
port: 5000
influxdb:
batching_options:
batch_size: 1000
exponential_base: 2
jitter_interval: 0
max_close_wait: 300000
max_retries: 5
enable: false
hostname: influxdb
method: asynchronous
port: 8086
log2file: true
mqtt:
enable: true
hostname: core-mosquitto
password: mdpmqtt #-< ton mot de passe MQTT
port: 1883 # -< voir le port
qos: 0
retain: true
username: usermqtt #-< ton user MQTT
myelectricaldata:
'ton num de pdl':
addresses: true
cache: 'true'
consumption: 'true'
consumption_detail: 'true'
consumption_detail_max_date: ''
consumption_max_date: ''
consumption_max_power: 'true'
consumption_price_base: '0.2276' #-< mettre à jour suivant PRIX
consumption_price_hc: '0.1828' #-< mettre à jour suivant PRIX
consumption_price_hp: '0.2460' #-< mettre à jour suivant PRIX
enable: 'true'
name: maison #-< mettre un nom
offpeak_hours_0: 2H00-7H00;14H00-17H00 # <- choisir les heures et jours
offpeak_hours_1: 2H00-7H00;14H00-17H00 # <- choisir les heures et jours
offpeak_hours_2: 2H00-7H00;14H00-17H00 # <- choisir les heures et jours
offpeak_hours_3: 2H00-7H00;14H00-17H00 # <- choisir les heures et jours
offpeak_hours_4: 2H00-7H00;14H00-17H00 # <- choisir les heures et jours
offpeak_hours_5: 2H00-7H00;14H00-17H00 # <- choisir les heures et jours
offpeak_hours_6: 2H00-7H00;14H00-17H00 # <- choisir les heures et jours
plan: HC/HP # -< choisir le bon plan suivant abonnement
production: 'false'
production_detail: 'false'
production_detail_max_date: ''
production_max_date: ''
production_price: '0'
refresh_addresse: 'true'
refresh_contract: 'true'
token: token_myelectricaldata #<- mettre ton token
ssl:
certfile: ''
gateway: false
keyfile: ''
tempo:
enable: false
Désolé, j’ai du misclick sur le bouton </> quand j’ai fait mon post
J’ai corrigé pour toi hier
Slt
Vérifie surtout sur quel plan tu es , je vois que tu as mis de base et je vois que tu as mis tempo en truc ?
Bonjour a tous,
j’ai pas de donnée chez enedis pour le 4,5 et 6.
Pareil pour vous ?
Edit:
Beh chez EDF , idem
J’ai pour le 4, que n’a pas enedis
J’ai laissé les données tempo, au cas où je voudrais m’en servir, mais j’ai bien sélectionné le contrat « Base »
J’allais poser la même question
Idem. OK, encore des problèmes chez EDF , enedis
Citation
Vos données quotidiennes seront actualisées prochainement. Nous travaillons activement à la mise à jour de votre graphique de consommation.
Pourquoi certaines données sont affichées comme indisponibles ?
Il arrive qu’EDF n’ait pas reçu tous les relevés de consommation attendus de la part du distributeur d’énergie. Généralement ils sont automatiquement remis à disposition. Si ce problème persiste au-delà de 20 jours, vous avez la possibilité de contacter votre service client EDF.
EDF arrive pas a collecter ces propres données …
Moi pas d’infos pour le 5 et 6.
J’irai voir du côté Enedis tout à l’heure, en ce moment téléphone…
EDIT: Enedis
Bonjour.c’est plus compliqué, le linky c’est pas EDF mais Enedis ( ex rte)
Pareil chez moi . Dernière valeur le 3
J’ai vérifié après avoir vérifier mon fichier config, et redémarré HA, mais je n’ai pas eu d’entité myelectricaldata de créées
