Bonjour, j’ai mis à jour MQTT et Mosquitto Broker et depuis mes données éléctriques qui remontaient via Zlinky ne fonctionne plus.
Voici les logs que j’ai dans mosquitto :
2023-09-07 11:54:36: New client connected from 172.30.32.1:37030 as mqttjs_464b6923 (p2, c1, k60, u'mqtt').
2023-09-07 11:54:36: Client mqttjs_464b6923 disconnected due to malformed packet.
2023-09-07 11:54:37: New connection from 172.30.32.1:37044 on port 1883.
2023-09-07 11:54:37: New client connected from 172.30.32.1:37044 as mqttjs_464b6923 (p2, c1, k60, u'mqtt').
2023-09-07 11:54:37: Client mqttjs_464b6923 disconnected due to malformed packet.
2023-09-07 11:54:38: New connection from 172.30.32.1:37058 on port 1883.
Les logs dans MQTT sont les suivants :
Zigbee2MQTT:error 2023-09-07 12:25:04: Not connected to MQTT server!
Zigbee2MQTT:error 2023-09-07 12:25:04: Cannot send message: topic: 'zigbee2mqtt/zlinky', payload: '{"active_enerfy_out_d01":7866.446,"active_enerfy_out_d02":14331.92,"active_enerfy_out_d03":0,"active_enerfy_out_d04":0,"active_power":360,"active_power_max":2420,"active_power_ph_b":336,"active_register_tier_delivered":"","apparent_power":564,"available_power":9,"average_rms_voltage_meas_period":228,"current_date":"E230907122455","current_index_tarif":3,"current_price":"HEURES PLEINES","current_summ_delivered":22198.378,"current_tarif":"H SUPER......
Zigbee2MQTT
data_path: /config/zigbee2mqtt
socat:
enabled: false
master: pty,raw,echo=0,link=/tmp/ttyZ2M,mode=777
slave: tcp-listen:8485,keepalive,nodelay,reuseaddr,keepidle=1,keepintvl=1,keepcnt=5
options: "-d -d"
log: false
mqtt:
server: mqtt://192.168.1.52:1883
user: mqtt
password: xxxxxxx
serial:
port: /dev/ttyUSB0
Mosquitto
logins:
- username: mqtt
password: xxxxxxxxxx
require_certificate: false
certfile: fullchain.pem
keyfile: privkey.pem
customize:
active: false
folder: mosquitto
Pouvez-vous m’aider s’il vous plait ?
Merci par avance
