2022-02-09 18:44:52 ERROR (MainThread) [homeassistant.components.http.forwarded] A request from a reverse proxy was received from 192.168.1.1, but your HTTP integration is not set-up for reverse proxies
alors que j’ai ajouté cette fois dans « ./storage/http »
"use_x_forwarded_for": true,
"trusted_proxies": [
"192.168.1.0/24"
dans
"version": 1,
"minor_version": 1,
"key": "http",
"data": {
"192.168.1.0/24"
"ip_ban_enabled": true,
"server_port": 8123,
"login_attempts_threshold": -1,
"cors_allowed_origins": [
"https://cast.home-assistant.io"
"ssl_profile": "modern"
à l’origine sur mon ancienne configuration qui fonctionnée, j’ai voulu juste mettre les choses au bon endroit.
Mon synlogy est bien configuré, rien n’as changé. J’avais ceci dans le configuration.yaml :
http:
use_x_forwarded_for: true
trusted_proxies:
- 192.168.1.0/24
# Configure a default setup of Home Assistant (frontend, api, etc)
default_config:
# Text to speech
tts:
- platform: google_translate
group: !include groups.yaml
script: !include scripts.yaml
scene: !include scenes.yaml
il me semble que c’est la même chose ? non ?
[center]System Health
| version | core-2022.2.3 |
| dev | false |
| hassio | true |
| docker | true |
| user | root |
| virtualenv | false |
| python_version | 3.9.7 |
| os_name | Linux |
| os_version | 5.10.92-v8 |
| arch | aarch64 |
| timezone | Europe/Paris |
| logged_in | false |
| can_reach_cloud_auth | ok |
| can_reach_cloud | ok |
| host_os | Home Assistant OS 7.3 |
| update_channel | stable |
| supervisor_version | supervisor-2022.01.1 |
| docker_version | 20.10.9 |
| disk_total | 58.9 GB |
| disk_used | 5.3 GB |
| healthy | true |
| supported | true |
| board | rpi3-64 |
| supervisor_api | ok |
| version_api | ok |
| installed_addons | Samba share (9.5.1), Terminal & SSH (9.3.0), Studio Code Server (4.1.0), Z-Wave JS to MQTT (0.35.0) |
Lovelace
| dashboards | 1 |
| resources | 0 |
| mode | auto-gen |
