MQTT error: connect ECONNREFUSED 127.0.0.1:1883
Je débute avec Ha et docker-compose et une clef Sonoff E sur un Pc Ubuntu (ça je connais).
J’ai plus ou moins suivi le tuto.
Avec « configuration.yaml » suivant:
homeassistant: true
permit_join: true
mqtt:
  base_topic: zigbee2mqtt
  server: mqtt://127.0.0.1:1883
  user: ***
  password: ***
serial:
  port: /dev/ttyACM0
  adapter: ezsp
frontend:
  port: 8080
advanced:
  homeassistant_legacy_entity_attributes: false
  legacy_api: false
  legacy_availability_payload: false
device_options:
  legacy: false
Voilà le log de Zigbee2MQTT
Zigbee2MQTT:info  2024-01-20 21:03:11: Logging to console and directory: '/app/data/log/2024-01-20.21-03-11' filename: log.txt
Zigbee2MQTT:info  2024-01-20 21:03:11: Starting Zigbee2MQTT version 1.35.1 (commit #9eaaa0f)
Zigbee2MQTT:info  2024-01-20 21:03:11: Starting zigbee-herdsman (0.30.0)
Assertion failed: Command (setConfigurationValue) returned unexpected state: [object Object]
Zigbee2MQTT:info  2024-01-20 21:03:14: zigbee-herdsman started (resumed)
Zigbee2MQTT:info  2024-01-20 21:03:14: Coordinator firmware version: '{"meta":{"maintrel":"1 ","majorrel":"7","minorrel":"3","product":12,"revision":"7.3.1.0 build 176"},"type":"EZSP v12"}'
Zigbee2MQTT:info  2024-01-20 21:03:14: Currently 0 devices are joined:
Zigbee2MQTT:warn  2024-01-20 21:03:14: `permit_join` set to  `true` in configuration.yaml.
Zigbee2MQTT:warn  2024-01-20 21:03:14: Allowing new devices to join.
Zigbee2MQTT:warn  2024-01-20 21:03:14: Set `permit_join` to `false` once you joined all devices.
Zigbee2MQTT:info  2024-01-20 21:03:14: Zigbee: allowing new devices to join.
Zigbee2MQTT:info  2024-01-20 21:03:14: Connecting to MQTT server at mqtt://127.0.0.1:1883
Zigbee2MQTT:error 2024-01-20 21:03:14: MQTT error: connect ECONNREFUSED 127.0.0.1:1883
Zigbee2MQTT:error 2024-01-20 21:03:14: MQTT failed to connect, exiting...
Sachant que MQTT Explorer se connecte bien avec mqtt://127.0.0.1:1883 et les mêmes identifiants.
Pour l'instant le Pc est en Wifi mais à terme il sera relié à ma box en filaire, donc je n'ai pas son adresse définitive.
Dans Portainer homeassistant et mqtt ont leurs ports ouverts. zigbee2mqtt est dans les choux.
Contenu de "mosquitto.conf"
persistence true
persistence_location /mosquitto/data/
log_dest file /mosquitto/log/mosquitto.log
log_type all
listener 1883
allow_anonymous true
Merci par avance pour vos conseils,
## Ma configuration
version core-2024.1.3
hassio false
python_version 3.11.6
os_version 6.5.0-14-generic
arch x86_64
dashboards 1
resources 0
mode auto-gen
oldest_recorder_run 19 janvier 2024 à 08:46
current_recorder_run 20 janvier 2024 à 19:34
estimated_db_size 0.58 MiB
database_version 3.41.2
``` ___
En essayant de suivre le tuto ça donne quoi ?
Vaut mieux utiliser le nom du container mqtt que d’utiliser l’adresse localhost.
Si tu débute dans tout ça pourquoi ne pas utiliser la méthode la plus facile avec HAOS?
BJ.
Clé E est en expérimentale
Ubuntu pour HA , tu as aps choisi la meilleur , le mieux est Debian
Regarde la pour faire ta base
Bonsoir,
Effectivement, en revenant plus ou moins aux paramètres du tuto et avec server: mqtt://mqtt:1883
homeassistant: true
permit_join: true
mqtt:
serial:
  port: /dev/ttyACM0
  adapter: ezsp
frontend:
  port: 8080
Ça marche: j’ai mes 2 prises SonOff Zigbee.
Pour Mqtt Explorer, le nom « mqtt » n’est pas reconnu, il faut « 127.0.0.1 ». Why !
Merci et @+
Bonsoir,
Certains disent que cela fonctionne. Je vais poursuivre. J’ai mis à jour le firmware.
Merci pour le tuto, mais je suis parti dans une autre optique: 3 containers.
MQTT Explorer tu l’as surement installé sur ta machine hôte sur Ubuntu… du coup 127.0.0.1 ça doit passer… mais il ne connais pas les noms des containers.
Z2M et Mosquitto sont dans des containers séparés… mais comme ils sont sur le même environnement docker il peuvent être appelés en utilisant directement le nom de leur container.
Vu la méthode d’installation choisie, va falloir prendre quelques cours de docker, car tu risque de revenir dès le prochain service que tu voudra installer :rofl:
